@Sponzo that image also doesnt work for me, did you have to unlock to bootloader or something else in dev settings?
jock replied to Alexander Polko's topic in Rockchip CPU Boxes
@Alexander Polko Do you still have stock firmware in eMMC? You should get some output from the serial uart if you have the stock firmware, otherwise your serial is not working correctly. Also, boot from sdcard only works via u-boot from stock firmware on this board, for the reason I stated above. -
Collabora is headed to Stuttgart for XR Expo 2026! Visit us in Hall 2, booth 2C22, to experience the latest around Monado and ElectricMaple, and catch our 2 talks! View the full article
Alexander Polko replied to Alexander Polko's topic in Rockchip CPU Boxes
I also tried different U-Boot SPL variants, but I was unable to get Armbian to boot. However, I noticed something interesting — on my MikroTik router I saw a DHCP lease that was issued to a client identified as "uboot", though I only noticed this after the fact and missed the chance to investigate further. -
Hi @jock, thank you very much for your detailed explanation and for pointing me to the multitool project! I successfully built the multitool image for rk3528 and wrote it to the SD card, but unfortunately the box does not boot from it — it stuck every time. I also tried connecting via UART (FT232 adapter, 1500000 baud, 8N1) but I only get garbage/noise in the terminal — no readable output at all, even right after powering on the device. -
@Nick A Thanks for taking my advice.😄 This is the test program of mine. You can play around with it if you have time. cpu_benchmark.py.zip
@qq20739111 thanks I'll remove the patch and compile a new image.
@Nick A As shown in the figure, I tested your newly released patched image on this fanless DIY heatsink dev board using a CPU benchmark tool, and the CPU performance is indeed heavily throttled! With v0.6.1, I scored 2571, with average core temps around 75°C. However, with v0.6.4, the all-core score dropped to just 985, with temps hovering around 60°C. This is even significantly lower than the official system image (1700+). I would really prefer a version without these patches; otherwise, the board's potential is being wasted. After all, sustained operation below 90°C is perfectly safe for this CPU. The official release limits CPU performance to prevent high-temp instability and reduce support tickets, but your image doesn't need to impose these restrictions.
@Kauã Fonseca There are SSH commands in my GitHub repository. Just SSH into your TV box and execute them one by one. sudo apt-get update sudo apt-get install -y build-essential linux-headers-$(uname -r) git git clone https://github.com/cdhigh/armbian_sv6256p.git cd armbian_sv6256p chmod +x ./parser-conf.sh make ARCH=arm64 KSRC=/lib/modules/$(uname -r)/build ls -lh ssv6x5x.ko sudo cp ./ssv6x5x-wifi.cfg /lib/firmware/ sudo cp ./ssv6x5x-sw.bin /lib/firmware/ sudo cp ./ssv6x5x.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/ sudo depmod -a sudo modprobe ssv6x5x ip link show nmtui -
Hi Ive just installed the latest version of Armbian (Ubuntu Noble+KDE) and everything works fine except it looks like it is not detecting my TV resolution correctly. I can choose 1920x1080@120hz but if I try yo go to 4K I can only select 24Hz I attach armbian monitor logs url, modetest and kscreendoctor My cable is HDMI 2.1 Any help would be appreciated modetest -c trying to open device '/dev/dri/card1'... is not a KMS device trying to open device '/dev/dri/card0'... done opened device `RockChip Soc DRM` on driver `rockchip` (version 1.0.0 at 0) Connectors: id encoder status name size (mm) modes encoders 83 82 connected HDMI-A-1 1880x1060 35 82 modes: index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot #0 4096x2160 24.00 4096 5116 5204 5500 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver #1 4096x2160 23.98 4096 5116 5204 5500 2160 2168 2178 2250 296703 flags: phsync, pvsync; type: driver #2 3840x2160 30.00 3840 4016 4104 4400 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver #3 3840x2160 29.97 3840 4016 4104 4400 2160 2168 2178 2250 296703 flags: phsync, pvsync; type: driver #4 3840x2160 25.00 3840 4896 4984 5280 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver #5 3840x2160 24.00 3840 5116 5204 5500 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver #6 3840x2160 23.98 3840 5116 5204 5500 2160 2168 2178 2250 296703 flags: phsync, pvsync; type: driver #7 1920x1080 120.00 1920 2008 2052 2200 1080 1084 1089 1125 297000 flags: phsync, pvsync; type: driver #8 1920x1080 119.88 1920 2008 2052 2200 1080 1084 1089 1125 296703 flags: phsync, pvsync; type: driver #9 1920x1080 100.00 1920 2448 2492 2640 1080 1084 1089 1125 297000 flags: phsync, pvsync; type: driver #10 1920x1080 60.00 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver #11 1920x1080 59.94 1920 2008 2052 2200 1080 1084 1089 1125 148352 flags: phsync, pvsync; type: driver #12 1920x1080 50.00 1920 2448 2492 2640 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver #13 1920x1080 30.00 1920 2008 2052 2200 1080 1084 1089 1125 74250 flags: phsync, pvsync; type: driver #14 1920x1080 29.97 1920 2008 2052 2200 1080 1084 1089 1125 74176 flags: phsync, pvsync; type: driver #15 1920x1080 24.00 1920 2558 2602 2750 1080 1084 1089 1125 74250 flags: phsync, pvsync; type: driver #16 1920x1080 23.98 1920 2558 2602 2750 1080 1084 1089 1125 74176 flags: phsync, pvsync; type: driver #17 1680x1050 59.88 1680 1728 1760 1840 1050 1053 1059 1080 119000 flags: phsync, nvsync; type: driver #18 1600x900 60.00 1600 1624 1704 1800 900 901 904 1000 108000 flags: phsync, pvsync; type: driver #19 1280x1024 60.02 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: driver #20 1152x864 75.00 1152 1216 1344 1600 864 865 868 900 108000 flags: phsync, pvsync; type: driver #21 1280x720 60.00 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type: driver #22 1280x720 59.94 1280 1390 1430 1650 720 725 730 750 74176 flags: phsync, pvsync; type: driver #23 1280x720 50.00 1280 1720 1760 1980 720 725 730 750 74250 flags: phsync, pvsync; type: driver #24 1280x720 30.00 1280 3040 3080 3300 720 725 730 750 74250 flags: phsync, pvsync; type: driver #25 1280x720 29.97 1280 3040 3080 3300 720 725 730 750 74176 flags: phsync, pvsync; type: driver #26 1280x720 24.00 1280 3040 3080 3300 720 725 730 750 59400 flags: phsync, pvsync; type: driver #27 1280x720 23.98 1280 3040 3080 3300 720 725 730 750 59341 flags: phsync, pvsync; type: driver #28 1024x768 60.00 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver #29 800x600 60.32 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver #30 720x576 50.00 720 732 796 864 576 581 586 625 27000 flags: nhsync, nvsync; type: driver #31 720x480 60.00 720 736 798 858 480 489 495 525 27027 flags: nhsync, nvsync; type: driver #32 720x480 59.94 720 736 798 858 480 489 495 525 27000 flags: nhsync, nvsync; type: driver #33 640x480 60.00 640 656 752 800 480 490 492 525 25200 flags: nhsync, nvsync; type: driver #34 640x480 59.94 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver props: 1 EDID: flags: immutable blob blobs: value: 00ffffffffffff004dd9057901010101 011e010380bc6a780a0dc9a057479827 12484c2108008180a9c0714fb3000101 01010101010108e80030f2705a80b058 8a005a227400001e023a801871382d40 582c45005a227400001e000000fc0053 4f4e5920545620202a33300a000000fd 0017790e883c000a20202020202001bf 020367f05861605d5e5f621f10140513 0420223c3e1203110265663f402f0d7f 071507503d07bc570601670403830f00 006e030c004000b8442b008001020304 67d85dc401788003eb0146d000480382 88627697e200cbe305df01e40f030030 e6060d018aac10011d007251d01e206e 2855005a227400001e000000000000a3 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 0 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 4 TILE: flags: immutable blob blobs: value: 84 max bpc: flags: range values: 8 8 value: 8 kscreen-doctor -o Output: 1 HDMI-A-1 ea40cb77-73bf-4175-8970-22f84927f147 enabled connected priority 1 HDMI replication source:0 Modes: 1:4096x2160@24.00*! 