orange pi one
I was installing armbian buster. Then decided to abort the installation and turned off power.
If I install armbian on a sd card and then put the sd card into the orange pi one,
the orange pi one keeps rebooting and display message boot. env
file invalid elf header rebooting. Is the orange pi garbage? Can I reset the orange pi one?
Thank you.
likely your SD card.
Expand
After I aborted the installation, I reinstalled armbian on the
same sd card. Turning on the orange pi one I got
the mentioned error messages. And gparted on a x86
computer displays an i/o error if I want to format
the sd card.
Therefore I took another sd card, which is 4gb and installed debian
on it. Turning on the orange pi one I get the same error
messages as when I used the first sd card. I think it is unlikely
that the second sd card is defect. The 4gb sd card
is a class 4 sd card. That is not good
enough?
  On 10/2/2019 at 4:01 PM, renky said:
The 4gb sd card is a class 4 sd card. That is not good enough?
Expand
I fully second Igor. You can either spend a couple hours "try & error"  and in the end you either buy new or start to read the link above from Igor.  As simple as it gets :-D
Expand
You wont have much fun with a Class 4 Card.
For better performance get a - if you can and can afford - a Class 10 Card from Sandisk or Samsung.
I like my OPi One's ( got 7 of them ) very much and they do work great for this little SBC.
And in my opinion they do work better with faster cards
