just to be precise: in my tests I've been using an orange pi zero - board rev 1.5 (the revision number is printed on the circuit board)
7 hours ago, maracuja said:
It is possible to hook a serial console to the board, but what kind of outcome do you expect?
If the kernel is trapping/crashing for some reason then this would likely be shown on the console, which could help provide a clue as to what might be going on...
I think it's a memory issue.
I have tested again with kernel 5.4.7 (Armbian 19.11.6)
I had a second ssh connection open this time running a "free -h" command every second.
While running apt on the first ssh connection it showed me that free swap went down to 0 bytes, used: 59 Mi, total: 59 Mi
I had changed zram config of armbian to use 25% instead of 50% memory. But I don't think that's the issue because others have the same problems without this change. And on kernel 4.19.x this memory issue does not seem to arise.
Also the fact that users with 512M memory don't have stability issues is a hint that it's a memory issue.
Setting CPU governor to performance (like described in this thread) does not seem to be a solution.
I had a freeze again while running apt and while CPU governor was set to performance running @ 1.01 GHz.
Memory before the test:
              total        used        free      shared  buff/cache   available
Mem:          238Mi        67Mi       132Mi       0.0Ki        38Mi       165Mi
Swap:          59Mi        20Mi        38Mi
Memory during the test (during freeze):
Mem:          238Mi        94Mi       127Mi          0B        16Mi       139Mi
Swap:          59Mi        58Mi       0.0Ki
Next run - this time with zram = 50%
After reboot:
Mem:          238Mi        72Mi       127Mi       0.0Ki        37Mi       159Mi
Swap:         119Mi       9.0Mi       109Mi
While "apt-get purge mosquitto" - it got stuck multiple times for a couple of minutes (=system unresponsive)
The whole process took waaaaay too long for just purging a package.
Mem:          238Mi        94Mi       122Mi       0.0Ki        20Mi       137Mi
Swap:         119Mi        79Mi        39Mi
@5kft You could try to do some apt-get install commands.
For example: apt-get install php7.3-fpm, apt-get install mosquitto
Then purge again.
And look if your swap gets used...
Maybe this is only orange pi zero specific. But it is 99.99% NOT a hardware issue. It must be a software issue. Something in the kernel, or a driver is eating up memory or the swap usage isn't configured correctly.
Did an "apt-get install mosquitto" and while "Setting up mosquitto" it said "Killed"
Dmesg gives me:
Oct 12 11:31:32 etj-55555555 systemd[1]: Reloading.
Oct 12 11:31:33 etj-55555555 systemd[1]: /lib/systemd/system/nginx.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Oct 12 11:31:34 etj-55555555 systemd[1]: Reloading.
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711235] systemd-bless-b invoked oom-killer: gfp_mask=0x40cc0(GFP_KERNEL|__GFP_COMP), order=2, oom_score_adj=0
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711260] CPU: 1 PID: 5174 Comm: systemd-bless-b Not tainted 5.4.8-sunxi #19.11.6
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711265] Hardware name: Allwinner sun8i Family
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711308] [<c010da8d>] (unwind_backtrace) from [<c010a0b1>] (show_stack+0x11/0x14)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711326] [<c010a0b1>] (show_stack) from [<c093634f>] (dump_stack+0x6f/0x7c)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711345] [<c093634f>] (dump_stack) from [<c01fc515>] (dump_header+0x41/0x172)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711359] [<c01fc515>] (dump_header) from [<c01fbcfb>] (oom_kill_process+0xfb/0x104)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711369] [<c01fbcfb>] (oom_kill_process) from [<c01fc3f7>] (out_of_memory+0x19f/0x228)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711383] [<c01fc3f7>] (out_of_memory) from [<c022eb0f>] (__alloc_pages_nodemask+0xaff/0xc9c)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711400] [<c022eb0f>] (__alloc_pages_nodemask) from [<c0213e95>] (kmalloc_order+0x19/0x38)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711412] [<c0213e95>] (kmalloc_order) from [<c0213ecd>] (kmalloc_order_trace+0x19/0x94)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711430] [<c0213ecd>] (kmalloc_order_trace) from [<c015d37b>] (devkmsg_open+0x3f/0xc0)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711445] [<c015d37b>] (devkmsg_open) from [<c0256975>] (chrdev_open+0x91/0x11c)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711459] [<c0256975>] (chrdev_open) from [<c0250051>] (do_dentry_open+0xd5/0x2e8)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711477] [<c0250051>] (do_dentry_open) from [<c025e2b5>] (path_openat+0x1ed/0xe14)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711487] [<c025e2b5>] (path_openat) from [<c025fabf>] (do_filp_open+0x4f/0x90)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711500] [<c025fabf>] (do_filp_open) from [<c0251081>] (do_sys_open+0x125/0x194)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711513] [<c0251081>] (do_sys_open) from [<c0101001>] (ret_fast_syscall+0x1/0x62)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711518] Exception stack(0xc0e91fa8 to 0xc0e91ff0)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711529] 1fa0:                   b6edd000 b6f09968 ffffff9c b6d7385c 000a0101 00000000
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711539] 1fc0: b6edd000 b6f09968 bef46ce4 00000142 00000000 00000000 0044af8c 00000000
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711545] 1fe0: 00000142 bef46b00 b6e7525d b6dfe746
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711550] Mem-Info:
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711572] active_anon:1329 inactive_anon:1532 isolated_anon:85
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711572]  active_file:1404 inactive_file:1017 isolated_file:22
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711572]  unevictable:4 dirty:0 writeback:0 unstable:0
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711572]  slab_reclaimable:4526 slab_unreclaimable:8663
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711572]  mapped:1787 shmem:53 pagetables:528 bounce:0
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711572]  free:32149 free_pcp:51 free_cma:31941
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711586] Node 0 active_anon:5316kB inactive_anon:6128kB active_file:5616kB inactive_file:4068kB unevictable:16kB isolated(anon):340kB isolated(file):88kB mapped:7148kB dirty:0kB writeback:0kB shmem:212kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711613] Normal free:128596kB min:5388kB low:5708kB high:6028kB active_anon:5288kB inactive_anon:6144kB active_file:5556kB inactive_file:4152kB unevictable:16kB writepending:0kB present:262144kB managed:243968kB mlocked:16kB kernel_stack:1304kB pagetables:2112kB bounce:0kB free_pcp:212kB local_pcp:0kB free_cma:127764kB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711616] lowmem_reserve[]: 0 0 0
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711625] Normal: 149*4kB (UMEC) 74*8kB (UMEC) 6*16kB (C) 5*32kB (C) 6*64kB (C) 4*128kB (C) 2*256kB (C) 2*512kB (C) 2*1024kB (C) 2*2048kB (C) 29*4096kB (C) = 128804kB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711663] 2545 total pagecache pages
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711669] 60 pages in swap cache
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711675] Swap cache stats: add 270671, delete 270604, find 8999/242120
