Ugo Riboni Posted December 23, 2019 Posted December 23, 2019 (edited) Hello everyone, Apologies if this is not the right forum for this questions, but could not find any more appropriate one after some searching. I get an HTTP 404 when I try to access the pre-built images for the nanopi m1 plus from the board page. I know the board is EOS but for other EOS boards I can still download the images. Is there any reason why this board seems to have disappeared completely ? Edited December 23, 2019 by Ugo Riboni fix link
martinayotte Posted December 23, 2019 Posted December 23, 2019 20 minutes ago, Ugo Riboni said: Is there any reason why this board seems to have disappeared completely ? They are moved in "_old" folder : https://dl.armbian.com/_old/nanopim1plus/archive/
Ugo Riboni Posted December 23, 2019 Author Posted December 23, 2019 20 minutes ago, martinayotte said: They are moved in "_old" folder : https://dl.armbian.com/_old/nanopim1plus/archive/ Ah, thanks a lot for the information ! Probably the links from the board page should be removed or fixed, then.
Igor Posted December 23, 2019 Posted December 23, 2019 4 hours ago, Ugo Riboni said: Probably the links from the board page should be removed or fixed, then. Fixed. Recreated images with most recent kernel 5.4.y ... untested. Give it a try!
Ugo Riboni Posted December 27, 2019 Author Posted December 27, 2019 On 12/23/2019 at 8:37 PM, Igor said: Fixed. Recreated images with most recent kernel 5.4.y ... untested. Give it a try! Thanks Igor ! I tried the ubuntu image and the few things I tested so far (i2c, audio input) work quite well. I'll keep testing and report in other threads if I find any issues.
