Armbianmonitor:
  Reveal hidden contents
A friend of mine told me that his OPi One freezes every couple of days for no reason. So I took it with me and see what I could find.
I connected another SBC via serial to the board and wait until it freezes. This is what I have got and no idea what the reason is....
The armbianmonitor output is from a fresh restart after power cycle.
Can you compare the dts of this kernel with earlier kernel? (v20.02 -- arch/arm/boot/dts especially cpu entries)
Seems like upstream did refactoring, I didn't want to touch anything since I've no way of testing changes.
I had these freezes also with my OPi One - no matter with armbian current or dev (buster & focal).
I hadnt this in 2019.
I did see it, because I used him as one of my piholes and when he did freeze some of my android-devices did act not normally while using the web (they seem to have a problem with using the 2nd dns in the network-settings)
I have another One running for month now (also as Pihole) and never had issues with it.
Issue recreated, though other virtual address this time.
[16668.716765] Unable to handle kernel paging request at virtual address 3f00d700
[16668.723992] pgd = 61a9cd52
[16668.726701] [3f00d700] *pgd=00000000
[16668.730286] Internal error: Oops: 80000005 [#1] SMP THUMB2
[16668.735770] Modules linked in: rfkill zstd snd_soc_hdmi_codec dw_hdmi_cec dw_hdmi_i2s_audio snd_soc_simple_card sun8i_codec_analog snd_soc_simple_card_utils sun8i_adda_pr_regmap sun4i_i2s snd_soc_core ac97_bus sunxi_cedrus(C) snd_pcm_dmaengine v4l2_mem2mem videobuf2_dma_contig snd_pcm sun8i_drm_hdmi videobuf2_memops dw_hdmi lima snd_timer sun4i_gpadc_iio videobuf2_v4l2 cec snd gpu_sched industrialio videobuf2_common soundcore sun8i_thermal videodev mc sun4i_drm sun4i_frontend sun8i_mixer evdev sun4i_tcon sun8i_tcon_top uio_pdrv_genirq uio cpufreq_dt zram zsmalloc ip_tables x_tables autofs4 gpio_regulator fixed gpio_keys
[16668.790725] CPU: 3 PID: 1 Comm: systemd Tainted: G         C  E     5.4.51-sunxi #trunk
[16668.798726] Hardware name: Allwinner sun8i Family
[16668.803435] PC is at 0x3f00d700
[16668.806577] LR is at 0xb6e8e746
[16668.809718] pc : [<3f00d700>]    lr : [<b6e8e746>]    psr: 20070093
[16668.815984] sp : d70edff8  ip : 000000c5  fp : 014df550
[16668.821207] r10: 00000000  r9 : bef6b288  r8 : b6f89c10
[16668.826431] r7 : 000000c5  r6 : b6f99968  r5 : b6f6bb1c  r4 : 014df550
[16668.832957] r3 : b6ec6b45  r2 : bef6afe8  r1 : bef6afe8  r0 : 00000015
[16668.839484] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[16668.846707] Control: 50c5387d  Table: 5688806a  DAC: 00000055
[16668.852452] Process systemd (pid: 1, stack limit = 0xc59b4d99)
[16668.858283] Stack: (0xd70edff8 to 0xd70ee000)
[16668.862642] dfe0:                                                       00000000 00000000
[16668.870824] Code: bad PC value
[16668.873883] ---[ end trace e1c9811577573273 ]---
[16668.878507] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[16669.915929] SMP: failed to stop secondary CPUs
[16669.920379] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
[    7.102323] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    7.102338] cpu cpu0: _opp_add: OPP not supported by regulators (1104000000)
[    7.102518] core: _opp_supported_by_regulators: OPP minuV: 1320000 maxuV: 1320000, not supported by regulator
[    7.102526] cpu cpu0: _opp_add: OPP not supported by regulators (1200000000)
[    7.102703] core: _opp_supported_by_regulators: OPP minuV: 1340000 maxuV: 1340000, not supported by regulator
[    7.102710] cpu cpu0: _opp_add: OPP not supported by regulators (1296000000)
[    7.102868] core: _opp_supported_by_regulators: OPP minuV: 1400000 maxuV: 1400000, not supported by regulator
[    7.102875] cpu cpu0: _opp_add: OPP not supported by regulators (1368000000)
[    7.103311] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal-cpufreq-0 failed:-22
Expand
That is not related to this specific issue. Armbian cannot clock higher on H3 since there is no proper support for the voltage regulator.
