Then also make sure what that is; I do not know exact HW and storage devices for OPi5Pro, but let's say wipe eMMC and SPI-flash first, so you are sure that only the U-Boot on the SD-card can be started. That one is easier to rewrite using another computer. OrangePi has virtually no support is my impression, just 1 image on googledrive then they go on to make a new SBC variant. But that 1 version might have good enough U-Boot so maybe rip that out the image and patch that into some own/Armbian image. Still no guarantee for success, but otherwise you need to develop/change DeviceTree and/or overlays yourself. I have a NanoPi-R6C, also RK3588S based, and it does well with 3 bootloader variants (FriendlyElec's, Armbian variants, EDK2-UEFI) for Armbian mainline based kernels.
Android TV Stick (iK316-H16430)
Werner replied to Muhammad Hanis Irfan Mohd Zaid's topic in General Chat
moved -
Hi @eselarm, Thats a good question. I have no idea :) I use joshua's ubuntu 24.04 image in this board since I can not boot armbian from emmc using the community version of armbian. It always fails. So i suppose it is the uboot it comes with joshua's image. If uboot is not embedded in that image, probably it is the default one that came with the board.
I've got this Android TV stick: https://shopee.com.my/RUBY-Smart-TV-24-Inch-Android-TV-Murah-TV-32-Inch-WiFi-4K-HDR-LED-Television-WiFi-Youtube-Netfli-i.1246310125.27851733843 Tried to run a progressive web app (PWA) and just learned that PWA is not supported by Android TV OS. I've found that since it's just a SBC, I can install any other OS on it and stumbled upon Armbian. Since I'm new, I would like to know what images is supported with this board and any related guides to install it. This board has 1 full HDMI port, 1 USB type A port for data, and 1 USB type C port for power only (this is just my assumption). No SD card slot. I just need it to be able to run a modern and latest browser to run the PWA. Thanks for all the help 😀
@salas What U-Boot are you using?
Remote backup of SD card for an Orange Pi?
eselarm replied to Geoffrey Schaller's topic in Beginners
Most SBC backup tools I have seen are based on rsync and they operate then on/with Ext4 filesystem. Is fine when you don't have complex servers and databases running. I am not sure about pihole, but I saw that by default it keeps a 1 year history so a database file of about 1GB. I am not sure what happens to integrity of such a file on the target if during copy/rsync the source file also changes. AFAIK databases have their ways to handle it, when power-loss or so, but not sure. If you want to be sure, use Btrfs as filesystem, then you can make atomic snapshots and use those for source of rsync or use: btrfs send -p <old snapshotnumber> <snapshot number>| ssh <remote_host> btrfs receive <backup folder>. That is the basic manual option. Complete tool is btrbk, it is standard in Debian repo, see https://digint.ch/btrbk/index.html docs of author. You still need some partition and bootloader handling I think. Or assume that a total crash is rare so only backup to NAS or so and reconstruct manually if you need a new SD-card or so or want to copy thing so eMMC of the OPi3. -
Werner replied to jondowd's topic in Orange Pi 5
jondowd replied to jondowd's topic in Orange Pi 5
It's not that I won't share it - I was waiting for some instruction of what information was needed. It looks like this... [ 15.261345] Internal error: Oops: 00000000960000004 [#1] SMP and what other information can I give that would help diagnose my trouble? After a restart, as the login prompt arrives - this comes on the screen and I can't seem get past it, other than powering the machine down and restarting it. Thank you for your help. Jon Dowd -
Maybe this helps? https://forum.armbian.com/topic/29427-shrink-backup-a-tool-for-backing-up-sbcs/
Which you won't share since we all have second sights, right? Also code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } armbianmonitor -u can be helpful. I have an Opi5 with nvme here and reboot works fine. -
