5 minutes ago, svenoone said:
Is there some update or a walkaround you know?
Use a kegacy image for now.
3 minutes ago, svenoone said:
Hey @NicoD,
Thank you for your note, I never tested the Legacy images, i will give them a try, but I am not happy with that :(
The alternative to that right now seems to be using a fixed frequency. I personally have been using the "userspace" governor with min and max set to 1416000 and had no crashes at all since I started using those!
The current status last I read seemed to me that people are currently testing and looking for a solution.  I think it's a regression introduced by newer kernel or something like that.  You can find more info in this other thread which is about desktop however there seems to be a lot of RK3399 specific discussion starting at the post I linked.
Best thing you could do at this point is familiarize yourself with the discussion / issue, perhaps try and modify dtb and other things if you are capable, if not just follow along and give additional testing when more advanced users eventually post their solutions.  Because the evidence becomes much stronger if testing has been done by multiple people to confirm results (instead of jut one person).
Also, if you don't own a UART yet, you probably should to get one (or more) on their way to you in the mail.  They are only couple bucks apiece, and IMO anyone who play with SBC should own at least one!
EDIT: NicoD advice a few posts up (use legacy kernel) or Pedro Lamas' may be best in this case.  I did not read it until after posting.  Understand that as a Mod I read almost everything that is posted, so I end up with shallow (therefore sometimes wrong) understanding on a wide variety of topics.  lol  Don't mind me, carry on.  Some of general ideas in my post still apply, however, so I leave those.  Cheers.
Edited by TRS-80
add last paragraph
I tried this, and it seemed to be working. I set max to 1800000 and userspace and 1h30m no crashes.
I then put to performance and it crashed within 5 minutes of changing it. Kernel 5.9.11
Really strange since I've got another image running stable with performance and at 2Ghz. No I'll not update it :)
Update : Userspace and 2Ghz crashed... I'll try performance and 1.8Ghz...
With performance governor at 1.8Ghz it's now been stable for 50 minutes browsing and playing video.
@IgorThe default images for NanoPi M4 is legacy while for other RK3399's its mainline(M4V2 and others...).
Wouldn't it be better to change it to legacy for all rk3399's until this issue has been solved?
I've also gotten emails from my viewers that they've been angered by the crashes. They don't seem to know to choose for legacy.
I've no idea why it does this. I suspect panfrost. So I'll build an image without panfrost. Tho I'm running an image on the M4V2 with panfrost and at 2Ghz. Also had the crashes whith ondemand governor. Not with performance. While now it happens on the M4 with performance and 2Ghz.
dmesg is giving a crapload of messages even with 1.8Ghz. Many about panfrost.
18.254453] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=173)
[   18.269223] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   18.269237] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   18.275456] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   20.328038] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   20.328045] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   20.328484] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   20.328488] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   20.328791] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   20.328794] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   20.330782] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   20.330788] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   20.331372] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   20.331378] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   20.332035] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   20.332040] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   20.372328] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.372336] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.372986] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.372991] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.373554] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.373559] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.374149] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.374153] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.374753] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.374758] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.375532] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.375537] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.497732] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.497743] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.498991] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.499002] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.500177] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.500189] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.501672] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.501683] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.503254] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.503283] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.589793] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.589803] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.757612] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.757623] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.844250] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.844261] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.844469] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.844477] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   21.017372] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   21.017383] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   21.101639] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   21.101651] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   21.101872] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   21.101878] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   21.487471] Bluetooth: RFCOMM TTY layer initialized
[   21.487485] Bluetooth: RFCOMM socket layer initialized
[   21.487499] Bluetooth: RFCOMM ver 1.11
[   22.086830] overlayfs: "xino" feature enabled using 2 upper inode bits.
[   22.208504] overlayfs: "xino" feature enabled using 2 upper inode bits.
[   24.458793] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   26.392230] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   26.392242] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   26.392950] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   26.392975] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   26.394864] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   26.394888] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   35.809313] vcca0v9_s3: disabling
[   95.272485] Purging 532480 bytes
[   95.274578] Purging 614400 bytes
[   95.279749] Purging 614400 bytes
[   95.283384] Purging 630784 bytes
[   95.288982] Purging 8781824 bytes
[   95.372108] Purging 8601600 bytes
[   95.393132] Purging 1794048 bytes
[   95.398198] Purging 1802240 bytes
[   95.400337] Purging 655360 bytes
[   95.401631] Purging 1740800 bytes
[  109.646147] panfrost_gem_shrinker_scan: 25 callbacks suppressed