[182764.941115] Bad mode in undefined instruction handler detected
[182764.952552] Internal error: Oops - bad mode: 0 [#1] SMP THUMB2
[182764.963861] Modules linked in: rfkill input_leds snd_soc_hdmi_codec sun4i_gpadc_iio industrialio sun8i_thermal sun8i_ce sunxi_cedrus(C) crypto_engine sun8i_di evdev uio_pdrv_genirq uio cpufreq_dt zram ip_tables x_tables autofs4 lima gpu_sched dw_hdmi_i2s_audio dw_hdmi_cec sunxi phy_generic gpio_keys display_connector
[182765.004106] CPU: 2 PID: 1 Comm: systemd Tainted: G         C        5.7.10-sunxi #trunk
[182765.018311] Hardware name: Allwinner sun8i Family
[182765.028826] PC is at 0xffff10ca
[182765.037366] LR is at 0xb6e87be6
[182765.045482] pc : [<ffff10ca>]    lr : [<b6e87be6>]    psr: 800701b7
[182765.056862] sp : d70dffb0  ip : b6f67ba0  fp : 00008000
[182765.067193] r10: 00000068  r9 : 00000001  r8 : 00000008
[182765.077505] r7 : 01b72dd0  r6 : b6f6776c  r5 : b6f677a0  r4 : 01b72dd0
[182765.089159] r3 : b6f67808  r2 : 01ae9248  r1 : 00000071  r0 : c0ff880c
[182765.100871] Flags: Nzcv  IRQs off  FIQs on  Mode ABT_32  ISA Thumb  Segment none
[182765.113591] Control: 50c5387d  Table: 568d406a  DAC: 00000000
[182765.124711] Process systemd (pid: 1, stack limit = 0x33bc84e2)
[182765.135980] Stack: (0xd70dffb0 to 0xd70e0000)
[182765.145799] ffa0:                                     c0ff880c 00000071 01ae9248 b6f67808
[182765.159593] ffc0: 01b72dd0 b6f677a0 b6f6776c 01b72dd0 00000008 00000001 00000068 00008000
[182765.173468] ffe0: b6f67ba0 d70dffb0 b6e87be6 ffff10ca 800701b7 ffffffff 00000000 00000000
[182765.187425] Code: f850 e02e 4668 efca (f8f0) efee
[182765.198035] ---[ end trace 2a7b257dd76743ba ]---
[182765.208522] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[182766.252010] SMP: failed to stop secondary CPUs
[182766.262576] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
I think I stop tinkering with this one. He's dead, Jim.
  On 7/29/2020 at 10:16 AM, guidol said:
But I think its only a software problem.....this One reacts like he has a bad armbian-image ;)
Expand
In theory you were right, but unfortunately it is not. I have two OPi One side by side. One with the defect and one known to work. I swapped the sd cards and the sd card out of the defective board booted flawless on the known-to-work board while the known-to-work sd card did not boot in the defective board.
After a dozen power cycles it came back once but I do not trust it anymore.
Expand
Have you tried powering through GPIO pins?
