RK3399: H.264 decoding not exposed in v4l2, only MPEG2 and VP8
McTurbo replied to McTurbo's topic in Orange Pi 4 LTS
Thanks so much for your help! -
Did you try to play a video through HDMI? was sound present? You can use a USB flash (pendrive) to try it. As, I understand, the RK3528 is not working with HDMI audio (in my case neither GPU acceleration for videoplayback, it plays but it's choppy).
rcu: INFO: rcu_sched self-detected stall on CPU rcu: 0-....: (5249 ticks this GP) idle=5ec4/1/0x40000002 softirq=471875/471875 fqs=2602 rcu: (t=5250 jiffies g=738401 q=352 ncpus=4) CPU: 0 PID: 14211 Comm: octoprint Tainted: G C 6.6.16-current-sunxi #1 Hardware name: Allwinner sun8i Family PC is at stmmac_get_stats64+0x24/0x128 LR is at 0xc32bb000 pc : [<c078c5cc>] lr : [<c32bb000>] psr: a0010033 sp : e1fed990 ip : c32b8000 fp : 00000001 r10: 00000000 r9 : c95dee40 r8 : 00000000 r7 : 00000000 r6 : 00000001 r5 : 00000000 r4 : 80000000 r3 : 0093d4a3 r2 : c32bae48 r1 : c50ba6b8 r0 : c32b8000 Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none Control: 50c5387d Table: 497a006a DAC: 00000051 stmmac_get_stats64 from dev_get_stats+0x27/0xd0 dev_get_stats from rtnl_fill_stats+0x25/0xb0 rtnl_fill_stats from rtnl_fill_ifinfo+0x4cd/0xde0 rtnl_fill_ifinfo from rtnl_dump_ifinfo+0x1ff/0x49c rtnl_dump_ifinfo from netlink_dump+0xcd/0x270 netlink_dump from __netlink_dump_start+0x15b/0x1ec __netlink_dump_start from rtnetlink_rcv_msg+0x177/0x25c rtnetlink_rcv_msg from netlink_rcv_skb+0x75/0xb0 netlink_rcv_skb from netlink_unicast+0x1c1/0x204 netlink_unicast from netlink_sendmsg+0x185/0x354 netlink_sendmsg from __sock_sendmsg+0x27/0x48 __sock_sendmsg from __sys_sendto+0x7f/0xac __sys_sendto from ret_fast_syscall+0x1/0x5c Exception stack(0xe1fedfa8 to 0xe1fedff0) dfa0: aa039794 0000000c 00000029 aa0397b0 00000014 00000000 dfc0: aa039794 0000000c aa03b920 00000122 00000000 00000029 00000014 00000000 dfe0: 00000122 aa038738 b6dd4325 b6d3db06 Same issue here. I am using Orange pi one. Problem afer installing 6.6.16-current-sunxi Huge utylization of CPU / system freze, I also using, mjpg_streamer, I am metionig about this, because I can only make it working/unfreze only after getting feed from camera on that hardware. I know weird, but it is how it is.
Hi. I would like to know if someone can help me. I was successfully able to compile armbian 6.6.30 with all of @Stephen Graf patches for my orangepi zero 3 having Full Audio working even on HDMI. see below for reference. Now I have a 2nd project. It runs the h616 with 2GB DDR3 RAM with AXP313. Can someone help me with a patch for the AXP313 on h616. Or alternatively, could my h618 orangepi zero 3 setup work if I patch it to run with DDR3? If so where can I find such a patch. Thanks in advance.
