@lex Posted June 19, 2016 Share Posted June 19, 2016 Here is the Guvcview for Orange PI (H3) if you want to watch your CMOS camera in action. Current version is 2.0.2.1. You can try to build it from source (https://github.com/avafinger/guvcview) or wait for the DEB packages if you find it useful. 1 Link to comment Share on other sites More sharing options...
Tido Posted June 19, 2016 Share Posted June 19, 2016 Is this maybe (fswebcam update for OPI (H3 only) in relation to your question ? Link to comment Share on other sites More sharing options...
@lex Posted June 19, 2016 Author Share Posted June 19, 2016 @Tido, it is not a question, it is an answer for those who don't have Guvcview working with CMOS camera. Guvcview works with USB camera only, unless you modify the source or get deb packages when ready. 3 Link to comment Share on other sites More sharing options...
@lex Posted June 19, 2016 Author Share Posted June 19, 2016 Updated the github to supress subchannel error! 1 Link to comment Share on other sites More sharing options...
Gravelrash Posted June 21, 2016 Share Posted June 21, 2016 (edited) @lex this is too long a post to send in a P.M. so steps and results listed below. The following is performed on a fresh rootfs on an OrangePi One - with the latest (at time of writing) Debian Desktop http://mirror.igorpecovnik.com/Armbian_5.13_Orangepione_Debian_jessie_3.4.112_desktop.7z following steps performed software installed apt-get install intltool autotools-dev libsdl1.2-dev libgtk-3-dev portaudio19-dev libpng12-dev libavcodec-dev libavutil-dev libudev-dev libusb-1.0-0-dev libpulse-dev libgsl0-dev libv4l-dev libv4l2rds0 --install-recommends -f -y cloned your repo into the working directory /usr/src/ git clone https://github.com/avafinger/guvcview edited ./bootstrap.sh and replace ./configure line with "./configure --prefix=/usr --enable-yuyv --disable-sdl2" -without quotation marks, as performing standard ./bootstrap.sh errors out with checking for GVIEWRENDER... noconfigure: error: Package requirements (sdl2 >= 2.0) were not met:No package 'sdl2' foundConsider adjusting the PKG_CONFIG_PATH environment variable if youinstalled software in a non-standard prefix. attempting to correct ask for mesa utils installation which will not install as it conflicts with other packages WITH A MODIFIED ./bootstrap.sh the following output is seen configure: guvcview 2.0.2 ---------------------- Prefix : /usr Pulseaudio : yes internal format : yuyv gsl : yes sdl2 : no mjpg decoder : libavcodec desktop file : yes debian menu : yes when issuing the make command, the following is noted root@orangepione:/usr/src/guvcview# make make all-recursive make[1]: Entering directory '/usr/src/guvcview' Making all in gview_v4l2core make[2]: Entering directory '/usr/src/guvcview/gview_v4l2core' CC libgviewv4l2core_la-v4l2_core.lo CC libgviewv4l2core_la-v4l2_formats.lo CC libgviewv4l2core_la-v4l2_controls.lo CC libgviewv4l2core_la-v4l2_devices.lo CC libgviewv4l2core_la-v4l2_xu_ctrls.lo CC libgviewv4l2core_la-uvc_h264.lo CC libgviewv4l2core_la-core_time.lo CC libgviewv4l2core_la-frame_decoder.lo CC libgviewv4l2core_la-colorspaces.lo CC libgviewv4l2core_la-jpeg_decoder.lo CC libgviewv4l2core_la-soft_autofocus.lo CC libgviewv4l2core_la-dct.lo CC libgviewv4l2core_la-control_profile.lo CC libgviewv4l2core_la-save_image.lo CC libgviewv4l2core_la-save_image_jpeg.lo CC libgviewv4l2core_la-save_image_bmp.lo CC libgviewv4l2core_la-save_image_png.lo CCLD libgviewv4l2core.la make[2]: Leaving directory '/usr/src/guvcview/gview_v4l2core' Making all in gview_audio make[2]: Entering directory '/usr/src/guvcview/gview_audio' CC libgviewaudio_la-audio.lo CC libgviewaudio_la-audio_fx.lo CC libgviewaudio_la-core_time.lo CC libgviewaudio_la-audio_portaudio.lo CC libgviewaudio_la-audio_pulseaudio.lo CCLD libgviewaudio.la make[2]: Leaving directory '/usr/src/guvcview/gview_audio' Making all in gview_render make[2]: Entering directory '/usr/src/guvcview/gview_render' CC libgviewrender_la-render.lo CC libgviewrender_la-render_fx.lo CC libgviewrender_la-render_osd_vu_meter.lo CC libgviewrender_la-render_osd_crosshair.lo CC libgviewrender_la-render_sdl1.lo CCLD libgviewrender.la make[2]: Leaving directory '/usr/src/guvcview/gview_render' Making all in gview_encoder make[2]: Entering directory '/usr/src/guvcview/gview_encoder' CC libgviewencoder_la-encoder.lo CC libgviewencoder_la-video_codecs.lo CC libgviewencoder_la-audio_codecs.lo CC libgviewencoder_la-libav_encoder.lo CC libgviewencoder_la-stream_io.lo CC libgviewencoder_la-file_io.lo CC libgviewencoder_la-matroska.lo CC libgviewencoder_la-avi.lo CC libgviewencoder_la-muxer.lo CCLD libgviewencoder.la make[2]: Leaving directory '/usr/src/guvcview/gview_encoder' Making all in guvcview make[2]: Entering directory '/usr/src/guvcview/guvcview' CC guvcview-guvcview.o CC guvcview-video_capture.o CC guvcview-core_io.o CC guvcview-options.o CC guvcview-config.o CC guvcview-gui.o CC guvcview-gui_gtk3.o gui_gtk3.c: In function ‘gui_error_gtk3’: gui_gtk3.c:437:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (title_lbl), 0, 0); ^ gui_gtk3.c:437:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3.c:443:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (text), 0, 0); ^ gui_gtk3.c:443:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3.c:454:3: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (text2), 0, 0); ^ gui_gtk3.c:454:3: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3.c:459:3: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (dev_lbl), 0.5, 0.5); ^ gui_gtk3.c:459:3: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] CC guvcview-gui_gtk3_menu.o CC guvcview-gui_gtk3_v4l2ctrls.o gui_gtk3_v4l2ctrls.c: In function ‘gui_attach_gtk3_v4l2ctrls’: gui_gtk3_v4l2ctrls.c:159:5: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (control_widgets_list[widget_list_size - 1].label), 1, 0.5); ^ gui_gtk3_v4l2ctrls.c:159:5: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] CC guvcview-gui_gtk3_videoctrls.o gui_gtk3_videoctrls.c: In function ‘gui_attach_gtk3_videoctrls’: gui_gtk3_videoctrls.c:107:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_Device), 1, 0.5); ^ gui_gtk3_videoctrls.c:107:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_videoctrls.c:150:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_FPS), 1, 0.5); ^ gui_gtk3_videoctrls.c:150:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_videoctrls.c:214:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_Resol), 1, 0.5); ^ gui_gtk3_videoctrls.c:214:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_videoctrls.c:269:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_InpType), 1, 0.5); ^ gui_gtk3_videoctrls.c:269:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_videoctrls.c:307:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_videoFilters), 0.5, 0.5); ^ gui_gtk3_videoctrls.c:307:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_videoctrls.c:408:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_osd), 0.5, 0.5); ^ gui_gtk3_videoctrls.c:408:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] CC guvcview-gui_gtk3_h264ctrls.o gui_gtk3_h264ctrls.c: In function ‘gui_attach_gtk3_h264ctrls’: gui_gtk3_h264ctrls.c:610:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_RateControlMode), 1, 0.5); ^ gui_gtk3_h264ctrls.c:610:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:651:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_RateControlMode_cbr_flag), 1, 0.5); ^ gui_gtk3_h264ctrls.c:651:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:681:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_TemporalScaleMode), 1, 0.5); ^ gui_gtk3_h264ctrls.c:681:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:716:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SpatialScaleMode), 1, 0.5); ^ gui_gtk3_h264ctrls.c:716:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:752:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_FrameInterval), 1, 0.5); ^ gui_gtk3_h264ctrls.c:752:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:794:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_BitRate), 1, 0.5); ^ gui_gtk3_h264ctrls.c:794:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:822:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_Hints), 1, 0.5); ^ gui_gtk3_h264ctrls.c:822:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:904:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SliceMode), 1, 0.5); ^ gui_gtk3_h264ctrls.c:904:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:931:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SliceUnits), 1, 0.5); ^ gui_gtk3_h264ctrls.c:931:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:957:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_Profile), 1, 0.5); ^ gui_gtk3_h264ctrls.c:957:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1020:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_Profile_flags), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1020:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1050:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_IFramePeriod), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1050:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1076:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_EstimatedVideoDelay), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1076:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1102:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_EstimatedMaxConfigDelay), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1102:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1128:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_UsageType), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1128:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1168:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SNRScaleMode), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1168:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1260:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_StreamFormat), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1260:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1286:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_EntropyCABAC), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1286:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1319:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_NumOfReorderFrames), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1319:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1356:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_View), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1356:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1386:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_StreamID), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1386:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1416:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SpatialLayerRatio), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1416:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_h264ctrls.c:1450:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_LeakyBucketSize), 1, 0.5); ^ gui_gtk3_h264ctrls.c:1450:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] CC guvcview-gui_gtk3_audioctrls.o gui_gtk3_audioctrls.c: In function ‘gui_attach_gtk3_audioctrls’: gui_gtk3_audioctrls.c:101:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SndAPI), 1, 0.5); ^ gui_gtk3_audioctrls.c:101:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_audioctrls.c:137:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SndDevice), 1, 0.5); ^ gui_gtk3_audioctrls.c:137:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_audioctrls.c:177:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SndSampRate), 1, 0.5); ^ gui_gtk3_audioctrls.c:177:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_audioctrls.c:229:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_SndNumChan), 1, 0.5); ^ gui_gtk3_audioctrls.c:229:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_audioctrls.c:263:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_Latency), 1, 0.5); ^ gui_gtk3_audioctrls.c:263:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_audioctrls.c:307:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (label_audioFilters), 0.5, 0.5); ^ gui_gtk3_audioctrls.c:307:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] CC guvcview-gui_gtk3_callbacks.o gui_gtk3_callbacks.c: In function ‘encoder_video_properties’: gui_gtk3_callbacks.c:1789:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_fps), 1, 0.5); ^ gui_gtk3_callbacks.c:1789:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1814:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_bit_rate), 1, 0.5); ^ gui_gtk3_callbacks.c:1814:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1832:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_qmax), 1, 0.5); ^ gui_gtk3_callbacks.c:1832:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1850:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_qmin), 1, 0.5); ^ gui_gtk3_callbacks.c:1850:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1868:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_max_qdiff), 1, 0.5); ^ gui_gtk3_callbacks.c:1868:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1886:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_dia), 1, 0.5); ^ gui_gtk3_callbacks.c:1886:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1904:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_pre_dia), 1, 0.5); ^ gui_gtk3_callbacks.c:1904:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1922:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_pre_me), 1, 0.5); ^ gui_gtk3_callbacks.c:1922:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1940:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_me_pre_cmp), 1, 0.5); ^ gui_gtk3_callbacks.c:1940:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1958:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_me_cmp), 1, 0.5); ^ gui_gtk3_callbacks.c:1958:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1976:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_me_sub_cmp), 1, 0.5); ^ gui_gtk3_callbacks.c:1976:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:1994:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_last_pred), 1, 0.5); ^ gui_gtk3_callbacks.c:1994:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2012:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_gop_size), 1, 0.5); ^ gui_gtk3_callbacks.c:2012:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2030:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_qcompress), 1, 0.5); ^ gui_gtk3_callbacks.c:2030:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2048:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_qblur), 1, 0.5); ^ gui_gtk3_callbacks.c:2048:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2066:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_subq), 1, 0.5); ^ gui_gtk3_callbacks.c:2066:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2084:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_framerefs), 1, 0.5); ^ gui_gtk3_callbacks.c:2084:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2102:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_me_method), 1, 0.5); ^ gui_gtk3_callbacks.c:2102:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2120:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_mb_decision), 1, 0.5); ^ gui_gtk3_callbacks.c:2120:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2138:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_max_b_frames), 1, 0.5); ^ gui_gtk3_callbacks.c:2138:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2156:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_num_threads), 1, 0.5); ^ gui_gtk3_callbacks.c:2156:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c: In function ‘encoder_audio_properties’: gui_gtk3_callbacks.c:2239:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_bit_rate), 1, 0.5); ^ gui_gtk3_callbacks.c:2239:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] gui_gtk3_callbacks.c:2258:2: warning: ‘gtk_misc_set_alignment’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:72) [-Wdeprecated-declarations] gtk_misc_set_alignment (GTK_MISC (lbl_sample_fmt), 1, 0.5); ^ gui_gtk3_callbacks.c:2258:2: warning: ‘gtk_misc_get_type’ is deprecated (declared at /usr/include/gtk-3.0/gtk/deprecated/gtkmisc.h:70) [-Wdeprecated-declarations] CCLD guvcview make[2]: Leaving directory '/usr/src/guvcview/guvcview' Making all in data make[2]: Entering directory '/usr/src/guvcview/data' Making all in icons make[3]: Entering directory '/usr/src/guvcview/data/icons' make[3]: Nothing to be done for 'all'. make[3]: Leaving directory '/usr/src/guvcview/data/icons' make[3]: Entering directory '/usr/src/guvcview/data' cd .. && /bin/bash ./config.status data/guvcview.appdata.xml.in config.status: creating data/guvcview.appdata.xml.in ITMRG guvcview.appdata.xml cd .. && /bin/bash ./config.status data/guvcview.desktop.in config.status: creating data/guvcview.desktop.in ITMRG guvcview.desktop cd .. && /bin/bash ./config.status data/guvcview.in config.status: creating data/guvcview.in cp guvcview.in guvcview make[3]: Leaving directory '/usr/src/guvcview/data' make[2]: Leaving directory '/usr/src/guvcview/data' Making all in po make[2]: Entering directory '/usr/src/guvcview/po' make[2]: Nothing to be done for 'all'. make[2]: Leaving directory '/usr/src/guvcview/po' Making all in po/gview_v4l2core make[2]: Entering directory '/usr/src/guvcview/po/gview_v4l2core' make[2]: Nothing to be done for 'all'. make[2]: Leaving directory '/usr/src/guvcview/po/gview_v4l2core' make[2]: Entering directory '/usr/src/guvcview' make[2]: Leaving directory '/usr/src/guvcview' make[1]: Leaving directory '/usr/src/guvcview' root@orangepione:/usr/src/guvcview# is the above expected behaviour of have i forgotten to do somethin?? Edited June 21, 2016 by zador.blood.stained Added spoiler for the big wall of text Link to comment Share on other sites More sharing options...
@lex Posted June 21, 2016 Author Share Posted June 21, 2016 Looks fine, i had this gtk3 warning on version 2.0.4 and the GUI window did not opened as expected. If you experience this behavior (gui not showing) i think you should go with version 2.0.4. Perhaps you have newer gtk3 libs. Make sure you don't have any other version installed and run 'make install' and check the version and start up guvcview with command line to see the GUI window. PS: /usr is the standard Ubuntu way! Change it in accordance with Debian if you prefer. Link to comment Share on other sites More sharing options...
Gravelrash Posted June 23, 2016 Share Posted June 23, 2016 looking good so far (git clone https://github.com/avafinger/guvcview) - issued a make install the from command line, issued guvcview and the application loaded. minor problem my end, i cant test it till the camera module arrives. Q. would you like me to continue with the packaging? Q. would you like me to wait until i have the camera module to test this works and then package. Link to comment Share on other sites More sharing options...
@lex Posted June 23, 2016 Author Share Posted June 23, 2016 I think Debian Jessie has Guvcview 2.0.2 deb packaging already, you can work on this. I leave the answers to Igor / TKaiser , Guvcview users must be aware to pass --cmos_camera=0 or it will not work correctly with USB cameras. If the answer is 'NO', we should work on 2.0.4 so people can choose to install it. Link to comment Share on other sites More sharing options...
Gravelrash Posted June 23, 2016 Share Posted June 23, 2016 gucview does have this packaed already - https://packages.debian.org/jessie/guvcview- 2.0.1 that is what i intended to base the package on. HOWEVER - when the debian package is extracted, there are quite a few files that are not there that are installed with the "make install" command. Link to comment Share on other sites More sharing options...
tkaiser Posted June 23, 2016 Share Posted June 23, 2016 We can provide an own package since zador added this as part of this commit just recently. When packages are ready and available somewhere I can always test them on request For my understanding: On which of our platforms does installation of guvcview makes some sense now (you also referenced Pine64 IIRC)? Link to comment Share on other sites More sharing options...