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711678] Free swap  = 74584kB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711681] Total swap = 121980kB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711684] 65536 pages RAM
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711687] 0 pages HighMem/MovableOnly
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711690] 4544 pages reserved
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711693] 32768 pages cma reserved
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711699] Unreclaimable slab info:
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.711702] Name                      Used          Total
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712107] zs_handle                179KB        204KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712187] RAWv6                     47KB         47KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712193] UDPv6                     35KB         35KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712216] TCPv6                     63KB         63KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712227] sgpool-128                30KB         30KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712236] sgpool-64                 31KB         31KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712245] sgpool-32                 15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712254] sgpool-16                  7KB          7KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712259] mqueue_inode_cache         15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712281] jfs_mp                     3KB          3KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712299] jbd2_inode                15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712316] kioctx                     7KB          7KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712334] rpc_buffers               32KB         32KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712343] RAW                       31KB         31KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712351] UDP                       61KB         61KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712359] request_sock_TCP           3KB          3KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712369] TCP                      126KB        126KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712383] eventpoll_pwq             15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712394] inotify_inode_mark         15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712406] request_queue            125KB        125KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712413] blkdev_ioc                16KB         16KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712422] biovec-max               453KB        453KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712432] biovec-128               126KB        126KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712439] biovec-64                 63KB         63KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712450] dmaengine-unmap-256         31KB         31KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712457] dmaengine-unmap-128         47KB         47KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712465] audit_buffer               4KB          4KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712473] skbuff_fclone_cache         31KB         31KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712484] skbuff_head_cache        173KB        173KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712492] configfs_dir_cache          7KB          7KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712503] file_lock_cache           16KB         16KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712523] fsnotify_mark_connector         15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712545] net_namespace             60KB         60KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712553] task_delay_info           19KB         19KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712564] taskstats                 30KB         30KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712574] proc_dir_entry            88KB         88KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712580] pde_opener                15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712591] seq_file                  15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712604] shmem_inode_cache        267KB        267KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712619] kernfs_iattrs_cache         15KB         15KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712635] kernfs_node_cache       2051KB       2051KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712654] filp                     409KB        437KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712674] names_cache              180KB        192KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712700] key_jar                  141KB        192KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712720] vm_area_struct           154KB        189KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712737] mm_struct                 32KB         32KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712745] files_cache               20KB         20KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712754] signal_cache             157KB        157KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712762] sighand_cache            252KB        252KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712769] task_struct              334KB        334KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712777] cred_jar                  40KB         40KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712785] anon_vma_chain           220KB        220KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712793] anon_vma                 163KB        163KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712798] pid                       20KB         20KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712803] trace_event_file          99KB         99KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712812] pool_workqueue            16KB         16KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712833] vmap_area                364KB        436KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712846] kmalloc-8k               984KB       1088KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712851] kmalloc-4k               356KB        356KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712856] kmalloc-2k               480KB        480KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712868] kmalloc-1k               850KB        864KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712881] kmalloc-512              598KB        656KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712886] kmalloc-256              132KB        132KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712891] kmalloc-192              173KB        173KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712896] kmalloc-128              292KB        292KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712903] kmalloc-64              1650KB       1652KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712908] kmem_cache_node           68KB         68KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712913] kmem_cache               251KB        252KB
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712916] Tasks state (memory values in pages):
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712920] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712970] [    295]     0   295     7021      358    59392      189             0 systemd-journal