My goal is to be able to boot mainline kernel actually. I can "boot" orangepi5-pro using the orangepi5 dts in mainline 6.15.4 , but I get no ethernet so that is a no go for me. I dont need wifi, bluetooth or display output, but I need ethernet, emmc and nvme at least. Fdt Ramdisk skip relocation No misc partition ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 Using Device Tree in place at 0000000008300000, end 0000000008316c97 can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. ## reserved-memory: shmem@10f000: addr=10f000 size=100 Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000) Total: 5511.816/5905.569 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.15.4 (root@pi5pro3.lan) (gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Sat Jun 28 00:27:52 UTC 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Xunlong Orange Pi 5 [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: 0x000000000010f000..0x000000000010f0ff (0 KiB) nomap non-reusable shmem@10f000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000004ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff] [ 0.000000] node 0: [mem 0x0000000100000000-0x00000003fbffffff] [ 0.000000] node 0: [mem 0x00000003fc500000-0x00000003ffefffff] [ 0.000000] node 0: [mem 0x00000004f0000000-0x00000004ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000004ffffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 1280 pages in unavailable ranges [ 0.000000] On node 0, zone Normal: 256 pages in unavailable ranges [ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 33 pages/cpu s97960 r8192 d29016 u135168 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=0e3353db-b89e-4834-bd3a-f7400169b277 rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.16-9fffbe1e78,bl31-v1.45,uboot-08/31/2024 [ 0.000000] Unknown kernel command line parameters "cgroup_enable=memory cgroup_memory=1", will be passed to user space. [ 0.000000] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes [ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] software IO TLB: area num 8. [ 0.000000] software IO TLB: mapped [mem 0x00000000eb000000-0x00000000ef000000] (64MB) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4192256 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] ftrace: allocating 68193 entries in 268 pages [ 0.000000] ftrace: allocated 268 pages with 3 groups [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 0.000000] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8. [ 0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: enabling workaround for GICv3: non-coherent attribute [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 480 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [424:479] [ 0.000000] GICv3: Using MBI frame 0x00000000fe610000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000 [ 0.000000] ITS [mem 0xfe640000-0xfe65ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] GIC: enabling workaround for ITS: non-coherent attribute [ 0.000000] ITS@0x00000000fe640000: allocated 8192 Devices @100150000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100160000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] ITS [mem 0xfe660000-0xfe67ffff] [ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001 [ 0.000000] GIC: enabling workaround for ITS: non-coherent attribute [ 0.000000] ITS@0x00000000fe660000: allocated 8192 Devices @100180000 (indirect, esz 8, psz 64K, shr 0) [ 0.000000] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100190000 (flat, esz 2, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000001001a0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000001001b0000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@100[1] /cpus/cpu@200[2] /cpus/cpu@300[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@400[4] /cpus/cpu@500[5] /cpus/cpu@600[6] /cpus/cpu@700[7] } [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000930] Console: colour dummy device 80x25 [ 0.000944] printk: legacy console [tty1] enabled [ 0.001803] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.001832] pid_max: default: 32768 minimum: 301 [ 0.001964] LSM: initializing lsm=capability,apparmor [ 0.002090] AppArmor: AppArmor initialized [ 0.002252] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.002310] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.005371] rcu: Hierarchical SRCU implementation. [ 0.005392] rcu: Max phase no-delay instances is 1000. [ 0.005725] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.006942] EFI services will not be available. [ 0.007404] smp: Bringing up secondary CPUs ... [ 0.008106] Detected VIPT I-cache on CPU1 [ 0.008184] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000 [ 0.008198] GICv3: CPU1: using allocated LPI pending table @0x00000001001c0000 [ 0.008243] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.009092] Detected VIPT I-cache on CPU2 [ 0.009165] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000 [ 0.009178] GICv3: CPU2: using allocated LPI pending table @0x00000001001d0000 [ 0.009220] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.010168] Detected VIPT I-cache on CPU3 [ 0.010236] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000 [ 0.010249] GICv3: CPU3: using allocated LPI pending table @0x00000001001e0000 [ 0.010287] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.011061] CPU features: detected: Spectre-v4 [ 0.011067] CPU features: detected: Spectre-BHB [ 0.011072] CPU features: detected: SSBS not fully self-synchronizing [ 0.011075] Detected PIPT I-cache on CPU4 [ 0.011112] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000 [ 0.011120] GICv3: CPU4: using allocated LPI pending table @0x00000001001f0000 [ 0.011143] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0] [ 0.011875] Detected PIPT I-cache on CPU5 [ 0.011918] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000 [ 0.011926] GICv3: CPU5: using allocated LPI pending table @0x0000000100200000 [ 0.011951] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0] [ 0.012678] Detected PIPT I-cache on CPU6 [ 0.012720] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000 [ 0.012729] GICv3: CPU6: using allocated LPI pending table @0x0000000100210000 [ 0.012753] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0] [ 0.013518] Detected PIPT I-cache on CPU7 [ 0.013561] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000 [ 0.013570] GICv3: CPU7: using allocated LPI pending table @0x0000000100220000 [ 0.013594] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0] [ 0.013683] smp: Brought up 1 node, 8 CPUs [ 0.013993] SMP: Total of 8 processors activated. [ 0.014007] CPU: All CPU(s) started at EL2 [ 0.014020] CPU features: detected: 32-bit EL0 Support [ 0.014034] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.014053] CPU features: detected: Common not Private translations [ 0.014068] CPU features: detected: CRC32 instructions [ 0.014086] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.014100] CPU features: detected: LSE atomic instructions [ 0.014114] CPU features: detected: Privileged Access Never [ 0.014128] CPU features: detected: PMUv3 [ 0.014141] CPU features: detected: RAS Extension Support [ 0.014158] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.014227] alternatives: applying system-wide alternatives [ 0.016345] CPU features: detected: Hardware dirty bit management on CPU4-7 [ 0.016628] Memory: 16221528K/16769024K available (17152K kernel code, 3516K rwdata, 12656K rodata, 8320K init, 752K bss, 522596K reserved, 16384K cma-reserved) [ 0.020718] devtmpfs: initialized [ 0.027560] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.027577] posixtimers hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.027639] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.027758] 22112 pages in range for non-PLT usage [ 0.027761] 513632 pages in range for PLT usage [ 0.027849] pinctrl core: initialized pinctrl subsystem [ 0.028160] DMI not present or invalid. [ 0.030469] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.031132] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.031323] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.031490] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.031519] audit: initializing netlink subsys (disabled) [ 0.031650] audit: type=2000 audit(0.029:1): state=initialized audit_enabled=0 res=1 [ 0.031995] thermal_sys: Registered thermal governor 'fair_share' [ 0.031999] thermal_sys: Registered thermal governor 'step_wise' [ 0.032007] thermal_sys: Registered thermal governor 'user_space' [ 0.032013] thermal_sys: Registered thermal governor 'power_allocator' [ 0.032052] cpuidle: using governor menu [ 0.032179] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.032326] ASID allocator initialised with 65536 entries [ 0.053320] rockchip_rk3588_pll_wait_lock: timeout waiting for pll to lock [ 0.053330] rockchip_rk3588_pll_set_params: pll update unsuccessful, trying to restore old params [ 0.058440] /vop@fdd90000: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.058480] /hdmi@fde80000: Fixed dependency cycle(s) with /vop@fdd90000 [ 0.061445] /pcie@fe190000: Fixed dependency cycle(s) with /pcie@fe190000/legacy-interrupt-controller [ 