NicoD Posted December 31, 2019 Share Posted December 31, 2019 Hi all. I'm doing some tests and I noticed wifi isn't working on the M4 with Bionic 5.4(server from download page) and 5.3(desktop self build) Both on-board wifi any usb wifi dongles aren't working. Anyone an idea why this is? Cheers. Link to comment Share on other sites More sharing options...
martinayotte Posted December 31, 2019 Share Posted December 31, 2019 2 minutes ago, NicoD said: Anyone an idea why this is? Most probably NetworkManager issue again and again ... Try to disable it and do "old school" /etc/network/interface config, I bet it will work ... 1 Link to comment Share on other sites More sharing options...
NicoD Posted December 31, 2019 Author Share Posted December 31, 2019 42 minutes ago, martinayotte said: Try to disable it and do "old school" /etc/network/interface config, I bet it will work . Doesn't seem to be working. I disabled networkmanager and set /etc/network/interface. ip a shows dummy0 instead of wlan0. I'll try an image of balbes to see if it's the same. Link to comment Share on other sites More sharing options...
NicoD Posted December 31, 2019 Author Share Posted December 31, 2019 @balbes150 image didn't boot on the M4 with the M4.dtb So I used the Rock Pi4 instead. I already had a working gaming image for it.@martinayotte I hope the PineH64 comment about no wifi on freshly builds isn't the same problem. I tried the PineH64 model b a few days ago and then it worked. I can't remember ever having problems with the M4 here either. I can be wrong, too many boards... All a happy new year. Link to comment Share on other sites More sharing options...
martinayotte Posted January 1, 2020 Share Posted January 1, 2020 17 hours ago, NicoD said: I hope the PineH64 comment about no wifi on freshly builds I don't have any issue on my PineH64 which is currently running 5.5.0-rc2 DEV build. Link to comment Share on other sites More sharing options...
heyden Posted January 1, 2020 Share Posted January 1, 2020 (edited) I see the same issue, i downloaded the latest OS available today on armbian https://dl.armbian.com/nanopim4/Buster_current Seems after the install both wifi and bluetooth not working and no adapter is displayed. this is the OS command i use and seems its a different board being listed in their image instead of RK3399 root@nanopim4:~# uname -a Linux nanopim4 5.4.6-rockchip64 #19.11.4 SMP PREEMPT Fri Dec 27 00:45:52 CET 2019 aarch64 GNU/Linux I tried replacing the mentioned firmware files as per @martinayotte and after a reboot it worked just fine.!! Thanks Edited January 1, 2020 by heyden Link to comment Share on other sites More sharing options...
pkfox Posted January 7, 2020 Share Posted January 7, 2020 On 12/31/2019 at 2:07 PM, NicoD said: Hi all. I'm doing some tests and I noticed wifi isn't working on the M4 with Bionic 5.4(server from download page) and 5.3(desktop self build) Both on-board wifi any usb wifi dongles aren't working. Anyone an idea why this is? Cheers. Hi Nico, is this with the M4 version 2 ? Link to comment Share on other sites More sharing options...
SergiiG Posted March 7, 2020 Share Posted March 7, 2020 Hi All, This thread has been silent for some time. Maybe there is already solution to run both Bluetooth and Wireless on M4 version 1 with new kernel 5.4. My problem is that after fresh installation of any 5.4 kernel image on my Nano M4, I have working bluetooth, but no wifi. When I apply firmware files suggested by @martinayotte, wifi starts to work, but bluetooth is not working any longer. So is there solution to have both wifi and bluetooth with 5.4 kernel. Also I have ordered 4x SATA HAT, what are my chances of getting this hat to work on 5.4 kernel? I can say that WiringPI provided by Friendly Elec are not working right away. Maybe I should switch back to legacy kernel to have everything working? Link to comment Share on other sites More sharing options...