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712981] [    326]     0   326     4060      163    16384      154         -1000 systemd-udevd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.712995] [    456]     0   456     1812        2    14336      768             0 haveged
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713005] [    579]     0   579     2657      336    20480      129             0 systemd-logind
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713014] [    584]     0   584     1830      157    14336       52             0 cron
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713024] [    592]   104   592     1371      284    16384       74          -900 dbus-daemon
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713046] [    599]     0   599     6796        0    16384       34             0 rngd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713063] [    604]     0   604     2183       17    18432      101             0 wpa_supplicant
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713078] [    606]     0   606     6197      211    22528      188             0 rsyslogd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713097] [    609]     0   609     5583        2    26624     1230             0 networkd-dispat
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713111] [    615]     0   615    15327      194    45056      387             0 NetworkManager
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713125] [    808]     0   808     8738        0    36864     1290             0 unattended-upgr
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713145] [    832]   105   832     2753      133    12288       57             0 chronyd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713160] [    838]   105   838      806        0    12288       61             0 chronyd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713176] [    862]     0   862     2220        2    16384      143         -1000 sshd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713194] [    936]     0   936     8994       53    24576      144             0 polkitd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713212] [    943]     0   943     1561        2    14336      212             0 dhclient
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713226] [   1178]     0  1178     1536        0    16384       29             0 agetty
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713243] [   1182]     0  1182      959        0    10240       24             0 agetty
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713262] [   1184]     0  1184     1536        0    14336       28             0 agetty
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713277] [   1264]     0  1264     2557      184    16384      174             0 sshd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713292] [   1267]     0  1267     2987        0    20480      220             0 systemd
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713308] [   1268]     0  1268     8105        0    30720      410             0 (sd-pam)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713319] [   1361]     0  1361     1957      210    14336      247             0 bash
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713332] [   1369]     0  1369     1957        2    16384      233             0 bash
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713345] [   1452]     0  1452     1688      319    14336       14             0 watch
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713361] [   1671]   111  1671     1171       78    14336       80             0 avahi-daemon
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713376] [   1672]   111  1672     1171        0    12288       60             0 avahi-daemon
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713405] [   5006]     0  5006    47314      298    45056      558             0 php-fpm7.3
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713416] [   5010]    33  5010    47314      101    38912      571             0 php-fpm7.3
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713425] [   5011]    33  5011    47314      101    38912      571             0 php-fpm7.3
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713436] [   5083]     0  5083    14172      798    65536     2688             0 apt-get
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713453] [   5137]     0  5137     2295      241    14336      373             0 dpkg
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713467] [   5138]     0  5138      368      241     8192       13             0 mosquitto.posti
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713489] [   5168]     0  5168      368      262    10240        0             0 invoke-rc.d
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713504] [   5172]     0  5172     2247      621    18432        0             0 systemctl
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713515] [   5173]     0  5173     8033      371    28672      340             0 (sd-executor)
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713529] [   5174]     0  5174     2592      645    18432        0             0 systemd-bless-b
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713541] [   5175]     0  5175     2595     1058    18432        0             0 systemd-cryptse
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713556] [   5176]     0  5176     2593     1035    20480        0             0 systemd-debug-g
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713569] [   5178]     0  5178     2596     1120    20480        0             0 systemd-fstab-g
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713583] [   5180]     0  5180     2593      662    18432        0             0 systemd-getty-g
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713596] [   5181]     0  5181     2596     1062    20480        0             0 systemd-gpt-aut
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713606] [   5182]     0  5182     2593     1064    18432        0             0 systemd-hiberna
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713614] [   5183]     0  5183     2593     1110    18432        0             0 systemd-rc-loca
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713623] [   5184]     0  5184     2593      817    18432        0             0 systemd-run-gen
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713631] [   5186]     0  5186     2593     1081    18432        0             0 systemd-system-
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713640] [   5187]     0  5187     2596      669    18432        0             0 systemd-sysv-ge
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713662] [   5188]     0  5188     2593      861    18432        0             0 systemd-veritys
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713675] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-0.slice/session-3.scope,task=apt-get,pid=5083,uid=0
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.713779] Out of memory: Killed process 5083 (apt-get) total-vm:56688kB, anon-rss:2096kB, file-rss:1096kB, shmem-rss:0kB, UID:0 pgtables:65536kB oom_score_adj:0
Oct 12 11:31:35 etj-55555555 kernel: [ 1361.730340] oom_reaper: reaped process 5083 (apt-get), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Oct 12 11:31:35 etj-55555555 systemd[1]: /lib/systemd/system/nginx.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Oct 12 11:31:36 etj-55555555 systemd[1]: Starting Mosquitto MQTT v3.1/v3.1.1 Broker...
