1 hour ago, dolphs said:
Noticed from the patching logs
Which patching logs?  Are you seeing errors w/-dev?
Are these patches still needed for 5.9 ?
1/ general-packaging-5.6.y.patch
2/ add-missing-H6-cpu-opp-in-5.7.y.patch
AFAICT I resolved everything that needed resolution in v5.9.  Again, are you seeing issues with something?
19 hours ago, Igor said:
I also noticed this today, but on a current build. Looking ...  https://armbian.atlassian.net/browse/AR-425
@Igor normally this message should go away when the file /var/run/resize2fs-reboot isnt there/deleted:
root@npi-duo-113(192.168.6.113):/etc/update-motd.d# more 98-armbian-autoreboot-warn
#!/bin/bash
# Copyright (c) Authors: http://www.armbian.com/authors
# This file is licensed under the terms of the GNU General Public
# License version 2. This program is licensed "as is" without any
# warranty of any kind, whether express or implied.
# DO NOT EDIT THIS FILE
# any changes will be lost on board support package update
if [[ -f /var/run/resize2fs-reboot ]]; then
        printf "\e[0;91mWarning: a reboot is needed to finish resizing the filesystem \x1B[0m \n"
        printf "\e[0;91mPlease reboot the system as soon as possible \x1B[0m \n"
fi
I tested to delete that file and rebooted, but its recreated at restart :(
System diagnosis information will now be uploaded to http://ix.io/2xc4
Welcome to Armbian 20.11.0-trunk Buster with Linux 5.9.0-rc4-sunxi
package bsp-kernel[20.11.0-trunk] u-boot[20.11.0-trunk] dtb   [20.11.0-trunk]
firmware          [20.11.0-trunk] config[20.11.0-trunk] branch[dev]
root@npi-duo-113(192.168.6.113):~# rm /var/run/resize2fs-reboot
root@npi-duo-113(192.168.6.113):~# ls -l /var/run/resize2fs-reboot
ls: cannot access '/var/run/resize2fs-reboot': No such file or directory
root@npi-duo-113(192.168.6.113):~# reboot
-rw-r--r-- 1 root root 0 Sep 11 16:28 /var/run/resize2fs-reboot
That is expected.
Result of https://github.com/armbian/build/blob/master/packages/bsp/common/usr/lib/armbian/armbian-resize-filesystem#L120 is always error which means resize was not finished - even resize was done "successfully".
Type partprobe as root.
Error: Partition(s) 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64 on /dev/mmcblk0 have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes.
2 hours ago, Igor said:
That is expected.
@Igordid see also this partprobe-error-message while transfer from MicroSD to emmc on the NPi Neo Core2 :(
Is this also the reason, why we got this wierd "mountpoint"  /var/log.hdd for root?:
root@npi-duo-113(192.168.6.113):~# mount
/dev/mmcblk0p1 on / type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
/dev/mmcblk0p1 on /var/log.hdd type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
root@npi-neo-core2-21(192.168.6.21):~# mount|grep mmc
/dev/mmcblk2p1 on / type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
/dev/mmcblk2p1 on /var/log.hdd type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
I haven't been able to find the source of the problems yet.
@guidol - no, while this may seem weird it's perfectly normal - this is a "bind mount", and this is how bind mounts appear in "mount".  You can create one of these yourself, for example:
root@nanopi:~# mkdir foo bar
root@nanopi:~# mount --bind foo bar
root@nanopi:~# mount | grep bar
/dev/mmcblk1p2 on /root/bar type f2fs (rw,relatime,lazytime,background_gc=on,discard,no_heap,user_xattr,inline_xattr,acl,inline_data,inline_dentry,flush_merge,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,fsync_mode=posix,compress_algorithm=lz4,compress_log_size=2)
root@nanopi:~#
(The "log.hdd" bind mount is created via "/usr/lib/armbian/armbian-ramlog".)  Hope this helps!
Hmm indeed last time flashed image using rufus, using etcher shows following error.
It seems kernel related. 5.8 -> ERROR
Just build Odroid N2 with legacy 4.9.y kernel. Works fine.
I used Kernel 5.9.0 rc2/rc4 and a NanoPi Neo Core2 - I dont have a Odroid N2 :)
Any kernel below 5.8 probably don't have this issue. Try sunxi legacy.
If my theory is correct.
Hmm get atm U-boot compilation errors.
