bout to try th latest 25.8.2
dale replied to Jean-Francois Lessard's topic in Amlogic meson
@Hqnicolas I will give it a try, but atm I'm happy with existing working patch for tm16xx. Edit: it seemed that @jock has updated the patch with latest code https://github.com/armbian/build/pull/8679 -
Unsupported kernel version while updating raspi-firmware on Debian 13
0jay replied to lovenemesis's topic in Raspberry Pi
may not help you (i'm running the pi4 build) but i find that putting holds on rpi-eeprom, raspi-firmware and raspberrypi-sys-mods from first boot solves this problem -
Actually using a zero2w but same image obv as rpi4... unable to login (refused ssh). had to switch back to the 25.2.3 build
Good evening all and thanks @Igor for the suggestions. I managed to connect to my Cubox-i4 from my laptop via USB with sudo picocom -b 115200 -r -l /dev/ttyUSB0 and now I have lots of messages, but no success with booting the Ubuntu 24.04 Noble minimal image. In particular, there is a complaint about a CRC error. I've attached the text generated by letting the boot process run for awhile. I decided to try the Bookworm minimal image, and I'm up and running right away with that. So I guess I will stick with Bookworm for now. If anyone generates a new Ubuntu 24.04 image they would like me to try, happy to give it a go. Or of course any other suggestions! booting_ubuntu_cubox-i.txt
Hqnicolas replied to Jean-Francois Lessard's topic in Amlogic meson
With 3 whipping in a language model you can, please give it a try to use the whip, language models are there to use you need to get updated cd /Downluads/ git clone https://github.com/armbian/build cd build ./compile.sh I WANT THE EDGE I WANT TO CHANGE KERNEL CONFIG CTRL+TAB sudo chmod 777 777.sh sudo chmod +X 777.sh sudo ./777.sh ps: I'm getting it to work natively on the h96-max-v56, many users want this feature but don't want to install anything it seems that @Jean-Francois Lessard polishing made this project look amazing, congratulations - Yesterday
m33ts4k0z replied to maximumsettings's topic in Orange Pi 5
@amazingfate Do you know if its possible to use tha latest mali blob with wayland and vulkan support (g24p0-wayland-gbm) and at the same time use the rkmpp on vendor 6.1.115? I got everything compiled and seemingly working but when I try to connect to a stream, all I see is black screen. This is with the moonlight-qt client and an orange pi 5 plus (rk3588) -
Having the same issue however your solution doesn't seem to work for me for whatever reason.
I burned the image with Balena Etcher and verified it. After the first attempt it did not boot. Downloaded and burned the image a second time on a different SD card, again not booting. The green light on the board stays on. I'm a fan of Armbian. Never had issues on my RPI5. I hoped this new powerfull SBC would be the same but no, Armbian is not working and the RADXA OS also is giving me lots of problems. Sorry to say, I'm a little dissapointed... Ernst-Jan
With the errant icon, yeah that kind of thing can be really frustrating with linux design. I'm not that deeply familiar with it. Usually when I experience something like that, I look it up in a search engine. What I can say is that many settings are stored in hidden directories under the user home folder. Hidden files start with a period. Go to your home directory: ls -la ...but which one to explore and what to look for... You'll probably find what you're looking for with a search engine. And on your rant, yes I've sensed our views of the computing world to be similar as well. Punching holes in cards - yes! You really would have to think and get it right the first time. And it's not so hard to do. You set the standard, practice it and make it a habit. My second computer was a Commodore 64, back in the early-mid '80s. I played lots of games on there. Even though I'd started programming in BASIC before that, I learned more to program on that computer, in BASIC, and in assembly language. I experienced from others' software and what I could do on my own, to be resourceful, and that creating software that is highly functional and can do "a lot" really doesn't require much more than a tiny program. There's no excuse for complicated software. Also others and myself created it right the first time without any "patches" or "software updates" BS - once it was done, it was done right! I almost never encountered bugs from others' software on my C64. I think there was one game than had bugs in it - that's it, it was an outlier. But that computer, you'd turn it on and get the prompt within maybe 200ms. There was no "boot up" BS. And its user interface is always immediately responsive. It was never sluggish. My first experience with the extremeness of bloating was with my first x86 PC around 1991 i think. It ran MS-DOS 5.0, which took up around 7 or 8 MB as I recall, on the hard drive (or was that Windows 3.1?). And to create an assembly language program that was just a "hello world", an executable .com of that would be around 30 bytes or so, but an executable .exe was around 784K or something crazy like that. 99% of that was .exe format overhead junk! And for today's operating systems and their functionality, there really is no excuse why the total size of the complete operating system on the hard drive should exceed a megabyte (or half that), let alone several gigabytes. The bloating of today is so far beyond reason it's way off in another galaxy. A minimum of 10,000 to 1. So much software today is based on scripting languages and run-time interpreters. Plus the linux operating system was originally designed back in the 1960s!!! ...as unix, before it was ported to personal computers as linux. Apparently, they've got layer upon layer upon layer of patches and changes and different ideas and outdated models all enmeshed in a galactic-sized mess. I've also seen how the MB, GB, and TB have been hijacked by a crooked industry which has redefined those terms to be powers of 1000 rather than the truth that they're powers of 1024. Even with that, the amount delivered on memory and storage devices, in may cases, falls short even of that crooked re-definition. Now an actual GB or MB is called "GiB" or "MiB", while what is often now called a MB or GB is a bold-faced lie! What the computer hardware and OS development needs is to throw away the existing model and create a new one from scratch. As a software engineer, I have done that numerous times on my own projects, and the result is always a spectacular improvement because I can apply what I learned from the previous iteration in developing the new foundation. And that's always a simple, creative and enjoyable process. It does take a some time to do, but the results are more than worth it, and the resulting accelerated pace of development later more than makes up for it. The Orange PI 5 Plus is my first ARM board. What I'm more looking forward to though is getting into RISC-V. I'm not to familiar with it yet, but It's completely open and apparently values simplicity. That might be a really great development environment for something genuinely new.
