Sorry, I don't have this device. Try inserting a USB flash drive into the USB connector and installing the OS from the SD card on it. Try the available options. And choose focusing on your own real logic. Of particular interest and attention if you install the OS on eMMC. Then boot from the eMMC without an SD card connected. And then insert the card into the SD connector and run $HOME/bin/armbian-install. What do you see in the selection window?
Radxa-cubie-a5e second Ethernet port not work after update
Samixa replied to Samixa's topic in Allwinner sunxi
Hello Nob0dy , If you use 25.11.0-trunk.129 after cold reboot you must make soft reboot then second Ethernet port work. -
apt install f2fs-tools
Hello! Stock image from armbian.com; Armbian_25.8.1_Rockpi-s_trixie_current_6.12.41_minimal.img Here is the armbianmonitor's output: https://paste.armbian.com/ikodekuzel The error might be caused by the absence of the f2fs package in the image. root@rockpi-s:~# armbian-install Select filesystem type for eMMC /dev/mmcblk0 2 f2fs <OK> Formating /dev/mmcblk0 to f2fs ... please wait. Error: Filesystem tools for f2fs not installed, exiting root@rockpi-s:~# find / -type f -name f2fs* root@rockpi-s:~#
Ok, I only use this utility on Radxa products ATM, and AFAIK they can't boot from USB without a bootloader on the eMMC or SD card. If I had an image on a USB flash drive attached to the SBC, where would armbian-install expect to find it mounted? And then, would choice #1 or #3 use the SD card or the USB image? Also, should option #2 not show? I don't know how it would copy from the eMMC to the eMMC... The operation of the script works well, but the menu could be much clearer for the Radxa products.
see: /usr/bin/armbian-install The create_armbian function takes different arguments depending on the selection number. Everything looks right on this selection screen. But it seems to me that we see an excessive selection offer in the next selection step and this is misleading. But on other platforms where loading is possible only from a soldered chip, which is defined by the kernel as /dev/mtd, the selection screen will look logical. Try installing the OS on an eMMC or on an SSD connected to the device via a USB-SATA adapter using various options. Experiment. If you find illogical options, then feel free to write your opinion here.
thanks for getting in touch, looks like you're the first one with these 2gb boxes I think the memory trainer for 4gb and 2gb are the same, do stress and performance tests, if crash occurs you really need a new memory trainer for 2gb, you can find an example of memory trainer on this @mvpwar logs do not use third party images, not even mine, always get the official ones This is really an unknown, I bought 4 boxes of this model in 2022, since then there have been changes in the manufacturer's list of materials, the wifi driver is not configured for a reason, the reason is that the wifi has changed several times, you can install the 2022 driver or you can look for users @dfahren who have a different chip here, or even detect a new chip unknown to everyone sudo rmmod brcmfmac_wcc brcmfmac brcmutil modprobe brcmfmac About the TTL debug: (link) windows debug (link) (link) search by image with Ai tool on aliexpress this topic have images from sd-card holder For this question we need to ask @Jean-Francois Lessard he was in contact with this drivers for a while. (Link) this display will be enabled on kernel 6.18+ if you want to mess with experimental images follow this I only got involved in this because there were many interested users, I wasn't one of them -
I am unable to reproduce this on BigTreeTech Pi (v1.2). Set wifi up using netplan via NetworkManager. Wifi connects after a reboot, same if I poweroff the device, disconnect power and then connect back up.
