  2. @billymore The "Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)" error indicates that the Linux kernel could not locate or mount the root file system during startup. . This is commonly caused by a missing or corrupted initial RAM filesystem (initramfs), an incorrect root= boot parameter write 0x4ff00000 rootfs.cpio.lzma.uboot
  3. @Jain Ziad I'm currently working on hardware acceleration, though I can't say yet if it will outperform the official Radxa builds since it uses the same drivers. I'll keep the community updated on the results.
  4. Yesterday
  5. Hello Armbian-Community! TL;DR I've successfully enabled the Rockchip RK3568 NPU (0.8 TOPS INT8) on the ODROID-M1 with 8GB RAM running Armbian 6.18.9-current-rockchip64. The only thing needed to make this work for everyone is a 1-line kernel patch in Armbian build that I've already submitted: https://github.com/armbian/build/pull/9403 Once this patch is merged into Armbian, the DKMS modules will work out-of-the-box on all RK3568 boards. The Problem 1. Hardkernel and Rockchip provide NPU patches for quite old kernel versions: rockchip <= 6.6 hardkernel <= 5.10 2. IOMMU page table allocation bug — On systems with >4GB RAM, the kernel's IOMMU allocates page tables above 4GB, but the NPU can only access the first 4GB of physical memory, causing DMA mapping failures and inference timeouts The Solution 1. Kernel Patch (1 line!) - .gfp_flags = 0, + .gfp_flags = GFP_DMA32, This forces IOMMU page tables to be allocated below 4GB, fixing NPU operation on 8GB boards. 2. DKMS Driver Package I've created a complete DKMS package that: - Includes DT overlays for NPU, IOMMU, power-domain, and clock configuration - Supports dynamic frequency scaling (100 MHz - 1000 MHz) - Provides `/dev/dri/renderD129` (DRM/GEM interface) for RKNN Runtime - Would compile against Armbian's stock kernel headers with the above patch merged The Questions 1. What would be the best way to provide those modules for installation in the armbian system? 2. Has someone a 4 GB version of the M1 and could test the modules?
  6. Hello, 4GB version. - Detecting meteors in GMN network (https://globalmeteornetwork.org/) - monitor other x64 machine and reset by power cycle (via gpio). rock64 is rock stable
  7. The sysfs GPIO interface does not allow you to create clock outputs as-is. You'd do better seeing if that pin can be exposed through the sysfs PWM interface. I know the NanoPi M4V2's fan controller works this way (RK3399), and you can set the duty cycle. But you'd have to check if PWM is supported on that pin, and can be used in the way you're hoping. Failing that, it is possible to bit-bang the GPIO lines yourself if you're willing to write some C code. You can use Kernel Timers for fairly accurate timing, as long as you set High Scheduler Priority and Real Time Scheduler Class. Note that kernel timers only have a user specified resolution of 1ns, so you might not hit that frequency exactly.
  8. Probably a new product. Images are not compatible unless specifically marked as such.
  9. Regarding the vendor kernel I also managed to get the GPU going with some AI help, but the HDMI hotplug issue persists. Will probably revisit it in the future. (the dtb should go in packages/blobs/h96-m9_original.dtb and the defconfig in patch/u-boot/legacy/u-boot-radxa-rk35xx/deconfig) h96-m9.csc h96-m9_original.dts h96-m9-rk3576_defconfig h96-m9_original.dtb
  10. I'm trying to get a clock signal of 32768 from the GPIO1 D4 pin of the rk3328 CPU, but I haven't been able to. I've tried everything, from `overlay dts` to `armbian-add-overlay`, but I can't get any output. I can set the value to 1 or 0 using the `echo 1 > /sys/class/gpio/gpio60/value` command, but the system doesn't give a clock output. Please help. Thank you in advance.