main-config.sh: workaround: set the default ARCH to arm64 (replacing armhf) main-config.sh: workaround: set the default ARCH to arm64 (replacing armhf) armhf was disabled for some releases and now we get spurious failures building certain artifacts (firmware) Signed-off-by: Ricardo Pardini ricardo@pardini.net View the full article
based on the messages, it seemed you managed to load the overlay for w1-gpio perhaps venture further and connect a device appropriately ? based on the data sheet https://www.analog.com/media/en/technical-documentation/data-sheets/DS18B20.pdf (page 15, fig 15) it seeemed detection works by master (host) pulling down the line for 480 uS then pull that up again. then the chip would respond by first pulling it down, and after some 60-240 uS pull that up to inform the host of presence. it may take using specialized equipment like a scope / logic analyzer to probe those signals. for what is worth, and not trying to disappoint you, I think it is probably easier to connect the sensor to a (simple) microcontroller e.g. using uart and for the microcontroller to interface the sensor. the thing is for things related to timing, it may take going pretty much close to 'bare metal' e.g. work the on chip hardware to synchronize those signals, e.g. using pwm, spi etc. a h616 manual is found here https://linux-sunxi.org/images/2/24/H616_User_Manual_V1.0_cleaned.pdf if you want to venture there. uart on orange pi zero 3 is likely available in the standard configs without dts overlays.
I read again info https://docs.armbian.com/User-Guide_Allwinner_overlays/ and compile overlay by command: armbian-add-overlay w1-gpio.dts I see that in /boot/overlay-user/ is file w1-gpio.dtbo in /boot/armbianEnv.txt user_overlays=w1-gpio param_w1_pin=PC10 param_w1_pin_int_pullup=1 after this I reboot OZPI v3 after restart OZPIv3 I check dmesg info where found [ 4.990724] Driver for 1-wire Dallas network protocol. [ 4.997793] sun50i-h616-pinctrl 300b000.pinctrl: pin PC10 already requested by onewire@0; cannot claim for 300b000.pinctrl:74 [ 4.997833] w1-gpio onewire@0: gpio_request (pin) failed [ 4.997841] w1-gpio: probe of onewire@0 failed with error -22 cat /sys/kernel/debug/gpio gpiochip0: GPIOs 0-287, parent: platform/300b000.pinctrl, 300b000.pinctrl: gpio-76 ( |red:status ) out lo gpio-77 ( |green:power ) out hi gpio-80 ( |regulator-usb1-vbus ) out hi gpio-166 ( |cd ) in lo ACTIVE LOW gpio-210 ( |reset ) out hi ACTIVE LOW Can anyone help?
on debian distro : sudo nautilus This folder and dtb folder is the same folder it's just an short link
So I been doing some testing and audio through headphone jack "Line Out" works. I added a patch to enable line out in my dts. +&codec { + allwinner,audio-routing = + "Line Out", "LINEOUT"; + status = "okay"; +}; + You need to to enable it using the mixer. (thanks to sasa in the orange pie thread) /usr/bin/amixer -c 0 set 'Left Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Left Output Mixer DACR' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACL' 100% unmute /usr/bin/amixer -c 0 set 'Right Output Mixer DACR' 100% unmute Bluetooth has a bug where you need to enable bluetooth in android first before it can work with armbian.
[PINE64 A64] Kernel panics with headless boot
daniele95100 replied to daniele95100's topic in Pine A64
Hi, I've tried to blacklist the driver, seemed stable but crashed after 2 weeks. At this point I don't know what else to try. For now i set kernel.panic=10 in /etc/sysctl.d/96-panic.conf to see if at least reboots when a panic happens. -
orange pi not booting from emmc when sd card in connected
Mainul Quraishi replied to Mainul Quraishi's topic in Beginners
Yes, that i did already. but this machine is supposed to work remotely and if I or for any reason, it reboots, it will never turn ON again if the SD card is not bootable. -
Michael Robinson replied to Mainul Quraishi's topic in Beginners
You will need to boot the board then insert the SD card. -
as mentioned except code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } .. everything should belong to your current user Take note of the permissions for code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } .. Which admin?
i am using armbian 24.2.1 debian bookworm inn orangepi 5b. At first i used sd card to boot. then i wanted to use emmc to boot. so i went to armbian-config and install os in emmc from there from sd card. now it is booting from emmc if the sd card is not connected but if the sd card is connected it is booting from sd card. The worst part is, if i connect a sd card where there is no OS, it will not even boot. How can i set a order like if there is bootable os in emmc boot from there and use the sd card as storage if not boot from sd card ?
