Allright....now all seems to work fine, good work :thumbup:
And with with 5.x kernel now my dual dvb-c stick has 2 working adapters (mostly the reason why i waited for working mainline kernel on this device)....
Expand
Nice to hear this :) I hope we will get more such reports which could remove "testing" label.
5.4.19 working fine on my HC1 through several reboots and with no apparent glitches. Lightly loaded system running a Samba / NFS file server + LMS (Squeezebox) music server. Although "unsupported" it seems quite happy with a Debian Stretch Lite userspace - is there a critical reason why I should upgrade or re-install to Buster for this kernel?
Expand
AFAIK none. Just kernel is not very well tested, but if it works for you ... keep it up. The same goes for Stretch.
  On 3/28/2020 at 12:44 PM, nihilista said:
Just to inform, newest 5.4.28-odroidxu4 kernel seems to work fine too. Hopefully past problems with every new update are gone ;-)
Expand
A few days in with 5.4.28 on odroid XU4, only serving light NAS, DLNA and torrenting tasks - fine so far.
i don't know if it's related but i answer an other post here with a similar problem : " no network access ".
resume : my HC1 boot well on unencrypted sdcard but when i try to boot on my full root encrypted ssd, it fail after successfully run cryptroot_unlock from initramfs .
Do you have any clue ?
Edited by rosbeef
Is there the same IP adresa after update and reboot? I had the same problem - after update i have got 192.168.1.194 ip, but before it was 192.168.1.193 - i realy do not know why
Edited by Romeo
Bad automatic words repairs on my cellphone
