  2. @Nick A One last question, if i do this will i still have to use UART and flash the firmware? imma guess it's a yes but i guess it's still worth asking.
  3. @Thur_Wander Here are the steps to create a secure boot image. This example is using the tanix-tx6s-axp313 defconfig. You probably want one of the X96q defconfig's.
  5. @Nick A could you explain this a bit to me? i'm actually quite new to this and i just got this TV box the only thing i managed to do was installing a software version from a guy who debloated and checked it for spyware. also when i use the reset button in the av jack it just ignores everything and recovers from an internal image or something.
  6. @Octavio Cuatrochio@Thur_Wander Maybe it has secure boot enabled.
  7. Hi, I am here in 2026 with the Amrbian 26.2.1, I've tried the proposed fix from @c0rnelius but it's not working on my OS version. If anyone has any updated solution that'd be amazing. Thank you
  8. I have this exact same model and the device appears to be heavily locked down... Did this method worK? i'm trying to get a linux ARM distribution running but i can't flash a custom ROM
  9. The most current download images for Helios64 are now all provided with linux 6.18.xx. I downloaded a minimal image and checked the dtb: it would not appear to contain the opp-microvolt patch that made Helios64 finally stable. So for the ones who have stability issues again on Helios64, I attached the patched dtb compiled for linux 6.18.xx using the exact same opp-microvolt values as in the previous dtb versions I compiled for linux 6.6 and 6.12. The current linux deb files can be downloaded from beta.armbian.com, the linux 6.18.18 deb files I used can be downloaded from here (to be installed with 'dpkg -i linux*'). In order to install the dtb, simply unzip it, copy it into the proper location, update initramfs and reboot: # install the dtb with the opp-microvolt patch: unzip rk3399-kobol-helios64.dtb-6.18.18-opp.zip cp rk3399-kobol-helios64.dtb-6.18.18-opp /boot/dtb/rockchip/rk3399-kobol-helios64.dtb update-initramfs -u reboot rk3399-kobol-helios64.dtb-6.18.18-opp.zip
  10. Another attempt, again check https://testing.armbian.de/r4s/?C=M&O=D for most recent debs. This time adding an artificial bus scan delay into the r4s dts. Another poke in the dark but perhaps...
  11. See inline comments. Dirty SPI may cause this but without logs from serial console this is just a guess
  12. Is there mainline support for a7a now
  13. I will try downgrading u-boot next once I find the older package somewhere. Kernel does not seem to be the cause given that it has been working fine with both my own build 6.6.122 and 6.6.128 before and rolling back not helping. New device is something I had on my mind for a while. But given the RAM and SSD prices these days, I do not really want to overspend. Not to mention that the SBC landscape has not been that great lately when it comes to compact NAS offerings. HC4 is five years old at this point. Many even recommend N100 but this is a whole different size category.
  14. I would not be surprised if there has always been a HW initialization issue. It is just that now with newer Linux (whole systemd stuff etc) you hit this problem. I always liked this HC1, but it is not even on Odroid WiKi anymore. You might need to focus on version/build of U-Boot in combination with kernel and DTB. I have some examples (Rockchip based SBC's) were it is make-or-break, e.g. if I just take latest U-Boot whole system / use-case is useless / gone. So I need to stick to legacy U-Boot or just buy other HW/platform.
  15. This could be, but something has changed and is now triggering this behaviour. Warm reboots have been working fine for years.
  16. Is the much trouble USB-SATA chip, I have it as 'cable', but unused as it at least fails with RPI4 when SSD. It looks like a sequencing/timing issue. You can treat it like external maybe and/or reset the USB device node. That usually works for various USB connected HW that fails at boot but when Linux/platform fully up and running, a reset then somehow avoids timing issues.