2:4096x2160@23.98 3:3840x2160@30.00 4:3840x2160@29.97 5:3840x2160@25.00 6:3840x2160@24.00 7:3840x2160@23.98 8:1920x1080@120.00 9:1920x1080@119.88 10:1920x1080@100.00 11:1920x1080@60.00 12:1920x1080@60.00 13:1920x1080@59.94 14:1920x1080@50.00 15:1920x1080@30.00 16:1920x1080@29.97 17:1920x1080@24.00 18:1920x1080@23.98 19:1680x1050@59.88 20:1600x900@60.00 21:1280x1024@60.02 22:1152x864@75.00 23:1280x720@60.00 24:1280x720@60.00 25:1280x720@59.94 26:1280x720@50.00 27:1280x720@30.00 28:1280x720@29.97 29:1280x720@24.00 30:1280x720@23.98 31:1024x768@60.00 32:800x600@60.32 33:720x576@50.00 34:720x576@50.00 35:720x480@60.00 36:720x480@60.00 37:720x480@59.94 38:720x480@59.94 39:640x480@60.00 40:640x480@59.94 Custom modes: None Geometry: 0,0 1821x960 Scale: 2.25 Rotation: 1 Overscan: 0 Vrr: incapable RgbRange: unknown HDR: incapable Wide Color Gamut: incapable ICC profile: none Color profile source: sRGB Color power preference: prefer efficiency and performance Brightness control: supported, set to 100% and dimming to 100% Color resolution: automatic (10), range: [8; 8] bits per color Allow EDR: unsupported Sharpness control: unsupported Automatic brightness: unsupported Thank you
If someone is eager to add sway - we have a new cleaner way to add and maintain (unit tests, AI auto maintain) new desktop: https://docs.armbian.com/Developer-Guide_Desktops/
I see. I actually tried to educate myself to see if I could help out, that is why I extracted the code in the first place. I would love to be able to help, but it seems outside of my capabilities. But I'll keep reading trying to learn, and maybe some day I will be able to make a pr rather than just a post on the forum. Thank you AGAIN for ALL you do!!
Which kernel, debian, mesa and sway versions are running normally when you run a stock Armbian? Which new versions have you observed working together? (even if it's not ARM). If they are too different, they may not work together due to library functions expecting other parameters. You can try it with Ubuntu Noble, which has newer packages than Debian Trixie (build Armbian by yourself).
https://actions.armbian.com/?repo=armbian.github.io Here anyone can monitor ... but the real problem is capacity to fix problems. Not knowning them. We have too many problems on the to do list It is not O.K., but also not a critical problem. This script is making a cache for this package which is needed in critical operations. Where it can't fail. This is why this was made in 1st place. We can't rely on upstream infrastructure.
This week in Armbian development saw significant progress across board support, desktop environments, and infrastructure. Notably, NanoPC T6 LTS Plus was added as a reusable board, and support for Ubuntu 26.04 LTS ("Resolute") expanded to desktop package coverage and testing. Multiple improvements targeted desktop environments, including package updates, installation fixes, and branding enhancements for browsers. Kernel and bootloader updates were implemented for various boards, with mainline kernel bumped to 7.0 stable and u-boot upgrades for Rockchip devices. Infrastructure enhancements included new CI workflows, multi-arch unit tests, and migration to a REST API. Several bug fixes, optimizations, and cosmetic cleanups rounded out the release, ensuring greater stability and usability for Armbian users. ChangesAdd Beaglebadge. by @Grippy98 in armbian/armbian.github.io#284Add few images. by @igorpecovnik in armbian/configng#858Add NanoPC T6 LTS Plus as reusable board. by @igorpecovnik in armbian/armbian.github.io#275Add NanoPC-T6 LTS Plus board support. by @igorpecovnik in armbian/build#9617arduino-uno-q: bump edge kernel to 7.0.0-unoq. by @SuperKali in armbian/build#9696base-files: symlink upstream distro logos to Armbian's. by @igorpecovnik in armbian/build#9688boot: stop emitting splash=verbose to the kernel cmdline. by @igorpecovnik in armbian/build#9653bsp: drop /etc/apt/preferences.d/armbian — desktop pin moves to armbian-config. by @igorpecovnik in armbian/build#9664bsp: ship Armbian distributor logo (svg + wordmark png variants). by @igorpecovnik