  2. Thamk you for clarification. Seems I'm little bit outdated.
  3. Just following up to see if the MAC address thing on the ethernet ports is fixed once and for all now?
  4. Yesterday
  5. Okay, where do I start.... Armianmonitor: https://paste.armbian.com/oletimumob I have this ancient Opi+. AND I KNOW THOSE TYPES OF UPDATES ARE NOT SUPPORTED. Yet, they often succeeds and I want to upgrade my system via do-release-upgrade For last six months I am stuck on this, attaching output from putty login screen AND lsb_release as a printscreen My sources.list.d look like this orangepiplus:sources.list.d:% dir armbian-config.sources armbian.list ubuntu.sources orangepiplus:sources.list.d:% cat armbian-config.sources Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg orangepiplus:sources.list.d:% cat armbian.list deb [arch=armhf signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com jammy main jammy-utils jammy-desktop orangepiplus:sources.list.d:% cat ubuntu.sources Types: deb URIs: http://ports.ubuntu.com/ubuntu-ports/ Suites: jammy jammy-updates jammy-security Components: main restricted universe multiverse Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg orangepiplus:sources.list.d:% Update package noble.tar.gz is downloaded and run, but then it results in this, not sure why? Updating repository information No valid mirror found While scanning your repository information no mirror entry for the upgrade was found. This can happen if you run an internal mirror or if the mirror information is out of date. Do you want to rewrite your 'sources.list' file anyway? If you choose 'Yes' here it will update all 'jammy' to 'noble' entries. If you select 'No' the upgrade will cancel. Continue [yN] y Generate default sources? After scanning your 'sources.list' no valid entry for 'jammy' was found. Should default entries for 'noble' be added? If you select 'No', the upgrade will cancel. Continue [yN] I agree to this but then it results in buttload of Hit/Err 404 errors, for some reason, it is a small part of it: n http://archive.ubuntu.com/ubuntu noble/universe armhf Packages Err http://archive.ubuntu.com/ubuntu noble/restricted armhf Packages 404 Not Found [IP: 91.189.91.81 80] Err http://archive.ubuntu.com/ubuntu noble/main armhf Packages 404 Not Found [IP: 91.189.91.81 80] Err http://archive.ubuntu.com/ubuntu noble/multiverse armhf Packages 404 Not Found [IP: 91.189.91.81 80] Err http://archive.ubuntu.com/ubuntu noble/universe armhf Packages 404 Not Found [IP: 91.189.91.81 80] Ign http://archive.ubuntu.com/ubuntu noble/restricted armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/main armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/multiverse armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/universe armhf Packages Err http://archive.ubuntu.com/ubuntu noble/restricted armhf Packages 404 Not Found [IP: 91.189.91.81 80] Ign http://archive.ubuntu.com/ubuntu noble/main armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/multiverse armhf Packages Ign http://archive.ubuntu.com/ubuntu noble/universe armhf Packages Fetched 508 kB in 6s (84.5 kB/s) It ends like this: es 404 Not Found [IP: 185.125.190.82 80], E:Failed to fetch http://security.ubuntu.com/ubuntu/dists/noble-security/main/binary-armhf/Packages 404 Not Found [IP: 91.189.91.82 80], E:Some index files failed to download. They have been ignored, or old ones used instead. Restoring original system state Aborting Reading package lists... Done Building dependency tree... Done Reading state information... Done === Command detached from window (Wed Apr 30 22:07:17 2025) === By trial and error I managed to overcome this by fully commenting out ubuntu sources (whole file) like this: #Types: deb #URIs: http://ports.ubuntu.com/ubuntu-ports/ #Suites: jammy jammy-updates jammy-security #Components: main restricted universe multiverse #Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg Then it does not ask me twice about generating default sources. And this way today it updated around 240 packages, asked for a restart too. But the system remained on 22 jammy. Not sure why it worked. After I run this again i get a buttload of "no candidate ver" errors and it just aborts - this is not a full output. No candidate ver: libpython3.10-minimal No candidate ver: libqt5core5a No candidate ver: libqt5gui5 No candidate ver: libssl3 No candidate ver: python3.10-minimal No candidate ver: resolvconf No candidate ver: rng-tools Restoring original system state Aborting Reading package lists... Done Building dependency tree... Done Reading state information... Done After this, now the system's time is approx 30 min late. Cant seem to fix it either. Unable to systemd-timesyncd because some missing dependency but I will not go into details at this moment. The same happens both on beta releases and stable. Fully updated via armbian-upgrade Where do I start? Clean install would be my LAST effort. I'd hate to do this Where do I begin
  6. I see. For last six months or so I had a hard time upgrading to noble. But this probably needs a separate thread with separate story since it is not really related.