Oct 12 11:31:36 etj-55555555 systemd[1]: Started Mosquitto MQTT v3.1/v3.1.1 Broker.
Oct 12 11:31:38 etj-55555555 systemd[1]: Reloading.
I have the same problem:(
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: rtl8188f_FirmwareDownload(): Shift for fw header!
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: rtl8188f_FirmwareDownload by IO write!
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x00050505
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: _8051Reset8188: Finish
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: _FWFreeToGo: Polling FW ready OK! (153, 12ms), REG_MCUFWDL:0x000505c6
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: rtl8188f_FirmwareDownload: DLFW OK !
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: rtl8188f_FirmwareDownload success. write_fw:1, 172ms
Oct  9 22:37:37 mass-test-34 kernel: RTL871X:  <=== rtl8188f_FirmwareDownload()
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: HalDetectPwrDownMode(): PDN=0
Oct  9 22:37:37 mass-test-34 kernel: RTL871X: Set RF Chip ID to RF_6052 and RF type to 3.
Oct  9 22:38:07 mass-test-34 kernel: rcu: INFO: rcu_sched self-detected stall on CPU
Oct  9 22:38:07 mass-test-34 kernel: rcu:       2-...!: (1 ticks this GP) idle=482/0/0x1 softirq=2690928/2690928 fqs=0
Oct  9 22:38:07 mass-test-34 kernel:    (t=15017 jiffies g=12013697 q=16)
Oct  9 22:38:07 mass-test-34 kernel: rcu: rcu_sched kthread starved for 15017 jiffies! g12013697 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x402 ->cpu=2
Oct  9 22:38:07 mass-test-34 kernel: rcu: RCU grace-period kthread stack dump:
Oct  9 22:38:07 mass-test-34 kernel: rcu_sched       I    0    10      2 0x00000000
Oct  9 22:38:07 mass-test-34 kernel: [<c086fd9f>] (__schedule) from [<c0870199>] (schedule+0x35/0x84)
Oct  9 22:38:07 mass-test-34 kernel: [<c0870199>] (schedule) from [<c0872b17>] (schedule_timeout+0xf3/0x218)
Oct  9 22:38:07 mass-test-34 kernel: [<c0872b17>] (schedule_timeout) from [<c016ccff>] (rcu_gp_kthread+0x34f/0x790)
Oct  9 22:38:07 mass-test-34 kernel: [<c016ccff>] (rcu_gp_kthread) from [<c01360c9>] (kthread+0x109/0x10c)
Oct  9 22:38:07 mass-test-34 kernel: [<c01360c9>] (kthread) from [<c01010f9>] (ret_from_fork+0x11/0x38)
Oct  9 22:38:07 mass-test-34 kernel: Exception stack(0xef143fb0 to 0xef143ff8)
Oct  9 22:38:07 mass-test-34 kernel: 3fa0:                                     00000000 00000000 00000000 00000000
Oct  9 22:38:07 mass-test-34 kernel: 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct  9 22:38:07 mass-test-34 kernel: 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
Oct  9 22:38:07 mass-test-34 kernel: Sending NMI from CPU 2 to CPUs 0:
Oct  9 22:38:07 mass-test-34 kernel: Sending NMI from CPU 2 to CPUs 1:
Oct  9 22:38:07 mass-test-34 kernel: NMI backtrace for cpu 2
Oct  9 22:38:07 mass-test-34 kernel: CPU: 2 PID: 0 Comm: swapper/2 Tainted: G         C  E     5.4.45-sunxi #20.05.3
Oct  9 22:38:07 mass-test-34 kernel: Hardware name: Allwinner sun8i Family
Oct  9 22:38:07 mass-test-34 kernel: [<c010dc49>] (unwind_backtrace) from [<c010a245>] (show_stack+0x11/0x14)
Oct  9 22:38:07 mass-test-34 kernel: [<c010a245>] (show_stack) from [<c085f97b>] (dump_stack+0x6f/0x7c)
Oct  9 22:38:07 mass-test-34 kernel: [<c085f97b>] (dump_stack) from [<c0863cdf>] (nmi_cpu_backtrace+0x6b/0x94)
Oct  9 22:38:07 mass-test-34 kernel: [<c0863cdf>] (nmi_cpu_backtrace) from [<c0863dd9>] (nmi_trigger_cpumask_backtrace+0xd1/0xdc)