Igor Posted June 23, 2016 Share Posted June 23, 2016 Eventually it can become a part of armbian but @lex should support this part on a long term: Like we do for hostapd, firmware, ... as example: https://github.com/igorpecovnik/lib/blob/master/extras/hostapd.sh https://github.com/igorpecovnik/lib/blob/master/extras/firmware.sh Link to comment Share on other sites More sharing options...
zador.blood.stained Posted June 23, 2016 Share Posted June 23, 2016 Building https://github.com/avafinger/guvcview with "debianization" overlay from Ubuntu resulted in these packages. 1 Link to comment Share on other sites More sharing options...
Gravelrash Posted June 23, 2016 Share Posted June 23, 2016 From the work i have done with @lex thus far: It is recomended that the changes he has made are compiled on the architecture of the board it is to be used on - in this instance H3 - from my notes of our discussions, it absolutely must NOT be cross-compiled For my understanding: On which of our platforms does installation of guvcview makes some sense now (you also referenced Pine64 IIRC)? Link to comment Share on other sites More sharing options...
@lex Posted June 23, 2016 Author Share Posted June 23, 2016 @tkaiser, ok, before this become part of armbian i think you should run some tests and see the limitations. i updated the https://github.com/avafinger/guvcview(Guvcview runs on OPI and Pine64+ with some restrictions on the driver side). Not referenced on Pine64 IIRC. @Igor, ok then. 1 Link to comment Share on other sites More sharing options...
zador.blood.stained Posted June 23, 2016 Share Posted June 23, 2016 Building https://github.com/avafinger/guvcview with "debianization" overlay from Ubuntu resulted in these packages. If anybody tests these, please let me know if this works or doesn't work, compared to self-compiled version. Link to comment Share on other sites More sharing options...
Gravelrash Posted June 24, 2016 Share Posted June 24, 2016 i dont seem to be even able to extract them... having said that - if you already have the files compiled and debs made, do you need me to continue working on a .deb build script? If anybody tests these, please let me know if this works or doesn't work, compared to self-compiled version. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted June 24, 2016 Share Posted June 24, 2016 i dont seem to be even able to extract them... I just built a jessie desktop system and tested installation of these packages. It works, but you have to install dependencies first (when you put packages in a repository this won't be a problem) Dependencies for libguvcview: libasound2 libavcodec56 libavcodec-extra-56 libavutil54 libgsl0ldbl libpng12-0 libportaudio2 libpulse0 libsdl1.2debian libudev1 libusb-1.0-0 libv4l-0 Dependencies for guvcview: libatk1.0-0 libcairo-gobject2 libcairo2 libgdk-pixbuf2.0-0 libglib2.0-0 libgtk-3-0 libpango-1.0-0 libpangocairo-1.0-0 but I don't have a camera to test this stuff. Edit: if this works with any camera, I may be able to find some USB web cams from laptops and solder a cable to them later. having said that - if you already have the files compiled and debs made, do you need me to continue working on a .deb build script? For guvcview - no, assuming this version works OK. There are a few desktop packages still (libvdpau-sunxi, libcedrus, xf86-video-fbturbo) which need packaging (not exactly scripts but "debianization" parts made with dh_make and manual editing of files). Sorry if you already wasted your time on guvcview. Link to comment Share on other sites More sharing options...
Gravelrash Posted June 24, 2016 Share Posted June 24, 2016 ok - on to other packaging needsa recomendation for the gucview that i was going to add Two .desktop shortcuts, one for standard usb and one for the onboard camera both require different launch parameters Link to comment Share on other sites More sharing options...
@lex Posted June 24, 2016 Author Share Posted June 24, 2016 @zador.blood.stained It should work with any camera (USB) if you pass --cmos_camera=0 on command line and will be able to work exactly as the original code. I am just worried about the struct size for some kernel version, as an example is the subchannel implemented in the BSP. If i recall correctly it was needed to start streaming on OLD kernel. But is just a thought. Link to comment Share on other sites More sharing options...
@lex Posted June 24, 2016 Author Share Posted June 24, 2016 Just pushed 2.0.4 to github. https://github.com/avafinger/guvcview_2.0.4 It is working on Debian Jessie and GTK3. Link to comment Share on other sites More sharing options...
Gravelrash Posted June 24, 2016 Share Posted June 24, 2016 soon as my camera lands i will test - wont be for about 2 weeks though Link to comment Share on other sites More sharing options...