  7. Hello, now tested with 6.12.23 -> handling of my user modules without problems. Regards, Rainer
  8. Hi there, Seems like the kernel is waiting for the wrong filesystem to become available. If blkid shows you PTUUID="8cdc55ae-c576-6f4c-a793-0397a48dccf0 and not any UUID=... associated with a filesystem on that partition, that means that either you do not have a [root] filesystem on that partition or that your root filesystem is on another partition of your SDcard. A PTUUID is the UUID for the partition itself, not for a filesystem. i.e. An empty partition still has a PTUUID. Most (if not all) filesystems have a UUID. Using a UUID makes it easier to have the kernel identify where a/the root filesystem is located. as it is not guaranteed how the storage devices are discovered at boot time. A UUID is linked to the filesystem and not to the device where it is stored on. If you are convinced that you have a root filesystem on a certain partition of your SDcard, you can always use rootdev=/dev/mmcblk1p1 (or wherever your root filesystem lives) in your /boot/armbianEnv.txt to instruct the kernel to expect a root filesystem there. ...but that partition does need to actually have a root filesystem, unless you end up in the same situation you are describing. Can you share the output of sudo parted /dev/mmcblk1 u s pr and sudo blkid -g followed by sudo blkid /dev/mmcblk* ? Groetjes,
  9. Today 6.12 is the current kernel.
  10. These patches are not tested on "edge" ( kernel version 6.12 ).
  11. Thanks for sharing your experience! I also own a T95Z Plus (S912) and agree that it runs great for most tasks. The S912 chip handles 4K streaming and light gaming really well, especially with optimized firmware. Have you tried any custom ROMs like ATVxperience or LibreELEC to improve performance further? A few tips that helped me: Cooling: Adding small heatsinks or a fan prevents throttling. Debloating: Removing unused apps with ADB or Debloater Tool speeds it up. Launcher: Switching to Wolf Launcher or ATV Launcher reduces lag. Would love to hear if you’ve found other tweaks!
  12. Thank God. I had the same problem as you. It seems like the only way is to write the Armbian boot disk from another system. I’ve been struggling with it for a long time and kept getting into BusyBox. I’ll try your method in a bit.
  13. Chips: Amlogic S805 SOC Hynix H5TQ4G63AFR-PBC - DDR3 RAM -2x IP101GR - 10/100Mbps transceiver MT29F64G08CBABA - NAND Flash Memory RTL8189ETV - Wifi module
  14. @Rodrigo Campos have you tried my latest images? There’s a new patch for dram detection.
  15. Last week
  16. It sounds like you're having a bit of a tough time getting that LCD screen to work with your Orange Pi. The fact that the manufacturer only provides drivers for Arduino and RP2040 is definitely limiting, but there are a few things you can try to get it up and running. Check the display's controller chip: The key to getting an LCD screen to work with any board is knowing what controller chip the screen uses. Often, drivers are not provided for specific boards, but if you can identify the chip (it could be something like an ILI9341, ST7789, etc.), you can search for libraries or drivers that support it on Linux-based systems like your Orange Pi. Linux Framebuffer or SPI Libraries: If it’s an SPI-based LCD, you might be able to use Linux framebuffer support or libraries like fbcp (framebuffer copy) or fbtft (framebuffer to TFT) which are often used for connecting LCDs to Raspberry Pi-like devices. These libraries could potentially work with your Orange Pi if the wiring is correct. Using Klipper with an LCD: Since you're trying to use this for a Klipper setup, check if there are any custom firmware or configurations in the Klipper community for connecting LCD screens to Orange Pi devices. Sometimes, other users will have created patches or drivers specifically for non-standard setups. Try finding alternative drivers: Even if the GitHub repository you found didn’t work, check if there are forks or alternative branches of that repository. It’s also worth checking out other forums or user groups that focus on 3D printing or Orange Pi setups. You might find someone who has already solved this issue. Wiring Check: Make sure that your wiring matches the expected configuration for your board. Sometimes, the issue can be as simple as a misconnected pin. Hope this helps! Let me know what controller the screen uses or if you need help with any specific steps.
  17. Found an appropriate workaround: Add the `brcmfmac_wcc` module to `/etc/initramfs-tools/modules`, and the wireless interface will be instantiated during initramfs loading and the netplan generator won't be confused by its absence. Also found another issue where the extra `brcmfmac43456-sdio.clm_blob` firmware file isn't properly registered by the module code, so mkinitramfs skips it. That's inherited from the Raspberry Pi firmware files which introduced the extra `clm_blob`. I filed it for the Pi kernel here: https://github.com/raspberrypi/linux/issues/6828, but the same issue affects the Armbian kernel + firmware combination. The fix is either a kernel patch or an initramfs hack like the following hook: #!/bin/sh -e # Copy missing firmware files for brcmfmac driver PREREQ="" prereqs () { echo "${PREREQ}"; } case "${1}" in prereqs) prereqs; exit 0 ;; esac ; . /usr/share/initramfs-tools/hook-functions echo "Copying missing firmware files for brcmfmac..." cp /lib/firmware/brcm/brcmfmac43456-sdio.clm_blob ${DESTDIR}/lib/firmware/brcm/ The hack is unaware of any firmware file platform variants like `radxa,zero` or `radxa,rockpi4b` and such - it just turns out the `brcmfmac43456-sdio.clm_blob` file doesn't have any.