Blank monitor arter login armbian ubuntu cinnamon
SteeMan replied to Anang Wahyudi's topic in Amlogic CPU Boxes
Is your monitor a standard 1080p resolution or something else? If you try a server build that doesn't load a graphical interface does it work? Have you tried something more standard like gnome instead of cinnamon? -
mvftrexc eartuih replied to Anang Wahyudi's topic in Amlogic CPU Boxes
I also installed armbian Armbian_community_25.11.0-trunk.273_Aml-s9xx-box_noble_current_6.12.49_cinnamon_desktop.img.xz di s905x tv box, installed on SD memory card, installation went smoothly, creating username and password was completed, after that load desktop enviroment and dark. no hdmi signal, then i turn it off and on again it can start and load to the password entry screen, and after i enter the password and press enter button, it loads then goes dark no signal Again -
➜ ~ dmesg| grep mmc [ 1.926019] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 2.026282] mmc0: new HS400 Enhanced strobe MMC card at address 0001 [ 2.031712] mmcblk0: mmc0:0001 A3A444 230 GiB [ 2.037074] mmcblk0: p1 [ 2.038122] mmcblk0boot0: mmc0:0001 A3A444 4.00 MiB [ 2.040301] mmcblk0boot1: mmc0:0001 A3A444 4.00 MiB [ 2.042564] mmcblk0rpmb: mmc0:0001 A3A444 4.00 MiB, chardev (243:0) [ 2.150020] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 2.150727] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 2.155343] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 2.155854] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 98,32 bit host data width,256 deep fifo [ 2.156969] dwmmc_rockchip fe2c0000.mmc: Got CD GPIO [ 2.169374] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.432912] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0) [ 2.714811] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 230 [ 2.717703] mmc1: new UHS-I speed SDR104 SDXC card at address 544c [ 2.719268] mmcblk1: mmc1:544c LX64G 58.9 GiB [ 2.721418] mmcblk1: p1 p2 [ 5.394333] EXT4-fs (mmcblk1p2): mounted filesystem 00560a2f-4a48-4f42-85db-f7197f411193 ro with ordered data mode. Quota mode: none. [ 8.122124] EXT4-fs (mmcblk1p2): re-mounted 00560a2f-4a48-4f42-85db-f7197f411193 r/w. Quota mode: none. ➜ ~ uname -a Linux t6.superkali.lan 6.14.4-edge-rockchip64 #1 SMP PREEMPT Fri Apr 25 08:51:21 UTC 2025 aarch64 GNU/Linux root@t6-2:~# dmesg | grep mmc [ 1.793233] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA [ 1.892860] mmc0: new HS400 Enhanced strobe MMC card at address 0001 [ 1.893418] mmcblk0: mmc0:0001 A3A444 230 GiB [ 1.900752] mmcblk0: p1 [ 1.901187] mmcblk0boot0: mmc0:0001 A3A444 4.00 MiB [ 1.902094] mmcblk0boot1: mmc0:0001 A3A444 4.00 MiB [ 1.903152] mmcblk0rpmb: mmc0:0001 A3A444 4.00 MiB, chardev (243:0) [ 2.015519] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 2.015588] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 2.015603] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 2.015721] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 98,32 bit host data width,256 deep fifo [ 2.016264] dwmmc_rockchip fe2c0000.mmc: Got CD GPIO [ 2.029321] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 2.270630] mmc_host mmc1: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0) [ 2.473628] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 247 [ 2.477145] mmc1: new UHS-I speed SDR104 SDXC card at address 544c [ 2.478144] mmcblk1: mmc1:544c LX64G 58.9 GiB [ 2.483356] mmcblk1: p1 [ 3.176039] EXT4-fs (mmcblk1p1): mounted filesystem 3aa41aca-1f77-4222-b253-8d444c3dfca5 ro with writeback data mode. Quota mode: none. [ 8.484634] EXT4-fs (mmcblk1p1): re-mounted 3aa41aca-1f77-4222-b253-8d444c3dfca5 r/w. Quota mode: none. root@t6-2:~# uname -a Linux t6-2.superkali.lan 6.14.4-edge-rockchip64 #1 SMP PREEMPT Fri Apr 25 08:51:21 UTC 2025 aarch64 GNU/Linux root@nanopct6-lts:~# dmesg | grep mmc [ 4.386835] dwmmc_rockchip fe2c0000.mmc: No normal pinctrl state [ 4.386849] dwmmc_rockchip fe2c0000.mmc: No idle pinctrl state [ 4.386921] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ 4.386972] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ 4.386986] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ 4.387034] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 157,32 bit host data width,256 deep fifo [ 4.387131] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree [ 4.387431] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree [ 4.403026] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 4.495259] mmc0: Command Queue Engine enabled [ 4.495299] mmc0: new HS400 Enhanced strobe MMC card at address 0001 [ 4.496710] mmcblk0: mmc0:0001 A3A561 57.6 GiB [ 4.505219] mmcblk0: p1 [ 4.505766] mmcblk0boot0: mmc0:0001 A3A561 4.00 MiB [ 4.506882] mmcblk0boot1: mmc0:0001 A3A561 4.00 MiB [ 4.507923] mmcblk0rpmb: mmc0:0001 A3A561 16.0 MiB, chardev (234:0) root@nanopct6-lts:~# uname -a Linux nanopct6-lts 6.1.84-vendor-rk35xx #1 SMP Wed Dec 18 05:56:40 UTC 2024 aarch64 GNU/Linux root@nanopct6-lts:~# The first two are the variants with 256GB of eMMC, therefore non-LTS, while the last one is the LTS variant with 64GB of eMMC. From my tests with both the edge version and the vendor kernel, both negotiate in HS400 without any problems: A test carried out by T6-2: /dev/mmcblk0p1: Timing cached reads: 7686 MB in 2.00 seconds = 3845.97 MB/sec Timing buffered disk reads: 854 MB in 3.00 seconds = 284.38 MB/sec I don't see your errors, so I think there might be something strange with your board. Can you try the edge kernel and tell me if you have the same problems, or the vendor kernel?
Hey @amazingfate, I have an issue with the build-in IR receiver on my OPI5+: ##O#O## OS: Armbian 25.8.1 noble aarch64 ####### Host: Orange Pi 5 Plus ########### Kernel: 6.1.115-vendor-rk35xx ############# Uptime: 2 mins ############### Packages: 1934 (dpkg), 5 (snap) ################ Shell: bash 5.2.21 ################# Resolution: 3840x2160 ##################### DE: GNOME 46.0 ##################### WM: Mutter ################# WM Theme: Adwaita Theme: Adwaita [GTK2/3] Icons: Adwaita [GTK2/3] Terminal: x-terminal-emul CPU: (8) @ 1.800GHz Memory: 2585MiB / 15957MiB After a reboot it works just fine, but once I suspend/resume it stops working. Logs look clear of errors. I have tried to troubleshoot with ChatGPT but goin' in circles and gave up. Lastly ended up with some speculations from it like: static int rockchip_pwm_remotectl_resume(struct device *dev) { struct remotectl_dev *rc_dev = dev_get_drvdata(dev); // Re-init or restart the device if (rc_dev && rc_dev->restart) rc_dev->restart(rc_dev); return 0; } static const struct dev_pm_ops rockchip_pwm_remotectl_pm_ops = { .resume = rockchip_pwm_remotectl_resume, }; static struct platform_driver rockchip_pwm_remotectl_driver = { .probe = rockchip_pwm_remotectl_probe, .driver = { .name = "rockchip_pwm_remotectl", .pm = &rockchip_pwm_remotectl_pm_ops, }, }; Do you think this is the problem, or if not can I share some details so you can try to find it?
hi guys, yesterdays announcement of Qualcomm Arduino UNO Q on some Dragonwing SoC ... but heard anybody about it already? how it can be open? some questions ... P.
Installing SliTaz on a TV Box with Rockchip RK3229
Werner replied to MXT5's topic in Rockchip CPU Boxes
moved -
Not an Armbian image. If you want to use this one, try to get support from where you got the image from.