  11. I'm moving forward. I managed to get the FEL - a true Male A <> Male A USB cable is required. FEL mode is now working. I'm able to transfer the u-boot-sunxi-with-spl.bin of Armbian but TX1 is booting on Android immediately (based on Armbian-unofficial_26.02.0-trunk_X96q-v5-1_bookworm_current_6.12.64_minimal.img - u-boot-sunxi-with-spl.bin extracted). This means that I don't have the possibility to boot on the Armbian USB drive (flashed with u-boot-sunxi-with-spl.bin) Similarly, I tried with another image based on MiniArch (MiniArch-20240715-6.18.7-board-h313.tanix_tx1-SD-Image.img.xz). I was able to transfer those MiniArch via FEL: sunxi-fel -v -p uboot bootloader/u-boot-sunxi-with-spl.bin write 0x40200000 Image write 0x4fa00000 dtbs/allwinner/sun50i-h313-tanix-tx1.dtb write 0x4fc00000 load-kernel.scr Original made Load-kernel.scr in the MiniArch-20240715-6.18.7-board-h313.tanix_tx1-SD-Image.img.xz : setenv bootargs console=ttyS0,115200 root=/dev/sda2 rw rootwait ram=1024M debug booti 0x40200000 - 0x4fa00000 With the MiniArch FEL, the TX1 is not booting on Android and I can see 4 penguins with cursor. I updated the load-kernel.scr to have some verbose by changing the console: setenv bootargs console=tty1 console=ttyS0,115200 root=/dev/sda2 rw rootwait rootdelay=60 ram=1024M debug loglevel=7 booti 0x40200000 - 0x4fa00000 Result: MiniArch bootloader and FEL transfer writes allow to boot. USB devices are detected (USB Hub, USB drive, keyboard) but nothing happens further, or it ends up with a kernel panic. Output of the Linux TX1 console after MiniArch FEL transfer sequence: 1.651121] sunxi-mc 4022000.mmc: initialized, max. request size: 2048 KB, u [ top_ops) 1.655936] sunti-drm display-engine: bound 6510000.tcon-top Cops sunBi_tcon_ 1.973277] mnc2: new high speed DDR MMC card at address 0001 _tcon_ops) 1.9745881 sunfi-drm display-engine: bound 6515000. lcd-controller Cops sunti 1.9789521 mncblk2: mmc2:0001 HAGZe@ 14.7 GiB 1.9825631 sunBi-du-hdmi 6000000.hdmi: Detected HDMI TX controller u2.12a wi th HDCP (DWC HDMI 2.0 TX PHY) p17 1.990428] mncblk2: p1 p2 p3 p1 p5 p6 p? p8 p9 p10 p11 p12 p13 p14 p15 p16 [ iver 1.991663] sunBi-du-hdmi 6000000.hdmi: registered Designbare HDMI I2C bus dr 1.998192] mncblkbooto: mnc2:0001 HAGZed 4.00 MiB 1.999521] sunti-drn display-engine: bound 6000000.hdmi Cops sunBi_du hami_o ps) 2.007404] mncblk2boot1: mnc2:0001 HAGZes 4.00 MiB 2.012147] [drm] Initialized sunfi-drm 1.0.0 for display-engine on minor o 2.723997] Console: switching to colour frane buffer device 240x67 2.7468481 sunti-den display-engine: larm] fb0: sunti-drodrufb frame buffer device 2.7554683 2.7573363 usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.18 of_cis_init 2.7599291 sunxi-nuc 4021000.mmc: allocated mnc-purseg 2. 763866] ush usb3: New USE device strings: Mfr=3, Product=2, SerialNumber=1 2.766352] of_cfs_init: 0K 2.771541] usb usb3: Product: Generic Platform OHCI controller 2.7789161 clk: Disabling unused clocks 2.781535] usb usb3: Manufacturer: Linux 6.18.7 ohci_hcd 2.785297] sunxi-nnc 4021000.mnc: initialized, max. request size: 16384 KB, uses new tinings mode 2.7875991 PM: genpd: Disabling unused power domains 2.7914431 usb usb3: SerialNumber: 5101400 .usb 2.8161741 check access for rdinit=/init failed: -2, ignoring 2.816738] hub 3-0:1.0: USB hub found [2.822049 Waiting 90 sec before mounting root device... 