[  109.646158] Purging 8540160 bytes
[  109.655674] Purging 1646592 bytes
[  109.662863] Purging 688128 bytes
[  122.512774] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[  122.512781] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[  549.862523] Purging 708608 bytes
[  549.867583] Purging 528384 bytes
[  549.870068] Purging 528384 bytes
[  549.871084] Purging 815104 bytes
[  549.871967] Purging 626688 bytes
[  549.876811] Purging 1937408 bytes
[  549.877977] Purging 1646592 bytes
[  549.879587] Purging 1937408 bytes
[  549.880918] Purging 1683456 bytes
[  549.881482] Purging 655360 bytes
[  557.292607] panfrost_gem_shrinker_scan: 22 callbacks suppressed
[  557.292614] Purging 704512 bytes
[  557.308433] Purging 8388608 bytes
[  557.329438] Purging 8388608 bytes
[  557.331833] Purging 1646592 bytes
[  557.999503] Purging 8421376 bytes
[  558.007722] Purging 876544 bytes
[  558.016235] Purging 1675264 bytes
[  558.029021] Purging 1777664 bytes
[  558.034336] Purging 8388608 bytes
[  558.323785] Purging 8462336 bytes
[  562.339770] panfrost_gem_shrinker_scan: 15 callbacks suppressed
[  562.339773] Purging 8622080 bytes
[  562.344202] Purging 1654784 bytes
[  565.321764] Purging 8564736 bytes
[  565.326913] Purging 1646592 bytes
[  565.335586] Purging 1908736 bytes
[  565.336333] Purging 524288 bytes
[  565.449535] Purging 1699840 bytes
[  565.453031] Purging 524288 bytes
[  565.463600] Purging 8388608 bytes
[  565.469031] Purging 8519680 bytes
[  571.294789] Purging 532480 bytes
[  571.299202] Purging 1687552 bytes
[  571.308228] Purging 8388608 bytes
[  571.314791] Purging 1822720 bytes
[  573.270878] Purging 577536 bytes
[  573.272881] Purging 28672 bytes
[  573.283848] Purging 8388608 bytes
[  573.288225] Purging 1777664 bytes
[  592.314047] Purging 655360 bytes
[  592.317810] Purging 1675264 bytes
[  592.324650] Purging 8519680 bytes
[  592.328326] Purging 1646592 bytes
[  607.109539] Purging 741376 bytes
[  607.111962] Purging 1937408 bytes
[  607.117752] Purging 8388608 bytes
[  607.123582] Purging 8388608 bytes
[  607.184513] Purging 1810432 bytes
[  607.194250] Purging 1654784 bytes
[  607.209137] Purging 561152 bytes
[  607.231449] Purging 1937408 bytes
[  607.234838] Purging 1777664 bytes
[  607.241481] Purging 8388608 bytes
[  615.358248] panfrost_gem_shrinker_scan: 45 callbacks suppressed
[  615.358252] Purging 8495104 bytes
[  615.362977] Purging 1646592 bytes
[  615.368097] Purging 8388608 bytes
[  656.300196] Purging 671744 bytes
[  656.303659] Purging 1806336 bytes
[  656.312270] Purging 8519680 bytes
[  733.298548] Purging 716800 bytes
[  733.304865] Purging 8548352 bytes
[  930.452524] Purging 765952 bytes
[  930.462074] Purging 540672 bytes
[  930.463080] Purging 610304 bytes
[  930.482408] Purging 8679424 bytes
[  930.484688] Purging 1646592 bytes
[  930.492447] Purging 1843200 bytes
[  930.495179] Purging 1687552 bytes
[  930.512367] Purging 524288 bytes
[  930.514007] Purging 1925120 bytes
[  930.515222] Purging 1646592 bytes
[  943.103345] panfrost_gem_shrinker_scan: 25 callbacks suppressed
[  943.103348] Purging 765952 bytes
[  943.105492] Purging 552960 bytes
[  943.112358] Purging 8388608 bytes
[  943.115758] Purging 1646592 bytes
[  943.118428] Purging 1781760 bytes
[  943.125582] Purging 8388608 bytes
[  943.131119] Purging 1777664 bytes
[  943.138189] Purging 1646592 bytes
[  943.144833] Purging 8388608 bytes
[  943.149485] Purging 1777664 bytes
[  957.409029] panfrost_gem_shrinker_scan: 13 callbacks suppressed
[  957.409034] Purging 2039808 bytes
[  957.411108] Purging 524288 bytes
[  957.413617] Purging 1937408 bytes
[  957.415206] Purging 557056 bytes
[  957.417632] Purging 1646592 bytes
[  957.420508] Purging 1908736 bytes
[  957.426530] Purging 8388608 bytes
[  959.814262] Purging 524288 bytes
[  959.816512] Purging 528384 bytes
[  959.820138] Purging 1007616 bytes
[  985.298124] panfrost_gem_shrinker_scan: 11 callbacks suppressed
[  985.298127] Purging 782336 bytes
[  985.301454] Purging 1937408 bytes
[  985.304449] Purging 1646592 bytes
[  985.312141] Purging 8519680 bytes
[ 1224.692038] Purging 765952 bytes
[ 1224.709203] Purging 638976 bytes
[ 1224.710923] Purging 1937408 bytes
[ 1224.714933] Purging 1777664 bytes
[ 1224.716522] Purging 1777664 bytes
[ 1224.726016] Purging 8388608 bytes
[ 1224.727871] Purging 1646592 bytes
[ 1224.732983] Purging 8388608 bytes
[ 1224.738962] Purging 8519680 bytes
[ 1243.884921] Purging 700416 bytes
[ 1243.891456] Purging 614400 bytes
[ 1243.895029] Purging 1937408 bytes
[ 1243.901561] Purging 8388608 bytes
[ 1243.908603] Purging 8388608 bytes
[ 1335.539719] Purging 643072 bytes
[ 1335.546250] Purging 8491008 bytes
[ 1335.554683] Purging 8519680 bytes
[ 1335.556868] Purging 1667072 bytes
[ 1335.560416] Purging 1687552 bytes
[ 1335.563254] Purging 1908736 bytes
[ 1335.569554] Purging 8388608 bytes
[ 1335.571981] Purging 1646592 bytes
[ 1335.573733] Purging 823296 bytes
[ 1335.576004] Purging 1646592 bytes
[ 1373.526979] panfrost_gem_shrinker_scan: 6 callbacks suppressed
[ 1373.526989] Purging 950272 bytes
[ 1373.535211] Purging 684032 bytes
[ 1373.538300] Purging 1675264 bytes
[ 1373.539655] Purging 1777664 bytes
[ 1373.541182] Purging 1908736 bytes
[ 1373.546372] Purging 1646592 bytes
[ 1373.551551] Purging 8388608 bytes
[ 1373.552905] Purging 1646592 bytes
[ 1373.566644] Purging 8519680 bytes
[ 1425.788360] Purging 532480 bytes
[ 1425.795019] Purging 8470528 bytes
[ 1441.163661] Purging 667648 bytes
[ 1441.169021] Purging 552960 bytes
[ 1441.185423] Purging 1769472 bytes
[ 1441.186742] Purging 655360 bytes
[ 1441.190155] Purging 1675264 bytes
[ 1441.201911] Purging 1908736 bytes
[ 1441.204909] Purging 1646592 bytes
[ 1441.214869] Purging 8388608 bytes
[ 1441.226626] Purging 8519680 bytes
[ 1441.229163] Purging 1777664 bytes
[ 1449.239856] panfrost_gem_shrinker_scan: 4 callbacks suppressed
[ 1449.239860] Purging 716800 bytes
[ 1449.242615] Purging 1675264 bytes
[ 1449.250327] Purging 8388608 bytes
[ 1449.252849] Purging 1777664 bytes
[ 1449.265362] Purging 8388608 bytes
[ 1449.271377] Purging 8519680 bytes
[ 1449.272668] Purging 1646592 bytes
[ 1449.277739] Purging 8519680 bytes
[ 1461.286741] Purging 704512 bytes
[ 1461.289420] Purging 1675264 bytes
[ 1461.296063] Purging 8519680 bytes
[ 1461.297274] Purging 1646592 bytes
[ 1470.743445] Purging 712704 bytes
[ 1470.753072] Purging 2121728 bytes
[ 1470.754140] Purging 561152 bytes
[ 1470.760090] Purging 1646592 bytes
[ 1470.772662] Purging 1646592 bytes
[ 1470.782698] Purging 8388608 bytes
[ 1470.784936] Purging 1646592 bytes
[ 1470.792608] Purging 8519680 bytes
[ 1470.797594] Purging 8388608 bytes
[ 1480.933348] Purging 524288 bytes
[ 1480.936529] Purging 737280 bytes
[ 1480.940204] Purging 1798144 bytes
[ 1480.946424] Purging 8650752 bytes
[ 1485.882042] Purging 749568 bytes
[ 1485.889615] Purging 1675264 bytes
[ 1485.897837] Purging 8519680 bytes
[ 1485.899444] Purging 1777664 bytes
[ 1485.903881] Purging 1646592 bytes
[ 1485.908971] Purging 8388608 bytes
[ 1498.834445] panfrost_gem_shrinker_scan: 2 callbacks suppressed
[ 1498.834450] Purging 860160 bytes
[ 1498.840303] Purging 1798144 bytes
[ 1498.848129] Purging 8388608 bytes
[ 1498.850365] Purging 1777664 bytes
[ 1501.845956] Purging 692224 bytes
[ 1501.860864] Purging 8417280 bytes
[ 1501.867045] Purging 1777664 bytes
[ 1501.872292] Purging 8388608 bytes
[ 1800.415056] Purging 524288 bytes
[ 1800.419341] Purging 696320 bytes
[ 1800.419916] Purging 598016 bytes
[ 1800.423685] Purging 1675264 bytes
