Armbian for Amlogic S912
1 hour ago, icusu said:
Hello all!  I have successfully gotten @balbes150's debian server image installed onto a few H96's that I am setting up for compiling.  I am hoping to reclaim some of the memory that systemd is using.  Specifically, I intend to completely disable hdmi output as well as the reserved memory for the mali gpu.  Does anyone have a guide I could read for uboot or something else that would allow me to accomplish this?  I'm not looking for someone to just fix the problem for me, but a pointer in the right direction would be quite nice. :)  Either way, thanks go out to balbes150 and others in these tv box threads which have gotten me to this point.
Here was discussed a similar question (to increase the memory by turning off the redundant memory).
http://forum.khadas.com/
[    6.531439@3] hdmitx: update physcial size: 16 9
[    6.536003@3] config: hdmitx: unknown cmd: 0x14000000
[   27.556171@3] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   27.577311@6]        3-...: (1 GPs behind) idle=4f9/140000000000000/0 softirq=341/342 fqs=2593
[   27.585638@6]        (detected by 6, t=5259 jiffies, g=-78, c=-79, q=51)
[   27.593029@6] Task dump for CPU 3:
[   27.598885@6] hdmi_init.sh    R  running task        0  2371      1 0x00000002
[   27.606987@6] Call trace:
[   27.612905@6] [<ffffff8009086434>] __switch_to+0x94/0xa8
[   27.618911@6] [<0000000000000001>] 0x1
[   62.476130@1] fb: mem_free_work, free memory: addr:6af000
[   90.576173@1] INFO: rcu_preempt detected stalls on CPUs/tasks:
[   90.592272@5]        3-...: (1 GPs behind) idle=4f9/140000000000000/0 softirq=341/342 fqs=10404
[   90.601310@5]        (detected by 5, t=21014 jiffies, g=-78, c=-79, q=66)
[   90.609069@5] Task dump for CPU 3:
[   90.615263@5] hdmi_init.sh    R  running task        0  2371      1 0x00000002
[   90.623679@5] Call trace:
[   90.629876@5] [<ffffff8009086434>] __switch_to+0x94/0xa8
[   90.636119@5] [<0000000000000001>] 0x1
[  153.600178@5] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  153.616626@7]        3-...: (1 GPs behind) idle=4f9/140000000000000/0 softirq=341/342 fqs=18194
[  153.625694@7]        (detected by 7, t=36768 jiffies, g=-78, c=-79, q=66)
[  153.633622@7] Task dump for CPU 3:
[  153.639999@7] hdmi_init.sh    R  running task        0  2371      1 0x00000002
[  153.648565@7] Call trace:
[  153.654867@7] [<ffffff8009086434>] __switch_to+0x94/0xa8
[  153.661227@7] [<0000000000000001>] 0x1
[  167.944416@0] random: crng init done
[  216.624164@0] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  216.645877@6]        3-...: (1 GPs behind) idle=4f9/140000000000000/0 softirq=341/342 fqs=25995
[  216.654917@6]        (detected by 6, t=52528 jiffies, g=-78, c=-79, q=66)
[  216.662897@6] Task dump for CPU 3:
[  216.669308@6] hdmi_init.sh    R  running task        0  2371      1 0x00000002
[  216.677892@6] Call trace:
[  216.684205@6] [<ffffff8009086434>] __switch_to+0x94/0xa8
[  216.690568@6] [<0000000000000001>] 0x1
[  242.696550@4] INFO: task kworker/1:1:1238 blocked for more than 120 seconds.
