Belgrado Posted August 25, 2020 Share Posted August 25, 2020 Hi guys! I have a problem with Orange Pi 3. After a night leaving the small board turned on I reboot the board and try to use a Bluetooth connector it shutdown. Again and again the same problem. When I touched the board it was so hot. Even when I use outside the case the board can't support a process for at least 30 minutes without turning off. I got the outputs of dmesg. As I don't know, I am a replay newbie, I ask for help here. Best regards. Paulo Link to comment Share on other sites More sharing options...
Werner Posted August 26, 2020 Share Posted August 26, 2020 armbianmonitor -u You can also try the following: increase boot verbosity (see documentation) and connect a serial console. Open it and log its output. Maybe leave it over night if needed. Also try messing with the bluetooth while serial console is connected and collect any output it may throw when crashing. Link to comment Share on other sites More sharing options...
Igor Posted August 29, 2020 Share Posted August 29, 2020 Board powers off if critical temperature is reached. Without fan / large enough heat sink + hot summer, this is expected to happen. Link to comment Share on other sites More sharing options...
