Younes_Thabet Posted June 18, 2019 Posted June 18, 2019 Hello all, Recently, I bought an Orange Pi Win Plus board and have installed Armbian on SDcard and it works fine but when i try to install it on emmc using "sudo nand-sata-install" it just shows "install/update the bootloader on SD/eMMC" in the options instead of "boot from eMMC - system on eMMC" as i have seen on the internet . so guys! what am i doing wrong!? Regards,
Igor Posted June 18, 2019 Posted June 18, 2019 On 6/18/2019 at 3:15 PM, Younes_Thabet said: it just shows "install/update the bootloader on SD/eMMC" Expand Two months ago eMMC support was disabled due to configuration mismatch and I forgot to adjust it and enable back. Install attached file with: dpkg -i linux-u-boot-next-orangepiwin_5.89_arm64.deb and repeat the process. I don't have eMMC based board so I can't verify. linux-u-boot-next-orangepiwin_5.89_arm64.debFetching info...
Fernando Fer Posted December 9, 2019 Posted December 9, 2019 Hi.. im in the same trouble .. i've got an OPI win plus and tried same exact thing.. to flash armbian on emmc.. and again the same thing.. i couldnt flash it!..(the same nag screen as Youne).. so i tried ur procedure (dpkg -i linux-u-boot-next-orangepiwin_5.89_arm64.deb) but it didnt resolve the problem.. cant u answer me something on it!?.. Thkz..
Mossroy Posted December 28, 2019 Posted December 28, 2019 Same issue on Olinuxino A64. with Armbian_19.11.3_Lime-a64_buster_current_5.3.9.7z image It was working in a previous version, so hopefully it will be fixed in next stable version
Igor Posted December 28, 2019 Posted December 28, 2019 On 12/28/2019 at 10:18 AM, Mossroy said: Same issue on Olinuxino A64. with Armbian_19.11.3_Lime-a64_buster_current_5.3.9.7z image It was working in a previous version, so hopefully it will be fixed in next stable version Expand I am running it from eMMC on most recent kernel - images are not ready, but you can build one and try.
martinayotte Posted December 28, 2019 Posted December 28, 2019 On 12/28/2019 at 10:18 AM, Mossroy said: Same issue on Olinuxino A64. Expand What "dmesg | grep -i mmc" is reporting ?
