can not ping as user,  pinging as root works.
kernel 4.19.62
tried..
ping 127.0.0.1
ping: socket: operation not permitted
ping 1
as root:
/sbin/getcap /bin/ping
nothing set
to fix it
as root:
chmod u+s /bin/ping
pinging as user works.
opps.
using orange pi lite.
... tells exactly nothing. That's why we ask for diagnostic report:
armbianmonitor -u
This is what "ls -l /bin/ping" is showing on my OPiLite :
-rwsr-xr-x 1 root root 47756 Nov 10  2016 /bin/ping
If your was screwed up by somehow ...
working on getting data back.  The device  is not online because too many external firewalls are in the way. so everything needs to be hand copied.
How to reproduce.
MY mistake, it is a R1 not lite
image is
Armbian_5.90_Orangepi-r1_Debian-buster_next_4.19.57.img
Date of file is July5at 15:33
Flash to SD.
monut  as loop.
/etc/armbian.txt
armbain5.90
kernel 4.19.57
ls -l /bin/ping
-rwxr-xr-x 1 root root 47704 Aug  3  2018 /bin/ping
Boot image in a r1
(no internet access)
configure root
configure user
login as root
ls -l /bin/ping
can ping as root.
because of no internet access (enterprise network) i cant use armbian-config
create file in lan /etc/network/interfaces.d
  auto eth0
  iface eth0 inet static
  address 192.168.5.250
  network 192.168.5.0
  netmask 255.255.255.0
  gateway 192.168.5.100
--bring it up
 ifup eth0 ... no errors
as root can ping debian.org (wierd did not touch resolv.conf)
james@orangepi:~$ su
Password:
root@orangepi:/home/james# ping 192.168.5.100
PING 192.168.5.100 (192.168.5.100) 56(84) bytes of data.
64 bytes from 192.168.5.100: icmp_seq=1 ttl=64 time=9.65 ms
64 bytes from 192.168.5.100: icmp_seq=2 ttl=64 time=5.56 ms
^C
--- 192.168.5.100 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 2ms
rtt min/avg/max/mdev = 5.564/7.604/9.645/2.042 ms
^Xroot@orangepi:/home/james# ping debian.org
PING debian.org (149.20.4.15) 56(84) bytes of data.
64 bytes from mirror-isc3.debian.org (149.20.4.15): icmp_seq=1 ttl=55 time=41.9 ms
64 bytes from mirror-isc3.debian.org (149.20.4.15): icmp_seq=2 ttl=55 time=38.8 ms
64 bytes from mirror-isc3.debian.org (149.20.4.15): icmp_seq=3 ttl=55 time=43.1 ms
^C
--- debian.org ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 38.826/41.298/43.140/1.824 ms
root@orangepi:/home/james# exit
exit
james@orangepi:~$ ping 192.168.5.100
ping: socket: Operation not permitted
james@orangepi:~$ ping debian.org
james@orangepi:~$
root@orangepi:/home/james# armbianmonitor -u
System diagnosis information will now be uploaded to no results to fetchPlease post the URL in the forum where you've been asked for.
aptiude, install upgrades, update to kernal 4.19.62, rebooted
had several crashes, had to power down twice.
both put massive pages of stuff. might be power related.
debian Buster with Armbian Linux ttyS0
orangepi login: root
Password:
Last login: Thu Aug 15 01:57:19 UTC 2019 on ttyS0
  ___  ____  _   ____  _
 / _ \|  _ \(_) |  _ \/ |
| | | | |_) | | | |_) | |
| |_| |  __/| | |  _ <| |
 \___/|_|   |_| |_| \_\_|
Welcome to Debian Buster with Armbian Linux 4.19.62-sunxi
System load:   0.08 0.14 0.07      Up time:       3 min
Memory usage:  31 % of 239MB      IP:            192.168.5.250
CPU temp:      42°C
Usage of /:    8% of 15G
[ General system configuration (beta): armbian-config ]
root@orangepi:~# ping debian.org
PING debian.org (5.153.231.4) 56(84) bytes of data.
64 bytes from senfter.debian.org (5.153.231.4): icmp_seq=1 ttl=48 time=197 ms
64 bytes from senfter.debian.org (5.153.231.4): icmp_seq=2 ttl=48 time=168 ms
^C
2 packets transmitted, 2 received, 0% packet loss, time 3ms
rtt min/avg/max/mdev = 167.717/182.552/197.387/14.835 ms
root@orangepi:~# exit
logout
Debian Buster with Armbian Linux ttyS0
orangepi login: james
Password:
Last login: Thu Aug 15 01:59:17 UTC 2019 on ttyS0
  ___  ____  _   ____  _
| | | | |_) | | | |_) | |
System load:   0.06 0.13 0.07      Up time:       4 min
CPU temp:      43°C
james@orangepi:~$ ls -l /bin/ping
james@orangepi:~$
root@orangepi:/home/james# chmod u+s /bin/ping
root@orangepi:/home/james# ping debian.orgf
ping: debian.orgf: Name or service not known
PING debian.org (128.31.0.62) 56(84) bytes of data.
64 bytes from mirror-csail.debian.org (128.31.0.62): icmp_seq=1 ttl=48 time=108 ms
64 bytes from mirror-csail.debian.org (128.31.0.62): icmp_seq=2 ttl=48 time=107 ms
64 bytes from mirror-csail.debian.org (128.31.0.62): icmp_seq=3 ttl=48 time=111 ms
c64 bytes from mirror-csail.debian.org (128.31.0.62): icmp_seq=4 ttl=48 time=108 ms
^C
5 packets transmitted, 4 received, 20% packet loss, time 10ms
rtt min/avg/max/mdev = 106.549/108.606/111.445/1.819 ms
exit
PING debian.org (130.89.148.14) 56(84) bytes of data.
64 bytes from klecker-misc.debian.org (130.89.148.14): icmp_seq=1 ttl=51 time=169 ms
64 bytes from klecker-misc.debian.org (130.89.148.14): icmp_seq=2 ttl=51 time=168 ms
^C
Edited by lanefu
I merged your posts
Effectively, this image doesn't have -rwsr-xr-x
@Igor, maybe it would be good to redo this image or DEB package that provide "ping" ...
This is one of those small Buster bugs? ... but if this ping permission problem is here, the problem is probably elsewhere as well? On the download we have bug fixed version 5.91 ...
https://dl.armbian.com/nanopi-r1/archive/
where some other bugs were addressed. Perhaps this was also fixed?