@Faheem328 Do you have free time? how much free time do you have exactly? we are looking for someone like you with a RK3528 box we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request let's talk?
Hi @Fiery_Fire, all the changes I used have been merged to armbian. I tried to build an image from the current main branch and I got no HDMI output too. I tried a newer kernel and applied all the patches from xdarklight's branch https://github.com/xdarklight/linux/tree/meson-mx-integration-6.15-20250608, here is an armbian branch: https://github.com/domin144/armbian-build/tree/meson_6.16 I compiled with this command: ./compile.sh build BOARD=aml-s805-mxq BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=trixie Now I get some output on HDMI, but it is so distorted, I cannot read any text. Something must have been changed in the 6.12 kernel between the time I tried it last and now. Unfortunately I will not have time to debug this in a foreseeable future. Hopefully this distorted output will be a better starting point for you than no output at all.
Secure Boot -Transpeed TV Stick M98-Y6 - H313
Nick A replied to rockamal's topic in Allwinner CPU Boxes
@rockamal maybe you’ll have better luck with x96q lpddr3 https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/159-add-x96-q-lpddr3-v1.3-defconfig.patch git clone https://github.com/NickAlilovic/build.git --branch v20250306 cd build pico patch/u-boot/u-boot-h616/159-add-x96-q-lpddr3-v1.3-defconfig.patch Change @@ -0,0 +1,191 @@ to @@ -0,0 +1,192 @@ add this to the bottom of the patch "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" Then you need to include the secure boot patch. pico patch/u-boot/u-boot-h616/secure-boot.patch create the secure boot patch. you can find it here. -
update to edge kernel rolling release 6.16.x
The Tall Man replied to Dantes's topic in NanoPi R6S/R6C
Thanks for giving it a nudge. Looks like some activity's brewing on it now. @laibsch, As I said before, I don't have an account with github. But I had looked at your Commit, and it looked to me like you copied the existing edge kernel's .dts, but with the needed modification. From my looking at it, I think it would work. Although if I were doing it, I would do it in 2 commits: 1. An initial commit that's just a copy of the present devicetree to bring it into the patch system, since it's apparently never been part of the patch system. 2. The change to address the specific issue. To address what paolosabatino's, comment on github said... The current kernel and edge kernel have two different devicetrees. The one this is about is the edge kernel's devicetree. -
sorry for the delay, @mvpwar for RK3566 NPU you can use the original armbian DTB that enables NPU support: https://github.com/armbian/linux-rockchip/blob/rk-6.1-rkr5.1/arch/arm64/boot/dts/rockchip/rk3566-h96max-v56.dts I think you will take fragments from ancient builds like this: https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/page/16/#findComment-211031 I don't know what the status is in version 6.17 but we are still required to use vendor 6.1
Thank you for the nudge. But who are you nudging? It isn't up to the PR author (me) to get this accepted. It's been rotting away since nobody actually tested it. And that could only be done by people who have the device, including @The Tall Man, I believe or others. I do not have access to the device(s) in question. And then one of the other devs needs to accept it. I'm happy to rebase or respond to reviews, but that hadn't happened, so we are now going in circles. So, the question is really who you are nudging.