2.831452] hub 3-0:1.0: 1 port detected 2.8428851 mnc1: new high speed SDIO card at address 0001 7.4519021 usb 3-1: new full-speed USB device number 2 using ohci-platform 7.6636101 usb 3-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00 7.6718951 usb 3-1: New USB device strings: Mfr=0, Product=1, Seria lNumber=0 7.679084] usb 3-1: Product: USBZ.0 HUB 7.684782J hub 3-1:1.0: USB hub found 7.6896091 hub 3-1:1.0: 4 ports detected 8.115235] usb 3-1.1: new full-speed USB device number 3 using ohci-platform 8.224936] usb 3-1,1: not running at top speed; connect to a high speed hub 8.266936] usb 3-1.1: New USB device found, idVendor=059f, idProduct=1022, bcdDevice= 1.00 8.2753821 8.282744] USD 3-1,1: New USB device strings: Mfral, Product=2, SerialMunber=3 usb 8.2871451 usb 3-1.1: Product: LaCie lanaKey 8.2912791 usb 3-1.1: Manufacturer: LaCie 3-1.1: SerialNumber: 97e0bfb3cfe007 8.501898] แรง 3-1.2: new full-speed USB device number 4 using ohci-platform 8.6079401 8.6163791 usb 3-1.2: New USB device found, idVendor=0318, idProduct=2808, bcdDevice= 2.00 3-1.2: New USB device strings: Mfr=0, Product=1, Seria lNumber=0 8.6237581 usb 3-1.2: Product: 2.4G Composite Devic 8.711901] uSb 3-1.3: new low-speed USB device number 5 using ohci-platform 8.847941] usb 8.8563831 usb 3-1.3: New USB device found, idVendor=04f2, idProduct=0403, bcdDevice= 1.65 3-1.3: New USB device strings: Mfr=1, Product=2, Seria lNumber=0 8.865882] usb 3-1.3: Product: USB Keyboard 8.8722631 usb 3-1.3: Manufacturer: Chicony 12.851997] sun501-h6-prcm-ppu 7010250. power-controller: sync_state() pending due to 1800000. gpu If I wait, I ended up seeing a kernel panic : Kernel panic - not suncing: UFS: Unable to mount rout fs ; on unknoun-block(0,0) 93.6966821 b30d 93.696690] 03.7097151 b30e 93.7097231 93.7224501 b30f 93.7227581 93.7357951 b310 93.735804] 33.748859] b311 163B4 mncblk2p9 а0085546-4166-744a-a353-fca9272bBe4d 163B4 mncblk2p10 а0085546-4166-741a-a353-fca9272bBete 16384 mncblk2p11 a0085546-4166-744a-a353-fca9272bBe4f 16384 mmcblkZp12 а0085546-4166-744a-a353-fca9272bBe50 512 mmcblk2p13 a0085546-4166-744a-a353-fca9272bBe51 15872 mncblk2p14 a0085546-4166-744a-a353-fca9272bBe52 163B4 mncblk2p15 a0085546-4166-744a-a353-fca9272bBe53 16384 mncblk2p16 а0085546-4166-744a-a353-fca9272bBe54 11423727 mmcblk2p17 a0085546-4166-744a-a353-fca9272bBe55 93.748867] 93.761944] b320 4096 mmcblkZbooto 93.7619521 (driver?) 93.7121621 b340 4096 mmcblk2boot1 93.7121121 (driver?) 99.7835151 List of all bdeu filesystems: 33.7895001 exts 93.7895061 ext4 93.793371] extz 33.7972031 ufat 93.8010141 msdos 93.8048091 93.8120251 Kernel panic - not suncing: UFS: Unable to mount rout fs ; on unknoun-block(0,0) 93.8221681 CPU: 2 UID: 0 PID: 1 Comm: swapper/0 Tainted: G 6.18.7 #1 PREEMPT 56ea6Zc682B4f70bf2 93.9338801 -1 end Kernel panic - not syncing: UFS: Unable to mount root fs on unknown-block(0,0) }— 93.836517] Tainted: [WI-WARN 93.841380] Hardware name: Tanix TX1 (DT) 93.8472801 Call trace: 93.8515981 show_stack+0x24/0x70 (C) 93.857135] dump_stack_lul+0x74/0x94 93.8626511 dump _stack+0x14/0x24 93.8677961 upanic+0x104/0x2d4 93.872767] panic +0x5c/0x64 93.877447] mount root gener ic+0x14/0x29B 93.8834131 mount_root +0x16c/0x188 93.8886741 prepare _namespace +0x1cc/0x22c 93.8945131 kernel_init_frecable+0x264/0x284 93.900587] kernel_init+0x1c/0x140 93.905767] ret_from_fork+0x10/0x20 93.9110311 MP: stopping secondary CPU: 93.9166281 Kernel Offset: disable 93.9217681 CPU features: At this stage, I'm stuck with the TX1 : - Armbian Image - no boot success - FEL difficult - MiniArch - boot started but stuck Any help would be appreciated.
  12. Dear all, I just received my new NanoPC-T6 Plus from FriendlyElec: https://www.friendlyelec.com/index.php?route=product/product&path=69&product_id=315 I couldn't find a dedicated image for this SBC, is it compatible with the one for the NanoPC T6 LTS (same board, upgraded LPDDR5 RAM) ? https://www.armbian.com/nanopct6-lts/ Best regards, Magic Sam
  13. the tft is working well on stock orangepi image but when I try the prebuilt armbian images or build it myself it look like this my dts file: 35Lcd.dts
  14. I've gotten it working. I'll detail the steps soon, but it's not difficult. I just want to confirm that running it this way I can boot from sd/usb/nvme/eMMC/Network, and see if changing the boot order works.
