Yarodin Posted June 29, 2020 Posted June 29, 2020 Armbianmonitor: http://ix.io/2qt3 A couple of years ago wifi worked without any problems on old version of Armbian, but on the current version It doen't work completely. Any suggestions? uname -a Linux HAMServer 5.4.45-sunxi #20.05.4 SMP Sun Jun 14 21:46:20 CEST 2020 armv7l armv7l armv7l GNU/Linux lsmod | grep 8189fs 8189fs 1069056 0 cfg80211 413696 1 8189fs ifconfig eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.88.16 netmask 255.255.255.0 broadcast 192.168.88.255 inet6 fe80::8385:e766:9c48:e593 prefixlen 64 scopeid 0x20<link> ether 02:81:a4:6e:47:9e txqueuelen 1000 (Ethernet) RX packets 7721 bytes 618507 (618.5 KB) RX errors 0 dropped 12 overruns 0 frame 0 TX packets 11125 bytes 2714338 (2.7 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 39 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Igor Posted June 29, 2020 Posted June 29, 2020 Several months ago we migrated from self maintained patch to "upstream" https://github.com/jwrdegoede/rtl8189ES_linux/tree/rtl8189fs Now. It is possible we are missing something ... As a temporal workaround - you can switch to some older kernel and wait until this is addressed.
martinayotte Posted June 29, 2020 Posted June 29, 2020 On 6/29/2020 at 8:25 AM, Yarodin said: Any suggestions? Expand In my case, a fresh 5.7.6 build on my OPi2E, the WiFi is working, although I'm using "old school" /etc/network/interfaces with NetworkManager disabled ...
Yarodin Posted June 29, 2020 Author Posted June 29, 2020 On 6/29/2020 at 2:11 PM, martinayotte said: In my case, a fresh 5.7.6 build on my OPi2E, the WiFi is working, although I'm using "old school" /etc/network/interfaces with NetworkManager disabled ... Expand 5.7.6 - what's it?
martinayotte Posted June 29, 2020 Posted June 29, 2020 On 6/29/2020 at 2:37 PM, Yarodin said: 5.7.6 - what's it? Expand A DEV build done by myself using Armbian build script ...
Werner Posted June 29, 2020 Posted June 29, 2020 On 6/29/2020 at 2:37 PM, Yarodin said: 5.7.6 - what's it? Expand Linux kernel version.
Yarodin Posted June 30, 2020 Author Posted June 30, 2020 I have tested a lot of kernels starting from 4.14.65 and even 5.7.6 (current dev build) - no success. I don't have any idea how it happened, but the built-in module seems to have died. Sorry for false bug report.
vmspike Posted July 11, 2020 Posted July 11, 2020 On 6/29/2020 at 2:11 PM, martinayotte said: In my case, a fresh 5.7.6 build on my OPi2E, the WiFi is working, although I'm using "old school" /etc/network/interfaces with NetworkManager disabled ... Expand You may test AP mode (if not yet tested). For me AP mode does not work with embedded adapter (rtl8189FS), all looks like configured properly but clients unable to connect after multiple attempts, client mode works. My device is orangepizeroplus 5.4.43-sunxi64 aarch64, Armbian Buster 20.05.2. AP configured with systemd-networkd 245 and iwd 1.8 Another adapter (rtl8192cu) works fine with the same setup.
martinayotte Posted July 11, 2020 Posted July 11, 2020 On 7/11/2020 at 12:47 AM, vmspike said: You may test AP mode (if not yet tested). Expand No, unfortunately, I have no needs for AP mode. I don't even know if the current driver is supporting it ...