0.063859] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /usb@fc000000 [ 0.064402] /i2c@fec80000/usb-typec@22/connector: Fixed dependency cycle(s) with /phy@fed80000 [ 0.064441] /usb@fc000000: Fixed dependency cycle(s) with /phy@fed80000 [ 0.064475] /phy@fed80000: Fixed dependency cycle(s) with /i2c@fec80000/usb-typec@22/connector [ 0.066929] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.067299] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000 [ 0.067470] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.067632] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000 [ 0.067791] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.067946] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000 [ 0.068150] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.068299] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000 [ 0.068496] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 0.068646] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000 [ 0.069359] /hdmi@fde80000: Fixed dependency cycle(s) with /hdmi0-con [ 0.069395] /hdmi0-con: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.070486] HugeTLB: allocation took 0ms with hugepage_allocation_threads=2 [ 0.070496] HugeTLB: allocation took 0ms with hugepage_allocation_threads=2 [ 0.070505] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.070511] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.070519] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.070524] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.070531] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.070537] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.070543] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.070550] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.126828] raid6: neonx8 gen() 6347 MB/s [ 0.183584] raid6: neonx4 gen() 6241 MB/s [ 0.240334] raid6: neonx2 gen() 5196 MB/s [ 0.297084] raid6: neonx1 gen() 4203 MB/s [ 0.353835] raid6: int64x8 gen() 1433 MB/s [ 0.410580] raid6: int64x4 gen() 1867 MB/s [ 0.467326] raid6: int64x2 gen() 2460 MB/s [ 0.524076] raid6: int64x1 gen() 2021 MB/s [ 0.524081] raid6: using algorithm neonx8 gen() 6347 MB/s [ 0.580822] raid6: .... xor() 4730 MB/s, rmw enabled [ 0.580827] raid6: using neon recovery algorithm [ 0.581271] iommu: Default domain type: Translated [ 0.581279] iommu: DMA domain TLB invalidation policy: strict mode [ 0.587176] SCSI subsystem initialized [ 0.587275] usbcore: registered new interface driver usbfs [ 0.587295] usbcore: registered new interface driver hub [ 0.587313] usbcore: registered new device driver usb [ 0.587371] mc: Linux media interface: v0.10 [ 0.587392] videodev: Linux video capture interface: v2.00 [ 0.587425] pps_core: LinuxPPS API ver. 1 registered [ 0.587431] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.587443] PTP clock support registered [ 0.587495] scmi_core: SCMI protocol bus registered [ 0.587710] Advanced Linux Sound Architecture Driver Initialized. [ 0.588125] Bluetooth: Core ver 2.22 [ 0.588149] NET: Registered PF_BLUETOOTH protocol family [ 0.588155] Bluetooth: HCI device and connection manager initialized [ 0.588163] Bluetooth: HCI socket layer initialized [ 0.588170] Bluetooth: L2CAP socket layer initialized [ 0.588180] Bluetooth: SCO socket layer initialized [ 0.588226] NetLabel: Initializing [ 0.588231] NetLabel: domain hash size = 128 [ 0.588236] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.588270] NetLabel: unlabeled traffic allowed by default [ 0.589731] clocksource: Switched to clocksource arch_sys_counter [ 0.670963] VFS: Disk quotas dquot_6.6.0 [ 0.670982] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.671235] AppArmor: AppArmor Filesystem Enabled [ 0.677902] NET: Registered PF_INET protocol family [ 0.678087] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.685075] tcp_listen_portaddr_hash hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 0.685184] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.685218] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.685889] TCP bind hash table entries: 65536 (order: 10, 4194304 bytes, linear) [ 0.688980] TCP: Hash tables configured (established 131072 bind 65536) [ 0.689163] MPTCP token hash table entries: 16384 (order: 7, 786432 bytes, linear) [ 0.689373] UDP hash table entries: 8192 (order: 8, 1310720 bytes, linear) [ 0.689895] UDP-Lite hash table entries: 8192 (order: 8, 1310720 bytes, linear) [ 