Looking to find out why the Orange Pi OS Build isn't finding this file.
 Tried on two separate Linux 18.04 OS and neither has this file.  When running Build_OrangePi.sh, right after entering the initial password, it drops out and claims the file lib32z1-dev not locate able.   The only thing I can think is I need to install the SDK to build the OrangePi OS for this?
Trying to do this from the Orange Pi Git Hub.
https://github.com/orangepi-xunlong/OrangePi_Build
 Thanks for any help.
Armbian has nothing to do with Xulung's build repository. You should state your issue at their forums.
  Werner,
  Okay, Thanks.   I guess you are saying this file isn't part of any regualar SDK and it's provided by Xulong.  I guess it's not a Linux file then.
 But it's referenced in so many other OS's..  I think ARMBIAN has left this file out of the OS.  It surely seems clear that this is an ARMBIAN problem.
https://packages.debian.org/jessie/lib32z1-dev
https://packages.ubuntu.com/xenial/lib32z1-dev
 I'm not going to list all of them.
It seems it's a unzip file.  I guess ARMBIAN doesn't include these in their database.
 Hey Thanks for the Help! So friendly here.
Not at all ! You are trying to build something that is not own by Armbian ...
BTW, Jessie is now End-of-Life ...
On 5/6/2020 at 12:22 PM, Narly9999 said:
lib32z1-dev
Free generic support, Google, 1st hit = explanation what this file is, will tell you more than we can:
https://packages.debian.org/sid/lib32z1-dev
There are thousands of libraries out there. To this moment, I never heard for this library.
Thanks Igor; Your broad intelligence prowess is legendary!  ;-)
Namaste Great one. 🙏