[ 1800.428086] Purging 1953792 bytes
[ 1800.429473] Purging 1810432 bytes
[ 1800.430609] Purging 1646592 bytes
[ 1800.431166] Purging 655360 bytes
[ 1800.432915] Purging 1806336 bytes
[ 1800.440390] Purging 8519680 bytes
[ 1825.008772] panfrost_gem_shrinker_scan: 1 callbacks suppressed
[ 1825.008778] Purging 8617984 bytes
[ 1825.018107] Purging 8388608 bytes
[ 1852.618626] Purging 634880 bytes
[ 1852.638452] Purging 8388608 bytes
[ 1852.646089] Purging 1777664 bytes
[ 1852.648860] Purging 1810432 bytes
[ 1852.659781] Purging 524288 bytes
[ 1852.661284] Purging 618496 bytes
[ 1852.664397] Purging 1646592 bytes
[ 1852.668254] Purging 1937408 bytes
[ 1852.851572] Purging 593920 bytes
[ 1852.857059] Purging 1662976 bytes
[ 1895.553470] panfrost_gem_shrinker_scan: 16 callbacks suppressed
[ 1895.553475] Purging 733184 bytes
[ 1895.561220] Purging 8388608 bytes
[ 1895.569151] Purging 8519680 bytes
[ 1895.574642] Purging 8388608 bytes
[ 1895.592873] Purging 1675264 bytes
[ 1896.306438] Purging 1908736 bytes
[ 1896.309574] Purging 1679360 bytes
[ 1896.313491] Purging 524288 bytes
[ 1896.318782] Purging 8781824 bytes
[ 1896.319978] Purging 1646592 bytes
[ 1927.816223] Purging 8536064 bytes
[ 1927.821657] Purging 1712128 bytes
[ 1927.825335] Purging 655360 bytes
[ 1927.826579] Purging 1675264 bytes
[ 1927.837100] Purging 8519680 bytes
[ 1927.838594] Purging 1777664 bytes
[ 1927.844100] Purging 8388608 bytes
[ 1966.311076] Purging 700416 bytes
[ 1966.318614] Purging 8548352 bytes
[ 2001.333433] Purging 8560640 bytes
[ 2001.814751] Purging 1884160 bytes
[ 2001.821615] Purging 8388608 bytes
[ 2001.829129] Purging 8519680 bytes
[ 2002.161136] Purging 1679360 bytes
[ 2002.170462] Purging 1908736 bytes
[ 2002.183662] Purging 8388608 bytes
[ 2002.358522] Purging 1744896 bytes
[ 2002.378115] Purging 1843200 bytes
[ 2002.390810] Purging 524288 bytes
[ 2027.969267] panfrost_gem_shrinker_scan: 3 callbacks suppressed
[ 2027.969275] Purging 8433664 bytes
[ 2028.080828] Purging 675840 bytes
[ 2028.085468] Purging 1806336 bytes
[ 2028.092161] Purging 1646592 bytes
[ 2028.093452] Purging 1777664 bytes
[ 2028.100954] Purging 8519680 bytes
[ 2028.139540] Purging 8388608 bytes
[ 2028.248497] Purging 8388608 bytes
[ 2028.262703] Purging 8388608 bytes
[ 2028.268906] Purging 8429568 bytes
[ 2032.976931] panfrost_gem_shrinker_scan: 54 callbacks suppressed
[ 2032.976934] Purging 1662976 bytes
[ 2032.985533] Purging 8388608 bytes
[ 2032.989870] Purging 696320 bytes
[ 2032.997976] Purging 8388608 bytes
[ 2033.007640] Purging 8388608 bytes
[ 2033.021027] Purging 8388608 bytes
[ 2033.073865] Purging 630784 bytes
[ 2033.077767] Purging 1675264 bytes
[ 2033.081262] Purging 1777664 bytes
[ 2033.089447] Purging 8388608 bytes
[ 2038.046092] panfrost_gem_shrinker_scan: 82 callbacks suppressed
[ 2038.046095] Purging 614400 bytes
[ 2038.047282] Purging 1646592 bytes
[ 2038.048889] Purging 1777664 bytes
[ 2038.057276] Purging 8388608 bytes
[ 2038.165198] Purging 573440 bytes
[ 2038.173279] Purging 8548352 bytes
[ 2038.174675] Purging 1777664 bytes
[ 2038.319659] Purging 1716224 bytes
[ 2038.327185] Purging 8388608 bytes
[ 2038.370700] Purging 8388608 bytes
[ 2044.032385] panfrost_gem_shrinker_scan: 95 callbacks suppressed
[ 2044.032394] Purging 675840 bytes
[ 2044.039357] Purging 1937408 bytes
[ 2044.054540] Purging 8388608 bytes
[ 2044.060002] Purging 1646592 bytes
[ 2044.070656] Purging 8556544 bytes
[ 2044.073203] Purging 561152 bytes
[ 2046.648699] Purging 1949696 bytes
[ 2046.652483] Purging 819200 bytes
[ 2046.655620] Purging 1646592 bytes
[ 2046.662345] Purging 1798144 bytes
[ 2049.125499] panfrost_gem_shrinker_scan: 47 callbacks suppressed
[ 2049.125506] Purging 622592 bytes
[ 2049.127786] Purging 1806336 bytes
[ 2049.156783] Purging 8388608 bytes
[ 2049.173557] Purging 1646592 bytes
[ 2049.202420] Purging 1646592 bytes
[ 2049.209047] Purging 8388608 bytes
[ 2049.367148] Purging 569344 bytes
[ 2049.380202] Purging 1703936 bytes
[ 2049.386191] Purging 8388608 bytes
[ 2049.404174] Purging 8388608 bytes
[ 2055.570471] panfrost_gem_shrinker_scan: 81 callbacks suppressed
[ 2055.570474] Purging 524288 bytes
[ 2418.873437] Purging 655360 bytes
[ 2418.878189] Purging 532480 bytes
[ 2418.885902] Purging 524288 bytes
[ 2418.887974] Purging 602112 bytes
[ 2418.925549] Purging 581632 bytes
[ 2418.926847] Purging 1675264 bytes
[ 2418.936350] Purging 1777664 bytes
[ 2418.942798] Purging 8519680 bytes
[ 2418.949240] Purging 8388608 bytes
[ 2418.951062] Purging 1777664 bytes
[ 2424.305983] panfrost_gem_shrinker_scan: 81 callbacks suppressed
[ 2424.305988] Purging 8515584 bytes
[ 2424.307511] Purging 1646592 bytes
[ 2424.333284] Purging 8499200 bytes
[ 2424.339869] Purging 8388608 bytes
[ 2424.346430] Purging 8388608 bytes
[ 2424.348090] Purging 1646592 bytes
[ 2424.349657] Purging 1982464 bytes
[ 2424.350216] Purging 655360 bytes
[ 2424.351440] Purging 1646592 bytes
[ 2424.356784] Purging 8388608 bytes
[ 2727.768160] panfrost_gem_shrinker_scan: 34 callbacks suppressed
[ 2727.768167] Purging 741376 bytes
[ 2727.772448] Purging 585728 bytes
[ 2727.775753] Purging 569344 bytes
[ 2727.779494] Purging 2056192 bytes
[ 2728.067705] Purging 8388608 bytes
[ 2728.075536] Purging 8388608 bytes
[ 2737.433755] Purging 794624 bytes
[ 2737.436483] Purging 1667072 bytes
[ 2737.445424] Purging 8650752 bytes
[ 2737.447862] Purging 1646592 bytes
[ 2737.454135] Purging 8388608 bytes
[ 2737.456505] Purging 1646592 bytes
[ 2737.463257] Purging 8519680 bytes
[ 2737.466759] Purging 1777664 bytes
[ 2737.469454] Purging 1646592 bytes
[ 2737.477719] Purging 8519680 bytes
[ 2771.468365] panfrost_gem_shrinker_scan: 22 callbacks suppressed
[ 2771.468378] Purging 708608 bytes
[ 2771.475294] Purging 1675264 bytes
[ 2771.484398] Purging 1994752 bytes
[ 2771.488660] Purging 528384 bytes
[ 2771.493449] Purging 1777664 bytes
[ 2771.507785] Purging 8404992 bytes
[ 2771.514334] Purging 1646592 bytes
[ 2771.520811] Purging 1908736 bytes
[ 2771.531738] Purging 8388608 bytes
[ 2771.541674] Purging 8519680 bytes
[ 2780.546578] panfrost_gem_shrinker_scan: 41 callbacks suppressed
[ 2780.546585] Purging 524288 bytes
[ 3046.925594] Purging 1015808 bytes
[ 3046.927129] Purging 610304 bytes
[ 3046.928973] Purging 524288 bytes
[ 3046.930650] Purging 1937408 bytes
[ 3046.932283] Purging 1777664 bytes
[ 3046.934904] Purging 557056 bytes
[ 3046.937683] Purging 1777664 bytes
[ 3046.940371] Purging 1671168 bytes
[ 3046.955855] Purging 8519680 bytes
[ 3046.958572] Purging 1777664 bytes
[ 3331.919677] panfrost_gem_shrinker_scan: 3 callbacks suppressed
[ 3331.919681] Purging 577536 bytes
[ 3331.927017] Purging 8577024 bytes
[ 3331.928895] Purging 573440 bytes
[ 3331.934846] Purging 8417280 bytes
[ 3332.096249] Purging 524288 bytes
[ 3332.099475] Purging 4345856 bytes
[ 3332.101777] Purging 540672 bytes
[ 3332.111906] Purging 8683520 bytes
[ 3332.113834] Purging 1777664 bytes
[ 3333.341479] Purging 7929856 bytes
[ 3435.049246] panfrost_gem_shrinker_scan: 1 callbacks suppressed
[ 3435.049250] Purging 589824 bytes
[ 3435.052791] Purging 557056 bytes
[ 3559.006383] Purging 589824 bytes
[ 3559.008573] Purging 532480 bytes
[ 3559.012171] Purging 659456 bytes
[ 3559.022481] Purging 8417280 bytes
[ 3559.025080] Purging 1777664 bytes
[ 3563.097167] Purging 724992 bytes
[ 3563.100408] Purging 528384 bytes
[ 3563.110544] Purging 8388608 bytes
And it crashed again after writing this message. After about  hour active time.
After changing all cores to 1.42Ghz and userspace governor I still have these errors.