0.690454] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.690773] RPC: Registered named UNIX socket transport module. [ 0.690782] RPC: Registered udp transport module. [ 0.690787] RPC: Registered tcp transport module. [ 0.690792] RPC: Registered tcp-with-tls transport module. [ 0.690798] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.691298] PCI: CLS 0 bytes, default 64 [ 0.691383] Trying to unpack rootfs image as initramfs... [ 0.698503] kvm [1]: nv: 566 coarse grained trap handlers [ 0.698745] kvm [1]: IPA Size Limit: 40 bits [ 0.698763] kvm [1]: GICv3: no GICV resource entry [ 0.698769] kvm [1]: disabling GICv2 emulation [ 0.698774] kvm [1]: GIC system register CPU interface enabled [ 0.698791] kvm [1]: vgic interrupt IRQ18 [ 0.698811] kvm [1]: VHE mode initialized successfully [ 0.700158] Initialise system trusted keyrings [ 0.700329] workingset: timestamp_bits=46 max_order=22 bucket_order=0 [ 0.700695] NFS: Registering the id_resolver key type [ 0.700712] Key type id_resolver registered [ 0.700718] Key type id_legacy registered [ 0.700731] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.700738] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.723786] NET: Registered PF_ALG protocol family [ 0.723800] xor: measuring software checksum speed [ 0.724322] 8regs : 6351 MB/sec [ 0.724723] 32regs : 8326 MB/sec [ 0.725048] arm64_neon : 10254 MB/sec [ 0.725053] xor: using function: arm64_neon (10254 MB/sec) [ 0.725062] Key type asymmetric registered [ 0.725068] Asymmetric key parser 'x509' registered [ 0.725102] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.725243] io scheduler mq-deadline registered [ 0.725251] io scheduler kyber registered [ 0.733227] ledtrig-cpu: registered to indicate activity on CPUs [ 0.735078] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.735090] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.735962] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.735973] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.736901] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.736913] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 0.737680] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.739948] printk: legacy console [ttyS2] disabled [ 0.740114] feb50000.serial: ttyS2 at MMIO 0xfeb50000 (irq = 40, base_baud = 1500000) is a 16550A [ 0.740214] printk: legacy console [ttyS2] enabled [ 0.895545] arm-smmu-v3 fc900000.iommu: ias 48-bit, oas 48-bit (features 0x001c1e8f) [ 0.896687] arm-smmu-v3 fc900000.iommu: allocated 65536 entries for cmdq [ 0.897806] arm-smmu-v3 fc900000.iommu: allocated 32768 entries for evtq [ 0.898891] arm-smmu-v3 fc900000.iommu: msi_domain absent - falling back to wired irqs [ 0.900808] platform fdb50000.video-codec: Adding to iommu group 0 [ 0.902062] platform fdba0000.video-codec: Adding to iommu group 1 [ 0.903254] platform fdba4000.video-codec: Adding to iommu group 2 [ 0.904482] platform fdba8000.video-codec: Adding to iommu group 3 [ 0.905704] platform fdbac000.video-codec: Adding to iommu group 4 [ 0.906853] platform fdd90000.vop: Adding to iommu group 5 [ 0.911863] rockchip-drm display-subsystem: bound fdd90000.vop (ops vop2_component_ops) [ 0.912924] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 0.913571] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 0.917039] brd: module loaded [ 0.920292] loop: module loaded [ 0.920776] rbd: loaded (major 254) [ 0.921119] lkdtm: No crash points registered, enable through debugfs [ 0.923637] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg6 [ 0.924494] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7 [ 0.925373] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs3-null-pins [ 0.926178] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs2-null-pins [ 0.926998] /spi@feb20000/pmic@0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins [ 0.928358] spi-nor spi5.0: supply vcc not found, using dummy regulator [ 0.929058] spi-nor spi5.