[  242.715772@4]       Not tainted 4.9.40 #1
[  242.722104@4] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[  242.730956@4] kworker/1:1     D    0  1238      2 0x00000000
[  242.740331@4] Workqueue: events aml_tvout_mode_work
[  242.748435@4] Call trace:
[  242.754944@4] [<ffffff8009086434>] __switch_to+0x94/0xa8
[  242.761530@4] [<ffffff8009bf2cc4>] __schedule+0x21c/0x748
[  242.768131@4] [<ffffff8009bf3230>] schedule+0x40/0xa8
[  242.774691@4] [<ffffff8009bf3724>] schedule_preempt_disabled+0x1c/0x30
[  242.782158@4] [<ffffff8009bf4ff4>] __mutex_lock_slowpath+0xac/0x188
[  242.789341@4] [<ffffff8009bf5138>] mutex_lock+0x68/0x80
[  242.795992@4] [<ffffff8009821e40>] validate_vmode+0x30/0x90
[  242.802614@4] [<ffffff8009822ae8>] refresh_tvout_mode+0x58/0xf0
[  242.809496@4] [<ffffff8009822e20>] aml_tvout_mode_work+0x30/0xa8
[  242.816486@4] [<ffffff80090bbf58>] process_one_work+0x1e0/0x498
[  242.823435@4] [<ffffff80090bc260>] worker_thread+0x50/0x4a8
[  242.830124@4] [<ffffff80090c2cd8>] kthread+0xf8/0x110
[  242.836821@4] [<ffffff8009083680>] ret_from_fork+0x10/0x50
[  279.648172@4] INFO: rcu_preempt detected stalls on CPUs/tasks:
[  279.670232@6]        3-...: (1 GPs behind) idle=4f9/140000000000000/0 softirq=341/342 fqs=33795
[  279.679620@6]        (detected by 6, t=68284 jiffies, g=-78, c=-79, q=66)
[  279.687897@6] Task dump for CPU 3:
[  279.694527@6] hdmi_init.sh    R  running task        0  2371      1 0x00000002
[  279.703470@6] Call trace:
[  279.710197@6] [<ffffff8009086434>] __switch_to+0x94/0xa8
[  279.717022@6] [<0000000000000001>] 0x1
Is it perhaps because I'm running headless with a screen?
Gathered from the latest commit image stretch 4.9.40. Recorded on the USB flash drive, added the dtb (kvim2_multios.dtb). Has launched on the VIM2 Max. Connected only to a wired network, a USB flash drive with the system and USB power. Joined VIM2 via SSH from the PC and performed the initial configuration. After a reboot everything works. Try to run this image. Maybe when you build something made not so.
https://yadi.sk/d/5zSm31vQ3S3ijn
Well I'm puzzled, but maybe I'm doing it the wrong way coz' your image @balbes150 also doesn't boot with the same hang/error...
I'm doing the same as I have done when installing Armbian on my Khadas VIM Pros:
- Android on the emmc,
- Flashing aml_autoscript.zip with System update application under android,
- Burning the image on sdcard with Etcher,
- Sdcard in sd-slot,
- Power on
=> Boot Armbian from the sdcard
So have these steps changed for the VIM2 (or perhaps for all S905x/S912) ???
Thanks.
You forgot to add the correct dtb file (copy from the /dtb directory to the root of the first section and rename to "dtb.img").
Sorry I forget to list this step ;) but I have done it. For a matter of fact, I have tried all the dtbs for VIM2 with the same result...
I have this image running on VIM1 (s905x) and VIM2 (s912). What u-boot is installed ? To run the kernel 4.9.40 on VIM1 (s905x) need a new u-boot. I use my version of u-boot with built-in multi-boot.
To run from external media, you can use any option of the dtb. The correct option dtb important to install the system in eMMC. Then you need to use strictly correct dtb.
Well I've tried your image and mine on one of my VIM Pro: It boots without any issue (with the right dtb of course ^_^). I might say the images are not the cause of the hang on my VIM2 Max
Perhaps a stupid question and not related to my issue: Which revision of the VIM2 Max do you have? Mine is a V1.2 201707. I have spotted on Google V1.0 and V1.1 for the VIM2 and I don't know what might be the differences...
1. Try updating the multi-boot using only the image Armbian. To capture the image, copy and rename the dtb file, to run Android, to run multi-boot activation.
2. What firmware version is installed in the eMMC of your VIM2 ?
On 21/12/2016 at 3:30 PM, lvmc said:
WiFi is now working on GT1.
1. Download & Copy AP6255 WiFi drivers extracted from Beelink's Android image:
Thanks for the instrutions - they did help me very much with the AP6330 onboard WiFi of the Sunvell T95K Pro
(S912 device = q201_6255):
Manually:
modprobe cfg80211
modprobe dhd firmware_path=/lib/firmware/brcm/fw_bcm40183b2.bin nvram_path=/lib/firmware/brcm/nvram_ap6330.txt
On boot:
# /etc/modules
cfg80211
dhd
# /etc/modprobe.d/options.conf
options dhd firmware_path=/lib/firmware/brcm/fw_bcm40183b2.bin nvram_path=/lib/firmware/brcm/nvram_ap6330.txt
lsmod:
root@sunvell-t95kpro:~# lsmod
brcmfmac              171742  0
brcmutil                5091  1 brcmfmac
joydev                 10336  0
dhd                   817295  0
cfg80211              415017  2 dhd,brcmfmac
aml_nftl_dev           95108  0
Now the WiFi does run very stable and without any big latency :)
Before I had used an external USB-WiFi Dongle from Edimax where I had a high latency :(
(and I did disable power-management in the /etc/network/interfaces)
Manually:
modprobe cfg80211
On boot:
# /etc/modules
cfg80211
dhd
lsmod:
brcmfmac              171742  0
joydev                 10336  0
dhd                   817295  0
Link off file wifi!
