Jedi Master Posted July 8, 2019 Posted July 8, 2019 Hi, I have been looking to download "Armbian_5.52_Olinuxino-a20_Debian_stretch_next_4.17.19.img". Torrent that I have is not seed, it been stuck for all day. Can anyone please provide me with downloadable link or please seed the torrent? Thank you Jedi
Igor Posted July 9, 2019 Posted July 9, 2019 Those are unofficial builds that Olimex make on their own. Why do you need that particular build? Is most recent from our download section not working properly?
guidol Posted July 9, 2019 Posted July 9, 2019 @Jedi Master original armbian-images for olinuxino a20 (lime or lime2 are booth a20 cpu) are here: https://dl.armbian.com/lime/archive/ stretch: https://dl.armbian.com/lime/archive/Armbian_5.83_Lime_Debian_stretch_next_4.19.38.7z https://dl.armbian.com/lime2/archive/ stretch: https://dl.armbian.com/lime2/archive/Armbian_5.83_Lime2_Debian_stretch_next_4.19.38.7z unoffcial armbian images from olimex are here:ftp://staging.olimex.com/Allwinner_Images/A20-OLinuXino/ the oldest unofficial should be here: ftp://staging.olimex.com/Allwinner_Images/A20-OLinuXino/3.archived_mainline_images/5.72.1/stretch/images/ asftp://staging.olimex.com/Allwinner_Images/A20-OLinuXino/3.archived_mainline_images/5.72.1/stretch/images/Armbian_5.72.1_Olinuxino-a20_Debian_stretch_next_4.19.17.7z
Jedi Master Posted July 9, 2019 Author Posted July 9, 2019 On 7/9/2019 at 5:58 AM, Igor said: Those are unofficial builds that Olimex make on their own. Why do you need that particular build? Is most recent from our download section not working properly? Expand Yes, I cannot make A20-Lime2 work with latest build. I'm using mini-usb ethernet adapter and it is not being recognized. `[ 4.180658] usb0-vbus: disabling` I read olimex forum and found out Armbian 5.52 works fine with mini-usb ethernet adapter. Even with night build, beta packages it's not working. Also, tried dtb enable usb host, didn't work at all. uname -a: `Linux lime2 5.1.16-sunxi #5.91.190707 SMP Mon Jul 8 00:07:38 CEST 2019 armv7l GNU/Linux` Any help is appreciated.
guidol Posted July 9, 2019 Posted July 9, 2019 why do you use the mini-usb (near the HDMI port) and not a normal-size usb-port? the mini-usb-port is a otg port did you enable usb only via dtb-file or also via armbian-config -> system -> hardware? you could try your mini-usb-ethernet adapter via mini2USB converter on the normal usb-port.
Jedi Master Posted July 9, 2019 Author Posted July 9, 2019 On 7/9/2019 at 3:42 PM, guidol said: why do you use the mini-usb (near the HDMI port) and not a normal-size usb-port? the mini-usb-port is a otg port did you enable usb only via dtb-file or also via armbian-config -> system -> hardware? you could try your mini-usb-ethernet adapter via mini2USB converter on the normal usb-port. Expand I tried armbian-config, I options like can, i2c1 i2c2 etc but not anything related to usb. I'm using mini-usb because it's DIY firewall, which is enclosed in a box, only exposing mini-usb and hdmi. That's why I'm limited here. BTW 5.72 build worked fine. Linux olinuxino 4.19.17-sunxi #5.72.1 SMP Thu Jan 24 13:30:13 EET 2019 armv7l GNU/Linux # Both eth0 and eth1 is shown now. enx405d8213b89a: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 40:5d:82:13:b8:9a txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.x.x netmask 255.255.255.0 broadcast 192.168.43.255 inet6 fe80::aeb2:1dfe:c406:cacc prefixlen 64 scopeid 0x20<link> ether 30:1f:9a:d0:11:e2 txqueuelen 1000 (Ethernet) RX packets 88077 bytes 121325510 (115.7 MiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 12098 bytes 901542 (880.4 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 62 It worked. I'm interested why it didn't work on latest build. Jedi.
Igor Posted July 9, 2019 Posted July 9, 2019 On 7/9/2019 at 2:23 PM, Jedi Master said: I cannot make A20-Lime2 work with latest build Expand You obviously can That's not a major failure - for your use case I can imagine, but in general not. On 7/9/2019 at 2:23 PM, Jedi Master said: Even with night build, beta packages it's not working. Expand Since nobody knows that there is a regression in this particular function (which we don't test), it can't be fixed. Now its known ... deep investigation and fixing when possible.
guidol Posted July 9, 2019 Posted July 9, 2019 @Jedi Master you can check with lsmod for g_serial or g_ether modules which can occupy the mini-usb port g_serial is a tty-terminal via the otg-port g_ether is a virtual ethernet-port via the otg-port but you need a "normal" usb-port on the mini-usb if you got g_serial or g_ether then you could try to rmmod the module? but I dont know if then it would be automatically a normal usb-port or you have to insmod another module for this purpose...
Jedi Master Posted July 9, 2019 Author Posted July 9, 2019 @guidol I see g_serial while doing lsmod. For now it's working for me. I'm using 5.72 build. The only thing that doesn't work now is reboot or shutdown -r now. It system does to shutdown state even with reboot or shutdown -r now.
Igor Posted July 9, 2019 Posted July 9, 2019 On 7/9/2019 at 5:06 PM, Jedi Master said: The only thing that doesn't work now is reboot or shutdown -r now. It system does to shutdown state even with reboot or shutdown -r now. Expand That is why we recommend you to stay with latest build ... and try to fix the issue with otg USB. We have fixed many others in the mean time.