in armbian/build#9674chore(deps): patch rustls-webpki and rand advisories. by @SuperKali in armbian/imager#132ci: add dependabot config (github-actions, daily). by @igorpecovnik in armbian/docker-armbian-build#16ci: build repository-update images for armhf. by @igorpecovnik in armbian/docker-armbian-build#22ci: build repository-update images for riscv64. by @igorpecovnik in armbian/docker-armbian-build#15ci: drop deprecated golint. by @SuperKali in armbian/armbian-router#41ci: multi-arch unit tests + JSON report published to armbian.github.io. by @igorpecovnik in armbian/configng#872ci: run unit tests under qemu-user for armhf + riscv64. by @igorpecovnik in armbian/configng#875ci: validate board config required fields on PR. by @igorpecovnik in armbian/build#9678copyright: match website footer. by @igorpecovnik in armbian/documentation#916cosmetic: clean up build warnings (locale, setfont, GPG, oras). by @igorpecovnik in armbian/build#9684desktops/common: strip armbian-imager on armhf/riscv64/loong64. by @igorpecovnik in armbian/configng#867desktops/common: use epiphany-browser on Ubuntu/riscv64. by @igorpecovnik in armbian/configng#870desktops/gnome: drop loong64 from sid. by @igorpecovnik in armbian/configng#877desktops/gnome: fix gnome-bluetooth-sendto install failure on jammy. by @igorpecovnik in armbian/configng#876desktops/mate: drop brisk-menu + mate-applet-trash from minimal. by @igorpecovnik in armbian/configng#866desktops/postinst: drop stray 'fi' from five scripts that fail bash -n. by @igorpecovnik in armbian/configng#879desktops/xfce: drop apport stack from packages_uninstall. by @igorpecovnik in armbian/configng#869desktops: add mode=build to skip user-dependent steps at image build time. by @igorpecovnik in armbian/configng#859desktops: availability + editorial-status filters, CSC menu. by @igorpecovnik in armbian/configng#863desktops: brand Chromium / Chrome / Firefox(-esr) first-run + homepage. by @igorpecovnik in armbian/configng#854desktops: disable DM in mode=build after install. by @igorpecovnik in armbian/configng#862desktops: drop libu2f-udev from resolute (no installation candidate). by @igorpecovnik in armbian/configng#853desktops: drop NetworkManager override from postinst scripts. by @igorpecovnik in armbian/configng#861desktops: drop plucky and questing release blocks. by @igorpecovnik in armbian/configng#849desktops: fix forky minimal installs (drop obsoleted/moved pkgs). by @igorpecovnik in armbian/configng#871desktops: flip netplan renderer to NetworkManager on live install. by @igorpecovnik in armbian/configng#880desktops: install runtime apt pin so apt.armbian.com .debs. by @igorpecovnik in armbian/configng#851desktops: route apt.armbian.com browsers + add code, armbian-imager, restore thunderbird. by @igorpecovnik in armbian/configng#848desktops: skip plymouth-theme install when mode=build. by @igorpecovnik in armbian/configng#865desktops: suppress dpkg conffile prompt on install (non-interactive). by @igorpecovnik in armbian/configng#856Disable Sk-am64b as its not compiling on Resolute. by @igorpecovnik in armbian/armbian.github.io#280distributions: mark questing (Ubuntu 25.10) as eos. by @igorpecovnik in armbian/build#9693Drop anubis and aptly. by @igorpecovnik in armbian/os#447extension: fix importlib_resources detection for U-Boot v2024.x-v2025.04. by @iav in armbian/build#9692external: add resolute (Ubuntu 26.04 LTS) to desktop package coverage. by @igorpecovnik in armbian/os#444external: add resolute (Ubuntu 26.04 LTS) to desktop package coverage. by @igorpecovnik in armbian/os#446external: consolidate chromium configs + add armhf/amd64 coverage. by @igorpecovnik in armbian/os#448external: drop jammy from desktop multi-release RELEASE lists. by @igorpecovnik in armbian/os#445external: pull libwidevinecdm0 for noble from liujianfeng1994 rockchip-multimedia PPA. by @igorpecovnik in armbian/os#451feat(api): migrate to api.armbian.com REST v1. by @SuperKali in armbian/imager#129Feature Proposal - armbian-firstlogin add support for web