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff [ 0.931239] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found [ 0.931787] rk_gmac-dwmac fe1c0000.ethernet: IRQ sfty not found [ 0.932399] rk_gmac-dwmac fe1c0000.ethernet: supply phy not found, using dummy regulator [ 0.933169] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output). [ 0.933796] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x42). [ 0.934294] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay. [ 0.934919] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0x10 [ 0.935460] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no). [ 0.941016] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID [ 0.941701] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 0.942330] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5 [ 0.942783] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported [ 0.943446] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported [ 0.944102] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported [ 0.944719] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported [ 0.945307] rk_gmac-dwmac fe1c0000.ethernet: TSO supported [ 0.945790] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 0.946495] rk_gmac-dwmac fe1c0000.ethernet: Enabled L3L4 Flow TC (entries=2) [ 0.947121] rk_gmac-dwmac fe1c0000.ethernet: Enabled RFS Flow TC (entries=10) [ 0.947746] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled [ 0.948272] rk_gmac-dwmac fe1c0000.ethernet: SPH feature enabled [ 0.948799] rk_gmac-dwmac fe1c0000.ethernet: Using 32/32 bits DMA host/device width [ 0.949950] mdio_bus stmmac-0: MDIO device at address 1 is missing. [ 0.951975] usbcore: registered new interface driver asix [ 0.952471] usbcore: registered new interface driver cdc_ether [ 0.953000] usbcore: registered new interface driver rndis_host [ 0.953544] usbcore: registered new interface driver cdc_ncm [ 0.954308] VFIO - User Level meta-driver version: 0.3 [ 0.971555] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 0.972049] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 0.972784] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010 [ 0.973078] ehci-platform fc800000.usb: EHCI Host Controller [ 0.973085] ohci-platform fc840000.usb: Generic Platform OHCI controller [ 0.973096] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 2 [ 0.973149] ohci-platform fc840000.usb: irq 57, io mem 0xfc840000 [ 0.973692] xhci-hcd xhci-hcd.0.auto: irq 54, io mem 0xfcd00000 [ 0.973769] ehci-platform fc880000.usb: EHCI Host Controller [ 0.973786] ohci-platform fc8c0000.usb: Generic Platform OHCI controller [ 0.973792] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 3 [ 0.973807] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4 [ 0.973910] ehci-platform fc880000.usb: irq 56, io mem 0xfc880000 [ 0.973930] ohci-platform fc8c0000.usb: irq 58, io mem 0xfc8c0000 [ 0.974111] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 5 [ 0.974254] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 0.974761] ehci-platform fc800000.usb: irq 55, io mem 0xfc800000 [ 0.975393] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6 [ 0.982313] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 0.982968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15 [ 0.983100] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00 [ 0.983701] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.984875] usb usb1: Product: xHCI Host Controller [ 0.985305] usb usb1: Manufacturer: Linux 6.15.4 xhci-hcd [ 0.985779] usb usb1: SerialNumber: xhci-hcd.0.auto [ 0.986535] hub 1-0:1.0: USB hub found [ 0.986883] hub 1-0:1.0: 1 port detected [ 0.987403] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.988166] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.15 [ 0.988892] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.989526] usb usb6: Product: xHCI Host Controller [ 0.989961] usb usb6: Manufacturer: Linux 6.15.4 xhci-hcd [ 0.990436] usb usb6: SerialNumber: xhci-hcd.0.auto [ 0.991111] hub 6-0:1.0: USB hub found [ 0.991456] hub 6-0:1.0: 1 port detected [ 0.991989] usbcore: registered new interface driver cdc_acm [ 0.992135] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15 [ 0.992487] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.992645] usbcore: registered new interface driver uas [ 0.993067] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00 [ 0.993244] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.993967] usbcore: registered new interface driver usb-storage [ 0.994414] usb usb3: Product: EHCI Host Controller [ 0.995247] mousedev: PS/2 mouse device common for all mice [ 0.995595] usb usb3: Manufacturer: Linux 6.15.4 ehci_hcd [ 0.996210] i2c_dev: i2c /dev entries driver [ 0.996568] usb usb3: SerialNumber: fc880000.usb [ 0.998852] hub 3-0:1.0: USB hub found [ 0.999232] fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected! [ 