IgorS Posted November 21, 2019 Share Posted November 21, 2019 Today I noticed something strange about packages : armbian-config and armbian-firmware (bionic all) Repository version becomes 19.11.3 (via apt update) but self built packages created via kernel build script are version 5.98 Other kernel packages are ok, version 4.19.85 What about this? Link to comment Share on other sites More sharing options...
guidol Posted November 21, 2019 Share Posted November 21, 2019 read here about the new names: Link to comment Share on other sites More sharing options...
guidol Posted November 21, 2019 Share Posted November 21, 2019 we "should" switch after apt update & upgrade inside armbian-config via system => other to the new kernel (legacy or current) - but after apt update & upgrade I was on linux-image-dev-meson64 (19.11.3) and after armian-config now on linux-image-current-meson64 (19.11.3) to what does current match? next, mainline, dev (,legacy - not...) or whats the difference between a dev and a current 19.11.3 image? dev was - for me - the most current. BTW: My package-info line does work with 19.11.3 ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to Armbian Buster with Linux 5.3.11-meson64 package bsp-kernel[19.11.3] u-boot[19.11.3] dtb[19.11.3] firmware[19.11.3] config[19.11.3] branch[current] Link to comment Share on other sites More sharing options...
Igor Posted November 21, 2019 Share Posted November 21, 2019 51 minutes ago, guidol said: dev was DEV = development. Currently there is none or its identical to CURRENT ... but later DEV will some time be 5.4.y. ... until CURRENT becomes DEV again Link to comment Share on other sites More sharing options...
guidol Posted November 21, 2019 Share Posted November 21, 2019 2 hours ago, Igor said: DEV = development. Currently there is none or its identical to CURRENT ... but later DEV will some time be 5.4.y. ... until CURRENT becomes DEV again is there a way to build a "CURRENT" (19.11.3) armbian-image with the armbian-build-system? this mean maybe special options to ./comspile.sh ? Or when will the armbian-build-system create as default the CURRENT version e.g. 19.11.3 ? OK, did found it Did got/use a bad .conf Link to comment Share on other sites More sharing options...