I notice similar freezes on some of my OrangePI One boards:
Aug 11 04:01:10   kernel: [11045.901932] asix 3-1.4.1:1.0 asix: link up, 100Mbps, full-duplex, lpa 0x41E1
Aug 11 04:05:50   kernel: [11326.227650] INFO: rcu_sched detected stalls on CPUs/tasks:
Aug 11 04:05:50   kernel: [11326.227679] 3-...: (1 ticks this GP) idle=992/1/0 softirq=363926/363926 fqs=1
Aug 11 04:05:50   kernel: [11326.227681] (detected by 2, t=41234 jiffies, g=193459, c=193458, q=5)
Aug 11 04:05:50   kernel: [11326.227697] Sending NMI from CPU 2 to CPUs 3:
Aug 11 04:05:50   kernel: [11326.227720] NMI backtrace for cpu 3
Aug 11 04:05:50   kernel: [11326.227728] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W O 4.13.15-sunxi #1
Aug 11 04:05:50   kernel: [11326.227730] Hardware name: Allwinner sun8i Family
Aug 11 04:05:50   kernel: [11326.227734] task: df4f2f40 task.stack: df51e000
Aug 11 04:05:50   kernel: [11326.227747] PC is at expire_timers+0x8e/0xe0
Aug 11 04:05:50   kernel: [11326.227752] LR is at run_timer_softirq+0x103/0x138
Aug 11 04:05:50   kernel: [11326.227755] pc : [] lr : [] psr: 000e0133
Aug 11 04:05:50   kernel: [11326.227758] sp : df51fe80 ip : df51fea8 fp : 4000001f
Aug 11 04:05:50   kernel: [11326.227761] r10: 1ee84000 r9 : c0dd3430 r8 : ffffe000
Aug 11 04:05:50   kernel: [11326.227763] r7 : c0d03f6c r6 : df51fea4 r5 : dfb33440 r4 : df76f8a0
Aug 11 04:05:50   kernel: [11326.227767] r3 : 000003df r2 : df76f808 r1 : c0604f21 r0 : dfb33440
Aug 11 04:05:50   kernel: [11326.227771] Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none
Aug 11 04:05:50   kernel: [11326.227775] Control: 50c5387d Table: 4a5bc06a DAC: 00000051
Aug 11 04:05:50   kernel: [11326.227779] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G W O 4.13.15-sunxi #1
Aug 11 04:05:50   kernel: [11326.227781] Hardware name: Allwinner sun8i Family
Aug 11 04:05:50   kernel: [11326.227801] [] (unwind_backtrace) from [] (show_stack+0x11/0x14)
Aug 11 04:05:50   kernel: [11326.227811] [] (show_stack) from [] (dump_stack+0x69/0x78)
Aug 11 04:05:50   kernel: [11326.227822] [] (dump_stack) from [] (nmi_cpu_backtrace+0x8b/0xd4)
Aug 11 04:05:50   kernel: [11326.227831] [] (nmi_cpu_backtrace) from [] (handle_IPI+0x75/0x278)
Aug 11 04:05:50   kernel: [11326.227840] [] (handle_IPI) from [] (gic_handle_irq+0x67/0x68)
Aug 11 04:05:50   kernel: [11326.227847] [] (gic_handle_irq) from [] (__irq_svc+0x65/0x94)
Aug 11 04:05:50   kernel: [11326.227851] Exception stack(0xdf51fe30 to 0xdf51fe78)
Aug 11 04:05:50   kernel: [11326.227856] fe20: dfb33440 c0604f21 df76f808 000003df
Aug 11 04:05:50   kernel: [11326.227863] fe40: df76f8a0 dfb33440 df51fea4 c0d03f6c ffffe000 c0dd3430 1ee84000 4000001f
Aug 25 18:28:35   kernel: [11326.227869] fe60: df51fea8 df51fe80 c0168ca7 c0168b52 000e0133 ffffffff
Aug 25 18:28:35   kernel: [11326.227877] [] (__irq_svc) from [] (expire_timers+0x8e/0xe0)
Aug 25 18:28:35   kernel: [11326.227887] [] (expire_timers) from [] (run_timer_softirq+0x103/0x138)
Aug 25 18:28:35   kernel: [11326.227899] [] (run_timer_softirq) from [] (__do_softirq+0xb9/0x25c)
Aug 25 18:28:35   kernel: [11326.227908] [] (__do_softirq) from [] (irq_exit+0x93/0xe4)
Aug 25 18:28:35   kernel: [11326.227919] [] (irq_exit) from [] (__handle_domain_irq+0x49/0x84)
Aug 25 18:28:35   kernel: [11326.227928] [] (__handle_domain_irq) from [] (gic_handle_irq+0x39/0x68)
Aug 25 18:28:35   kernel: [11326.227934] [] (gic_handle_irq) from [] (__irq_svc+0x65/0x94)
Aug 25 18:28:35   kernel: [11326.227937] Exception stack(0xdf51ff78 to 0xdf51ffc0)
Aug 25 18:28:35   kernel: [11326.227940] ff60: 00000001 00000000
Aug 25 18:28:35   kernel: [11326.227947] ff80: 00000000 c01165e1 ffffe000 c0d03fcc c0d03f6c c0cb33b8 c0dd2c3f 00000000