17.458165] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=173)
[   17.473075] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   17.473094] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   17.473600] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   19.493897] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   19.493905] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   19.494445] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   19.494450] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   19.494851] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   19.494857] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   19.495420] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   19.495426] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   19.496048] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   19.496053] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   19.496703] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   19.496709] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   19.541759] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.541766] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.542572] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.542579] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.543257] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.543264] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.544043] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.544051] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.544955] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.544961] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.546175] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.546182] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.669717] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.669729] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.671212] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.671223] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.672526] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.672538] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.674130] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.674143] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.675735] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.675746] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.761644] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.761656] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.929515] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.929526] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.013453] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.013464] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.013653] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.013659] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.186522] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.186533] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.269385] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.269395] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.269574] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   20.269580] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   20.678874] Bluetooth: RFCOMM TTY layer initialized
[   20.678889] Bluetooth: RFCOMM socket layer initialized
[   20.678909] Bluetooth: RFCOMM ver 1.11
[   21.004155] overlayfs: "xino" feature enabled using 2 upper inode bits.
[   21.108648] overlayfs: "xino" feature enabled using 2 upper inode bits.
[   23.666903] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   25.577894] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   25.577922] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   25.579643] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   25.579654] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   25.580558] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   25.580568] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   35.809520] vcca0v9_s3: disabling
[  174.557676] Purging 524288 bytes
[  174.576679] Purging 8130560 bytes
[  174.577424] Purging 647168 bytes
[  174.728961] Purging 1015808 bytes
[  174.735647] Purging 581632 bytes
[  174.742137] Purging 593920 bytes
[  174.745432] Purging 626688 bytes
[  174.751878] Purging 8605696 bytes
[  174.758158] Purging 8519680 bytes
[  177.318465] Purging 782336 bytes
http://ix.io/2H3M
1 hour ago, NicoD said:
I suspect panfrost.
Isn't disabled by default on Armbian?
It doesn't seem so. Enabled by default. It's a downloaded image from backups. It was 5.8.6 but upgraded to 5.9.11.
I'll double check tomorrow.
I'll let it do a stability test all night with 1.42Ghz all cores and userspace governor. It seems it gets more stable the lower the clock-frequency. But seems to have gotten worse the last days. It used to be usable.
@IgorPanfrost is indeed activated by default. Newly downloaded https://redirect.armbian.com/region/EU/nanopim4/Focal_current_desktop
Only did update and installed mesa-utils. No upgrade.
Weird thing is that the repo for the mesa drivers isn't in the repo list. So it can't update the driver.
I'll update the driver and do stability tests.
This is the repo
sudo add-apt-repository ppa:oibaf/graphics-drivers
Edited by NicoD
added info
Still crashes with the driver update and ondemand governor. Also with performance and 2Ghz.
Many errors in dmesg, not only panfrost related. But I'm about sure the panfrost driver is the cause of the crashes.
nicod@nanopim4:~$ dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.9.11-rockchip64 (root@beast) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.11.1 SMP PREEMPT Fri Nov 27 21:59:08 CET 2020
[    0.000000] Machine model: FriendlyElec NanoPi M4
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 128 MiB at 0x0000000070c00000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fba4100-0x7fba5fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] On node 0 totalpages: 523776
[    0.000000]   DMA zone: 4088 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261632 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 262144 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 32 pages/cpu s93784 r8192 d29096 u131072
[    0.000000] pcpu-alloc: s93784 r8192 d29096 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 515592
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=2806decf-e4bd-423c-9ac4-6d7c3a5947b6 rootwait rootfstype=ext4 bootsplash.bootfile=bootsplash.armbian console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=f20ec8b3-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 1814040K/2095104K available (14528K kernel code, 2096K rwdata, 5992K rodata, 4224K init, 575K bss, 149992K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @7f100000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x000000007f0b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x000000007f0c0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] random: get_random_bytes called from start_kernel+0x690/0x848 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001315] Console: colour dummy device 80x25
[    0.001333] printk: console [tty1] enabled
[    0.001452] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001466] pid_max: default: 32768 minimum: 301
[    0.001615] LSM: Security Framework initializing
[    0.001657] Yama: becoming mindful.
[    0.001800] AppArmor: AppArmor initialized
[    0.001879] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001901] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.005063] rcu: Hierarchical SRCU implementation.
[    0.006224] Platform MSI: interrupt-controller@fee20000 domain created
[    0.006691] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.009047] EFI services will not be available.
[    0.009684] smp: Bringing up secondary CPUs ...
[    0.010604] Detected VIPT I-cache on CPU1
[    0.010644] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.010662] GICv3: CPU1: using allocated LPI pending table @0x000000007f0d0000
[    0.010716] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.011793] Detected VIPT I-cache on CPU2
[    0.011825] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.011840] GICv3: CPU2: using allocated LPI pending table @0x000000007f0e0000
[    0.011876] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.012946] Detected VIPT I-cache on CPU3
[    0.012977] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.012992] GICv3: CPU3: using allocated LPI pending table @0x000000007f0f0000
[    0.013027] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.014065] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[    0.014075] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.014082] Detected PIPT I-cache on CPU4
[    0.014116] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.014130] GICv3: CPU4: using allocated LPI pending table @0x000000007f180000
[    0.014169] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.015176] Detected PIPT I-cache on CPU5
[    0.015204] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.015217] GICv3: CPU5: using allocated LPI pending table @0x000000007f190000
[    0.015246] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.015396] smp: Brought up 1 node, 6 CPUs
[    0.015405] SMP: Total of 6 processors activated.
[    0.015414] CPU features: detected: 32-bit EL0 Support
[    0.015423] CPU features: detected: CRC32 instructions
[    0.015432] CPU features: detected: 32-bit EL1 Support
[    0.043439] CPU: All CPU(s) started at EL2
[    0.043503] alternatives: patching kernel code
[    0.046440] devtmpfs: initialized
[    0.061565] Registered cp15_barrier emulation handler
[    0.061585] Registered setend emulation handler
[    0.062442] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.062506] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.065574] xor: measuring software checksum speed
[    0.105083]    8regs     :  2346.000 MB/sec
[    0.145170]    32regs    :  2757.000 MB/sec
[    0.185260]    arm64_neon:  2226.000 MB/sec
[    0.185265] xor: using function: 32regs (2757.000 MB/sec)
[    0.185316] pinctrl core: initialized pinctrl subsystem
[    0.185962] DMI not present or invalid.
[    0.186549] NET: Registered protocol family 16
[    0.189457] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.190887] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.191666] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.191763] audit: initializing netlink subsys (disabled)
[    0.192059] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.193291] thermal_sys: Registered thermal governor 'fair_share'
[    0.193296] thermal_sys: Registered thermal governor 'bang_bang'
[    0.193302] thermal_sys: Registered thermal governor 'step_wise'
[    0.193308] thermal_sys: Registered thermal governor 'user_space'
[    0.193777] cpuidle: using governor menu
[    0.194093] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.194318] ASID allocator initialised with 65536 entries
[    0.195549] Serial: AMBA PL011 UART driver
[    0.258209] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.258219] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.258227] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.258234] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.263986] cryptd: max_cpu_qlen set to 1000
[    0.341663] raid6: neonx8   gen()  1664 MB/s
[    0.409814] raid6: neonx8   xor()  1222 MB/s
[    0.477976] raid6: neonx4   gen()  1683 MB/s
[    0.546128] raid6: neonx4   xor()  1265 MB/s
[    0.614293] raid6: neonx2   gen()  1508 MB/s
[    0.682435] raid6: neonx2   xor()  1159 MB/s
[    0.750593] raid6: neonx1   gen()  1182 MB/s
[    0.818749] raid6: neonx1   xor()   942 MB/s
[    0.886932] raid6: int64x8  gen()   993 MB/s
[    0.955075] raid6: int64x8  xor()   578 MB/s
[    1.023230] raid6: int64x4  gen()   991 MB/s
[    1.091367] raid6: int64x4  xor()   589 MB/s
[    1.159521] raid6: int64x2  gen()   927 MB/s
[    1.227689] raid6: int64x2  xor()   522 MB/s
[    1.295824] raid6: int64x1  gen()   726 MB/s
[    1.363988] raid6: int64x1  xor()   389 MB/s
[    1.363994] raid6: using algorithm neonx4 gen() 1683 MB/s
[    1.363999] raid6: .... xor() 1265 MB/s, rmw enabled
[    1.364005] raid6: using neon recovery algorithm
[    1.368303] vcc5v0_sys: supplied by vdd_5v
[    1.368434] vbus_typec: supplied by vdd_5v
[    1.368496] vcc5v0_core: supplied by vdd_5v
[    1.368892] vcc3v3_sys: supplied by vcc5v0_core
[    1.368981] vcc3v0_sd: supplied by vcc3v3_sys
[    1.369089] vcc5v0_usb1: supplied by vcc5v0_sys
[    1.369539] vcc5v0_usb2: supplied by vcc5v0_sys
[    1.369967] iommu: Default domain type: Translated
[    1.373241] vgaarb: loaded
[    1.373755] SCSI subsystem initialized
[    1.374013] libata version 3.00 loaded.