  15. This is not working for me either. I had audio initially working with the "Radxa OS" (Ubuntu 24.04), but after a few reboots, seems to lose audio and reverts to "Dummy Output" audio placeholder for the Output Device. No luck at all with sound on Armbian even after following the instructions laid out here. Would be nice to get audio working reliably for the Q6A on Armbian as its my favorite SBC to date, but no sound is a show stopper.
  16. Last week
  17. It appears there would have been no problem with the Logitech Unifying Dongle that uses Bluetooth. I ended up buying a Logitech Keyboard/Mouse combination that is practically identical except uses WiFi protocol rather than Bluetooth as per the suggestion of the vendor of the HamClock Quadra4K. PeeSHaw.... Prices have come down I guess... I found it at the local Wally World for $19.95 on sale... Crazy! I was asking because I had an older Logitech Bluetooth mouse and dongle and was thinking I would just use them and get the keyboard... Thank you for the help!
  18. It works, I'm soooo happy with this. Big thank you!!!
  19. Not excited AT ALL about Allwinner, but there are few (actually none that I've found?) choices for low-priced, "higher performance" SBCs with WiFi 6, BT 5.4, USB3, GB Ethernet, PoE and a small size and factory case. I'll take anything rockchip in a heartbeat I much prefer their chips. My go-to has been the RockPI-S, but it's low performance CPU, WiFi 4, BT 4, 100M Ethernet, USB2, and getting pretty old. AFAIK, there's nothing out there that checks all the boxes, sadly.
  20. @NicoD I download and extract the Wine-Proton prebuilt binaries, then let Box64 do the rest. This is the script I used (You might want to change the directories)
  21. There was a commit 4 days ago on that repo metioned above: https://github.com/joilg/x88pro/commit/a6630814a98b39ec39dc22108c01e35f5d456395 Anyone noticed? Anyone tried it? Any change?
  22. This is putting some sort of warning flag for myself. 'pretty sure', 'chatGPT', a Rockchip board v.s. Allwinner board.
  23. OK, so it actually was cold in FL for a couple weeks and I did a power hack. I ported Java UIO to Java UIO 2. Java UIO (HawtJNI) This was the "Old School" high-performance approach. It relied on a custom C wrapper and JNI to bridge the gap. How it works: You have to write a C helper file, compile it into a shared library (.so) for on ARM architecture (armv7l, aarch64), and bundle it in your JAR. The Overhead: Every call from Java to C has a "JNI transition cost." To minimize this, you used moveJavaToNative to bulk-transfer buffers, which added complexity to the Java code. Java UIO 2 (FFM / Project Panama) The "Modern" approach. It treats native memory and functions as first-class citizens in Java. I now cross compile on x86_64 for arm32 and arm64. How it works: Java uses Linker and SymbolLookup to find functions in u8g2 or libc directly. No custom C wrapper is strictly required unless you want to simplify complex macros. The Overhead: Transitions are heavily optimized by the JVM (often inlined). By using MemorySegment, you can point Java directly at the UIO hardware registers or the U8g2 tile buffer. The Armbian Advantage: It is "Write Once, Run Anywhere" for native code. As long as the system library (like libSDL2.so) exists on the Armbian filesystem, the same JAR will work on an Orange Pi 5, a Pine64, or even a Raspberry Pi without re-compiling C code.
  24. It is possible but I think it is currently broken / unfinished / does not work (properly) yet.
  25. I seem to remember at one point thinking that U-Boot could be installed into the SPI on the a5e and then I could choose the boot order. Is that possible or did I just dream it? If it is, how do I install U-Boot into the SPI? Is there one specifically for the a5e?
  26. does any has vpu supported image for radxa cubie a7z
  27. Could you please explain how to install wine-proton? I've been out of it for a while and don't remember a thing. I'll add it to armbian-gaming when I can make it work. And make a video about the process.
  28. Actually not as I am human - I need time and focus to be able to understand what the code does. Same as everyone else. BASH is list of commands and if you are average tech person you can interpret those command, one after another to understand what is going on. AI can help. You can, but you can not expect that I will answer them. Perhaps someone else will, perhaps nobody. I show you how you can understand it without destroying my brain - I need to look into the code to answer questions ... Its Friday evening here and I already answered at maximum effort.