0.999240] hub 3-0:1.0: 1 port detected [ 0.999401] fan53555-regulator 2-0042: FAN53555 Option[10] Rev[1] Detected! [ 0.999681] fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected! [ 1.000409] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15 [ 1.001466] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.001470] usb usb5: Product: EHCI Host Controller [ 1.002206] usb usb5: Manufacturer: Linux 6.15.4 ehci_hcd [ 1.003276] usb usb5: SerialNumber: fc800000.usb [ 1.003312] rtc-hym8563 6-0051: no valid clock/calendar values available [ 1.003487] hub 5-0:1.0: USB hub found [ 1.003503] hub 5-0:1.0: 1 port detected [ 1.005606] rtc-hym8563 6-0051: registered as rtc0 [ 1.007027] rtc-hym8563 6-0051: no valid clock/calendar values available [ 1.007614] rtc-hym8563 6-0051: hctosys: unable to read the hardware clock [ 1.008116] rockchip-rga fdb80000.rga: HW Version: 0x03.02 [ 1.008820] rockchip-rga fdb80000.rga: Registered rockchip-rga as /dev/video0 [ 1.009690] usbcore: registered new interface driver uvcvideo [ 1.010877] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property [ 1.013508] sdhci: Secure Digital Host Controller Interface driver [ 1.014053] sdhci: Copyright(c) Pierre Ossman [ 1.014436] Synopsys Designware Multimedia Card Interface Driver [ 1.015167] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.016377] arm-scmi arm-scmi.2.auto: Using scmi_smc_transport [ 1.016907] arm-scmi arm-scmi.2.auto: SCMI max-rx-timeout: 30ms / max-msg-size: 104bytes / max-msg: 20 [ 1.017789] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16 [ 1.018587] arm-scmi arm-scmi.2.auto: SCMI Notifications - Core Enabled. [ 1.019203] arm-scmi arm-scmi.2.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 1.025854] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.026591] hid: raw HID events driver (C) Jiri Kosina [ 1.027329] usbcore: registered new interface driver usbhid [ 1.027823] usbhid: USB HID core driver [ 1.030576] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.15 [ 1.031307] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.031942] usb usb2: Product: Generic Platform OHCI controller [ 1.032462] usb usb2: Manufacturer: Linux 6.15.4 ohci_hcd [ 1.032937] usb usb2: SerialNumber: fc840000.usb [ 1.033758] hub 2-0:1.0: USB hub found [ 1.033813] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available [ 1.034109] hub 2-0:1.0: 1 port detected [ 1.035680] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.15 [ 1.035716] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available [ 1.036450] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.037900] usb usb4: Product: Generic Platform OHCI controller [ 1.038434] usb usb4: Manufacturer: Linux 6.15.4 ohci_hcd [ 1.038723] usbcore: registered new interface driver snd-usb-audio [ 1.038920] usb usb4: SerialNumber: fc8c0000.usb [ 1.040516] hub 4-0:1.0: USB hub found [ 1.040904] hub 4-0:1.0: 1 port detected [ 1.042057] Initializing XFRM netlink socket [ 1.042476] NET: Registered PF_PACKET protocol family [ 1.043067] Key type dns_resolver registered [ 1.043452] Key type ceph registered [ 1.044028] libceph: loaded (mon/osd proto 15/24) [ 1.049961] registered taskstats version 1 [ 1.050450] Loading compiled-in X.509 certificates [ 1.054967] Key type .fscrypt registered [ 1.055316] Key type fscrypt-provisioning registered [ 1.056402] Btrfs loaded, zoned=no, fsverity=no [ 1.056854] AppArmor: AppArmor sha256 policy hashing enabled [ 1.076343] random: crng init done [ 1.083807] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 1.246494] usb 5-1: new high-speed USB device number 2 using ehci-platform [ 1.384450] usb 5-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 1.385196] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.385835] usb 5-1: Product: USB 2.0 Hub [ 1.387049] hub 5-1:1.0: USB hub found [ 1.387645] hub 5-1:1.0: 4 ports detected [ 3.055599] Freeing initrd memory: 92432K [ 3.070564] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 3.071501] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 3.072197] clk: Disabling unused clocks [ 3.075155] PM: genpd: Disabling unused power domains [ 3.075634] ALSA device list: [ 3.075900] No soundcards found. [ 3.080084] Freeing unused kernel memory: 8320K [ 3.080529] Run /init as init process [ 3.416753] rk_gmac-dwmac fe1c0000.ethernet end0: renamed from eth0 [ 4.616898] async_tx: api initialized (async) [ 4.714374] NET: Registered PF_INET6 