[    1.374268] usbcore: registered new interface driver usbfs
[    1.374311] usbcore: registered new interface driver hub
[    1.374419] usbcore: registered new device driver usb
[    1.375057] pps_core: LinuxPPS API ver. 1 registered
[    1.375063] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.375078] PTP clock support registered
[    1.375367] EDAC MC: Ver: 3.0.0
[    1.376519] NetLabel: Initializing
[    1.376526] NetLabel:  domain hash size = 128
[    1.376531] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.376594] NetLabel:  unlabeled traffic allowed by default
[    1.377111] clocksource: Switched to clocksource arch_sys_counter
[    1.499591] VFS: Disk quotas dquot_6.6.0
[    1.499667] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.500500] AppArmor: AppArmor Filesystem Enabled
[    1.510910] NET: Registered protocol family 2
[    1.511758] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.511850] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.512118] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.512453] TCP: Hash tables configured (established 16384 bind 16384)
[    1.512604] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.512694] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.512950] NET: Registered protocol family 1
[    1.512980] NET: Registered protocol family 44
[    1.512994] PCI: CLS 0 bytes, default 64
[    1.513257] Trying to unpack rootfs image as initramfs...
[    2.641307] Freeing initrd memory: 15384K
[    2.642558] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    2.643015] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    2.643688] kvm [1]: IPA Size Limit: 40bits
[    2.644434] kvm [1]: vgic-v2@fff20000
[    2.644469] kvm [1]: GIC system register CPU interface enabled
[    2.644713] kvm [1]: vgic interrupt IRQ10
[    2.645010] kvm [1]: Hyp mode initialized successfully
[    2.655929] Initialise system trusted keyrings
[    2.655983] Key type blacklist registered
[    2.656185] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    2.662404] zbud: loaded
[    2.663957] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.664804] fuse: init (API version 7.31)
[    2.666151] integrity: Platform Keyring initialized
[    2.730762] Key type asymmetric registered
[    2.730768] Asymmetric key parser 'x509' registered
[    2.730809] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.731066] io scheduler mq-deadline registered
[    2.731072] io scheduler kyber registered
[    2.731202] io scheduler bfq registered
[    2.748965] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.748991] OF: /pcie@f8000000: Missing device_type
[    2.749022] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.749043] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.749971] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    2.749998] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    2.756781] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.756793] dma-pl330 ff6d0000.dma-controller: 	DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    2.758300] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.758312] dma-pl330 ff6e0000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.763266] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.766646] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 39, base_baud = 1500000) is a 16550A
[    2.766815] serial serial0: tty port ttyS0 registered
[    2.767609] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 40, base_baud = 1500000) is a 16550A
[    2.767787] printk: console [ttyS2] enabled
[    2.769083] Serial: AMBA driver
[    2.770539] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.782188] loop: module loaded
[    2.787826] libphy: Fixed MDIO Bus: probed
[    2.788160] tun: Universal TUN/TAP device driver, 1.6
[    2.789254] thunder_xcv, ver 1.0
[    2.789298] thunder_bgx, ver 1.0
[    2.789339] nicpf, ver 1.0
[    2.790432] e1000e: Intel(R) PRO/1000 Network Driver
[    2.790436] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.790486] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.790491] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.790537] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    2.790543] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.790820] sky2: driver version 1.30
[    2.791523] VFIO - User Level meta-driver version: 0.3
[    2.800715] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
[    2.816921] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.816942] ehci-pci: EHCI PCI platform driver
[    2.816981] ehci-platform: EHCI generic platform driver
[    2.819431] ehci-platform fe380000.usb: EHCI Host Controller
[    2.819476] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    2.819632] ehci-platform fe380000.usb: irq 31, io mem 0xfe380000
[    2.833132] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.833377] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    2.833387] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.833396] usb usb1: Product: EHCI Host Controller
[    2.833404] usb usb1: Manufacturer: Linux 5.9.11-rockchip64 ehci_hcd
[    2.833411] usb usb1: SerialNumber: fe380000.usb
[    2.833999] hub 1-0:1.0: USB hub found
[    2.834046] hub 1-0:1.0: 1 port detected
[    2.836812] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.836834] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    2.836971] ehci-platform fe3c0000.usb: irq 33, io mem 0xfe3c0000
[    2.849139] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.849372] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    2.849383] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.849391] usb usb2: Product: EHCI Host Controller
[    2.849399] usb usb2: Manufacturer: Linux 5.9.11-rockchip64 ehci_hcd
[    2.849407] usb usb2: SerialNumber: fe3c0000.usb
[    2.849905] hub 2-0:1.0: USB hub found
[    2.849951] hub 2-0:1.0: 1 port detected
[    2.850715] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.850757] ohci-pci: OHCI PCI platform driver
[    2.850813] ohci-platform: OHCI generic platform driver
[    2.851139] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.851160] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    2.851296] ohci-platform fe3a0000.usb: irq 32, io mem 0xfe3a0000
[    2.913342] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[    2.913353] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.913361] usb usb3: Product: Generic Platform OHCI controller
[    2.913368] usb usb3: Manufacturer: Linux 5.9.11-rockchip64 ohci_hcd
[    2.913375] usb usb3: SerialNumber: fe3a0000.usb
[    2.913853] hub 3-0:1.0: USB hub found
[    2.913891] hub 3-0:1.0: 1 port detected
[    2.914575] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    2.914595] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    2.914713] ohci-platform fe3e0000.usb: irq 34, io mem 0xfe3e0000
[    2.977313] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
[    2.977323] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.977331] usb usb4: Product: Generic Platform OHCI controller
[    2.977338] usb usb4: Manufacturer: Linux 5.9.11-rockchip64 ohci_hcd
[    2.977345] usb usb4: SerialNumber: fe3e0000.usb
[    2.977821] hub 4-0:1.0: USB hub found
[    2.977859] hub 4-0:1.0: 1 port detected
[    2.979355] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.979378] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    2.979554] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    2.979580] xhci-hcd xhci-hcd.0.auto: irq 230, io mem 0xfe800000
[    2.979994] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    2.980004] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.980012] usb usb5: Product: xHCI Host Controller
[    2.980019] usb usb5: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
[    2.980026] usb usb5: SerialNumber: xhci-hcd.0.auto
[    2.980522] hub 5-0:1.0: USB hub found
[    2.980570] hub 5-0:1.0: 1 port detected
[    2.980932] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.980948] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
[    2.980965] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    2.981040] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.981223] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[    2.981232] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.981240] usb usb6: Product: xHCI Host Controller
[    2.981248] usb usb6: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
[    2.981255] usb usb6: SerialNumber: xhci-hcd.0.auto
[    2.981727] hub 6-0:1.0: USB hub found
[    2.981774] hub 6-0:1.0: 1 port detected
[    2.982319] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.982342] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
[    2.982528] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    2.982593] xhci-hcd xhci-hcd.1.auto: irq 231, io mem 0xfe900000
[    2.982982] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
[    2.982992] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.983000] usb usb7: Product: xHCI Host Controller
[    2.983007] usb usb7: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
[    2.983014] usb usb7: SerialNumber: xhci-hcd.1.auto
[    2.983474] hub 7-0:1.0: USB hub found
[    2.983512] hub 7-0:1.0: 1 port detected
[    2.983846] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    2.983861] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
[    2.983877] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    2.983952] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.984089] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
