dolphs Posted August 27, 2020 Author Posted August 27, 2020 If 5.9 will be LTS, is that confirmed officially undeva @Werner? I'd say let's head for 5.9 in DEV then asap. @5kft Also please note from 5.9-rc2 DVFS is incorporated for H5 chipsets ( like 5.8 had for H6 ) 4 hours ago, 5kft said: I think there are still some patch issues with the H6...? Hmm yes , eg. build with EXTRAWIFI=no and you will find out some issues there. Speaking of building a kernel with custom .config, If 'd create config file in " ~/armbian/userpatches/kernel/sunxi-dev " ( as no sunxi64-dev is available ). Read some here but appears I'm too tired to understand atm, so please hint me to proper path. thx!
5kft Posted August 27, 2020 Posted August 27, 2020 5 hours ago, dolphs said: If 5.9 will be LTS, is that confirmed officially undeva @Werner? I'd say let's head for 5.9 in DEV then asap. @5kft Also please note from 5.9-rc2 DVFS is incorporated for H5 chipsets ( like 5.8 had for H6 ) I haven't seen anything announced that 5.9 is LTS...where did you see this @Werner ? BTW, I messed around with this a bit (had to patch a few things), and a super quick test build looks promising: root@192.168.1.151's password: _ _ ____ _ _ _ | \ | | _ \(_) / \ (_)_ __ | \| | |_) | | / _ \ | | '__| | |\ | __/| | / ___ \| | | |_| \_|_| |_| /_/ \_\_|_| Welcome to Armbian 20.08.0-trunk Buster with Linux 5.9.0-rc2-sunxi No end-user support: built from trunk System load: 1.05 0.32 0.11 Up time: 0 min Memory usage: 14 % of 492MB IP: 192.168.1.151 CPU temp: 41°C Usage of /: 23% of 7.2G Last login: Fri Aug 21 15:28:22 2020 root@air:~# cat /proc/version Linux version 5.9.0-rc2-sunxi (root@8b25ad840cf6) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #trunk SMP Thu Aug 27 22:27:48 UTC 2020 root@air:~# cpufreq-info -c 0 cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 5.44 ms. hardware limits: 480 MHz - 1.30 GHz available frequency steps: 480 MHz, 648 MHz, 816 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.22 GHz, 1.25 GHz, 1.30 GHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 480 MHz and 1.30 GHz. The governor "ondemand" may decide which speed to use within this range. current CPU frequency is 480 MHz (asserted by call to hardware). cpufreq stats: 480 MHz:89.62%, 648 MHz:0.97%, 816 MHz:0.08%, 960 MHz:0.08%, 1.01 GHz:0.08%, 1.06 GHz:0.05%, 1.10 GHz:0.02%, 1.15 GHz:0.04%, 1.20 GHz:0.04%, 1.22 GHz:0.02%, 1.25 GHz:0.02%, 1.30 GHz:8.98% (171) root@air:~# root@air:~# cat /sys/class/thermal/thermal_zone0/temp 32928 root@air:~# root@air:~# ls -al /boot/ total 31799 drwxr-xr-x 4 root root 1024 Aug 27 16:04 . drwxr-xr-x 18 root root 4096 Aug 21 15:28 .. -rw-r--r-- 1 root root 277 Aug 27 16:04 armbianEnv.txt -rw-r--r-- 1 root root 1536 Aug 21 17:57 armbian_first_run.txt.template -rw-r--r-- 1 root root 230454 Aug 21 17:57 boot.bmp -rw-r--r-- 1 root root 3895 Aug 21 17:57 boot.cmd -rw-r--r-- 1 root root 3967 Aug 21 17:57 boot.scr -rw-r--r-- 1 root root 188640 Aug 27 15:27 config-5.9.0-rc2-sunxi lrwxrwxrwx 1 root root 19 Aug 27 16:03 dtb -> dtb-5.9.0-rc2-sunxi drwxr-xr-x 3 root root 10240 Aug 27 16:02 dtb-5.9.0-rc2-sunxi -rw-r--r-- 1 root root 10116125 Aug 27 16:03 initrd.img-5.9.0-rc2-sunxi -rw-r--r-- 1 root root 0 Aug 27 16:03 .next drwxr-xr-x 2 root root 1024 Aug 24 09:16 overlay-user -rw-r--r-- 1 root root 4072041 Aug 27 15:27 System.map-5.9.0-rc2-sunxi lrwxrwxrwx 1 root root 23 Aug 27 16:03 uInitrd -> uInitrd-5.9.0-rc2-sunxi -rw-r--r-- 1 root root 10116189 Aug 27 16:03 uInitrd-5.9.0-rc2-sunxi -rwxr-xr-x 1 root root 7806728 Aug 27 15:27 vmlinuz-5.9.0-rc2-sunxi lrwxrwxrwx 1 root root 23 Aug 27 16:03 zImage -> vmlinuz-5.9.0-rc2-sunxi root@air:~#
Werner Posted August 28, 2020 Posted August 28, 2020 It has not been announed, more a best guess since the past showed that every fifth new version became LTS. (5.9) 5.4 4.19 4.14 4.9 4.4 ....
dolphs Posted August 28, 2020 Author Posted August 28, 2020 Looks promising, 5.9 topic created here meanwhile
5kft Posted August 29, 2020 Posted August 29, 2020 On 8/19/2020 at 1:21 PM, martinayotte said: Even less misery since all the one seen as "Reversed patch detected! Skipping patch." means the patch already present in Megous branch, so I will do the clean up by removing them. So, I will check how to fix the only remining ones ... I went ahead and cleaned up the remaining problems for 5.8. I don't have an H6 board so I can't test the changes there, but I believe they should work fine (I did a rework of my previous thermal changes for H6 and re-applied on the new 5.8 base). 2
martinayotte Posted August 29, 2020 Posted August 29, 2020 1 hour ago, 5kft said: I went ahead and cleaned up the remaining problems for 5.8. Thanks ! I will take a look later this weekend ... 1
ZupoLlask Posted September 12, 2020 Posted September 12, 2020 On 6/18/2020 at 8:25 AM, dolphs said: [scripts/Makefile.modpost:111: Module.symvers] Error 1 compilation.log:make: *** Hi @dolphs, Have you found the ultimate culprit for this compilation error? I'm getting this one compiling a Realtek (lwfinger) module with latest Armbian stable kernel. I think this is something related with a kernel compilation option (Module.symvers generation) but I'm still looking into this subject... Thanks!
Werner Posted September 14, 2020 Posted September 14, 2020 On 9/13/2020 at 12:06 AM, ZupoLlask said: Hi @dolphs, Have you found the ultimate culprit for this compilation error? I'm getting this one compiling a Realtek (lwfinger) module with latest Armbian stable kernel. I think this is something related with a kernel compilation option (Module.symvers generation) but I'm still looking into this subject... Thanks! This topic is outdated. sunxi-dev has been pushed to kernel version 5.9 while current is now 5.8 If you have issues while compiling this should be reported here: https://github.com/armbian/build/issues
ZupoLlask Posted September 14, 2020 Posted September 14, 2020 I overcame that issue by running make with the following environment variable: - USER_EXTRA_CFLAGS="-fno-stack-protector" `USER_EXTRA_CFLAGS="-fno-stack-protector" make all` This may help someone... 👍 2