NicoD Posted March 8, 2020 Author Share Posted March 8, 2020 On 1/7/2020 at 7:30 AM, pkfox said: Hi Nico, is this with the M4 version 2 ? Sorry, only now I see this comment. It was the version 1. I haven't looked into it again. I'll see if I find time this week to test again. 22 hours ago, sergiigladchuk said: Maybe I should switch back to legacy kernel to have everything working? Indeed. That is best. Only for panfrost mainline is better now. But it'll take some time before everything is perfect in mainline. Link to comment Share on other sites More sharing options...
SergiiG Posted March 9, 2020 Share Posted March 9, 2020 11 hours ago, NicoD said: Sorry, only now I see this comment. It was the version 1. I haven't looked into it again. I'll see if I find time this week to test again. Indeed. That is best. Only for panfrost mainline is better now. But it'll take some time before everything is perfect in mainline. Thanks NicoD. No hurry here, I checked yesterday official Friend Elec images for NanoPi M4, they are still on 4.4 kernel, so I just installed Buster server with 4.4 and all works fine, and hat should be fine as well. 1 Link to comment Share on other sites More sharing options...
Yingzheng Posted March 28, 2020 Share Posted March 28, 2020 is this issue fixed now? it seems that i still encounter this problem... Link to comment Share on other sites More sharing options...
takeshi Posted April 6, 2020 Share Posted April 6, 2020 I have the same issue on my NanoPiM4 building to the latest (5.4) Debian. Bluetooth is working but wifi is not. Tried troubleshooting a bit today - but I'm having trouble tracking down where the kernel mod load list is as /etc/modules-load.d/modules.conf contains nothing. I've identified what I believe the "correct" driver should be, but lsmod & hwinfo are both giving odd results as to which bcrm43456 driver is loaded....or loaded at all. Some direction on which / how to track down the device tree would be appreciated. Link to comment Share on other sites More sharing options...
jimg Posted April 15, 2020 Share Posted April 15, 2020 This got wifi working for me (but broke bluetooth ): $ cd /lib/firmware/brcm $ sudo mv brcmfmac4356-sdio.bin brcmfmac4356-sdio.bin.old $ sudo mv brcmfmac4356-sdio.txt brcmfmac4356-sdio.txt.old copy drivers from this post to ~/Downloads: $ sudo cp ~/Downloads/brcmfmac4356-sdio.* . $ sudo chmod g+w brcmfmac4356-sdio.bin $ sudo chmod g+w brcmfmac4356-sdio.txt then reboot Link to comment Share on other sites More sharing options...
SergiiG Posted April 15, 2020 Share Posted April 15, 2020 5 hours ago, jimg said: This got wifi working for me (but broke bluetooth ): $ cd /lib/firmware/brcm $ sudo mv brcmfmac4356-sdio.bin brcmfmac4356-sdio.bin.old $ sudo mv brcmfmac4356-sdio.txt brcmfmac4356-sdio.txt.old copy drivers from this post to ~/Downloads: $ sudo cp ~/Downloads/brcmfmac4356-sdio.* . $ sudo chmod g+w brcmfmac4356-sdio.bin $ sudo chmod g+w brcmfmac4356-sdio.txt then reboot Yes, same thing happened to me - wifi worked but not bluetooth, that is why I switched back to legacy kernel. Link to comment Share on other sites More sharing options...
jimg Posted April 15, 2020 Share Posted April 15, 2020 3 hours ago, sergiigladchuk said: Yes, same thing happened to me - wifi worked but not bluetooth, that is why I switched back to legacy kernel. Bluetooth works for me, but only if I completely power off and do a cold boot. It doesn't work on a warm restart. Note that firmware updates currently will overwrite these changes, so be careful when doing an apt-get update && apt-get upgrade. Link to comment Share on other sites More sharing options...
@lex Posted April 15, 2020 Share Posted April 15, 2020 Wifi and Bluetooth works fine on Mainline kernel 5.6.y with the more up to date firmware found here: https://people.linaro.org/~manivannan.sadhasivam/rock960_wifi/ Link to comment Share on other sites More sharing options...
