@Werner I ran this from the build folder git fetch origin pull/6618/head and I'm trying to build it again - from what I see on the tty it looks to be compiling and linking
DEV【 Tanix TX66】 RK3566 4GB/32GB 8K 2.4/5WIFI 1GiB BT USB2/3 SD IR SPDIF
maka replied to gen ha's topic in Rockchip CPU Boxes
You have to change the mdio ethernet phy from 0 to 1 in your DTB. -
Hi Team, I hope you're all keeping well. I'm into my first foray into armbian, and I'm having trouble just getting it to boot on my Nanopi R6S. Feeling a bit thick, like I'm missing something obvious. I can get FriendlyELEC's rk3588-sd-debian-bookworm-core-6.1-arm64-20240511 to boot without any trouble, but not armbian images. My procedure: Format microSD card with the SD Card Formatter from the SD Association Burn image to SD card with balena etcher Eject microSD reader from my PC Pop microSD into the device and apply power When it boots into the FriendlyELEC image: the SYS light shines solid red for about 3 seconds then the SYS light starts blinking After a short while, the WAN light comes on for about 2 seconds then goes off. The SYS light continues blinking. When I try an armbian image: the SYS light just shines solid red ad infinitum. It also does the same with no SD card at all. Things I've tried: Two separate microSD cards, both will happily boot the FriendlyELEC images Three type-C power supplies (two Lenovo OEM 65W supplies that I use with my laptop + a Belkin 100W PD unit that gets used for everything) Waiting a long time for anything to happen on screen or with the LEDs I have also tried win32diskimager to burn the images to the microSD cards to ensure it's not a problem with balena Cleared any bootloader on the eMMC while booted into the FriendlyELEC image (per the FriendlyELEC wiki) dd if=/dev/zero of=/dev/mmcblk2 bs=8M count=1 Armbian images I've tried: My own built Armbian images - very impressed with armbian-build! Armbian_community_24.5.0-trunk.563_Nanopi-r6s_bookworm_edge_6.8.9_minimal.img.xz from Armbian website (verified SHA of a5e6da3593d221813cc874415b3c1f7f509aca9a09ff008a5bca7eb73313e2e7) Armbian_community_24.5.0-trunk.563_Nanopi-r6s_jammy_edge_6.8.9_gnome_desktop.img.xz from Armbian website (verified SHA of cf2dd5f25f1dae97ea3750e00cf335c1b68dc861b4d5d98b0fc0420050227a88) Am I doing something obviously wrong?
I was downloading minimal/server images. This is an output from serial console: U-Boot SPL 2024.01-armbian (Feb 09 2024 - 18:57:17 +0000) DRAM: 2048 MiB Trying to boot from MMC1 and pretty the same from older armbian version from another memory card: U-Boot SPL 2023.07.02-armbian (Aug 31 2023 - 08:27:30 +0000) DRAM: 2048 MiB Trying to boot from MMC1 I have problem with h2testw on my Windows 11 laptop. Laptop has buildin micro sd card reader that works but windows often shows memory card disk on the disks list but I cant assign drive letter. Additionaly I can't refresh the view. h2testw expects me to select drive. I also tried to use other power supply (5V 2,5A - minimal for Orange Pi Prime) but with no success.
Those are not what you have installed on that SD card.
Description Add support for RK3588 based board Cool PI CM5 EVB Jira reference number [AR-9999] How Has This Been Tested? ./compile.sh build BOARD=coolpi-cm5 BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='3dsupport browsers chat desktop_tools editors email internet multimedia office programming remote_desktop' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base DOWNLOAD_MIRROR=bfsu EXPERT=yes EXTRAWIFI=no KERNEL_CONFIGURE=no PREFER_DOCKER=no RELEASE=noble Download the compiled img to sdcard, and can boot. Checklist: Please delete options that are not relevant. [✓ ] My code follows the style guidelines of this project [✓] I have performed a self-review of my own code [✓] I have commented my code, particularly in hard-to-understand areas [✓] My changes generate no new warnings [✓] Any dependent changes have been merged and published in downstream modules View the full article
Hello. I am taking the task of organizing and performing the BTT Pi and CB1 support update. The plan is to use mainline kernel 6.6 and 6.8 (basically the default sunxi64 config) instead of the BTT fork and use patches to backport kernel patches for drivers and hardware support. The Jira issue is AR-2312, which is a collection of things that will need to be done for this initiative. @Gunjan Gupta @c0rnelius @ag123 @jernej @ALIGMSTEN I'm asking for your help on this, as Igor has said to me that you are more knowledgeable on the state of the board and what it needs. From what I've found, there has been a PR that upgraded the kernel used for BTT CB1 to 6.1.79 using patches, and there's a discussion on reconstructing or copying the BigTreeTech device tree for 6.6.y and up. The BTT's changes are mostly drivers, device tree and other hardware support and backporting. I think BTT's linux 6.2.y branch should be used as the starting point to determine what board-specific patches and changes are needed. Some of the drivers are already in the 6.6.y (CURRENT) and 6.8.y (EDGE) kernel versions, some are added by armbian, some are only in the vendor's fork.
https://www.google.com/search?q=how+do+i+checkout+a+pr+github
Just a remark: setting MIN_SPEED to 600 MHz would have NO effect on power consumption but required frequency switching would be less: switching between 408 and 600MHz would be avoided and the system could transition directly from 600 MHz to the highest frequency (essentially switching only between two states for each cpu). The huge power savings are impressive!
