  2. seems like openwrt already figured this and the fix is actually upstream: https://github.com/torvalds/linux/commit/c3fe7071e196e25789ecf90dbc9e8491a98884d7 (also see https://github.com/immortalwrt/immortalwrt/commit/7ef19bb9cd59f5018fc96b01a5465ed84038cfe8) This may tell that one or more Armbian patches make things worse , no clue though which one if any.
  3. Yesterday
  4. The SBC I'm using has an 8 core CPU that's getting close to my laptop, 32GB of RAM, and currently has 256GB eMMC + 1TB NVMe.... Yes, it's something of a research project, but at the current rate, I believe that if I can get a working GPU I should be able to run a game via Steam at usable frame rate. Currently Steam can't use the GPU, because Mali doesn't have the required capabilities, but LLVMpipe is giving me ~2fps, using the CPU, while also emulating x86... My goal here is not as much a practical machine, but a test/build platform, without buying one of system76 $5000+ ARM workstations. Also, hardware video decode would be nice. It is not weak by any means tho, see attached!
  5. Hi @Werner, I bought an UART USB device and followed your video here https://www.youtube.com/watch?v=UpVMO7gbnYM to read boot logs. I'm not a huge expert but looks like there is a problem finding /boot when two nvme are connected. Please find attached the following logs: uart-bootcorrectnvme.log -> one nvme plugged (the one with os installed in slot 1) - works! uart-bootdualnvme.log -> two nvme plugged (the one with os installed in slot 1) - fails! uart-bootmicrosd.log -> two nvme plugged + microsd plugged - works! Tests have been executed with official 30W Radxa Power adapter ( same result with POE+ 25W hat) Please, let me know if there is anything else I can provide. Thanks uart-bootcorrectnvme.log uart-bootdualnvme.log uart-bootmicrosd.log
  6. Hello everyone. I'm kind of new in this SBC bussiness. I'm looking for a way to enable the ethernet port of the expansion board on this device. Hardware wise the port works on Dietpi, but the GPU works better on this version of armbian (Armbian Linux 6.19.9-edge-sunxi64). Anyone who could tell me o point me to the right direction? Thanks.
  7. @Werner I have tried your command but no success. Here is what a clean boot of Armbian shows. I also ran some commands with the outputs below.
  8. sven-ola
    Hello @1111Windows, you are booting an unknown u-boot from NVME that does not find any meaningful data stored on the NVME. You may need to re-insert the SD card or swap to a working SD card or so. I attach the (timestamp stripped for better diff) version from you (forum.txt) and the expected UART output on my RV2 (minicom.txt). The latter I have captured after re-downloading and SD-flashing the mentioned trixie-gnome img which has a root file system with UUID=8f6e5f9c-3108-4e4d-8fbd-10a8295d396e. HTH // Sven-Ola forum.txt minicom.txt
  9. Thank you very much. Will attempt to erase the SPI flash memory.
  10. https://docs.armbian.com/Process_Contribute/#adding-a-new-board
  11. @sven-ola Have you tried booting from a microSD card? I downloaded Armbian-unofficial_26.02.0-trunk_Orangepirv2_trixie_current_6.18.18_gnome_desktop.img and flashed it to my microSD card, but it won't boot. log: sys: 0x200 try sd... bm:3 j... U-Boot SPL 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) [ 0.381] DDR type LPDDR4X [ 0.383] set ddr tx odt to 80ohm! [ 0.393] lpddr silicon init consume 11ms [ 0.394] Change DDR data rate to 2400MT/s [ 0.633] Boot from fit configuration x1_orangepi-rv2 [ 0.635] ## Checking hash(es) for config conf_18 ... OK [ 0.641] ## Checking hash(es) for Image uboot ... crc32+ OK [ 0.652] ## Checking hash(es) for Image fdt_18 ... crc32+ OK [ 0.674] ## Checking hash(es) for config config_1 ... OK [ 0.677] ## Checking hash(es) for Image opensbi ... crc32+ OK [ 0.725] U-Boot 2022.10_armbian-2022.10-Sd61c-P155c-H452d-V4161-B61c5-R448a (Mar 17 2026 - 03:52:17 +0000) [ 0.732] CPU: rv64imafdcv [ 0.734] Model: ky x1 orangepi-rv2 board [ 0.738] DRAM: 2 GiB [ 0.830] Core: 414 devices, 29 uclasses, devicetree: board [ 0.843] WDT: Started PMIC_WDT with servicing (60s timeout) [ 0.848] WDT: Started watchdog@D4080000 with servicing (60s timeout) [ 0.857] MMC: [ 0.956] *** Warning - bad CRC, using default environment [ 0.961] initialize_console_log_buffer [ 