Geralt Posted February 22, 2020 Share Posted February 22, 2020 I have Rock Pi4B and printer 3D Sapphire Pro from Two Trees. In the Armbian I want use print server OctoPrint. Instalation OctoPrint was easly and server works but don't connect to my printer. When I use lsusb i see Bus 004 Device 003: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter. In the list dev/tty* don't shows me mounting port to this device. I try defined udev rules: SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", SYMLINK+="sapphire" or SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", ATTRS{devpath}=="1.2", SYMLINK+="sapphire" but without fine result. I'm rookie in linux and armbian and don't have the idea whot do it to valid define. Please help me. Link to comment Share on other sites More sharing options...
Igor Posted February 22, 2020 Share Posted February 22, 2020 6 minutes ago, Paweł Mętelski said: When I use lsusb i see Bus 004 Device 003: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter. In the list dev/tty* don't shows me mounting port to this device. Please provide logs with: armbianmonitor -u Link to comment Share on other sites More sharing options...
Geralt Posted February 22, 2020 Author Share Posted February 22, 2020 1 hour ago, Igor said: Please provide logs with: armbianmonitor -u Sorry but I don't understand what i must typing. root@rockpi4b:/ # armbianmonitor -u System diagnosis information will now be uploaded to Please post the URL in the forum where you've been asked for. root@rockpi4b:/ # Link to comment Share on other sites More sharing options...
Igor Posted February 22, 2020 Share Posted February 22, 2020 31 minutes ago, Paweł Mętelski said: System diagnosis information will now be uploaded to There was no URL like http://ix.io/2cr7 ? You use official Armbian? I assume you have internet connection on that board? What about dmesg after you plug and unplug that usb device? Link to comment Share on other sites More sharing options...
Geralt Posted February 22, 2020 Author Share Posted February 22, 2020 I was logined on the root. If I change user If I use armbianmoniotor -U it works armbianmonitor.log I instaled armbian from https://dl.radxa.com/rockpi/images/third-party/ After use dmesg in line 657 is information about this device. dmesg.log Maybe i should install different Armbaian? Link to comment Share on other sites More sharing options...
lanefu Posted February 22, 2020 Share Posted February 22, 2020 38 minutes ago, Paweł Mętelski said: I instaled armbian from https://dl.radxa.com/rockpi/images/third-party/ After use dmesg in line 657 is information about this device. thats a very old image. Try downloading an image directly from armbian Link to comment Share on other sites More sharing options...
Geralt Posted March 1, 2020 Author Share Posted March 1, 2020 Hello! I resigned from Armbian because I fought two weeks and not every thing working in this linux. I insaled on my Rock Pi 4 lastes (and others too) Armbian. This is terrible which I had to instaled and changing on my Rock Pi 4. And the end wifi disconnect after about 10 minuts of operation. I had to reboot computer every time. In Debian 9 I instaled octoprnit. In Debian it wasen.t easly either because I had small problem in install python. I'm glad you made it. Link to comment Share on other sites More sharing options...
Igor Posted March 2, 2020 Share Posted March 2, 2020 On 3/1/2020 at 1:18 PM, Geralt said: I resigned from Armbian On 2/23/2020 at 12:17 AM, Geralt said: I instaled armbian from https://dl.radxa.com/rockpi/images/third-party/ That's very old unofficial build made by Radxa people which we don't even try to support. On 3/1/2020 at 1:18 PM, Geralt said: Debian 9 ... where you will have many other problems. But since you are "new to Linux", there is a lot to explore. Link to comment Share on other sites More sharing options...