protocol family [ 4.715947] Segment Routing with IPv6 [ 4.716324] In-situ OAM (IOAM) with IPv6 [ 4.723206] device-mapper: ioctl: 4.49.0-ioctl (2025-01-17) initialised: dm-devel@lists.linux.dev [ 4.726511] Key type encrypted registered [ 4.733545] 8021q: 802.1Q VLAN Support v1.8 [ 4.740925] rk_gmac-dwmac fe1c0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 4.743535] rk_gmac-dwmac fe1c0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-1 [ 4.746426] rk_gmac-dwmac fe1c0000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) [ 33.759835] vcc3v3_pcie20: disabling [ 34.774410] rk_gmac-dwmac fe1c0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 34.775895] rk_gmac-dwmac fe1c0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-1 [ 34.777527] rk_gmac-dwmac fe1c0000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19)
jondowd posted a topic in Orange Pi 5
My first post here - I'm new to SBCs and stoked I got my home webserver up and running on a Orange Pi 5 which boots from an NVMe (pats-self-on-back : -) It runs great, pages are up, and it's all SO COOL, but it fails to do a restart... I can do a shutdown -h now, count to three and power it back up and all is well, but if I do a shutdown -r now it will go down, start back up, all the way to the login prompt but then barfs a long Oops message. God please... don't make me start over ! - Yesterday
@allatutti Did it work with orangepi5 (no Pro) dts? Is it good enough for basic tasks ?
I have a pair of Orange Pi 3's acting as redundant PiHoles on my home network. After a bit of tinkering and configuring, I have them set up the way I want, and would like to keep them that way. Of course, a good backup plan is essential to this. Looking online, I found Image-Utils for Raspberry Pi, but that is limited in support for only the Raspbian OS. Is there a good system out there to make a cloneable image of an SD card in an Orange Pi, either from the Pi itself to a remote source (NFS mount, etc.), or from a remote source pulling from the Pi? I'd like to schedule this as a CRON job, so that in the event of a hardware failure, I can just restore the image to a new SD card and deploy it with minimal loss. Thank you!
I will check them out for sure but for dashboard i have my own webview-based UI solution (general purpose, reactive) will be open-sourced later when i have free-time to document the usage, similar to Phoenix LiveView but more lightweight and a bit faster but only supports one client at the time. I also have my own open source flow-based automation runtime (https://bitbucket.org/bmikulas/ciprus) and for that i am using Blender as the base for my flow editor with node editor plugin (https://github.com/nortikin/sverchok) using custom nodes which are auto-generated from graph node definitions. That's why i could make good use of that remote desktop so i won't need to upload the flows i can just update them on the server and the file checker will start updating the flows on the fly to the newer version according to the file stamps at least that was the idea.
Ver 20250627-edge kernel 6.16-rc3
Armbian doesn't release this old LTS release now, but you can build one from github.com/armbian/build Yes, flatpak version is using ffmpeg in its own sandbox without rkmpp support, if you build the deb locally, it will get linked with ffmpeg on system which has rkmpp support. - Last week
tanod replied to maximumsettings's topic in Orange Pi 5
Thank you ! @amazingfate I would rather have Jammy instead, but cannot find Armbian jammy ISO for my Orange Pi 5 Plus. Not too confi building it myself for noble. I already tried the flatpak version on my current noble but even though It runs fine on Wayland it says no HW acc and then I get stuck trying to have it working. Is it going to have HW acc if i succeed to build it? Thanks in advance! -
Wlan0 stopped showing up on Beelink GT1 Ultimate
SteeMan replied to moonlightzzz's topic in Amlogic CPU Boxes
Since this issue is well over a year old, I'm not sure where you stand with this. Are you still looking to get a fix? If so, answering all of the questions asked would be helpful. When you say "broke again" what do you mean by broke? Apparently the box is running and you can update it as you continue to update it per the message above saying you have upgraded to 6.12.32. Have you tried a fresh image installed on a new SD card to see if that works (vs. your upgraded system)?