Robert Steinman replied to Hqnicolas's topic in Rockchip CPU Boxes
Hi @Hqnicolas first of all, thanks for all yours and other efforts on this project. I had an eye on it a few months back but only this week did I dig out my two boxes.. A few questions for you if you don't mind answering? I have two boxes, 2GB version I was using for development (Android image) and then full fledged 8GB version. Now, because the boxes were in storage for a year or two I thought I had the 4GB and 8GB version, do you happen to have somewhere the Bootloader image for the 2GB model? I've done a google but can only find the 4 and 8GB version. I was experimenting with Armbian and kinda bloated the image so I'll start from scratch. I went ahead and flashed Armbian on both now without issues, however, I've noticed the Wifi is quite slow on it - around 120-240KB/s download and ping to `1.1.1.1` gives around 30 - 300ms, I've had `top` going at the same time and don't see any high CPU utilization. The Wifi driver is something like `bcmrfm` or alike. Is this normal? I've got my 2GB version hooked up to serial out. I do remember seeing an output in plain English however I can't remember the settings, would you be able to tell me? I've tried the common baud rates with Minicom but no matter what I do I just get a garbled output. The link from previous messages for the SDCard holder is now invalid, could you point me to one that will fit nicely on the board? Finally, from your last post, I see you got the front display displaying data, could you point me in the right direction to code for this? Either C++ or Python will do. I do plan on a monitor for eth, wifi and with time + load + temp possibly. Thanks, Robert. -
I use ubunta jammy 1.0.8 for desktop, a 32 GB sd drive, and I was able to achieve a new result: the image was recorded (there were problems with the sd card) and now I just have a red light on all the time, and the operating system does not boot, so the image is not displayed on the monitor, no
Hello, can someone help me with Armbian for this Android box, which seems to have a good configuration for a media center? I would like to know how to flash it and which firmware image I can install on it. Thank you. BBox 4K Specifications: Dimensions: 15x15x3.6cm SoC: Marvell BG4-CT Processor RAM: 2 GB Internal Memory: 16 GB 4K – UHD: Ultra HD, for 4 times better image quality DTS and Dolby sound with S/PDIF and HDMI audio output 128 GB TV recorder, to be completed with the media of your choice Connectivity: SD card reader / 2 USB 2.0 ports Wi-Fi Bluetooth
Which image are you using to boot?
Thanks for compiling that overlay in to a DTB - i've just tried putting that in to /boot/dtb/rockchip/rk3588-nanopc-t6.dtb, rebooted, and it successfully booted and used HS200 mode for the MMC! [ +0.015056] mmc0: SDHCI controller on fe2e0000.emmc [fe2e0000.emmc] using ADMA [ +0.006109] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ +0.000031] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ +0.000008] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ +0.000023] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 95,32 bit host data width,256 deep fifo [ +0.000004] mmc0: new HS200 MMC card at address 0001 [ +0.000045] dwmmc_rockchip fe2c0000.mmc: Got CD GPIO [ +0.000236] mmcblk0: mmc0:0001 A3A444 230 GiB [ +0.002488] mmcblk0: p1 [ +0.000267] mmcblk0boot0: mmc0:0001 A3A444 4.00 MiB [ +0.000759] mmcblk0boot1: mmc0:0001 A3A444 4.00 MiB [ +0.000672] mmcblk0rpmb: mmc0:0001 A3A444 4.00 MiB, chardev (243:0) I'm puzzled as to why that worked, but the overlay didn't work. I would have grabbed some logs if I could, but there was no display output so I think the only output would have been on the UART? Unfortunately, I bought the version that comes in a case and the UART is on the top side of the board that I can't access. Searching around, it doesn't look like it is easy to pop it out of the case either. Just in case putting it in to user overlays was wrong, I tried reverting to the original DTB, putting the overlay in /boot/dtb-6.12.44-current-rockchip64/rockchip/overlay/rockchip-rk3588-nanopc-t6-emmc.dtbo, activating it via armbian-config, and rebooting. Unfortunately I hit the same issue as before where it wouldn't boot. Is there a way I can debug why the overlay isn't working without getting access to the UART header on the top of the board?