0.962] Have allocated memory for console log buffer [ 0.967] In: serial [ 0.969] Out: serial [ 0.971] Err: serial [ 1.116] k1x_qspi spi@d420c000: qspi iobase:0x0x00000000d420c000, ahb_addr:0x0x00000000b8000000, max_hz:26500000Hz [ 1.124] k1x_qspi spi@d420c000: rx buf size:128, tx buf size:256, ahb buf size=512 [ 1.131] k1x_qspi spi@d420c000: AHB read enabled [ 1.136] k1x_qspi spi@d420c000: bus clock: 26500000Hz, PMUap reg[0xd4282860]:0x0000075b [ 1.143] k1x_qspi spi@d420c000: AHB buf size: 512 [ 1.148] SF: Detected XM25QU128C with page size 256 Bytes, erase size 64 KiB, total 16 MiB List of MTD devices: [ 1.159] * nor0 [ 1.160] - device: flash@0 [ 1.163] - parent: spi@d420c000 [ 1.166] - driver: jedec_spi_nor [ 1.170] - path: /soc/spi@d420c000/flash@0 [ 1.173] - type: NOR flash [ 1.176] - block size: 0x10000 bytes [ 1.180] - min I/O: 0x1 bytes [ 1.183] - 0x000000000000-0x000001000000 : "nor0" [ 1.188] - 0x000000000000-0x000000010000 : "bootinfo" [ 1.193] - 0x000000010000-0x000000020000 : "private" [ 1.198] - 0x000000020000-0x000000060000 : "fsbl" [ 1.203] - 0x000000060000-0x000000070000 : "env" [ 1.208] - 0x000000070000-0x0000000a0000 : "opensbi" [ 1.213] - 0x0000000a0000-0x000001000000 : "uboot" [ 1.219] Failed to get fastboot key config: -19 [ 1.222] Failed to probe HUSB239: -19 [ 1.227] RGMII interface [ 1.228] eth0: ethernet@cac80000 [ 1.231] MAC mapping file path not set in environment [ 1.236] K1X: :_load_env_from_blk [ 1.247] Can't set block device [ 1.248] Net: eth0: ethernet@cac80000 [ 1.254] Hit any key to stop autoboot: 0 Loading K1-X Environment ... [ 2.260] [ 2.261] Running NVMe Scan ... [ 2.272] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 2.277] Now init Rterm... [ 2.279] pcie prot id = 1, porta_init_done = 0 [ 2.283] Now waiting portA resister tuning done... [ 2.288] porta redonly_reg2: 00005d37 [ 2.292] pcie_rcal = 0x00005d37 [ 2.295] pcie port id = 1, lane num = 2 [ 2.298] Now int init_puphy... [ 2.301] waiting pll lock... [ 2.304] Now finish init_puphy.... [ 2.307] pcie_dw_k1x pcie@ca400000: Unable to get phy0 [ 2.312] pcie_dw_k1x pcie@ca400000: Unable to get phy1 [ 2.317] pcie_dw_k1x pcie@ca400000: PCIe interface power on, set gpio 116 to 1 [ 3.426] PCIE-0: Link down [ 3.438] pcie_dw_k1x pcie@ca800000: has no power on gpio. [ 3.441] pcie_dw_k1x pcie@ca800000: has no power-on-status flag, use default. [ 3.448] Now init Rterm... [ 3.450] pcie prot id = 2, porta_init_done = 0 [ 3.455] Now waiting portA resister tuning done... [ 3.459] porta redonly_reg2: 00005d37 [ 3.463] pcie_rcal = 0x00005d37 [ 3.466] pcie port id = 2, lane num = 2 [ 3.470] Now int init_puphy... [ 3.472] waiting pll lock... [ 3.475] Now finish init_puphy.... [ 3.479] pcie_dw_k1x pcie@ca800000: Unable to get phy0 [ 3.484] pcie_dw_k1x pcie@ca800000: Unable to get phy1 [ 4.590] PCIE-1: Link down [ 4.642] pcie_dw_k1x pcie@ca400000: has no power-on-status flag, use default. [ 4.646] Now init Rterm... [ 4.648] pcie prot id = 1, porta_init_done = 0 [ 4.653] Now waiting portA resister tuning done... [ 4.657] porta redonly_reg2: 00005d37 [ 4.661] pcie_rcal = 0x00005d37 [ 4.664] pcie port id = 1, lane num = 2 [ 4.668] Now int init_puphy... [ 4.671] waiting pll lock... [ 4.673] Now finish init_puphy.... [ 4.677] pcie_dw_k1x pcie@ca400000: Unable to get phy0 [ 4.682] pcie_dw_k1x pcie@ca400000: Unable to get phy1 [ 4.687] pcie_dw_k1x pcie@ca400000: PCIe interface power on, set gpio 116 to 1 [ 5.795] PCIE-0: Link down [ 5.807] pcie_dw_k1x pcie@ca800000: has no power on gpio. [ 5.810] pcie_dw_k1x pcie@ca800000: has no power-on-status flag, use default. [ 5.817] Now init Rterm... [ 5.819] pcie prot id = 2, porta_init_done = 0 [ 5.824] Now waiting portA resister tuning done... [ 5.828] porta redonly_reg2: 00005d37 [ 5.832] pcie_rcal = 0x00005d37 [ 5.835] pcie port id = 2, lane num = 2 [ 5.839] Now int init_puphy... [ 5.841] waiting pll lock... [ 5.844] Now finish init_puphy.... [ 5.848] pcie_dw_k1x pcie@ca800000: Unable to get phy0 [ 5.853] pcie_dw_k1x pcie@ca800000: Unable to get phy1 [ 6.959] PCIE-1: Link down [ 6.963] no nvme partition table available [ 6.964] Couldn't find partition nvme 0:1 [ 6.968] Couldn't find partition nvme 0:1 [ 6.972] Couldn't find partition nvme 0:1 [ 6.976] Couldn't find partition nvme 0:1 [ 6.980] Couldn't find partition nvme 0:1 =>
