Hello!
I'm tryiing to make iBeacon scan service. But can't make Bluetooth work on OPi0+2H5.
I'm using "Armbian_20.02.1_Orangepizeroplus2-h5_bionic_current_5.4.20_minimal.img" as OS, but no hci devices in system after start. I reded many topics from this forum and nothig helps me. Can't start BT :(
Is BlueTooth part work on this board? Can I use it?
I need only "lescan" functional....
Thx, for reply. But I finaly launch BT device.
Next steps:
1. Disable uart1 overlay
2. copyed firmware for ap6212 from last broadcom package into /lib/firmware/bcm....
3. modified ap6212-bluetooth
      - at start add:
        devmem2 0x1f00060 b 1
        echo 10 > /sys/class/gpio/export
        echo out > /sys/class/gpio/gpio10/direction
        echo 0 > /sys/class/gpio/gpio10/value
        echo 1 > /sys/class/gpio/gpio10/value
        sleep 0.1
      - at end add: (else after soft reboot wifi will not work)
        devmem2 0x1f00060 b 0
        sleep 0.1
        echo 10 > /sys/class/gpio/unexport
        sleep 0.1
Next steps:
      - at start add:
        sleep 0.1
        sleep 0.1
        sleep 0.1
Hi , i have a same problem with opiz+2  Mainline kernel 5.4.2x  i  could not find ap6212-bluetooth file (i did it before on legacy kernel), now i have only bluetooth file. I try to edit this file but nothing change. Could you a bit clear how to success with bluetooth.  Thanks
Bluetooth init success :) with Orange pi zero plus 2 Mainline kernel 5.4.28
i solve problem with these steps:
1) install bluetooth support from armbian-config
2) install devmem2 and compile if not installed
wget http://free-electrons.com/pub/mirror/devmem2.c
gcc ./devmem2.c
mv ./a.out /usr/local/bin/devmem2
3) add modules bluetooth and hci_uart to /etc/modules
4) remove bluetooth service (we will add new script)
update-rc.d bluetooth remove
5) remove blutooth init script (editing not worked for me)
rm /etc/init.d/bluetooth
6) copy modified  bluetooth init script file(ap6212) to /etc/init.d/
7) edit permissions
chmod +x /etc/init.d/ap6212
8) enable service script
systemctl enable ap6212
9) reboot
after reboot probably you will see your service succefully running
systemctl status ap6212
● ap6212.service - LSB: Start bluetooth daemons
   Loaded: loaded (/etc/init.d/ap6212; generated)
   Active: active (running) since Tue 2020-04-28 23:31:54 UTC; 38s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 735 ExecStart=/etc/init.d/ap6212 start (code=exited, status=0/SUCCESS)
    Tasks: 1 (limit: 371)
   Memory: 4.2M
   CGroup: /system.slice/ap6212.service
           └─1071 /usr/sbin/bluetoothd
Apr 28 23:31:51 orangepizeroplus2-h5 systemd[1]: Starting LSB: Start bluetooth daemons...
Apr 28 23:31:54 orangepizeroplus2-h5 ap6212[735]: Starting Patch ap6212:/dev/mem opened.
Apr 28 23:31:54 orangepizeroplus2-h5 ap6212[735]: Memory mapped at address 0xffff87107000.
Apr 28 23:31:54 orangepizeroplus2-h5 ap6212[735]: Value at address 0x1F00060 (0xffff87107060): 0x0
Apr 28 23:31:54 orangepizeroplus2-h5 ap6212[735]: Written 0x1; readback 0x1
Apr 28 23:31:54 orangepizeroplus2-h5 ap6212[735]: Starting ap6212: bluetoothd.
Apr 28 23:31:54 orangepizeroplus2-h5 systemd[1]: Started LSB: Start bluetooth daemons.
Apr 28 23:31:54 orangepizeroplus2-h5 bluetoothd[1071]: Bluetooth daemon 5.50
Apr 28 23:31:54 orangepizeroplus2-h5 bluetoothd[1071]: Starting SDP server
Apr 28 23:31:54 orangepizeroplus2-h5 bluetoothd[1071]: Bluetooth management interface 1.14 initialized
Q: what is difference between ap6212 and bluetooth service init?
A:  added gpio  controls
Now you can attach uart with sucess
hciattach /dev/ttyS1 any 115200 flow bdaddr 00:90:4c:c5:12:38
hciconfig hci0 up
i could not change mac adress device always setup with AA:AA:AA:AA:AA:AA
if you can please let me know.
