Hostapd won't start in HT40 mode using 8812bu and noscan=1, starts ok if there is no AP's around
There is a patched version that enables noscan=1 , but the one I'm using seems like it hasn't been patched.
When there is no AP's around HT40 kicks in ok without noscan=1.
With noscan=1 and AP's are around hostapd won't even start in HT20 mode.
Any help?
root@orangepilite2:~# modinfo 88x2bu|grep version:
version:        v5.8.7.1_35809.20191129_COEX20191120-7777
srcversion:     43C721C4A870A632EBDE0B5
parm:           rtw_chip_version:int
root@orangepilite2:~# uname -a && hostapd -v
Linux orangepilite2 5.4.43-sunxi64 #20.05.2 SMP Tue Jun 2 17:20:17 CEST 2020 aarch64 GNU/Linux
hostapd v2.9
User space daemon for IEEE 802.11 AP management,
IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator
Copyright (c) 2002-2019, Jouni Malinen <j@w1.fi> and contributors
the noscan=1 patch take the AP out of compliance with 802.11
simply put - I could fix it, but not inclined to do so...
root@cbsim:/etc/config# modinfo ath9k
module: /lib/modules/5.4.65/ath9k.ko
license: Dual BSD/GPL
depends: mac80211,ath9k_hw,ath9k_common,compat,cfg80211,ath
vermagic: 5.4.65 mod_unload MIPS32_R2 32BIT
root@cbsim:/etc/config# uname -a && hostapd -v
Linux cbsim 5.4.65 #0 Sun Sep 13 22:19:27 2020 mips GNU/Linux
hostapd v2.10-devel
Thanks guys!
@sfx2000, are you suggesting me to go with hostapd v2.10-devel and it would work?
@Werner, here's the armbianmonitor -u http://ix.io/2x61
root@orangepilite2:~# hostapd /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
Line 9: unknown configuration item 'noscan '
1 errors found in configuration file '/etc/hostapd/hostapd.conf'
Failed to set up interface with /etc/hostapd/hostapd.conf
Failed to initialize interface
@Igor , in a nutshell, to be safe it would work, I have to find source code for the hostapd 2.6, put your patches in that project and compile it? Does that patched hostapd 2.6 already exists so that I can skip all the hassle of compiling I'm not familiar with, like a *.deb file?
No, I think the exact problem is as I describe it, but I don't plan to dig into that anytime soon. You can also later fix our scripts and save us some hassle :)
I had the same issue after upgrade and I just removed noscan=1 option from hostapd.conf.
BTW, here is the listing from armbianmonitor, if anyone finds it useful: http://ix.io/3xDv