Aug 25 18:28:35   kernel: [11326.227953] ffa0: 00000000 00000000 01400000 df51ffc8 c0107087 c0107088 400e0033 ffffffff
Aug 25 18:28:35   kernel: [11326.227962] [] (__irq_svc) from [] (arch_cpu_idle+0x28/0x2c)
Aug 25 18:28:35   kernel: [11326.227973] [] (arch_cpu_idle) from [] (do_idle+0x115/0x16c)
Aug 25 18:28:35   kernel: [11326.227982] [] (do_idle) from [] (cpu_startup_entry+0x19/0x1c)
Aug 25 18:28:35   kernel: [11326.227990] [] (cpu_startup_entry) from [<40101491>] (0x40101491)
Aug 25 18:28:35   kernel: [11326.228712] rcu_sched kthread starved for 41232 jiffies! g193459 c193458 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x0
Aug 25 18:28:35   kernel: [11326.228717] rcu_sched R running task 0 8 2 0x00000000
Aug 25 18:28:35   kernel: [11326.228736] [] (__schedule) from [] (schedule+0x2f/0x68)
Aug 25 18:28:35   kernel: [11326.228746] [] (schedule) from [] (schedule_timeout+0x75/0x2ec)
Aug 25 18:28:35   kernel: [11326.228757] [] (schedule_timeout) from [] (rcu_gp_kthread+0x425/0x690)
Aug 25 18:28:35   kernel: [11326.228769] [] (rcu_gp_kthread) from [] (kthread+0xfd/0x104)
Aug 25 18:28:35   kernel: [11326.228780] [] (kthread) from [] (ret_from_fork+0x11/0x20)
Aug 25 18:32:47   kernel: [12265.081326] hrtimer: interrupt took 8625 ns
Without a reason, it freezes, but:
1. A web server that runs on this OPI is still somehow functional for about several hours. I have a root shell via this web so I can run some commands and get results.
2. System time changed to Apr 25 1979 . This also noticable from the log above.
3. systemctl is not working like I can't get a list of units. It just does not produce any output.
The kernel is 4.13.15-sunxi #1 SMP Tue Nov 21 23:35:46 MSK 2017 armv7l armv7l armv7l GNU/Linux.
At the same time /var/log/syslog has other errors like that:
Aug 11 04:07:56   systemd[1]: systemd-logind.service: Watchdog timeout (limit 3min)!
Aug 11 04:07:56   systemd[1]: systemd-logind.service: Main process exited, code=killed, status=6/ABRT
Aug 11 04:07:56   systemd[1]: systemd-logind.service: Unit entered failed state.
Aug 11 04:07:56   systemd[1]: systemd-logind.service: Failed with result 'signal'.
Aug 11 04:07:56   systemd[1]: systemd-logind.service: Service has no hold-off time, scheduling restart.
Aug 11 04:07:56   systemd[1]: Stopped Login Service.
Aug 25 18:28:35   wpa_supplicant[2055]: wlx74da38f15c54: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1
Aug 25 18:28:35   systemd[1]: Starting Login Service...
Aug 25 18:28:36   systemd[1]: systemd-logind.service: Main process exited, code=exited, status=1/FAILURE
Aug 25 18:28:36   systemd[1]: Failed to start Login Service.
Aug 25 18:28:36   systemd[1]: systemd-logind.service: Unit entered failed state.
Aug 25 18:28:36   systemd[1]: systemd-logind.service: Failed with result 'exit-code'.
Aug 25 18:28:36   systemd[1]: Time has been changed
Aug 25 18:32:51   wpa_supplicant[2055]: message repeated 3 times: [ wlx74da38f15c54: CTRL-EVENT-SCAN-FAILED ret=-16 retry=1]
Aug 25 18:33:11   systemd-udevd[286]: seq 3700 '/devices/platform/soc/1c20800.pinctrl/gpiochip0/gpio/gpio20' killed
Aug 25 18:33:11   systemd-udevd[286]: seq 3700 '/devices/platform/soc/1c20800.pinctrl/gpiochip0/gpio/gpio20' is taking a long time
Aug 25 18:33:11   systemd-udevd[286]: worker [5282] terminated by signal 9 (Killed)
Aug 25 18:33:11   systemd-udevd[286]: worker [5282] failed while handling '/devices/platform/soc/1c20800.pinctrl/gpiochip0/gpio/gpio20'
It is weird because this OrangePI was running fine for about half a year or year.
Expand
use armbianmonitor -u, most likely rogue process eating all memory