setup fallback. by @Grippy98 in armbian/build#9639Fix. by @igorpecovnik in armbian/os#453Fix copyright formatting in mkdocs.yml. by @igorpecovnik in armbian/documentation#917fix recomputer rk35xx dts. by @ackPeng in armbian/linux-rockchip#470Fix USB Type-C port for Orangepi 5/5B. by @chaitan3 in armbian/build#9624fix(cache): switch to sort_by_key for LRU ordering. by @SuperKali in armbian/imager#131fix(download): use direct_url so filename keeps its extension. by @SuperKali in armbian/imager#130fix(kernel-config): append missing newline to .config before edits. by @iav in armbian/build#9681fix: armbian-resize-filesystem diskdevname fallback for /dev/sda* devices. by @mvanhorn in armbian/build#9595gateway-dk-ask: pin ASK with libxml2 2.12+ compat fix for fmc. by @tomazzaman in armbian/build#9677json-generation: handle .tar.xz image archives. by @SuperKali in armbian/armbian.github.io#283kernel-headers: add version to linux-headers virtual package. by @iav in armbian/build#9686mainline: bump to 7.0 stable. by @EvilOlaf in armbian/build#9661make-yaml-redirector: add more special extensions. by @SuperKali in armbian/actions#18map: accept .tar.xz and register boot-payload / hyperv.zip.xz specialExtensions. by @SuperKali in armbian/armbian-router#40Minor fixes and improvements. by @tomazzaman in armbian/build#9655module_devicetree_overlays: rewrite — atomic writes + subcommand interface + rename. by @igorpecovnik in armbian/configng#846mvebu: helios4 edge → 6.18 LTS, restore orphaned patches. by @iav in armbian/build#9694nanopi-r3s-lts: bump uboot to v2026.04. by @EvilOlaf in armbian/build#9671nightly: blacklist gateway-dk. by @igorpecovnik in armbian/armbian.github.io#281Optimized config. by @igorpecovnik in armbian/os#452Orangepi-5-max: Remove upstreamed patches and use mainline bluetooth.. by @fbernier in armbian/build#9673partitioning: fix #9201 /etc/fstab entry (double comma). by @iav in armbian/build#9488patch/misc: rtw88: fix patch rtw88 driver in 6.12.y, remove in 6.18. by @EvilOlaf in armbian/build#9652readme: add desktops bullet to the feature list. by @igorpecovnik in armbian/configng#857remove stray left-over patch. by @EvilOlaf in armbian/build#9670Rockchip family tweaks: add to group only if group doesn't exists yet. by @igorpecovnik in armbian/build#8479rockchip-rk3588: add Rock 5 ITX PWM fan control overlay. by @ccarpinteri in armbian/build#9695rockchip64: bump some boards u-boot to v2026.04. by @paolosabatino in armbian/build#9662rockchip: migrate xt-q8l-v10 uboot patches. by @paolosabatino in armbian/build#9669rockchip: upgrade u-boot to v2026.04. by @paolosabatino in armbian/build#9663software/jellyfin: gate udevadm reload on udevd presence. by @igorpecovnik in armbian/configng#873sunxi: remove old patchsets. by @EvilOlaf in armbian/build#9687targets: align with armbian/build desktop-to-armbian-config PR. by @igorpecovnik in armbian/os#449tests: enable resolute on every desktop test. by @igorpecovnik in armbian/configng#852ti: configs: family: k3: Update baseline to 12.00.00.07. by @jonaswood01 in armbian/build#9643Try with this. by @igorpecovnik in armbian/os#454u-boot: v2026.01: fix BTRFS zstd decompression failure (error 70). by @iav in armbian/build#9651Update board_slug and board_name for NanoPC T6. by @igorpecovnik in armbian/armbian.github.io#285Update RELEASE version in google-chrome.conf. by @igorpecovnik in armbian/os#450workflows: chunk external-download matrix across 4 parallel invocations. by @igorpecovnik in armbian/armbian.github.io#282workflows: run external-package purge once per workflow, not per chunk. by @igorpecovnik in armbian/armbian.github.io#286xt-q8l-v10: forward-port u-boot board patches to v2026.04. by @igorpecovnik in armbian/build#9666 View the full article
@Nick A Rising CPU temps aren't really a concern. I'm using a massive 6x6cm aluminum heatsink for passive cooling. Even without a fan, it keeps the CPU stable under full load for long periods. The real bottleneck is the frequency throttling, which is really holding back performance.