Hi, Werner and Tallman. The slow update did seem a bit odd to me - its why I mentioned my good network connection. I'll try again later and see what happens. I am in eastern europe, and we don't normally get this kind of problem. I used to have a network connection of only 6 Mbit/s until about a year ago, and even that worked OK at the time. (948 Mbit/s as we have now is great). Normally my Linux Mint apt-update is usually less than a minute. Tallman:- we seem to have common likes and dislikes!. First, Firefox is definitely not installed on my Armbian, so I'll have a look at trying to install it later. Like you, I also dislike Snap and Flatpak packages. My first experience with a computer was back in the early 1960's with a Honeywell 803 - it had 1K x 18bit word magnetic memory, so any program written to run on it (usually Algol 63 - more or less machine code) had to be *tiny*. A colleague wrote a successful program to play whist on it - it rather makes the bloat associated with snap/flatpak packages look very silly to someone like me. My programming experience ended some years ago for various reasons, but I am firmly convinced that modern machines could be far faster and more efficient than they are if modern programmers had to use much less memory. We had to be very careful how we used space, and spent time optimizing anything we wrote. (actually not written - it was mostly hand-punched paper tape. (whats a keyboard)? I believe if modern programmers had to do this, we would not hear so much about the insecurity of software/networks - and I won't even go into how much companies like Microsoft appear to contribute to this bloat. I would have thought that an OS should contain all the elements (dependency files) necessary to run any software compatible with the hardware, so therefore it should only be necessary to install 'system' packages, instead of snap/flatpak with all the attendant dependencies (bloat). - Sorry - rant over. Finally, another question, which is driving me nuts. While I was playing with Armbian, I accidentally dragged the LibreOffice Write icon over the Armbian Config Icon, and got a new 'unnamed icon' folder - and I can find no way to get rid of it. I assumed this created a similarly named folder somewhere, so all I had to do was delete it but extensive file searching hasn't traced it so far - any pointers please? Thanks again, Keith Edit: thanks for that Torz77 - should be able to find it, I guess.
Firefox is called firefox-esr in Debian (Extended Support Release)
Recently, when I run `armbian-upgrade`, I was greeted with an update to raspi-firmware. However, this version of firmware doesn't seem to work with the corresponding intramfs with kernel 6.12.44. sudo armbian-upgrade Hit:1 https://mirrors.ustc.edu.cn/armbian trixie InRelease Hit:2 https://mirrors.ustc.edu.cn/debian trixie InRelease Hit:3 https://mirrors.ustc.edu.cn/debian trixie-updates InRelease Hit:4 https://mirrors.ustc.edu.cn/debian-security trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Get:6 https://apt.syncthing.net syncthing InRelease [24.2 kB] Fetched 24.2 kB in 2s (14.8 kB/s) 2 packages can be upgraded. Run 'apt list --upgradable' to see them. The following packages will be upgraded: armbian-config raspi-firmware Summary: Upgraded: 2, Newly installed: 0, To remove: 0, Not upgraded: 0 Download size: 13.2 MB Space required/available: 272 kB / 553 GB Get:1 https://mirrors.ustc.edu.cn/armbian trixie/trixie-utils arm64 raspi-firmware all 1:1.20250915-1~bookworm [13.0 MB] Get:2 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.11.0-trunk.234.0923.175957 [157 kB] Fetched 13.2 MB in 2s (5,967 kB/s) (Reading database ... 46602 files and directories currently installed.) Preparing to unpack .../raspi-firmware_1%3a1.20250915-1~bookworm_all.deb ... Unpacking raspi-firmware (1:1.20250915-1~bookworm) over (1:1.20250430-4~bookworm) ... Preparing to unpack .../armbian-config_25.11.0-trunk.234.0923.175957_all.deb ... Unpacking armbian-config (25.11.0-trunk.234.0923.175957) over (25.11.0-trunk.192.0915.191809) ... Setting up armbian-config (25.11.0-trunk.234.0923.175957) ... Setting up raspi-firmware (1:1.20250915-1~bookworm) ... Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ... Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ... WARNING: Unsupported kernel version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Processing triggers for initramfs-tools (0.148.3) ... update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711 WARNING: Unsupported initramfs version (6.12.44-current-bcm2711) - skipping setup NOTE: Manual boot configuration may be required Summary: Upgraded: 0, Newly installed: 0, To remove: 0, Not upgraded: 0 How exactly should I do in this case? In the past, I normally invoke update-intramfs to perform the the intramfs update. Thanks,
jock replied to Hqnicolas's topic in Rockchip CPU Boxes
You're welcome @Hqnicolas 👍 -
I came here to thank @jock https://github.com/armbian/build/pull/8679 and ask you to make the test @Vincenzoernst1 @GBEM @guenter you don't need to install external driver anymore merged 2 commits into armbian:main from paolosabatino:update-tm16xx 4 days ago Available since https://github.com/armbian/build/tree/v25.11.0-trunk.258 rockchip rk3566: h96-TVbox: Include i2c Led Pins into dts. by @hqnicolas in armbian/build#8666 rockchip64: update tm16xx driver from kernel mailing list. by @paolosabatino in armbian/build#8679 -
We support Armbian software but not random software from the internet. RKdevtool is as far as I know a tool from Radxa, not Armbian, either. CPU boxes are cheap and cheap for a reason. Nobody really supports them. We give some very limited community support here. With your current random software this is not the right spot for you. Best of luck to you.
The wifi and ethernet both are not working for my transpeed 8k tv device. it has a rk3528 chipset. 1. I tried resetting it from its android factory setting. it did not work. 2. I found its image which i flashed via RKdevtool. Still the both wifi and lan did not work. 3. i tried external usb wifi dongle but it did not detect it. 4. I tried to install debian OS i found somewhere on internet designed for rk3528 on it as alternative but rkdevtool did not identified the image Any suggestions would be welcome. Thanks in advance,
HW (features are determined by kernel used in the image) related issues are shared among all variants, desktop, cli, minimal, Debian or Ubuntu.
