I tried many time with different version of armbian o.s. for orange pi zero plus, but operative system dont want to start....
Work only old version DietPi ...
With armbian o.s. , at start, I see orange e green ethernet led ON fixed and nothing other....
Why ?
1. Provide quality information for us to work with.
2. Use the forum search to find a solution. Make sure you've read the Armbian documentation.
3. Include Logs: armbianmonitor -u (paste URL in your forum post)
4. If your board does not boot, provide a log from serial console or take a screenshot
  On 5/31/2020 at 9:13 AM, Igor said:
- which image exactly: Armbian_20.02.1_Orangepizeroplus_stretch_current_5.4.20, Armbian_20.02.1_Orangepizeroplus_buster_current_5.4.20, Armbian_20.02.1_Orangepizeroplus_bionic_current_5.4.20
- are you sure you are using correct image for this board? yes....Orange Zero Pi Plus
- do you have a serial console? I Have a USB/TTL... I dont tried
- dietpi is a script that only rebrands armbian.
- kernel version is essential to say anything.  5.40.20
Board runs fine for us: (No. 21)
https://dl.armbian.com/_test-reports/2020-05-21_22.45.09.html
Expand
  On 5/31/2020 at 10:34 AM, c.man said:
I dont tried
Expand
Your best chance to know whats going on inside is this thing so go ahead and use it.
- which image exactly:  Armbian_20.02.1_Orangepizeroplus_buster_current_5.4.20
Expand
I downloaded
https://dl.armbian.com/orangepizeroplus/archive/Armbian_20.02.1_Orangepizeroplus_buster_current_5.4.20.7z
unzipped it with 7Zip and flashed the .img with Ether to the card and it does boot and work on my
OPi Zero Plus (H5):
System diagnosis information has been uploaded to http://ix.io/2nVF
login as: root
root@192.168.6.98's password:
  ___  ____  _   _____                ____  _
 / _ \|  _ \(_) |__  /___ _ __ ___   |  _ \| |_   _ ___
| | | | |_) | |   / // _ \ '__/ _ \  | |_) | | | | / __|
| |_| |  __/| |  / /|  __/ | | (_) | |  __/| | |_| \__ \
 \___/|_|   |_| /____\___|_|  \___/  |_|   |_|\__,_|___/
Welcome to Armbian buster with Linux 5.4.20-sunxi64
package bsp-kernel[20.02.1] u-boot[20.02.1] dtb   [20.02.1]
firmware          [20.02.1] config[20.02.1] branch[current]
System load:   0.19 0.06 0.02   Up time:       1 min
Memory usage:  18 % of 479MB    IP:            192.168.6.98
CPU temp:      59°C
Usage of /:    17% of 7.2G
Last login: Sun May 31 16:29:52 2020 from 192.168.6.17
  On 5/31/2020 at 1:42 PM, guidol said:
I downloaded
OPi Zero Plus (H5):
Expand
ok. could it be SD Card ? I use a kingstone Industrial like this class 10.
Or could it be a power problem ? I usa a mobile charger with 5V 2 A
Expand
Images shall only be written with imaging tools that validate burning results.  This saves you from corrupted SD card contents.
Approved Tools:
  • USBImager a lightweight cross-platform imaging tool
  • Balena Etcher an electron / node.js based cross-platform imaging tool (may contain spyware)
Solved !
My sbc Is a Orange Pi zero, not Orange Pi zero plus...with correct ISO imagefile, o.s. now work !
Inviato dal mio Redmi 8 utilizzando Tapatalk