When I replaced 6.12.58-current-sunxi with armbian-utility to 6.6.16-current-sunxi It did not fully boot up again. Hopefully, replacing the whole content of /boot with the 6.1.24-sunxi kernel from the original image worked and brought m2u back to life. Also, the related modules folder was transferred. So it looks like it is a kernel problem.
Ngô Huỳnh Ngọc Khánh replied to Chiều Nhạt Nắng's topic in Rockchip CPU Boxes
First of all, a huge thank you for your work on bringing Armbian to RK3128 TV boxes. Your guide is incredibly detailed and practical — not just theoretically correct, but actually usable in real-world scenarios where hardware varies wildly. That’s something many tutorials lack. It’s clear you spent a lot of time testing across different boards, and it really helps people like me who are dealing with these unpredictable cheap TV boxes. I also want to say I truly appreciate how you approached the NAND installation process using rkdeveloptool. The way you structured the workflow, especially handling boot components and low-level flashing, made it much easier to understand what’s actually happening under the hood instead of just blindly following commands. I happen to have a bunch of RK3128 devices myself, and thanks to your work, I’ve successfully brought several of them back to life. Even with different variants of RK3128, I was able to get them running properly on NAND with kernel 4.x, which is honestly impressive given how inconsistent these boards can be. That said, I’d like to ask if you might consider extending your approach to RK3228/RK3229 devices using rkdeveloptool on Windows, similar to what you’ve done for RK3128. I’ve been trying to replicate a similar workflow based on your guide and also by studying the multitool source, especially the step-nand function. So far, I’ve attempted: Reusing trust.img and legacy U-Boot from the multitool BSP folder Manually creating a GPT at 0x8000 Writing the image with dd while skipping the first 4MB (similar to step-nand logic) Unfortunately, none of these attempts have worked so far. The main challenge is that many RK3229 boards don’t have an accessible SD card slot (or even pads for one), which makes recovery and testing much harder. If SD boot were available, this would be much easier to debug and iterate. Since you’ve already done the hard work of figuring things out for RK3128 using rkdeveloptool, I was wondering if you might be willing to give RK3229 a try using a similar method. Even a partial guide or some hints about differences in bootloader layout, trust image, or NAND handling would be extremely helpful. Thanks again for your contribution — it’s genuinely valuable for the community. Hopefully RK3229 can be the next one to crack Cheers! -
Just doing upgrades 2nd time on the same image, and it upgraded u-boot and linux-image regardless of armbian-utility put them on hold... I will try to get the kernel from the original image, but if it fails due to the u-boot version difference, I will need to flash it 3rd time, and then I will prevent it from upgrades on these essential packages, like Back In Time.
Maybe you already know, but to be sure (you guys are most likely always swamped), the keyrings workflow has failed the last two runs with the same error, on April 8 & April 15... https://github.com/armbian/armbian.github.io/actions/workflows/generate-keyring-data.yaml ERROR: Unable to find debian-archive-keyring package URL from https://packages.debian.org/sid/all/debian-archive-keyring/download Thanks for all you do! Edit With the limited understanding I have of this, I extracted relevant code and just ran a check on my local machine, and it returned: % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 3012 100 3012 0 0 509 0 00:05 00:05 509 Debian debian-archive-keyring URL: http://ftp.debian.org/debian/pool/main/d/debian-archive-keyring/debian-archive-keyring_2025.1_all.deb % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 3021 100 3021 0 0 532 0 00:05 00:05 532 Debian debian-ports-archive-keyring URL: http://ftp.debian.org/debian/pool/main/d/debian-ports-archive-keyring/debian-ports-archive-keyring_2026.02.04_all.deb (the reason it took 5s was due to the time it took me to press "allow" on the outgoing curl connection in my firewall) So maybe it was just a fluke, and it was just really unlucky failing resolving to packages.debian.org instead of ftp.debian.org those two times. Idk, just wanted to make sure everything was correctly configured. Ignore this if all is ok.
Just found out after upgrading everything on Armbian_23.05.0-trunk_Bananapim2ultra_jammy_current_6.1.24.img.xz, there is no way back once it stops booting. Tried the lowest legacy kernel and also sunxi u-boot and legacy u-boot, everything in chroot, and no success. So I need to start again, reflash the image and prevent the kernel and u-boot upgrades via armbian-config. Is it everything after kernel 6.1.24 when it breaks? Actually, it should be after 6.1.37, which is part of another functional system image.