  18. Has anyone activated the ov13855 camera on Orange Pi 5 (kernel 6.1.x)? If so, can you share your experience?
  19. On Armbian 25.2.1, I can't find package tags. In contrast, on a pure Debian host (non-armbian), the command "apt-cache show gcc" says in part: Tag: devel::compiler, devel::lang:c, devel::library, implemented-in::c, interface::commandline, role::devel-lib, role::metapackage, role::program, suite::gnu, works-with::software:source I'd also like to see tags on Armbian so I can search for packages based on their tags. Thanks.
  20. What steps are you doing to get this working manually? What is the overlay file you are loading (trying to load), and where does that file exist on the system?
  21. armbianEnv.txt seem is not being loaded. I am trying to get i2c-1 up and I have it checked in armbian-config but all I get is i2c-2 showing. Loading the overlay manually gets the device to show up but not after a reboot. What am I doing wrong? ChatGPT sends me on a wild ride trying to fix. /boot/armbianEnv.txt rootfstype=ext4 overlays=i2c1 i2c-rtc ds3231 ds1307 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  22. 5) Control a flight vehicle with real time input and outputs. [jgauthier@gamma build]$ diff -u config/kernel/linux-sunxi64-edge.config userpatches/linux-sunxi64-edge.config [jgauthier@gamma build]$ I'm not sure why it's expected that those would be different. I made the configuration with 'make menuconfig' and then copied to to userpatches. I did this because, at the time, I thought it was being overwritten. It was, but that was due to armbian-kernel.sh.
  23. 1) Play (decode) video audio 2) Read the status of multiple sensors at regular intervals 3) Generate pulses on GPIO 4) Transmit the packet at the right time over Ethernet, UART ... 5) .......? diff -u config/kernel/linux-sunxi64-edge.config userpatches/linux-sunxi64-edge.config
  24. I have exactly the same issue. Cannot boot after upgrade, also newly flashed image won't boot with exactly the same trace. I compiled latest upstream U-Boot v2025.04 as described here (Pre-Built FIP variant). https://docs.u-boot.org/en/latest/board/amlogic/odroid-c2.html Then I patched Armbian image with latest U-Boot. dd if=u-boot.bin.sd.bin of=Armbian_25.2.1_Odroidc2_bookworm_current_6.12.13_minimal.img conv=notrunc bs=512 skip=1 seek=1 And that works for me, system boots just fine
  25. Looks like 23.5.1 with U-Boot 2022.7 works as well (23.5.1 Bookworm 6.1.30). Spoke too soon. It never loaded the kernel.
  26. Have you tried applying this to the 6.12 kernel?
  27. @going I can, yes. But at the moment I don't want to distract from the wifi issue I am trying to solve. I am building a test application that must perform real time operations. I have previously done this with other ARM boards/distributions, but for this small project I am trying to go with "simplicity" (nothing is ever simple) I can provide the 'duff -u' for your interest, but I don't know what you want me to compare it against. i have linux-sunxi64-edge.config in my userpatches/ folder. It's generated from make menuconfig, and then I removed 'CGROUP_SCHED' from armbian-kernel.sh. Real-time applications work fine now. (They do not with group scheduling) root:~/# ./cyclictest --mlockall --smp --priority=80 --interval=200 --distance=0 # /dev/cpu_dma_latency set to 0us policy: fifo: loadavg: 0.30 0.37 0.17 2/200 1471 T: 0 ( 1468) P:80 I:200 C: 379209 Min: 7 Act: 18 Avg: 10 Max: 83 T: 1 ( 1469) P:80 I:200 C: 379008 Min: 6 Act: 19 Avg: 10 Max: 68 T: 2 ( 1470) P:80 I:200 C: 378802 Min: 7 Act: 19 Avg: 10 Max: 79 T: 3 ( 1471) P:80 I:200 C: 378595 Min: 7 Act: 20 Avg: 10 Max: 75
  28. What is your goal? 25.02 is a stable release. There is no 25.05 stable release yet (that will happen towards the end of next month). So what is out there now are daily development rolling builds of 20.05. So if you want to track development then this would make sense (note the use 0f the word 'daily' there, things can change that often, and these changes aren't well tested yet), but if you want tested stability then you should wait until the next stable release comes out.