Thanks
Save as ap6212 and copy to /etc/init.d/
#! /bin/sh
### BEGIN INIT INFO
# Provides: ap6212
# Required-Start:    $local_fs $syslog $remote_fs dbus
# Required-Stop:     $local_fs $syslog $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Start bluetooth daemons
### END INIT INFO
# bluez    Bluetooth subsystem starting and stopping
# originally from bluez's scripts/bluetooth.init
# Edd Dumbill <ejad@debian.org>
# LSB 3.0 compilance and enhancements by Filippo Giunchedi <filippo@debian.org>
# Updated for bluez 4.7 by Mario Limonciello <mario_limonciello@dell.com>
# Updated for bluez 5.5 by Nobuhiro Iwamatsu <iwamatsu@debian.org>
# Note: older daemons like dund pand hidd are now shipped inside the
# bluez-compat package
PATH=/sbin:/bin:/usr/sbin:/usr/bin
DESC=ap6212
DAEMON=/usr/sbin/bluetoothd
HCIATTACH=/usr/bin/hciattach
HID2HCI_ENABLED=1
HID2HCI_UNDO=1
SDPTOOL=/usr/bin/sdptool
# If you want to be ignore error of "org.freedesktop.hostname1",
# please enable NOPLUGIN_OPTION.
# NOPLUGIN_OPTION="--noplugin=hostname"
NOPLUGIN_OPTION=""
SSD_OPTIONS="--oknodo --quiet --exec $DAEMON -- $NOPLUGIN_OPTION"
test -f $DAEMON || exit 0
# FIXME: any of the sourced files may fail if/with syntax errors
test -f /etc/default/bluetooth && . /etc/default/bluetooth
test -f /etc/default/rcS && . /etc/default/rcS
. /lib/lsb/init-functions
set -e
# FIXME: this function is possibly a no-op
run_sdptool()
	# declaring IFS local in this function, removes the need to
	# save/restore it
	local IFS o
	test -x $SDPTOOL || return 1
# FIXME: where does SDPTOOL_OPTIONS come from?
	if ! test -z "$SDPTOOL_OPTIONS" ; then
		IFS=";"
		for o in $SDPTOOL_OPTIONS ; do
			#echo "execing $SDPTOOL $o"
			IFS=" "
			if [ "$VERBOSE" != no ]; then
				$SDPTOOL $o
			else
				$SDPTOOL $o >/dev/null 2>&1
			fi
		done
	fi
hci_input()
    log_progress_msg "switching to HID/HCI no longer done in init script, see /usr/share/doc/bluez/NEWS.Debian.gz" || :
fixstart()
  log_daemon_msg "Starting Patch $DESC"
  /usr/local/bin/devmem2 0x1f00060 b 1
  sleep 0.1
fixstop()
	# disable gpio pin, if not wifi not active on soft restart / reboot
  log_daemon_msg "Disable Patch $DESC"
  /usr/local/bin/devmem2 0x1f00060 b 0
  sleep 0.1
  sleep 0.1
alias enable_hci_input=hci_input
alias disable_hci_input=hci_input
alias enable_fix=fixstart
alias disable_fix=fixstop
case $1 in
  start)
  	enable_fix
	log_daemon_msg "Starting $DESC"
	if test "$BLUETOOTH_ENABLED" = 0; then
		log_progress_msg "disabled. see /etc/default/bluetooth"
		log_end_msg 0
		exit 0
	fi
	start-stop-daemon --start --background $SSD_OPTIONS
	log_progress_msg "${DAEMON##*/}"
	run_sdptool || :
	if test "$HID2HCI_ENABLED" = 1; then
		enable_hci_input
	fi
	log_end_msg 0
  stop)
  	disable_fix
	log_daemon_msg "Stopping $DESC"
		log_progress_msg "disabled."
		log_end_msg 0
		exit 0
	fi
	if test "$HID2HCI_UNDO" = 1; then
		disable_hci_input
	fi
	start-stop-daemon --stop $SSD_OPTIONS
	log_progress_msg "${DAEMON}"
	log_end_msg 0
  restart|force-reload)
	$0 stop
	sleep 1
	$0 start
  status)
	status_of_proc "$DAEMON" "$DESC" && exit 0 || exit $?
	N=/etc/init.d/ap6212
	echo "Usage: $N {start|stop|restart|force-reload|status}" >&2
	exit 1
esac
exit 0
# vim:noet
On 4/28/2020 at 8:06 PM, Levent Erenler said:
Bluetooth init success  with Orange pi zero plus 2 Mainline kernel 5.4.28
I've followed the steps here on mainline kernel 5.8.5. $systemctl status ap6212 looks similar to yours. However $hcitool dev cannot find devices. I can't find my Bluetooth mac address.
Any thoughts or help would be great!
Here is my actual working init script for bluetooth.
It works on Armbian Linux 6.6.36-current-sunxi64 v23.8.1 Bookworm
board is Orange Pi Zero Plus 2 H5
no additional dtb overlay is needed, no extra modules
just install bluetooth support and devmem2 package - https://ubuntu.pkgs.org/22.04/ubuntu-universe-arm64/devmem2_0.0-0ubuntu2_arm64.deb.html
then enable script via 'systemctl enable ap6212-bluetooth'
and check /etc/default/ap6212 file ...
ap6212-bluetooth
Edited by JRD McLAREN