Will check back later building rc5
Displaying message: * [\e[32ml\e[0m][\e[32mc\e[0m] sun8i-set-machid.patch failed wrn
Displaying message: * [\e[32ml\e[0m][\e[32mc\e[0m] sunxi-boot-splash.patch failed wrn
Displaying message: * [\e[32ml\e[0m][\e[32mc\e[0m] xxx-disable-de2-to-improve-edid-detection.patch failed wrn
Displaying message: ERROR in function compile_uboot compilation.sh:220 err
Displaying message: U-boot compilation failed  err
Displaying message: Process terminated  info
EDIT: yup rc5 got build just now ( for: n2black )
Good "morning",
After rc6 it seems there is a small glitch
Either fix or remove 0001-bootslpash.patch :
Just compiled dev for orangepioneplus H6-board
- patching.log
Processing file /home/armbian/patch/misc/0001-bootsplash.patch
1 out of 5 hunks FAILED -- saving rejects to file drivers/video/fbdev/core/fbcon.c.rej
compilation.log
drivers/video/fbdev/core/dummyblit.c:81:14: error: assignment to ‘void (*)(struct vc_data *, struct fb_info *, int,  int,  int)’ from incompatible pointer type ‘void (*)(struct vc_data *, struct fb_info *, int,  int,  int,  int)’ [-Werror=incompatible-pointer-types]
   81 |  ops->cursor = dummy_cursor;
cc1: some warnings being treated as errors
make[4]: *** [scripts/Makefile.build:283: drivers/video/fbdev/core/dummyblit.o] Error 1
make[3]: *** [scripts/Makefile.build:500: drivers/video/fbdev/core] Error 2
make[2]: *** [scripts/Makefile.build:500: drivers/video/fbdev] Error 2
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [scripts/Makefile.build:500: drivers/video] Error 2
make[1]: *** Waiting for unfinished jobs....
make: *** [Makefile:1786: drivers] Error 2
17 minutes ago, dolphs said:
Good "morning",
Linus decided that this code is not needed so we have two choices:
- put the code back (last two commits)
- remove support for kernel boot splash
I already tried to fix it this morning, but it will need to wait until evening or tomorrow.
IMHO we should get rid of boot splash. It is just a nice-to-have that creates unnecessary work to maintenance.
6 hours ago, Igor said:
We'll put it back - 5.8.y will be around for a while.
perhaps 5.8.y will be around just another month till it will reach EOL.
If I am allowed I'd choose @Werner's proposal as it potentially could re-appear in a future kernel as it seems people are committed to its return ( @phoronix ) and for now put it aside imho
Its already fixed :) And its also because supporting @lanefu Pinebook PRO support efforts. Nice to have this features there.
OK sounds good!
It seems that one has been eliminated, ( smooth patching.log )
however yet stuff related to dax: ( as well a lot of rtl8811cu warnings ) - from compilation.log Error captured:
drivers/dax/super.c:325:6: error: redefinition of ‘dax_supported’
  325 | bool dax_supported(struct dax_device *dax_dev, struct block_device *bdev,
In file included from drivers/dax/super.c:16:
./include/linux/dax.h:162:20: note: previous definition of ‘dax_supported’ was here
  162 | static inline bool dax_supported(struct dax_device *dax_dev,
make[2]: *** [scripts/Makefile.build:283: drivers/dax/super.o] Error 1
make[1]: *** [scripts/Makefile.build:500: drivers/dax] Error 2
Tried to build with EXTRAWIFI=no to see if it persists but this leads into failing patches:
[ warn ] * [l][c] wifi-4003-fix-sha256_state-clashes.patch [ failed ]
[ warn ] * [l][c] wifi-4004-fix-cfg80211-for-5.8.patch [ failed ]
Processing file /home/build/build/patch/kernel/sunxi-dev/wifi-4003-fix-sha256_state-clashes.patch
The text leading up to this was:
|diff --git a/drivers/net/wireless/rtl8189es/include/rtw_security.h b/drivers/net/wireless/rtl8189es/include/rtw_security.h
|index 5820a55..3e8e428 100644
|--- a/drivers/net/wireless/rtl8189es/include/rtw_security.h
|+++ b/drivers/net/wireless/rtl8189es/include/rtw_security.h
No file to patch.  Skipping patch.