[    2.984097] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.984105] usb usb8: Product: xHCI Host Controller
[    2.984112] usb usb8: Manufacturer: Linux 5.9.11-rockchip64 xhci-hcd
[    2.984119] usb usb8: SerialNumber: xhci-hcd.1.auto
[    2.984597] hub 8-0:1.0: USB hub found
[    2.984633] hub 8-0:1.0: 1 port detected
[    2.985224] usbcore: registered new interface driver usb-storage
[    2.987708] mousedev: PS/2 mouse device common for all mice
[    2.989041] i2c /dev entries driver
[    2.997737] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.999142] vdd_cpu_b: supplied by vcc3v3_sys
[    3.002477] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.003852] vdd_gpu: supplied by vcc3v3_sys
[    3.008039] rk808 0-001b: chip id: 0x0
[    3.012441] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    3.012471] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    3.013451] vdd_center: supplied by vcc3v3_sys
[    3.014102] vdd_cpu_l: supplied by vcc3v3_sys
[    3.014433] vcc_ddr: supplied by vcc3v3_sys
[    3.015078] vcc_1v8: supplied by vcc3v3_sys
[    3.016408] vcc1v8_cam: supplied by vcc3v3_sys
[    3.017502] vcc3v0_touch: supplied by vcc3v3_sys
[    3.018694] vcc1v8_pmupll: supplied by vcc3v3_sys
[    3.019911] vcc_sdio: supplied by vcc3v3_sys
[    3.020965] vcca3v0_codec: supplied by vcc3v3_sys
[    3.022181] vcc_1v5: supplied by vcc3v3_sys
[    3.023234] vcca1v8_codec: supplied by vcc3v3_sys
[    3.024430] vcc_3v0: supplied by vcc3v3_sys
[    3.024797] vcc3v3_s3: supplied by vcc3v3_sys
[    3.025205] vcc3v3_s0: supplied by vcc3v3_sys
[    3.028929] rk808-rtc rk808-rtc: registered as rtc0
[    3.029462] random: fast init done
[    3.029501] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:12 UTC (1358499012)
[    3.037460] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    3.039600] sdhci: Secure Digital Host Controller Interface driver
[    3.039606] sdhci: Copyright(c) Pierre Ossman
[    3.039631] Synopsys Designware Multimedia Card Interface Driver
[    3.041138] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
[    3.041192] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
[    3.041206] dwmmc_rockchip fe310000.mmc: Version ID is 270a
[    3.041266] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
[    3.041568] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
[    3.041577] mmc_host mmc0: card is non-removable.
[    3.053321] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.066896] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    3.066925] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    3.066939] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    3.067028] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    3.067518] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    3.080504] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.094146] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.095902] mmc2: CQHCI version 5.10
[    3.096394] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.098018] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.099625] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.102534] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.121832] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    3.124336] ledtrig-cpu: registered to indicate activity on CPUs
[    3.126117] hid: raw HID events driver (C) Jiri Kosina
[    3.126403] usbcore: registered new interface driver usbhid
[    3.126409] usbhid: USB HID core driver
[    3.131436] vcc1v8_s3: supplied by vcc_1v8
[    3.131555] vcca1v8_s3: supplied by vcc1v8_s3
[    3.134475] drop_monitor: Initializing network drop monitor service
[    3.135643] NET: Registered protocol family 10
[    3.160348] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    3.180526] Segment Routing with IPv6
[    3.180675] NET: Registered protocol family 17
[    3.180860] 8021q: 802.1Q VLAN Support v1.8
[    3.180935] Key type dns_resolver registered
[    3.181954] registered taskstats version 1
[    3.181970] Loading compiled-in X.509 certificates
[    3.187593] Loaded X.509 cert 'Build time autogenerated kernel key: cf582b85d37ac5e7e16062bd2222df75b99b261f'
[    3.187858] zswap: loaded using pool lzo/zbud
[    3.188355] Key type ._fscrypt registered
[    3.188362] Key type .fscrypt registered
[    3.188368] Key type fscrypt-provisioning registered
[    3.192478] mmc2: Command Queue Engine enabled
[    3.192496] mmc2: new HS200 MMC card at address 0001
[    3.192592] Btrfs loaded, crc32c=crc32c-generic
[    3.193282] mmcblk2: mmc2:0001 BJTD4R 29.1 GiB
[    3.193519] mmcblk2boot0: mmc2:0001 BJTD4R partition 1 4.00 MiB
[    3.193796] mmcblk2boot1: mmc2:0001 BJTD4R partition 2 4.00 MiB
[    3.193983] mmcblk2rpmb: mmc2:0001 BJTD4R partition 3 4.00 MiB, chardev (243:0)
[    3.195163]  mmcblk2: p1
[    3.213202] Key type encrypted registered
[    3.213236] AppArmor: AppArmor sha1 policy hashing enabled
[    3.275304] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    3.275352] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    3.275373] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    3.276230] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    3.276271] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    3.276441] vcca0v9_s3: supplied by vcc1v8_s3
[    3.321136] usb 7-1: new high-speed USB device number 2 using xhci-hcd
[    3.426398] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 184
[    3.433558] mmc0: new ultra high speed SDR104 SDIO card at address 0001
[    3.472130] usb 7-1: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 0.50
[    3.472141] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.472149] usb 7-1: Product: USB2.0 Hub
[    3.472156] usb 7-1: Manufacturer: VIA Labs, Inc.
[    3.528193] hub 7-1:1.0: USB hub found
[    3.528384] hub 7-1:1.0: 4 ports detected
[    3.623118] usb 8-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    3.715515] usb 8-1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice= 0.50
[    3.715525] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.715534] usb 8-1: Product: USB3.0 Hub
[    3.715541] usb 8-1: Manufacturer: VIA Labs, Inc.
[    3.736222] hub 8-1:1.0: USB hub found
[    3.736464] hub 8-1:1.0: 4 ports detected
[    3.801284] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    3.802074] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    3.804504] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.805271] of_cfs_init
[    3.805313] of_cfs_init: OK
[    3.808918] Freeing unused kernel memory: 4224K
[    3.817254] Run /init as init process
[    3.817261]   with arguments:
[    3.817267]     /init
[    3.817272]   with environment:
[    3.817277]     HOME=/
[    3.817281]     TERM=linux
[    3.817287]     ubootpart=f20ec8b3-01
[    3.817291]     cgroup_enable=memory
[    3.817296]     cgroup_memory=1
[    4.281734] usb 8-1.3: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[    4.314084] usb 8-1.3: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.21
[    4.314098] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.314106] usb 8-1.3: Product: 4-Port USB 3.0 Hub
[    4.314114] usb 8-1.3: Manufacturer: Generic
[    4.348486] hub 8-1.3:1.0: USB hub found
[    4.349968] hub 8-1.3:1.0: 4 ports detected
[    4.441176] usb 7-1.3: new high-speed USB device number 3 using xhci-hcd
[    4.470869] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[    4.470885] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[    4.471116] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[    4.471503] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    4.471518] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    4.471531] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[    4.471554] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    4.471669] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    4.471679] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    4.476707] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    4.480984] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    4.481006] rk_gmac-dwmac fe300000.ethernet: 	DWMAC1000
[    4.481018] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[    4.481028] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[    4.481038] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[    4.481047] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[    4.481056] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[    4.481262] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[    4.481273] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[    4.481283] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.486498] libphy: stmmac: probed
[    4.522167] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[    4.523313] rockchip-vop ff900000.vop: Adding to iommu group 3
[    4.539006] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
[    4.539154] [drm] unsupported AFBC format[3231564e]
[    4.541335] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
[    4.541697] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.548326] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.605239] usb 7-1.3: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.21
[    4.605252] usb 7-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.605261] usb 7-1.3: Product: 4-Port USB 2.0 Hub
[    4.605269] usb 7-1.3: Manufacturer: Generic
[    4.608341] bootsplash: Loading splash file (563104 bytes)
[    4.608390] bootsplash: Loaded (563104 bytes, 2 pics, 76 blobs).
