Cosmetic issues may appear during the procedure and fixing them might take from hours to days.
Starting early in the morning, backup late in the evening CET.
Upgrade from v4.3.6 -> 4.4.3
What's new:
https://invisioncommunity.com/release-notes/440-r81/
https://invisioncommunity.com/release-notes/441-r82/
https://invisioncommunity.com/release-notes/442-r83/
https://invisioncommunity.com/release-notes/443-r84/
1st stage done, now adjustments and fixing. Report problems here.
New theme, which supposed to work better is under "Armbian NG". You can select it in the footer.
on my Smartphone the space for content is MUCH smaller using the new theme Armbian NG.
with Default and normal Armbian I have to scroll much less inside a thread ;)
while using any of the 3 themes in some threads there is the following error-message:
[[Template core/front/global/commentEditLine is throwing an error.
This theme may be out of date.
Run the support tool in the AdminCP to restore the default theme.]]
is the update complete or in running state?
Ah, yeah, it happens with the "Default theme" when you click on the main tabs ("Giveaways", "Applications", ...)
On 5/2/2019 at 6:08 PM, Igor said:
now bug fixing.
in my profile, I click on the profile of a 'profile visitor', I only get errors.
fixed