Two desktops needs additional testing: https://github.com/armbian/build/pull/6626 https://github.com/armbian/build/pull/6625 ... we are high on closing existing tasks and very low on time dealing with this. There are several other bugs that needs attention: https://www.armbian.com/participate/
Description Enabling KDE Neon at Noble How Has This Been Tested? [ ] Build test [ ] Running desktop inspection Checklist: Please delete options that are not relevant. [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
Hey there were you able to run it or not ?
Can anyone tell me how to repair the Ethernet port? The error log is as follows: [ 26.619270] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 26.621884] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed [ 26.624545] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed [ 26.769290] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 26.774068] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [Generic PHY] (irq=POLL) [ 26.777878] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state [ 26.780446] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state [ 26.784638] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [ 26.788899] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [ 26.791572] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [ 26.796881] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo [ 26.880900] platform mtd_vendor_storage: deferred probe pending [ 26.881880] dwmmc_rockchip fe2c0000.dwmmc: No normal pinctrl state [ 26.886026] dwmmc_rockchip fe2c0000.dwmmc: No idle pinctrl state [ 26.888690] dwmmc_rockchip fe2c0000.dwmmc: IDMAC supports 32-bit address mode. [ 26.891380] dwmmc_rockchip fe2c0000.dwmmc: Using internal DMA controller. [ 26.893932] dwmmc_rockchip fe2c0000.dwmmc: Version ID is 270a [ 26.896371] dwmmc_rockchip fe2c0000.dwmmc: DW MMC controller at irq 68,32 bit host data width,256 deep fifo [ 27.776978] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 27.779377] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed [ 27.781771] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Hw setup failed
Description Tested only for assembly at this point. It needs further optimisations. How Has This Been Tested? [x] Build test [ ] Booted image with i3wm Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
How do I checkout a PR
CPU : RK3566 / Mali-G52 GPU RAM : 2GB/4GB LPDDR4 ROM : eMMC 16G/32G/64G Bluetooth : BT 5.0 DC In : DC 5V/2A USB Host : 2 High speed USB 2.0, 1 USB 3.0 Card Reader : TF Card reader Lan : RJ45 Ethernet port 1GiB Wifi : Built-in Wifi, 802.1.1b/g/n/ac ; 2.4G/5G SPDIF : Coaxial(Optical) DTB: rk3566-slzn.dtb
The directory listing you show has files from 2020. But this download page doesn't have anything that old. You are not using builds that are current.
Description I'm sorry, the error on the 6.8 kernel occurred because I didn't synchronize my code in time, resulting in patch errors that affected the compilation. Based on the hints here, I am optimizing the device tree for the firefly-rk3399 kernel: https://github.com/armbian/build/pull/6611 How Has This Been Tested? [x] Almost all hardware functions(HDMI, WiFi, BT, GbE, USB...). [x] System startup. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
I have the same problem, this is what I did: Download the firmware from this page the xfce https://www.armbian.com/amlogic-s9xx-tv-box/ My SD is 64 GB in FAT 32 Use BalenaEtcher and win32disk I made a copy of "u-boot-s905x-s912" and renamed it u-boot.ext This is my extlinux file: I insert SD and press the AV button and connect power and it only reaches the Android recovery
Either checkout the PR instead of main and try again or wait until it got merged.
Just tried a fresh clone and ran compile.sh - and it crashed as before - it builds a ras pi image OK but not the nanopim4v2
patching: rewrite: fully stabilize patch index stanzas as well as From lines patching: rewrite: fully stabilize patch index stanzas as well as From lines git format-patch --zero-commit doesn't affect index xxx...yyy lines, only From: so use the classy "use a regex with a callback" solution as git format-patch doesn't offer one this will make all patches change when rewritten, but hopefully for the last time ! we need to preserve index 000000000000..xxx as zeros, which indicate new file creation, thus: new file creations are rewritten as index 000000000000..111111111111 non-creations are rewritten as index 111111111111..222222222222 this is the final version of #6455 View the full article
extensions: rk-panthor: mesa-oibaf + DEFAULT_OVERLAYS="panthor-gpu" extensions: rk-panthor: mesa-oibaf + DEFAULT_OVERLAYS="panthor-gpu" I had worked this before AF sent his oneliner, but I forgot to PR Should be the same, except avoids sadness when trying with the wrong kernel/branch View the full article