  17. Good day, I have recently purchased an Orange Pi 5 Pro and want to use Armbian on it. Armbian (Debian 13 Trixie) does not boot and gives a initramfs error. I have read on erasing the SPI flash memory, but have a few questions. Will erasing the SPI flash memory affect the booting of other operating systems. Is it safe to erase the SPI flash memory? What is the issue around Armbian not booting because of the SPI flash memory? How exactly would I safely erase the SPI flash memory? Thank You
  18. Other packages upgraded by unattended-upgrades: Start-Date: 2026-03-15 10:51:39 Commandline: apt upgrade Requested-By: julas (1000) Upgrade: linux-base:armhf (4.12~bpo12+1, 4.12.1~bpo12+1) End-Date: 2026-03-15 10:51:51 Start-Date: 2026-03-16 06:20:00 Commandline: /usr/bin/unattended-upgrade Upgrade: linux-image-current-odroidxu4:armhf (25.11.2.3, 26.2.1) End-Date: 2026-03-16 06:21:56 Start-Date: 2026-03-16 06:22:47 Commandline: /usr/bin/unattended-upgrade Upgrade: base-files:armhf (25.11.2-12.4+deb12u12-bookworm, 26.2.1-12.4+deb12u13-bookworm), armbian-bsp-cli-odroidxu4-current:armhf (25.11.2, 26.2.1) End-Date: 2026-03-16 06:23:48 Start-Date: 2026-03-16 06:24:54 Commandline: /usr/bin/unattended-upgrade Upgrade: armbian-firmware:armhf (25.11.2, 26.2.1) End-Date: 2026-03-16 06:26:03 Start-Date: 2026-03-16 06:26:48 Commandline: /usr/bin/unattended-upgrade Upgrade: linux-dtb-current-odroidxu4:armhf (25.11.2.3, 26.2.1) End-Date: 2026-03-16 06:26:52 Start-Date: 2026-03-16 06:27:35 Commandline: /usr/bin/unattended-upgrade Upgrade: linux-u-boot-odroidxu4-current:armhf (25.11.2, 26.2.1) End-Date: 2026-03-16 06:27:37 Unfortunately, the previous versions seem to be gone from the repos. Is there any way of getting these back?
  19. Rolling "back" linux-{dtb,image}-current to my self-built 6.6.128 did not help.
  20. I was able to see the data on the drive just fine when connected to another machine via eSATA cable. Oddly enough, the partition showed back up again after reattaching it to the odroid and starting it again. I have then rebooted the odroid again, and the partition went away once again. So it appears to be some sort of cold vs warm boot difference.
  21. Hello, I have updated my Odroid HC1 to 26.2.1 - just the kernel, u-boot and such. I have been running a self-built 6.6.128 prior so kernel version itself is unlikely the issue. After rebooting, my SATA drive seems dead - no partitions are detected, only the main sda device. This is what the journal said before: Mar 05 15:51:31 kernel: usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd Mar 05 15:51:31 kernel: usb 4-1: New USB device found, idVendor=152d, idProduct=0578, bcdDevice=31.02 Mar 05 15:51:31 kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 05 15:51:31 kernel: usb 4-1: Product: USB to ATA/ATAPI Bridge Mar 05 15:51:31 kernel: usb 4-1: Manufacturer: JMicron Mar 05 15:51:31 kernel: usb 4-1: SerialNumber: 0123456789ABCDEF Mar 05 15:51:31 kernel: SCSI subsystem initialized Mar 05 15:51:31 kernel: usbcore: registered new interface driver usb-storage Mar 05 15:51:31 kernel: scsi host0: uas Mar 05 15:51:31 kernel: usbcore: registered new interface driver uas Mar 05 15:51:31 kernel: scsi 0:0:0:0: Direct-Access JMicron Generic 3102 PQ: 0 ANSI: 6 Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Write Protect is off Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Mode Sense: 53 00 00 08 Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Disabling FUA Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes) Mar 05 15:51:31 kernel: sda: sda1 Mar 05 15:51:31 kernel: sd 0:0:0:0: [sda] Attached SCSI disk This is what it says now: Mar 19 09:36:34 kernel: usb 4-1: New USB device found, idVendor=152d, idProduct=0578, bcdDevice=31.02 Mar 19 09:36:34 kernel: usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 19 09:36:34 kernel: usb 4-1: Product: USB to ATA/ATAPI Bridge Mar 19 09:36:34 kernel: usb 4-1: Manufacturer: JMicron Mar 19 09:36:34 kernel: usb 4-1: SerialNumber: 0123456789ABCDEF Mar 19 