Oct  9 22:38:07 mass-test-34 kernel: [<c0863dd9>] (nmi_trigger_cpumask_backtrace) from [<c016f061>] (rcu_dump_cpu_stacks+0x7f/0x9c)
Oct  9 22:38:07 mass-test-34 kernel: [<c016f061>] (rcu_dump_cpu_stacks) from [<c016e40d>] (rcu_sched_clock_irq+0x5a5/0x71c)
Oct  9 22:38:07 mass-test-34 kernel: [<c016e40d>] (rcu_sched_clock_irq) from [<c0173e99>] (update_process_times+0x29/0x50)
Oct  9 22:38:07 mass-test-34 kernel: [<c0173e99>] (update_process_times) from [<c0181a47>] (tick_sched_timer+0x37/0x74)
Oct  9 22:38:07 mass-test-34 kernel: [<c0181a47>] (tick_sched_timer) from [<c017486b>] (__hrtimer_run_queues+0xef/0x230)
Oct  9 22:38:07 mass-test-34 kernel: [<c017486b>] (__hrtimer_run_queues) from [<c017520d>] (hrtimer_interrupt+0xd1/0x1fc)
Oct  9 22:38:07 mass-test-34 kernel: [<c017520d>] (hrtimer_interrupt) from [<c06ff233>] (arch_timer_handler_phys+0x27/0x2c)
Oct  9 22:38:07 mass-test-34 kernel: [<c06ff233>] (arch_timer_handler_phys) from [<c0165113>] (handle_percpu_devid_irq+0x57/0x1a0)
Oct  9 22:38:07 mass-test-34 kernel: [<c0165113>] (handle_percpu_devid_irq) from [<c0161065>] (generic_handle_irq+0x1d/0x28)
Oct  9 22:38:07 mass-test-34 kernel: [<c0161065>] (generic_handle_irq) from [<c016151f>] (__handle_domain_irq+0x43/0x84)
Oct  9 22:38:07 mass-test-34 kernel: [<c016151f>] (__handle_domain_irq) from [<c0517211>] (gic_handle_irq+0x39/0x6c)
Oct  9 22:38:07 mass-test-34 kernel: [<c0517211>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94)
Oct  9 22:38:07 mass-test-34 kernel: Exception stack(0xef149f60 to 0xef149fa8)
Oct  9 22:38:07 mass-test-34 kernel: 9f60: 00000000 0df67480 ef6c7034 c01164c1 ffffe000 c0e04fa4 c0e04fec 00000004
Oct  9 22:38:07 mass-test-34 kernel: 9f80: 00000000 c0db99f0 c0ec4b25 00000000 c0f0cf98 ef149fb0 c0107c6f c0107c70
Oct  9 22:38:07 mass-test-34 kernel: 9fa0: 400f0033 ffffffff
Oct  9 22:38:07 mass-test-34 kernel: [<c0101ae5>] (__irq_svc) from [<c0107c70>] (arch_cpu_idle+0x28/0x2c)
Oct  9 22:38:07 mass-test-34 kernel: [<c0107c70>] (arch_cpu_idle) from [<c014126b>] (do_idle+0x143/0x1b0)
Oct  9 22:38:07 mass-test-34 kernel: [<c014126b>] (do_idle) from [<c01414b9>] (cpu_startup_entry+0x19/0x20)
Oct  9 22:38:07 mass-test-34 kernel: [<c01414b9>] (cpu_startup_entry) from [<40102531>] (0x40102531)
Oct  9 22:38:07 mass-test-34 kernel: Sending NMI from CPU 2 to CPUs 3:
Oct  9 22:38:07 mass-test-34 kernel: NMI backtrace for cpu 3
Oct  9 22:38:07 mass-test-34 kernel: CPU: 3 PID: 10 Comm: rcu_sched Tainted: G         C  E     5.4.45-sunxi #20.05.3
Oct  9 22:38:07 mass-test-34 kernel: PC is at _raw_spin_unlock_irqrestore+0x1c/0x20
Oct  9 22:38:07 mass-test-34 kernel: LR is at force_qs_rnp+0xef/0xf8
Oct  9 22:38:07 mass-test-34 kernel: pc : [<c08734bc>]    lr : [<c016c05f>]    psr: 00010033
Oct  9 22:38:07 mass-test-34 kernel: sp : ef143f18  ip : 00000004  fp : 00000008
Oct  9 22:38:07 mass-test-34 kernel: r10: 00000008  r9 : c0e05448  r8 : 00000000
Oct  9 22:38:07 mass-test-34 kernel: r7 : 00000001  r6 : c0dbafc0  r5 : c0e04fa8  r4 : c0e10d00
Oct  9 22:38:07 mass-test-34 kernel: r3 : 0000feee  r2 : 00000008  r1 : 60010013  r0 : c0e10d00
Oct  9 22:38:07 mass-test-34 kernel: Flags: nzcv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment none
Oct  9 22:38:07 mass-test-34 kernel: Control: 50c5387d  Table: 6df7006a  DAC: 00000051
Oct  9 22:38:07 mass-test-34 kernel: [<c085f97b>] (dump_stack) from [<c0863d05>] (nmi_cpu_backtrace+0x91/0x94)
Oct  9 22:38:07 mass-test-34 kernel: [<c0863d05>] (nmi_cpu_backtrace) from [<c010c885>] (handle_IPI+0x49/0x2bc)