1 out of 1 hunk ignored
|diff --git a/drivers/net/wireless/rtl8189es/core/rtw_security.c b/drivers/net/wireless/rtl8189es/core/rtw_security.c
|index 8dac771..9b3a1f9 100644
|--- a/drivers/net/wireless/rtl8189es/core/rtw_security.c
|+++ b/drivers/net/wireless/rtl8189es/core/rtw_security.c
5 out of 5 hunks ignored
|diff --git a/drivers/net/wireless/rtl8811cu/include/rtw_security.h b/drivers/net/wireless/rtl8811cu/include/rtw_security.h
|index ac8432e..5f74fb7 100755
|--- a/drivers/net/wireless/rtl8811cu/include/rtw_security.h
|+++ b/drivers/net/wireless/rtl8811cu/include/rtw_security.h
|diff --git a/drivers/net/wireless/rtl8811cu/core/rtw_security.c b/drivers/net/wireless/rtl8811cu/core/rtw_security.c
|index b537a26..f8c42f4 100755
|--- a/drivers/net/wireless/rtl8811cu/core/rtw_security.c
|+++ b/drivers/net/wireless/rtl8811cu/core/rtw_security.c
|diff --git a/drivers/net/wireless/rtl8188eu/include/rtw_security.h b/drivers/net/wireless/rtl8188eu/include/rtw_security.h
|index 0adc700..2a9cf9d 100644
|--- a/drivers/net/wireless/rtl8188eu/include/rtw_security.h
|+++ b/drivers/net/wireless/rtl8188eu/include/rtw_security.h
|diff --git a/drivers/net/wireless/rtl8188eu/core/rtw_security.c b/drivers/net/wireless/rtl8188eu/core/rtw_security.c
|index 5807521..0b3eed2 100644
|--- a/drivers/net/wireless/rtl8188eu/core/rtw_security.c
|+++ b/drivers/net/wireless/rtl8188eu/core/rtw_security.c
|diff --git a/drivers/net/wireless/rtl88x2bu/include/rtw_security.h b/drivers/net/wireless/rtl88x2bu/include/rtw_security.h
|index ac8432e..5f74fb7 100644
|--- a/drivers/net/wireless/rtl88x2bu/include/rtw_security.h
|+++ b/drivers/net/wireless/rtl88x2bu/include/rtw_security.h
|diff --git a/drivers/net/wireless/rtl88x2bu/core/rtw_security.c b/drivers/net/wireless/rtl88x2bu/core/rtw_security.c
|index b537a26..f8c42f4 100644
|--- a/drivers/net/wireless/rtl88x2bu/core/rtw_security.c
|+++ b/drivers/net/wireless/rtl88x2bu/core/rtw_security.c
Processing file /home/build/build/patch/kernel/sunxi-dev/wifi-4004-fix-cfg80211-for-5.8.patch
|diff --git a/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c
|index d77cc17..32cc240 100644
|--- a/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c
|+++ b/drivers/net/wireless/rtl8189es/os_dep/linux/ioctl_cfg80211.c
3 out of 3 hunks ignored
|diff --git a/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c
|index c0df148..9bff924 100755
|--- a/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c
|+++ b/drivers/net/wireless/rtl8811cu/os_dep/linux/ioctl_cfg80211.c
|diff --git a/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c
|index 721723e..62fd530 100644
|--- a/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c
|+++ b/drivers/net/wireless/rtl8188eu/os_dep/linux/ioctl_cfg80211.c
|diff --git a/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c b/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c
|index 2fd4e28..b463e55 100755
|--- a/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c
|+++ b/drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c
Overall just a minor issue since it does no harm.
It spits out the same warnings so it seems not to be related to 3rd party WiFi.
For the DAX issue: https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/?h=pending-fixes&id=88b67edd7247466bc47f01e1dc539b0d0d4b931e
Probably fixed in next RC
That I addressed previously as well , suppose when we hit final 5.9 that will be worked on .
Yet "testing purposes" ( DEV ) I compile using following flags ( default is EXTRAWIFI=yes ) :
./compile.sh BRANCH=dev RELEASE=buster BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no
Will check back when rc7 has been released ( rgd dax ), thanks for that info!
If you cannot wait simply apply the patch by hand or put it as patch file into the sunxi-dev patch folder. It will compile then.
Exactly - this is because these additional Wi-Fi drivers are conditionally added outside of each local target patchset.  If the drivers aren't included (e.g., via "EXTRAWIFI=no", then the patches will fail because there are no files to patch.  As @Werner notes, this is really just a cosmetic issue.
On 9/22/2020 at 10:36 AM, Werner said:
looks like this patch has been added for rc6/ is fixed meanwhile, thanks! ( as well u-boot bumped to 7 )
-rw-rw-r-- 1 root root 796917760 Sep 24 09:52 Armbian_20.11.0-trunk_Orangepioneplus_buster_dev_5.9.0-rc6_minimal.img
-rw-rw-r-- 1 root sudo       137 Sep 24 09:52 Armbian_20.11.0-trunk_Orangepioneplus_buster_dev_5.9.0-rc6_minimal.img.sha
-rw-rw-r-- 1 root sudo     19667 Sep 24 09:52 Armbian_20.11.0-trunk_Orangepioneplus_buster_dev_5.9.0-rc6_minimal.img.txt
Processing file /home/build/build/patch/kernel/sunxi-dev/wifi-brcmfmac-fix-txctl-credits.patch
1 out of 1 hunk FAILED -- saving rejects to file drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c.rej
Something else got bricked in the meantime :lol:
holy smokes!
You are so right , indeed this time I built with "extrawifi=no" option so I did not "bother" about WiFi errors/ warnings, but definitely this is a point of interest for next iteration
Just fixed this in master; they rolled this patch into upstream with -rc6.   Thanks for noting this!
@5kft  - The image does build,  however the error @Werner mentioned earlier today is there compiling:
Please find attached patching.log, note the "wifi-brcmfmac-fix-txctl-credits.patch" that complains with:
patching.log
Yes, do a pull and try again - I just removed the offending patch as it was merged upstream in -rc6 :thumbup:
(See https://github.com/armbian/build/commit/9637d3d0f94203a8ea18495d61090dbe202aeeaf)