09:36:34 kernel: SCSI subsystem initialized Mar 19 09:36:34 kernel: usbcore: registered new interface driver usb-storage Mar 19 09:36:34 kernel: scsi host0: uas Mar 19 09:36:34 kernel: usbcore: registered new interface driver uas Mar 19 09:36:34 kernel: scsi 0:0:0:0: Direct-Access JMicron Generic 3102 PQ: 0 ANSI: 6 Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Unit Not Ready Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Sense Key : 0x4 [current] Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81 Mar 19 09:36:34 kernel: r8152-cfgselector 6-1: reset SuperSpeed USB device number 2 using xhci-hcd Mar 19 09:36:34 kernel: r8152 6-1:1.0: load rtl8153a-3 v2 02/07/20 successfully Mar 19 09:36:34 kernel: r8152 6-1:1.0 eth0: v1.12.13 Mar 19 09:36:34 kernel: r8152-cfgselector 6-1: reset SuperSpeed USB device number 2 using xhci-hcd Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Sense Key : 0x4 [current] Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81 Mar 19 09:36:34 kernel: r8152 6-1:1.0: load rtl8153a-3 v2 02/07/20 successfully Mar 19 09:36:34 kernel: r8152 6-1:1.0 eth0: v1.12.13 Mar 19 09:36:34 kernel: r8152 6-1:1.0 enx001e06326076: renamed from eth0 Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Sense Key : 0x4 [current] Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81 Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B) Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] 0-byte physical blocks Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Asking for cache data failed Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes not a multiple of physical block size (0 bytes) Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (0 bytes) Mar 19 09:36:34 kernel: sd 0:0:0:0: [sda] Attached SCSI disk I will try attaching the drive to another PC to exclude a poorly timed hardware failure.
  22. hi all. any hints to merge olimex imx8 board and compile armbian kernel 6.x and deb12 ?
  23. hello ,my box is mortal t1 2g8rom and motherboard show mortal t2 v2.0 it's broken and i wanna make linux boot what's the most version to be able for my box
  24. [ 1.234958] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 1.235032] rockchip-pcie f8000000.pcie: probe with driver rockchip-pcie failed with error -110 PCI support on this SoC has never been fully stable. Patch that tries to mitigate the issue, exists: https://github.com/armbian/build/blob/main/patch/kernel/archive/rockchip64-6.18/rk3399-fix-pci-phy.patch Not really much we can do more - use a kernel that it works, try current one with few reboots, ... I know its not perfect but we have nobody that can afford investing few weeks trying to fix this. Imagine the frustration if nothing will be improved - which I highly suspect for this case.
  25. Hm. Well. Im out of ideas. Perhaps openwrt will find something when they're going to work on 6.18. Unmarked the old solution for now since it no longer applies.
  26. I don't know if it's useful, but folks have been attaching external GPUs to low power boards for a while. My personal favorite was sacking and desoldering a USB3 controller to reuse it's PCIE lane: https://mloduchowski.com/raspberry-pi-4-b-pci-express/ Others have run into the same BAR limitation you noted: https://www.jeffgeerling.com/blog/2020/external-gpus-and-raspberry-pi-compute-module-4/ From a practical perspective, I'm not sure how many folks would be interested in discrete GPUs, as I'm not sure these sorts of boards would have the CPU or PCIE lanes to really make use of that extra horsepower. Most would get a dedicated embedded system, or a bespoke NVidia setup. For what it's worth, I ran into an issue where the kernel was too big for u-boot to boot it, and would just throw a synchronous abort and reset. The difference between working and not working was 7 MB.
  27. Yesterday
  28. That is true that there are images that target server vs. desktop. But they share the same kernel. I find what you are working on an interesting idea. Good luck getting it working.