[    4.648818] hub 7-1.3:1.0: USB hub found
[    4.649269] Console: switching to colour frame buffer device 240x67
[    4.650502] hub 7-1.3:1.0: 4 ports detected
[    4.776599] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    4.798142] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    5.005140] usb 7-1.3.2: new full-speed USB device number 4 using xhci-hcd
[    5.054592] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    5.115752] usb 7-1.3.2: New USB device found, idVendor=062a, idProduct=4101, bcdDevice= 1.08
[    5.115765] usb 7-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.115774] usb 7-1.3.2: Product: 2.4G Keyboard Mouse
[    5.115782] usb 7-1.3.2: Manufacturer: MOSART Semi.
[    5.194527] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2:1.0/0003:062A:4101.0001/input/input1
[    5.253752] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-xhci-hcd.1.auto-1.3.2/input0
[    5.257626] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2:1.1/0003:062A:4101.0002/input/input2
[    5.258162] input: MOSART Semi. 2.4G Keyboard Mouse Consumer Control as /devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2:1.1/0003:062A:4101.0002/input/input3
[    5.317519] input: MOSART Semi. 2.4G Keyboard Mouse System Control as /devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2:1.1/0003:062A:4101.0002/input/input4
[    5.317864] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3.2/7-1.3.2:1.1/0003:062A:4101.0002/input/input5
[    5.318390] hid-generic 0003:062A:4101.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-xhci-hcd.1.auto-1.3.2/input1
[    5.397158] usb 7-1.3.3: new low-speed USB device number 5 using xhci-hcd
[    5.403350] systemd[1]: System time before build time, advancing clock.
[    5.417431] systemd[1]: Inserted module 'autofs4'
[    5.454044] systemd[1]: systemd 245.4-4ubuntu3.3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    5.454974] systemd[1]: Detected architecture arm64.
[    5.495831] systemd[1]: Set hostname to <nanopim4>.
[    5.505392] usb 7-1.3.3: New USB device found, idVendor=045e, idProduct=00cb, bcdDevice= 1.00
[    5.505405] usb 7-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.505414] usb 7-1.3.3: Product: Microsoft USB Optical Mouse
[    5.505422] usb 7-1.3.3: Manufacturer: PixArt
[    5.547403] input: PixArt Microsoft USB Optical Mouse as /devices/platform/usb@fe900000/fe900000.usb/xhci-hcd.1.auto/usb7/7-1/7-1.3/7-1.3.3/7-1.3.3:1.0/0003:045E:00CB.0003/input/input6
[    5.547901] hid-generic 0003:045E:00CB.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt Microsoft USB Optical Mouse] on usb-xhci-hcd.1.auto-1.3.3/input0
[    5.584224] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[    5.801000] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly.
[    6.039779] random: systemd: uninitialized urandom read (16 bytes read)
[    6.044173] systemd[1]: Created slice system-modprobe.slice.
[    6.044711] random: systemd: uninitialized urandom read (16 bytes read)
[    6.046235] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.060047] random: systemd: uninitialized urandom read (16 bytes read)
[    6.061402] systemd[1]: Created slice User and Session Slice.
[    6.062067] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.063305] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.063853] systemd[1]: Reached target User and Group Name Lookups.
[    6.064200] systemd[1]: Reached target Remote File Systems.
[    6.064523] systemd[1]: Reached target Slices.
[    6.064855] systemd[1]: Reached target Swap.
[    6.065343] systemd[1]: Reached target System Time Set.
[    6.066224] systemd[1]: Listening on Syslog Socket.
[    6.067014] systemd[1]: Listening on fsck to fsckd communication Socket.
[    6.067579] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.068855] systemd[1]: Listening on Journal Audit Socket.
[    6.069690] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.070580] systemd[1]: Listening on Journal Socket.
[    6.071442] systemd[1]: Listening on udev Control Socket.
[    6.072127] systemd[1]: Listening on udev Kernel Socket.
[    6.077816] systemd[1]: Mounting Huge Pages File System...
[    6.083444] systemd[1]: Mounting POSIX Message Queue File System...
[    6.089450] systemd[1]: Mounting Kernel Debug File System...
[    6.095141] systemd[1]: Mounting Kernel Trace File System...
[    6.101855] systemd[1]: Starting Restore / save the current clock...
[    6.115366] systemd[1]: Starting Set the console keyboard layout...
[    6.122203] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    6.122809] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    6.127991] systemd[1]: Started Nameserver information manager.
[    6.129239] systemd[1]: Reached target Network (Pre).
[    6.130965] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.131179] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    6.137956] systemd[1]: Starting Load Kernel Modules...
[    6.143620] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.149603] systemd[1]: Starting udev Coldplug all Devices...
[    6.171977] systemd[1]: Mounted Huge Pages File System.
[    6.174046] systemd[1]: Mounted POSIX Message Queue File System.
[    6.175848] systemd[1]: Mounted Kernel Debug File System.
[    6.177897] systemd[1]: Mounted Kernel Trace File System.
[    6.184499] systemd[1]: Finished Restore / save the current clock.
[    6.188056] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    6.189660] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    6.200193] systemd[1]: Finished Load Kernel Modules.
[    6.204056] systemd[1]: Finished Remount Root and Kernel File Systems.
[    6.216744] systemd[1]: Mounting FUSE Control File System...
[    6.222741] systemd[1]: Mounting Kernel Configuration File System...
[    6.224225] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    6.224574] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    6.231893] systemd[1]: Starting Load/Save Random Seed...
[    6.237830] systemd[1]: Starting Apply Kernel Variables...
[    6.248720] systemd[1]: Starting Create System Users...
[    6.256871] systemd[1]: Mounted FUSE Control File System.
[    6.261716] systemd[1]: Mounted Kernel Configuration File System.
[    6.295592] systemd[1]: Finished Create System Users.
[    6.303956] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.313398] systemd[1]: Finished Apply Kernel Variables.
[    6.367419] systemd[1]: Finished Create Static Device Nodes in /dev.
[    6.376906] systemd[1]: Starting udev Kernel Device Manager...
[    6.482657] systemd[1]: Finished Set the console keyboard layout.
[    6.484138] systemd[1]: Reached target Local File Systems (Pre).
[    6.492299] systemd[1]: Mounting /tmp...
[    6.510300] systemd[1]: Mounted /tmp.
[    6.512330] systemd[1]: Reached target Local File Systems.
[    6.533717] systemd[1]: Starting Armbian ZRAM config...
[    6.543012] systemd[1]: Starting Set console font and keymap...
[    6.552900] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    6.554695] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
[    6.555429] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    6.572390] systemd[1]: Finished Set console font and keymap.
[    6.582104] systemd[1]: plymouth-read-write.service: Succeeded.
[    6.586705] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    6.589378] systemd[1]: Started udev Kernel Device Manager.
[    6.800021] systemd[1]: Finished udev Coldplug all Devices.
[    6.813845] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    6.815515] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    6.816543] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
[    6.818238] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    6.818407] systemd[1]: Reached target Local Encrypted Volumes.
[    6.834898] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    6.846173] systemd[1]: Starting Raise network interfaces...
[    6.891887] zram: Added device: zram0
[    6.896879] zram: Added device: zram1
[    6.898316] zram: Added device: zram2
[    6.989544] zram1: detected capacity change from 0 to 1005936640
[    7.204721] Bluetooth: Core ver 2.22
[    7.204802] NET: Registered protocol family 31
[    7.204805] Bluetooth: HCI device and connection manager initialized
[    7.204809] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.204821] Bluetooth: HCI socket layer initialized
[    7.204829] Bluetooth: L2CAP socket layer initialized
[    7.204847] Bluetooth: SCO socket layer initialized
[    7.205907] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.207003] systemd[1]: Found device /dev/ttyS2.
[    7.241586] brcmfmac: F1 signature read @0x18000000=0x17224356
[    7.247959] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio for chip BCM4356/2
[    7.249214] usbcore: registered new interface driver brcmfmac
[    7.256040] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4356-sdio.friendlyarm,nanopi-m4.txt failed with error -2
[    7.265537] mc: Linux media interface: v0.10
[    7.285552] Bluetooth: HCI UART driver ver 2.3
[    7.285589] Bluetooth: HCI UART protocol H4 registered
[    7.285592] Bluetooth: HCI UART protocol BCSP registered
[    7.285726] Bluetooth: HCI UART protocol LL registered
[    7.285731] Bluetooth: HCI UART protocol ATH3K registered
[    7.285805] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    7.286244] Bluetooth: HCI UART protocol Intel registered
[    7.291050] Bluetooth: HCI UART protocol Broadcom registered
[    7.291058] Driver 'hci_uart_qca' needs updating - please use bus_type methods
[    7.291107] videodev: Linux video capture interface: v2.00
[    7.291111] Bluetooth: HCI UART protocol QCA registered
[    7.291115] Bluetooth: HCI UART protocol AG6XX registered
[    7.291160] Bluetooth: HCI UART protocol Marvell registered
[    7.314387] systemd[1]: Finished Raise network interfaces.
