wollik 1 Posted July 22, 2020 Share Posted July 22, 2020 Hi forum members, on my interactive bash I can use the armbian variables like BOARD , BOARD_NAME or BOARDFAMILY, but these variables ard not seen when I try to use them in a bash script. Any hints ? 0 Quote Link to post Share on other sites
guidol 267 Posted July 22, 2020 Share Posted July 22, 2020 there must be a difference between $BOARD and $TERM or $PWD because in a script it works for $TERM and $PWD I tought when it is a "gobal" variabel which was exported via export= it should work, but I also got this problem today with a script while trying to set a global environment variable My variable is only useable in the script and wehen it ends it isnt global anymore Havent also found the "magic searchword" today 0 Quote Link to post Share on other sites
xwiggen 6 Posted July 22, 2020 Share Posted July 22, 2020 source /etc/armbian-release echo $BOARD 0 Quote Link to post Share on other sites
lanefu 258 Posted July 23, 2020 Share Posted July 23, 2020 in case this example helps lane@hambone:~$ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepi3 BOARD_NAME="Orange Pi 3" BOARDFAMILY=sun50iw6 BUILD_REPOSITORY_URL=https://github.com/armbian/rkbin BUILD_REPOSITORY_COMMIT=3e533c9 DISTRIBUTION_CODENAME=bionic DISTRIBUTION_STATUS=supported VERSION=20.05.0-trunk.038 LINUXFAMILY=sunxi64 BRANCH=current ARCH=arm64 IMAGE_TYPE=nightly BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image lane@hambone:~$ source /etc/armbian-release lane@hambone:~$ echo "${BOARD_NAME} ${LINUXFAMILY}" Orange Pi 3 sunxi64 0 Quote Link to post Share on other sites
guidol 267 Posted July 23, 2020 Share Posted July 23, 2020 I thought it will work without a file Ok with a source-file my script-idea of a startrek-lightline for lcd4linux is working now with the following bash script (which is used by lcd4linux): #!/bin/bash -e lightfile="/var/lightactual.val" if [ -f "$lightfile" ]; then # found - do nothing sleep 0 else echo 'lightactual=0' > $lightfile fi source $lightfile # echo 'val of lightactual='$lightactual lightline[0]='---------##---------' lightline[1]='--------#--#--------' lightline[2]='-------#----#-------' lightline[3]='------#------#------' lightline[4]='-----#--------#-----' lightline[5]='----#----------#----' lightline[6]='---#------------#---' lightline[7]='--#--------------#--' lightline[8]='-#----------------#-' lightline[9]='#------------------#' echo ${lightline[$lightactual]} lightactual=$((lightactual+1)) if [ $lightactual -eq 10 ] then lightactual=0 fi echo 'lightactual='$lightactual > $lightfile # echo "lightactual after count-up="$lightactual 0 Quote Link to post Share on other sites
xwiggen 6 Posted July 23, 2020 Share Posted July 23, 2020 The BOARD etc variables are imported in /etc/profile.d/armbian-check-first-login.sh, which in turn is only loaded in interactive login shells. 0 Quote Link to post Share on other sites
wollik 1 Posted July 23, 2020 Author Share Posted July 23, 2020 Hi xwiggen, T H A N K S ! Using the source command in my script fixed my issues. Regards Wolfgang 0 Quote Link to post Share on other sites