Oct  9 22:38:07 mass-test-34 kernel: [<c010c885>] (handle_IPI) from [<c0517241>] (gic_handle_irq+0x69/0x6c)
Oct  9 22:38:07 mass-test-34 kernel: [<c0517241>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94)
Oct  9 22:38:07 mass-test-34 kernel: Exception stack(0xef143ec8 to 0xef143f10)
Oct  9 22:38:07 mass-test-34 kernel: 3ec0:                   c0e10d00 60010013 00000008 0000feee c0e10d00 c0e04fa8
Oct  9 22:38:07 mass-test-34 kernel: 3ee0: c0dbafc0 00000001 00000000 c0e05448 00000008 00000008 00000004 ef143f18
Oct  9 22:38:07 mass-test-34 kernel: 3f00: c016c05f c08734bc 00010033 ffffffff
Oct  9 22:38:07 mass-test-34 kernel: [<c0101ae5>] (__irq_svc) from [<c08734bc>] (_raw_spin_unlock_irqrestore+0x1c/0x20)
Oct  9 22:38:07 mass-test-34 kernel: [<c08734bc>] (_raw_spin_unlock_irqrestore) from [<c016c05f>] (force_qs_rnp+0xef/0xf8)
Oct  9 22:38:07 mass-test-34 kernel: [<c016c05f>] (force_qs_rnp) from [<c016cd65>] (rcu_gp_kthread+0x3b5/0x790)
Oct  9 22:38:07 mass-test-34 kernel: [<c016cd65>] (rcu_gp_kthread) from [<c01360c9>] (kthread+0x109/0x10c)
Oct  9 22:38:07 mass-test-34 system-monitor[606]: Frequency:  480MHz LoadAvg: 0.33 CPU Load:  3% Temp: 59.6°C Cooling: 0/8
Oct  9 22:38:12 mass-test-34 system-monitor[606]: Frequency: 1368MHz LoadAvg: 0.75 CPU Load:  0% Temp: 85.7°C Cooling: 0/8
Oct  9 22:38:17 mass-test-34 system-monitor[606]: Frequency: 1368MHz LoadAvg: 0.75 CPU Load:  1% Temp: 79.1°C Cooling: 0/8
Oct  9 22:38:22 mass-test-34 system-monitor[606]: Frequency: 1368MHz LoadAvg: 0.75 CPU Load:  1% Temp: 78.9°C Cooling: 0/8
Oct  9 22:38:27 mass-test-34 system-monitor[606]: Frequency: 1368MHz LoadAvg: 0.75 CPU Load:  1% Temp: 79.6°C Cooling: 0/8
Oct  9 22:38:32 mass-test-34 system-monitor[606]: Frequency: 1368MHz LoadAvg: 0.75 CPU Load:  4% Temp: 80.3°C Cooling: 0/8
Oct  9 22:39:36 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:39:42 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:39:53 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:40:07 mass-test-34 npm[729]: 9 Oct 22:40:07 - [error] [http request:d0d57557.05fd78] no response from server
Oct  9 22:40:10 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:40:20 mass-test-34 systemd[1]: systemd-udevd.service: Watchdog timeout (limit 3min)!
Oct  9 22:40:20 mass-test-34 systemd[1]: systemd-udevd.service: Killing process 328 (systemd-udevd) with signal SIGABRT.
Oct  9 22:40:24 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:40:31 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:40:50 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:40:57 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:41:15 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:41:24 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:41:34 mass-test-34 dhclient[1306]: DHCPREQUEST for 10.50.180.71 on eth0 to 10.48.0.1 port 67
Oct  9 22:41:38 mass-test-34 npm[729]: 9 Oct 22:41:38 - [error] [http request:d0d57557.05fd78] no response from server
Oct  9 22:17:14 mass-test-34 syslog-ng[578]: syslog-ng starting up; version='3.19.1'
Oct  9 22:17:12 mass-test-34 kernel: Booting Linux on physical CPU 0x0
I changed the swappiness from 100 (=aggressive swapping) to 20.
sysctl -w vm.swappiness=20
System seemed more responsive first but it got stuck again when installing php7.3
I set up the led to blink when accessing the sd card:
echo "mmc0" > /sys/class/leds/orangepi\:red\:status/trigger
It's fully on now.  System only responds to pings. Guess the system is so busy that it doesn't even switch the LED.