On 12/02/2017 at 1:08 PM, Quintus23M said:
Has anybody tried to build and run a mainline Linux kernel on a S912 device?
I do have a Beelink GT1 and would like to use a 4.9.x kernel, no graphics required for my headless server, just ethernet and maybe wifi for later. Currently I was able to boot the GT1 with an Armbian image from @balbes150, but this image has only a 3.14.29 kernel.
Any advice and pointers are really appreciated.
My friend, did you run the 4.9.x kernel on Beelink GT1? I'm trying to run more than not boot.
Asked balbes150 same question, but about Beelink GT1 Ultimate. It's only possible to rub 3.xx kernel on this device.
A new u-boot is needed to run kernel 4.9. I checked on my Tronsmart Vega S96 (S912) - with the dtb from VIM2 and the new u-boot system working with the 4.9 core.
Hardware: AlfaWise H96 Pro+
Armbian Version: Armbian_5.37_S9xxx_Ubuntu_xenial_4.9.40_server_20180204.img.xz
SOC: Amlogic S912
First thanks to all the people evolved in this great project :)
This is my first post here, I'm a newer armbian user :)
I'm using it has a headless server for my projects with docker and mongodb and my spring boot/aurelia framework projects,
and it works like a real server, without lags at all, simple awesome , my main objective is put my solutions in a economic/cheaper server :)
I already do that in raspberry pi 3, but I miss one important part that is use it has a Access Point with HostAPD like in RPI
Next the problem:
I Have problems configure Wifi card,
I cant use Wifi at all, and dont have wlan0
mario@amlogic:~$ dmesg | grep wlan0
mario@amlogic:~$ dmesg | grep wifi
[ 1.024140] wifi: power_on_pin_OD = 0;
[ 1.024254] aml_wifi wifi: [wifi_dev_probe] no power_on_pin2
[ 1.024460] aml_wifi wifi: [pwm_double_channel_conf_dt] wifi pwm dt ok
[ 1.024604] aml_wifi wifi: [pwm_double_channel_conf] wifi pwm conf ok
[ 1.024737] aml_wifi wifi: [wifi_dev_probe] interrupt_pin=97
[ 1.024855] aml_wifi wifi: [wifi_dev_probe] irq_num=0, irq_trigger_type=1
[ 1.024992] aml_wifi wifi: [wifi_dev_probe] power_on_pin=96
[ 1.025108] aml_wifi wifi: [wifi_dev_probe] clock_32k_pin=0
[ 1.025595] aml_wifi wifi: [wifi_setup_dt] wifi_setup_dt
[ 1.025757] aml_wifi wifi: [wifi_setup_dt] irq num is:(126)
[ 1.025874] aml_wifi wifi: [wifi_setup_dt] interrupt_pin(97)
[ 1.026007] aml_wifi wifi: [wifi_setup_dt] power_on_pin(96)
[ 4.195633] efusekeyname: mac_wifi  offset: 24 size: 12
I try everything that I remember, read a lot here in this post about wifi,
but I dont even know if my alfawise is working with wifi
I try all the DTBs from this armbian release one by one,
with modprobe, but nothing
  • gxl_p230_2g.dtb
  • gxl_p231_1g.dtb
  • gxl_p231_2g.dtb
  • gxl_p400_2g.dtb
  • gxl_p401_2g.dtb
  • gxm_p200_2g.dtb
  • kvim2_android.dtb
  • kvim2_linux.dtb
  • kvim2_multios.dtb
  • kvim2_volumio.dtb
  • kvim_android.dtb
  • kvim_linux.dtb
I try to follow this post https://forum.armbian.com/topic/2138-armbian-for-amlogic-s912/?page=19&tab=comments#comment-49228
added wifi_dummy to /etc/modules
I even get driver from android firmware SCV4-Test1-Blue-PCB-H96ProPlus.zip
(the link to cfg80211 driver from above post is broken)
copied to /lib/modules/4.9.40/kernel/drivers/net/wireless/
and try to use modprobe on it like explained in above post
sudo modprobe cfg80211
modprobe dhd
modprobe: ERROR: could not insert 'dhd': No such device
but It never works, It seems I need help......i'm a bit lost now, without any wise idea of how I can configure wifi in this device
Or maybe I'm doing something stupid, or don't even know how to do it (I bet on this horse LOL)
The other problem is I cant backup my /dev/mmcblk0
always have the error `error reading '/dev/mmcblk0': Input/output error`
try many times, even try to use hard-disk and samba share but the problem is reading the mmcblk0
it always fail!
