Tarzanus 2 Posted November 12, 2019 Share Posted November 12, 2019 Anyone has the following box and managed to find the correct dtb?The box is being sold under "Android 9.0 TV Box A95X Z2 4GB RAM 64GB 2.4G 5G Wifi RK3318 Quad Core..." name on aliexpress and ebay. I tried copying armbian to sd-card and it refuses to boot. I checked various DTBs with no luck. Anyone else got it to work? Link to post Share on other sites More sharing options...
Tarzanus 2 Posted November 17, 2019 Author Share Posted November 17, 2019 None of the dtb files work. I got the armbian from balbes150 (https://yadi.sk/d/DSO6euzB3ahemo) . I changed dtbs in "/extlinux/extlinux.conf" file and when I tried booting using sd-card, the device remained 'dead' and refused to turn on. It's funny, because aida64 says system is created from Ubuntu kernel. I wish I could just enter the underlying system . Link to post Share on other sites More sharing options...
Tarzanus 2 Posted December 5, 2019 Author Share Posted December 5, 2019 Peeked inside. I can see memory modules and it seems the model is identical to A95x F2R Link to post Share on other sites More sharing options...
hexdump 66 Posted January 7, 2020 Share Posted January 7, 2020 @Tarzanus - you might give this approach a try: best wishes - hexdump 1 Link to post Share on other sites More sharing options...
Tarzanus 2 Posted January 9, 2020 Author Share Posted January 9, 2020 Thank you! I'll try, hopefully tonight. Thank you for letting me know about this! Regards Link to post Share on other sites More sharing options...
Tarzanus 2 Posted January 9, 2020 Author Share Posted January 9, 2020 I tried placing his dtb file into Armbian_19.11.3_Rk3328-tv_eoan_legacy_4.4.154_desktop_20191126.img and it doesn't work. I'll try doing some more research. Link to post Share on other sites More sharing options...
hexdump 66 Posted January 9, 2020 Share Posted January 9, 2020 you need to dd the trust.img as well - just read the thread from the post i linked to onwards for the file and more info ... good luck - hexdump 1 Link to post Share on other sites More sharing options...
Tarzanus 2 Posted January 10, 2020 Author Share Posted January 10, 2020 I tried that as well, remained black, nothing. I took the file he extracted and it didn't work. I checked the firmware version I have and it says PQ2A.190205.003-9.0-201910140936. Couldn't find the firmware on the internet to extract the files myself. Perhaps If I install wireshark and try updating, I can get the update URL or something.. Sadly I have very little time to spare lately. Link to post Share on other sites More sharing options...
hexdump 66 Posted January 10, 2020 Share Posted January 10, 2020 who knows if there will be any updates for such cheap boxes at all Link to post Share on other sites More sharing options...
balbes150 897 Posted January 11, 2020 Share Posted January 11, 2020 17 hours ago, hexdump said: who knows if there will be any updates for such cheap boxes at all Is this a question or a statement of fact ? Link to post Share on other sites More sharing options...
hexdump 66 Posted January 11, 2020 Share Posted January 11, 2020 @balbes150 - i think this depends on the actual box Link to post Share on other sites More sharing options...
Tarzanus 2 Posted January 13, 2020 Author Share Posted January 13, 2020 I got into desktop environment. Wifi and BT doesn't work but LAN does. Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 19, 2020 Share Posted January 19, 2020 (edited) Any image file for A95x Z2 RK3318 bought on Aliexpress. Now stock on booting logo. "Android 9.0 TV Box A95X Z2 4GB RAM 64GB 2.4G 5G Wifi RK3318 Quad Core..." seems to be of bad quality. Thanks in advance Edited January 19, 2020 by Bassalh123 Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 19, 2020 Share Posted January 19, 2020 Tried to flash the box with similar .img files using pc tool but no luck. I need the exact correct image file compatible with the box. Link to post Share on other sites More sharing options...
Tarzanus 2 Posted January 20, 2020 Author Share Posted January 20, 2020 Use image from @balbes150 from this topic RC2 of 5.5 mainline kernel works best (haven't tried rc6 yet, but with rc5, USB3 stopped working. When you burn the image to your SD-card patch it up following this procedure: System works pretty well, except for Wi-fi and bluetooth. The system is not fully optimized and it has issues playing video clips, especially at higher resolution. I hope GPU support will also get polished if that's the issue. 1 Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 20, 2020 Share Posted January 20, 2020 I got in touch with manufacturer so hope he will supply the right firmware for this shit box. Link to post Share on other sites More sharing options...
Максим Круземан 2 Posted January 20, 2020 Share Posted January 20, 2020 (edited) On 1/19/2020 at 7:24 PM, Bassalh123 said: similar .img Try A95X R3 image. Found on another forum it's compatible. Edited January 20, 2020 by Максим Круземан 1 Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 21, 2020 Share Posted January 21, 2020 Can you give a link please? I will try this anyways https://androidtvbox.eu/new-firmware-a95x-r3-with-android-9-0-rk3318-soc-20190927/ Link to post Share on other sites More sharing options...