My OPi Zero 512MB with
Linux opi-zero 5.9.0-rc7-sunxi #trunk SMP Sat Oct 10 21:41:45 +03 2020 armv7l GNU/Linux
after reboot:
MiB Mem :    492.1 total,    337.5 free,     56.2 used,     98.4 buff/cache
MiB Swap:    246.0 total,    246.0 free,      0.0 used.    419.0 avail Mem
governor for all 4 cpus:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 0 1 2 3
  CPUs which need to have their frequency coordinated by software: 0 1 2 3
  maximum transition latency: 5.44 ms.
  hardware limits: 480 MHz - 1.01 GHz
  available frequency steps: 480 MHz, 648 MHz, 816 MHz, 960 MHz, 1.01 GHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
  current policy: frequency should be within 480 MHz and 1.01 GHz.
                  The governor "ondemand" may decide which speed to use
                  within this range.
  current CPU frequency is 816 MHz (asserted by call to hardware).
  cpufreq stats: 480 MHz:99.80%, 648 MHz:0.05%, 816 MHz:0.07%, 960 MHz:0.03%, 1.01 GHz:0.05%  (15687)
root@opi-zero(192.168.6.99):~# uptime
 15:46:22 up 1 day, 15:25,  1 user,  load average: 0.00, 0.00, 0.00
Next memory exception (page allocation failure) I found while doing rsync...
This time I even disabled ram-log (50MB). ZRAM still @ 50%.
During this failure the system did not freeze. So even if you have 512M, there might still be something broken with page allocation on kernels after 4.9.x!
[  147.806318] rsync: page allocation failure: order:0, mode:0xa20(GFP_ATOMIC), nodemask=(null),cpuset=/,mems_allowed=0
[  147.806351] CPU: 0 PID: 1451 Comm: rsync Not tainted 5.4.8-sunxi #19.11.6
[  147.806355] Hardware name: Allwinner sun8i Family
[  147.806392] [<c010da8d>] (unwind_backtrace) from [<c010a0b1>] (show_stack+0x11/0x14)
[  147.806409] [<c010a0b1>] (show_stack) from [<c093634f>] (dump_stack+0x6f/0x7c)
[  147.806427] [<c093634f>] (dump_stack) from [<c022dfa9>] (warn_alloc+0x99/0x100)
[  147.806440] [<c022dfa9>] (warn_alloc) from [<c022ebf9>] (__alloc_pages_nodemask+0xbe9/0xc9c)
[  147.806451] [<c022ebf9>] (__alloc_pages_nodemask) from [<c022ee1b>] (page_frag_alloc+0xe3/0xec)
[  147.806463] [<c022ee1b>] (page_frag_alloc) from [<c07ec1e1>] (__napi_alloc_skb+0x6d/0xac)
[  147.806481] [<c07ec1e1>] (__napi_alloc_skb) from [<c06e362d>] (stmmac_napi_poll_rx+0x285/0x7d8)
[  147.806498] [<c06e362d>] (stmmac_napi_poll_rx) from [<c07fe703>] (net_rx_action+0xdb/0x2dc)
[  147.806511] [<c07fe703>] (net_rx_action) from [<c01022f7>] (__do_softirq+0xdf/0x288)
[  147.806524] [<c01022f7>] (__do_softirq) from [<c01202c3>] (irq_exit+0x7b/0x90)
[  147.806541] [<c01202c3>] (irq_exit) from [<c01601d3>] (__handle_domain_irq+0x47/0x84)
[  147.806557] [<c01601d3>] (__handle_domain_irq) from [<c05ca51d>] (gic_handle_irq+0x39/0x6c)
[  147.806569] [<c05ca51d>] (gic_handle_irq) from [<c0101ae5>] (__irq_svc+0x65/0x94)
[  147.806574] Exception stack(0xc00bbd78 to 0xc00bbdc0)
[  147.806581] bd60:                                                       cd0fde58 c00bbec8
[  147.806590] bd80: c00bbe10 00002c20 cf0ab3c0 00000002 cd0fde58 cfb3e010 cfb3e037 00000003
[  147.806599] bda0: 00000027 c00bbe78 5841c1d2 c00bbdc8 c025bf6f c0266be0 a0070033 ffffffff
[  147.806614] [<c0101ae5>] (__irq_svc) from [<c0266be0>] (__d_lookup_rcu+0x50/0x114)
[  147.806630] [<c0266be0>] (__d_lookup_rcu) from [<c025bf6f>] (lookup_fast+0x3b/0x1bc)
[  147.806642] [<c025bf6f>] (lookup_fast) from [<c025e195>] (path_openat+0xcd/0xe14)
[  147.806651] [<c025e195>] (path_openat) from [<c025fabf>] (do_filp_open+0x4f/0x90)
[  147.806665] [<c025fabf>] (do_filp_open) from [<c0251081>] (do_sys_open+0x125/0x194)
[  147.806677] [<c0251081>] (do_sys_open) from [<c0101001>] (ret_fast_syscall+0x1/0x62)
[  147.806681] Exception stack(0xc00bbfa8 to 0xc00bbff0)
[  147.806689] bfa0:                   b6ee4000 b6f53968 ffffff9c bebada14 00020000 00000000
[  147.806698] bfc0: b6ee4000 b6f53968 bebada14 00000142 bebada14 00478418 00008000 00466948
