cibomato 8 Posted July 18, 2015 Share Posted July 18, 2015 Hi Igor, I've read about your latest image and I'd like to obtain the stability fixes you've made. Is there a way to get this without doing a whole fresh installation? Idoubt that an aptitude upgrade will bring me these changes!? Thanks and best regards, Jochen Link to post Share on other sites More sharing options...
0 Igor 2458 Posted July 18, 2015 Share Posted July 18, 2015 Check FAQ, section kernel update. The only note here is that you also need to update u-boot since most likely there is a problem. Download my kernel TAR pack, uncompress and install with: dpkg -i FILENAME Soon this part will be solvable via apt-get update / upgrade. I am working on it. Link to post Share on other sites More sharing options...
0 cibomato 8 Posted July 18, 2015 Author Share Posted July 18, 2015 Thanks for fast reply! Just to understand this: are you 'stability fixes' included in the kernel upgrade? Link to post Share on other sites More sharing options...
0 Igor 2458 Posted July 18, 2015 Share Posted July 18, 2015 yes they are. Boards are now stable after 2-3 weeks of burn in test. Link to post Share on other sites More sharing options...
0 cibomato 8 Posted July 18, 2015 Author Share Posted July 18, 2015 Worked! Although the cubie ran very stable over the last few weeks with 4.0.5 already. Thank you! Link to post Share on other sites More sharing options...
0 Remy 0 Posted July 21, 2015 Share Posted July 21, 2015 hi Igor, very great work, i have the same problem but i'm using banana router ( lamobo r1) how to update to your latest version without reinstalling all from zero ? thank you a lot Remy Link to post Share on other sites More sharing options...
0 Igor 2458 Posted July 22, 2015 Share Posted July 22, 2015 Thanks. Just follow the guide in FAQ. It's simple. Link to post Share on other sites More sharing options...
0 Remy 0 Posted July 24, 2015 Share Posted July 24, 2015 Sorry, may be a misunderstand, i mean how to upgrade from previous version of debia wheezy, to your latest, not to jessy ( omv don't work with this one) thank you Link to post Share on other sites More sharing options...
0 Igor 2458 Posted July 25, 2015 Share Posted July 25, 2015 Aha, this is missing from FAQ.Download latest root filesystem and install with dpkg -i This is the latest at the moment: http://mirror.igorpecovnik.com/rootfs/linux-wheezy-root-lamobo-r1_3.2_armhf.deb Kernel upgrade is also advisable. That's described in FAQ. If you are on 3.4.10 upgrade to latest 3.4.x, if you are on 3.19 or higher upgrade to latest 4.x .. You can also upgrade from 3.4 to 4.x but make sure you know about the limitations and changes. Link to post Share on other sites More sharing options...
0 andrewufrank 1 Posted August 4, 2015 Share Posted August 4, 2015 i followed the instructions in the FAQ to upgrade the kernel (to 4.0.5). from 3.4. in the archive i found also a new firmware image and linux-libc-dev. the faq does not indicte that they should be installed - is this correct? why? -- after the installation, the boot starts and hangs with "starting kernel". it would be helpful in the FAQ if you could suggest how to fix things if something goes wrong. the update i did on the ssd and thus i thought i could just start with the old system i had on the sd memory card. but chaning the boot.scr there did not resolve the problem. it still hangs with 'starting kernel'. what can be done? thank you for your good work! Link to post Share on other sites More sharing options...
0 Igor 2458 Posted August 5, 2015 Share Posted August 5, 2015 Firmware upgrade is not needed because it's the same. Libc also not. Technically you only need to change kernel, U-boot is highly recommended since you can only boot up with one CPU if you don't change u-boot. This part might be fixed with latest u-boot but with the one available for download you need to do. If you want to boot old kernel you need to remove file .next in /boot That's the trick to mention - but it's seen from boot.cmd ... What else can be wrong? 4.0.5 ... If you are booting from SATA it's possible that it's not supported in this kernel yet. Rather use more recent kernel. That one boots from SATA for sure. Next image is coming with apt-get upgrade for kernel. Link to post Share on other sites More sharing options...
0 disconnect 5 Posted August 6, 2015 Share Posted August 6, 2015 Next image is coming with apt-get upgrade for kernel. How can upgrade from v4.0 to the newest v4.1 (3.4.108 kernel)? There are no kernel, uboot files for CB2 only for CT. Link to post Share on other sites More sharing options...
0 Igor 2458 Posted August 7, 2015 Share Posted August 7, 2015 They share the same kernel. Wrote on mobile phone Link to post Share on other sites More sharing options...
0 disconnect 5 Posted August 7, 2015 Share Posted August 7, 2015 They share the same kernel. Wrote on mobile phone Is the deb under the red R button is needed? Link to post Share on other sites More sharing options...
Question
cibomato 8
Hi Igor,
Jochen
Link to post
13 answers to this question