I try to backup, because I like to install armbian on mmcblk0
I dont need android, maybe in a near future, or when I like to sell it
$ sudo ddbr
DO YOU WANT TO BACKUP OR RESTORE ?
BACKUP=(b) RESTORE=(r) b
AVAILABLE DEVICES: mmcblk0 sda1 sda2
YOU ARE RUNNING xenial FROM sda2
INTERNAL EMMC IS: mmcblk0 SIZE:  30535680
ROOT (sda2) FREE SPACE IS:   74266064
DO YOU WANT COMPRESSION ?
YES=(y) NO=(n) n
SAVING mmcblk0 TO /ddbr/Amlogic-emmc.img...
dd: error reading '/dev/mmcblk0': Input/output error
Thanks to all, for the excellent distro
Edited by koakh
Prettify Post
1 hour ago, balbes150 said:
Use the version of the images with kernel 3.14.
Thanks @balbes150
I Will try "Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_server_20171226.img.xz" and respond ASAP
Once again Thanks
25 minutes ago, balbes150 said:
I recommend using 5.41 (mali6)
Thanks @balage
Can we send me the link or the filename of 5.41 mali server?
Thanks
edited: I think I found it here (Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_server_20180225.img.xz)
can You confirm that is the advised version
Thanks (Again)
Hello
If i choose to install ubuntu , wich version can i best to choose for kodi , plex and ipvanisch ?
Mate or Server , i have the Beelink GT1 Ultimate 3gb/32gb .
Root and 1234 is the standard ? for inlog (armbian 5.41)
Friendly Regards , Richard
10 hours ago, balbes150 said:
yes
Thanks @balbes150
After Installed Armbian_5.41_S9xxx_Ubuntu_xenial_3.14.29_server_20180225
Now I have wlan0 but I cant use it :(
$ cat /etc/modules
#aml_nftl_dev
#wifi_dummy
cfg80211
dhd
$ lsmod
wlan                 3435325  0
xt_addrtype             2923  2
zram                    8953  8
ch341                   5434  0
rtc_hym8563             5568  0
cfg80211              415017  1 wlan
 $ sudo lshw
  *-network:1
       description: Wireless interface
       physical id: 4
       logical name: wlan0
       serial: 84:5d:d7:4a:32:02
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=ar6k_wlan driverversion=3.14.29 firmware=N/A link=no multicast=yes wireless=Qcom:802.11n
$ wlan0     Link encap:Ethernet  HWaddr 84:5d:d7:4a:32:02
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
nmtui can't scan networks/activate networks
I try manually play with device with
$ sudo iw dev
phy#0
    Interface p2p0
        ifindex 7
        wdev 0x2
        addr 86:5d:d7:cf:32:02
        type P2P-device
    Interface wlan0
        ifindex 6
        wdev 0x1
        type managed
$ iw wlan0 link
$ sudo ip link set wlan0 up
$ sudo ip link show wlan0
6: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DORMANT group default qlen 1000
    link/ether 84:5d:d7:4a:32:02 brd ff:ff:ff:ff:ff:ff
$ sudo iw wlan0 link
$ sudo iw wlan0 scan
(wait a 40sec and output nothing, it cant find any network, like nmtui )
seems like im playing with a wifi_dummy
$ dmesg | grep wifi
[    2.342807] aml_wifi wifi.35: [wifi_dev_probe] no power_on_pin2
[    2.342823] aml_wifi wifi.35: [wifi_dev_probe] set pwm as 32k output
[    2.342882] aml_wifi wifi.35: [wifi_dev_probe] dhd_static_buf setup
[    2.342977] aml_wifi wifi.35: [wifi_dev_probe] interrupt_pin=241
[    2.342991] aml_wifi wifi.35: [wifi_dev_probe] irq_num=100, irq_trigger_type=1
[    2.343006] aml_wifi wifi.35: [wifi_dev_probe] power_on_pin=240
[    2.343019] aml_wifi wifi.35: [wifi_dev_probe] clock_32k_pin=0
[    2.343354] aml_wifi wifi.35: [wifi_setup_dt] wifi_setup_dt
[    2.343399] aml_wifi wifi.35: [wifi_setup_dt] interrupt_pin(241)
[    2.343421] aml_wifi wifi.35: [wifi_setup_dt] power_on_pin(240)
[    6.383600] efusekeyname:        mac_wifi    offset:    12    size:     6
[  207.567537] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  207.870725] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Enable! 240
[  208.458580] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  208.658625] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Enable! 240
[  210.348703] dhd_wifi_platform_load: Enter
[  210.348750] wifi_platform_set_power = 1
[  210.348800] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  210.548955] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Enable! 240
[  211.050686] wifi_platform_bus_enumerate device present 1
[  213.126880] wifi_platform_set_power = 0
[  213.126905] wifi_platform_bus_enumerate device present 0
[  213.126953] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  213.327004] wifi_platform_set_power = 1
[  213.327035] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  213.527065] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Enable! 240
[  214.030677] wifi_platform_bus_enumerate device present 1
[  216.106908] wifi_platform_set_power = 0
[  216.106933] wifi_platform_bus_enumerate device present 0
[  216.106981] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  216.307030] wifi_platform_set_power = 1
[  216.307064] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Disable! 240
[  216.507115] aml_wifi wifi.35: [extern_wifi_set_enable] WIFI  Enable! 240
$ sudo modprobe cfg80211
$ sudo modprobe dhd
Maybe someone can help, I try hard, but it seems without some help I'm trapped here, cant use WiFi card :(
update: I dont have tried all the DTBs......only when I have a monitor and keyboard connected to box, currently my only have ssh
Thanks to all
modprobe qca9377
or
modprobe wlan
Thanks it work até first line with
modprobe Alan
Now I ser the networks in nmtui ;)
Thanks @balbes150 you spare me a few suffering hours.