  12. Heres what I am seeing on my screen https://drive.google.com/file/d/1SSNnvOy-BjxAzklcAoApjS2zz1HnMn-v/view?usp=sharing Heres me messing with the headphon jack https://drive.google.com/file/d/1Z2Guva-FWYv2mu3VCPujXPoc7r_iqpB6/view?usp=sharing
  13. Sorry for the late reply I got caught up with my new job and forgot my password for my previous account. eselarm you are probably not wrong but as I have continued to use armbian it seems more like armbian can't differentiate between the headphone jack and the internal speakers. It's like they are one and the same this didn't happen with mint or antix although it was still very broken on antix. [Should I move this part to a separate topic] Unrelated to the headphone jack but I also found that when my Chromebook goes to sleep or when I close the lid armbian will just unmount itself, have a blinking _ on the upper left of the screen or a terminal I can't get out of so l and I have to reflash my micro sd card as a temporary fix. also the minimal build always fails to install a new desktop environment. But everytime I reflash the latest build of Gnome it runs a bit better each time, which is great.
  14. I ran into what appears to be the same issue (see my log). I have added the suggested qemu-user-static package, which forced removal of another qemu- family package I had previously installed to work around problems with binfmt. Not only did it compile correctly, it also ran so much faster, as you can see in the number of log lines for this build! Thank you for the assistance and getting me on the right track with the right package selection! Best Regards, Lobosito
  15. @tin harden A7A mainline is still a WIP.
  16. @Thur_Wander For debugging purposes, UART is highly recommended. Use balena Etcher to write the compiled image to your SD card.
  17. Last week
  18. @Nick A One last question, if i do this will i still have to use UART and flash the firmware? imma guess it's a yes but i guess it's still worth asking.
  19. @Thur_Wander Here are the steps to create a secure boot image. This example is using the tanix-tx6s-axp313 defconfig. You probably want one of the X96q defconfig's.
  20. @Nick A could you explain this a bit to me? i'm actually quite new to this and i just got this TV box the only thing i managed to do was installing a software version from a guy who debloated and checked it for spyware. also when i use the reset button in the av jack it just ignores everything and recovers from an internal image or something.
  21. @Octavio Cuatrochio@Thur_Wander Maybe it has secure boot enabled.
  22. Hi, I am here in 2026 with the Amrbian 26.2.1, I've tried the proposed fix from @c0rnelius but it's not working on my OS version. If anyone has any updated solution that'd be amazing. Thank you
  23. I have this exact same model and the device appears to be heavily locked down... Did this method worK? i'm trying to get a linux ARM distribution running but i can't flash a custom ROM
  24. The most current download images for Helios64 are now all provided with linux 6.18.xx. I downloaded a minimal image and checked the dtb: it would not appear to contain the opp-microvolt patch that made Helios64 finally stable. So for the ones who have stability issues again on Helios64, I attached the patched dtb compiled for linux 6.18.xx using the exact same opp-microvolt values as in the previous dtb versions I compiled for linux 6.6 and 6.12. The current linux deb files can be downloaded from beta.armbian.com, the linux 6.18.18 deb files I used can be downloaded from here (to be installed with 'dpkg -i linux*'). In order to install the dtb, simply unzip it, copy it into the proper location, update initramfs and reboot: # install the dtb with the opp-microvolt patch: unzip rk3399-kobol-helios64.dtb-6.18.18-opp.zip cp rk3399-kobol-helios64.dtb-6.18.18-opp /boot/dtb/rockchip/rk3399-kobol-helios64.dtb update-initramfs -u reboot rk3399-kobol-helios64.dtb-6.18.18-opp.zip
  25. Another attempt, again check https://testing.armbian.de/r4s/?C=M&O=D for most recent debs. This time adding an artificial bus scan delay into the r4s dts. Another poke in the dark but perhaps...
  26. See inline comments. Dirty SPI may cause this but without logs from serial console this is just a guess
  27. Is there mainline support for a7a now