Hi, thanks for the efforts with this. Just tried this on my MXQ Pro V72 (3228A) with latest Armbian w/ XFCE. Unfortunately, any playback on mpv within xfce did not have good performance. In terms of hardware decode, only h264 8-bit could run w/ hw decode. Meanwhile 10-bit H264 and HEVC did not run with HW decode at all. All files were tested at 1080p. Playback performance was only good when run in virtual terminal, but on XFCE, even 8bit H264 stuttered, not to mention the pink/red color issue (which was fixed with the additional mesa flags). I thought it was a throttling issue, since xfce sensors report 80C, so I added a fan blowing from under the tv box and the temps are now within 55-70C. However that did not fix the issue. Is there anything else I could check or try? Thanks.
Orange Pi Lite. problem with latest firmware.
AlexTransit replied to AlexTransit's topic in Allwinner sunxi
checked in detail. spi-dev - it works (in the new firmware) gpio - it works key the path by name is different ( /dev/input/by-path/platform-gpio-keys-event ) I haven't been able to launch the display on spi0.1 yet -
jock replied to McTurbo's topic in Orange Pi 4 LTS
Definitely, if you look at the kernel source code you can enable the codec Yes, it is. I think it is in the kernel mailing list, so it is something that is already floating around and eventually will be merged. -
This device is used to control the Audio HUB сrossbar switch, for example it makes possible to use external i2s interfaces. https://github.com/elkoni/Opi_Zero_3_I2S3_5.4/blob/main/OpiZero3_I2S_3_mixer.JPG
- 16 replies
- Banana Pi M4 Zero
- Orange Pi Zero 2
(and 1 more)
Tagged with:
Hi, the Armbian_community_24.5.0-trunk.563_Bananapi_jammy_current_6.6.30_xfce_desktop.img shows black screen after going to the desktop GUI (the LCD panel shows "no signal").. PS: The Armbian_23.11.1_Bananapi_jammy_current_6.1.63_xfce_desktop.img after an update/upgrade shows black screen after going to the desktop GUI (the LCD panel shows "no signal") as well.. The Armbian_22.11.0-trunk_Bananapi_bullseye_edge_5.19.6_xfce_desktop.img Armbian_23.8.2_Bananapi_jammy_current_6.1.51_xfce_desktop.img Armbian_23.11.1_Bananapi_jammy_current_6.1.63_xfce_desktop.img work.
Description phytium_embedded: update phytium u-boot binary to support 50Mhz SDIO WiFi. Phytium has not open-sourced the u-boot they use, so I have to use the non-free u-boot binary file they provide. How Has This Been Tested? [x] Successfully built. [x] System startup. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
Except what? You open up a flood door like that, you have to explain to op and hold his hand in how to find out what different users/groups are supposed to own different files. And since I have no idea what op has installed on his system, and how he did it, and what user he was when he did (sudo and root is NOT the same) I recommend op reinstall and do everything the correct way. Example from a system with docker running, nothing out of the ordinary. 3 cointainers the correct way, user in docker group and never using sudo with docker. $ sudo find . -group root -printf '.'| wc -c 153 153 files/directories just for root inside ~/. And this is only a quick search for root group, there are obviously other users and groups owning a whole bunch of stuff too. Probably a GREAT idea to "sudo chown -R 1000:1000 ~/"... Remember, op stated: And this is just an example of what can happen. Blows my mind an armbian admin thinks blindly taking ownership is a good idea... 😮
Oh, yes. This must also work. or "commit:xxxxxxxxxxxxxxxxx"
I meant this line: KERNELBRANCH="tag:v6.1.69" which uniquely determines which version of the kernel patches are applied cleanly. I.e. to version 6.1.69 and not to the current 6.1.90 for today.
in a normal case, files in your home directory should belong to you except ..