Максим Круземан 2 Posted January 21, 2020 Share Posted January 21, 2020 48 minutes ago, Bassalh123 said: Can you give a link please? Try this - https://mega.nz/#F!GmpTBIzD!xQWmniBzJIqnm8kmKXZu-Q (TOPSION TP01 4/64 (MB A95X F2R)) And this - https://drive.google.com/drive/folders/1qO-lCGaPb6qwQ1_V6WZCxNyIjjb68FPE ( A95X R3 (MB A95X F2R) ) 1 Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 21, 2020 Share Posted January 21, 2020 I tried the second one already "A95X R3 RK3328.img" no luck with the flashing tool. I will give the first one a go once downloaded. Thanks for your reply, Greetings from Hassan here in Ireland. Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 21, 2020 Share Posted January 21, 2020 Yes Mr. Максим Круземан the first one works like a charm, using factory tool 1.66and drivers. Thanks a million buddy https://mega.nz/#F!GmpTBIzD!xQWmniBzJIqnm8kmKXZu-Q (TOPSION TP01 4/64 (MB A95X F2R)) Link to post Share on other sites More sharing options...
Максим Круземан 2 Posted January 21, 2020 Share Posted January 21, 2020 1 hour ago, Bassalh123 said: first one works like a charm Always happy to help! I ordered HK1 Max (2/16) especially for armbian, receive in end of this week. Will try to run. It's maybe on RK3318 CPU, not RK3328. Link to post Share on other sites More sharing options...
Bassalh123 0 Posted January 21, 2020 Share Posted January 21, 2020 1 hour ago, Максим Круземан said: Always happy to help! I ordered HK1 Max (2/16) especially for armbian, receive in end of this week. Will try to run. It's maybe on RK3318 CPU, not RK3328. You are a star. Keep the good work. Link to post Share on other sites More sharing options...
Tarzanus 2 Posted January 24, 2020 Author Share Posted January 24, 2020 Here, I've made some hdparm tests: Test of eMMC /dev/mmcblk0: Timing cached reads: 846 MB in 2.00 seconds = 422.99 MB/sec Timing buffered disk reads: 342 MB in 3.02 seconds = 113.37 MB/sec Test of SD-card /dev/mmcblk2: Timing cached reads: 820 MB in 2.00 seconds = 409.24 MB/sec Timing buffered disk reads: 68 MB in 3.04 seconds = 22.33 MB/sec Test USB3.0 dongle /dev/sda1: Timing cached reads: 946 MB in 2.00 seconds = 472.31 MB/sec Timing buffered disk reads: 330 MB in 3.02 seconds = 109.37 MB/sec Test USB3.1 dongle /dev/sda: Timing cached reads: 920 MB in 2.00 seconds = 459.98 MB/sec Timing buffered disk reads: 362 MB in 3.01 seconds = 120.45 MB/sec It looks like USB3 port is the fastest option. eMMC is also quite fast. Sadly, SD-card seems to be on USB2 lines and works rather slow. Link to post Share on other sites More sharing options...
Commie 0 Posted September 1, 2020 Share Posted September 1, 2020 On 1/21/2020 at 12:53 PM, Максим Круземан said: Try this - https://mega.nz/#F!GmpTBIzD!xQWmniBzJIqnm8kmKXZu-Q (TOPSION TP01 4/64 (MB A95X F2R)) Can someone reupload this file? I'm desperate to flash my box as it doesn't put up any application that i try to run on it. Thanks. Link to post Share on other sites More sharing options...
marine1988 0 Posted September 6, 2020 Share Posted September 6, 2020 please re upload the image! Link to post Share on other sites More sharing options...
Nila 0 Posted September 15, 2020 Share Posted September 15, 2020 On 1/21/2020 at 8:46 PM, Bassalh123 said: You are a star. Keep the good work. Can you upload the file you downloaded? I have this product with below link https://www.aliexpress.com/item/4000057505566.html kindly reply ASAP Link to post Share on other sites More sharing options...
Nila 0 Posted October 14, 2020 Share Posted October 14, 2020 On 1/21/2020 at 5:23 PM, Максим Круземан said: Try this - https://mega.nz/#F!GmpTBIzD!xQWmniBzJIqnm8kmKXZu-Q (TOPSION TP01 4/64 (MB A95X F2R)) And this - https://drive.google.com/drive/folders/1qO-lCGaPb6qwQ1_V6WZCxNyIjjb68FPE ( A95X R3 (MB A95X F2R) ) link 1 is not working, kindly upload it on Google drive Link to post Share on other sites More sharing options...