Its so easy when we have the knowledge, and so hard when we are try and fail to learn ;)
Once again you are the man
PS. Sorry my bad English. Its not my native language....
5 hours ago, balbes150 said:
modprobe qca9377
or
modprobe wlan
Hello Again
I use "modprobe wlan" and it "load" module and I can use wifi :) (Thanks Again)
but, after reboot, I must always do the same "modprobe wlan"
I put wlan on /etc/modules but it wont "load" wlan on boot
It only works with above combination, and launch "modprobe wlan" after boot/login
cat /etc/modules
aml_nftl_dev
#wifi_dummy
cfg80211
dhd
# this is note loaded
wlan
Any idea is appreciated, thanks
Update:
$ dmesg | grep wlan
$ dmesg | grep wlan
[    2.352247] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem: WIFI MEM Allocated
[   13.191319] ======== dhd_wlan_init_plat_data ========
[   13.222553] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   13.253521] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   13.263757] dhd_wlan_init_gpio: host_oob_irq: 100
[   13.271307] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   15.594082] wlan: loading driver v4.5.20.037
[   27.130863] ======== dhd_wlan_deinit_plat_data ========
[   27.141717] ======== dhd_wlan_init_plat_data ========
[   27.146895] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   27.151961] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   27.157505] dhd_wlan_init_gpio: host_oob_irq: 100
[   27.162239] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   35.674650] wlan: driver load failure
[   40.973680] ======== dhd_wlan_deinit_plat_data ========
[   40.984504] ======== dhd_wlan_init_plat_data ========
[   40.989626] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   40.994754] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   41.000063] dhd_wlan_init_gpio: host_oob_irq: 100
[   41.004927] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   55.385551] ======== dhd_wlan_deinit_plat_data ========
[   55.399437] ======== dhd_wlan_init_plat_data ========
[   55.406001] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   55.412421] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   55.418709] dhd_wlan_init_gpio: host_oob_irq: 100
[   55.424961] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   69.631380] ======== dhd_wlan_deinit_plat_data ========
[   69.780403] ======== dhd_wlan_init_plat_data ========
[   69.794767] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   69.809041] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   69.823197] dhd_wlan_init_gpio: host_oob_irq: 100
[   69.837174] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   70.323227] wlan: loading driver v4.5.20.037
[   83.902800] ======== dhd_wlan_deinit_plat_data ========
[   83.916720] ======== dhd_wlan_init_plat_data ========
[   83.923267] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   83.929730] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   83.929734] dhd_wlan_init_gpio: host_oob_irq: 100
[   83.929736] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[   90.734570] wlan: driver load failure
[   96.761044] ======== dhd_wlan_deinit_plat_data ========
[   96.761083] ======== dhd_wlan_init_plat_data ========
[   96.761087] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[   96.761091] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[   96.761095] dhd_wlan_init_gpio: host_oob_irq: 100
[   96.761099] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[  108.841384] ======== dhd_wlan_deinit_plat_data ========
[  108.841422] ======== dhd_wlan_init_plat_data ========
[  108.841426] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[  108.841430] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[  108.841434] dhd_wlan_init_gpio: host_oob_irq: 100
[  108.841438] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[  120.961724] ======== dhd_wlan_deinit_plat_data ========