[  147.806705] bfe0: 00000142 bebad8c8 b6e7c25d b6e05746
[  147.806709] Mem-Info:
[  147.806726] active_anon:99 inactive_anon:249 isolated_anon:0
                active_file:447 inactive_file:502 isolated_file:0
                slab_reclaimable:3973 slab_unreclaimable:7604
                mapped:592 shmem:80 pagetables:415 bounce:0
                free:32645 free_pcp:56 free_cma:32145
[  147.806739] Node 0 active_anon:396kB inactive_anon:996kB active_file:1788kB inactive_file:2008kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:2368kB dirty:0kB writeback:0kB shmem:320kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[  147.806756] Normal free:130580kB min:5388kB low:5708kB high:6028kB active_anon:368kB inactive_anon:1004kB active_file:1752kB inactive_file:2052kB unevictable:16kB writepending:0kB present:262144kB managed:243968kB mlocked:16kB kernel_stack:1168kB pagetables:1660kB bounce:0kB free_pcp:224kB local_pcp:32kB free_cma:128580kB
[  147.806758] lowmem_reserve[]: 0 0 0
[  147.806766] Normal: 3*4kB (EC) 207*8kB (UEC) 158*16kB (UEC) 41*32kB (UC) 12*64kB (C) 13*128kB (C) 7*256kB (C) 2*512kB (C) 1*1024kB (C) 0*2048kB 29*4096kB (C) = 130564kB
[  147.806801] 1050 total pagecache pages
[  147.806808] 6 pages in swap cache
[  147.806813] Swap cache stats: add 18554, delete 18543, find 779/1883
[  147.806816] Free swap  = 52860kB
[  147.806818] Total swap = 121980kB
[  147.806821] 65536 pages RAM
[  147.806824] 0 pages HighMem/MovableOnly
[  147.806826] 4544 pages reserved
[  147.806829] 32768 pages cma reserved
Hello, I have been using many of these cards as gateways for my product for 2 years and I realized that some stop working and do not return to work alone. We have scritps to restart if communicating stop with our server. But still they are in a state that does not respond to ssh and also does not restart the card. I've tried to connect watchdog on the board, but it's as if it isn't locked, but it doesn't respond to ssh (using the zerotier) or the commands we use. I made a test environment here at home with 5 orange pi zero and 2 with the nanopi neo to test the same software running on the boards and try to replicate the problem. I tried to put the same network structure that are used on clients using 4G modems, but I can hardly replicate the problem. I even made freeze it once but since I was unable to connect through the lan on ssh and therefore I didn't get much information. Now I am connecting one of the cards through uart and I am saving the logs to try to verify what is happening. I tested using a forkbomb to try to force the problem and I realized that it goes a long time without responding but after about 15 minutes the plate will respond again but with the processes finished (I don't know if it is normal behavior), but it is not yet the same problem because ssh answers in this case. I would like any suggestions from you. Thanks.
Linux LLKGAACAAACAKJKL 4.19.62-sunxi #5.92 SMP Wed Jul 31 22:07:23 CEST 2019 armv7l GNU/Linux
Hello guys, I'm back again in this thread. I fixed the CPU freq to 480 MHz or 640MHz (I don't need higher clock speed) and I can report that these boards (now running Armbian 5.9) kernel are stable. Probably the boards get unstable when switching frequency. The approx 10 boards have been running now for at least a few months at a fixed frequency. No problems seen, apart a uSD suffering from bitrot.
The board is even stable using bokki wokki USB chargers as power supply. I did not try fixed frequencies at higher speed than 640MHz.
R.
This is common cause of troubles since stabilising CPU frequency switching is a hard job.
Apparently yes. I never had issues with governers before and I use them quite a lot. For me it first occurred on Orange-Pi Zero (H2) and Orange-Pi-PC (H3). Anyway, these boards are in use again and fortunately do not need to be trashed :-)
R.