[    7.325577] typec_fusb302 4-0022: No cable types defined, using default cables
[    7.326380] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[    7.332548] rockchip-rga ff680000.rga: HW Version: 0x03.02
[    7.332884] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[    7.336672] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[    7.345020] rkvdec ff660000.video-codec: Adding to iommu group 1
[    7.352724] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[    7.353889] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4356-sdio for chip BCM4356/2
[    7.355293] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    7.355976] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
[    7.356113] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
[    7.360139] rt5651 1-001a: Failed to reguest IRQ 0: -22
[    7.368314] panfrost ff9a0000.gpu: clock rate = 500000000
[    7.368678] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4356/2 wl0: Mar  4 2020 22:06:08 version 7.35.349.87 (r724447 CY) FWID 01-c68a2890
[    7.384982] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[    7.384987] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[    7.384991] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[    7.384993] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[    7.398381] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[    7.409343] dw-apb-uart ff180000.serial: failed to request DMA
[    7.425152] Registered IR keymap rc-cec
[    7.425268] rc rc0: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0
[    7.425419] input: dw_hdmi as /devices/platform/ff940000.hdmi/rc/rc0/input7
[    7.470960] asoc-simple-card rt5651-sound: ASoC: no DMI vendor name!
[    7.614819] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    7.649525] systemd[1]: Starting Load/Save RF Kill Switch Status...
[    7.678519] random: crng init done
[    7.678528] random: 7 urandom warning(s) missed due to ratelimiting
[    7.683166] asoc-simple-card hdmi-sound: ASoC: no DMI vendor name!
[    7.685700] systemd[1]: Finished Load/Save Random Seed.
[    7.687541] Bluetooth: hci0: BCM: chip id 101
[    7.687851] Bluetooth: hci0: BCM: features 0x2f
[    7.688942] Bluetooth: hci0: BCM4354A2
[    7.688956] Bluetooth: hci0: BCM4356A2 (001.003.015) build 0000
[    7.690712] Bluetooth: hci0: BCM4356A2 'brcm/BCM4356A2.hcd' Patch
[    7.708861] systemd[1]: Started Load/Save RF Kill Switch Status.
[    7.719880] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    7.727313] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    7.727620] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    7.728035] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    7.728295] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.728386] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    7.728486] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.728589] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    7.728657] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.736713] systemd[1]: plymouth-read-write.service: Succeeded.
[    7.737898] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    7.797213] Adding 982356k swap on /dev/zram1.  Priority:5 extents:1 across:982356k SSFS
[    7.897608] zram0: detected capacity change from 0 to 52428800
[    7.932160] systemd[1]: Finished Armbian ZRAM config.
[    7.936821] systemd[1]: Starting Armbian memory supported logging...
[    7.995080] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard
[    7.995116] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
[    8.403211] Bluetooth: hci0: BCM4356 37.4MHz AMPAK AP6356-0055
[    8.403237] Bluetooth: hci0: BCM4356A2 (001.003.015) build 0266
[   10.050353] systemd[1]: Finished Armbian memory supported logging.
[   10.059516] systemd[1]: Starting Journal Service...
[   10.206106] systemd[1]: Started Journal Service.
[   10.242680] systemd-journald[717]: Received client request to flush runtime journal.
[   16.078494] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.078500] Bluetooth: BNEP filters: protocol multicast
[   16.078511] Bluetooth: BNEP socket layer initialized
[   16.110199] NET: Registered protocol family 38
[   16.566421] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=173)
[   16.589219] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   16.589238] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   16.590153] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   18.553858] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   18.554354] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   18.555571] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   18.556062] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   18.557195] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   18.557688] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   18.558990] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   18.559482] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   18.560858] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   18.561421] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   18.562923] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   18.563415] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
[   18.606616] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.607111] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.608529] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.609024] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.610494] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.610985] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.612289] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.612779] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.614219] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.614712] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.616337] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.616829] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.739281] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.739776] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.741038] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.741710] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.742890] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.743380] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.744588] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.745078] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.746563] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.747055] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   18.833478] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   18.833974] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.001375] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.001869] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.085330] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.085823] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.086674] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.087162] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.259244] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.259740] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.345613] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.346121] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.347242] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   19.347746] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   19.726347] Bluetooth: RFCOMM TTY layer initialized
[   19.726362] Bluetooth: RFCOMM socket layer initialized
[   19.726376] Bluetooth: RFCOMM ver 1.11
[   20.229184] overlayfs: "xino" feature enabled using 2 upper inode bits.
[   20.319852] overlayfs: "xino" feature enabled using 2 upper inode bits.
[   22.766976] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   24.631939] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   24.632446] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   24.635184] rockchip-i2s ff890000.i2s: Fail to set mclk -22
[   24.635686] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
[   24.638710] rockchip-i2s ff8a0000.i2s: Fail to set mclk -22
[   24.639250] rockchip-i2s ff8a0000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff8a0000.i2s: -22
Update : With browsing on firefox I get a lot more errors about panfrost. Now on 1.42Ghz all cores and userspace. It is more stable, but not fully.
[   35.810058] vcca0v9_s3: disabling
[  127.601012] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE40
               Reason: TODO
               raw fault status: 0x6F002C1
               decoded fault status: SLAVE FAULT
               exception type 0xC1: TRANSLATION_FAULT_LEVEL1
               access type 0x2: READ
               source id 0x6F0
[  127.619912] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE40
               Reason: TODO
               raw fault status: 0xF002C1
               source id 0xF0
[  127.726632] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE40
               Reason: TODO
               raw fault status: 0x4F002C1
               source id 0x4F0
[  128.026717] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE40
               Reason: TODO
               source id 0xF0
[  128.029605] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE40
               Reason: TODO
               source id 0x6F0
[  128.132717] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x5118f00, tail=0x5118f00, sched_job=00000000c9ddda8e
[  128.136808] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE80
               Reason: TODO
               raw fault status: 0x2F002C1
               source id 0x2F0
[  128.205528] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE80
               Reason: TODO
               source id 0x2F0
[  128.303126] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE80
               Reason: TODO
               source id 0x6F0
[  128.510963] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000106ABFE80
               Reason: TODO
               source id 0x2F0
[  128.644706] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x50b8540, tail=0x50b8540, sched_job=000000008f7d57d5
[  128.916218] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26040
               Reason: TODO
               source id 0x6F0
[  129.020017] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26040
               Reason: TODO
               source id 0x6F0
[  129.359233] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26040
               Reason: TODO
               source id 0x6F0
[  129.444682] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x4366f00, tail=0x4366f00, sched_job=000000003509f700
[  129.446343] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26100
               Reason: TODO
               source id 0x6F0
[  129.464307] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26100
               Reason: TODO
               source id 0x6F0
[  129.524223] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D260C0
               Reason: TODO
               source id 0x2F0
[  129.629230] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D260C0
               Reason: TODO
               source id 0x2F0
[  129.744217] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26100
               Reason: TODO
               source id 0x6F0
[  129.864226] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000104D26100
               Reason: TODO
               source id 0x6F0
[  129.956690] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x50b8540, tail=0x50b8540, sched_job=00000000fb755837
[  130.070169] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000007497A600
               Reason: TODO
               source id 0x6F0
[  130.596703] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x5119200, tail=0x5119200, sched_job=00000000c2eecbd9
[  130.600525] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000007497A600
               Reason: TODO
               source id 0x6F0
[  131.044984] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000007497A600
               Reason: TODO
               source id 0x6F0
[  131.047724] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x00000001069E8E40
               Reason: TODO
               source id 0x4F0
[  131.108681] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x39f0540, tail=0x39f0540, sched_job=0000000001e94f55
[  303.057999] Purging 909312 bytes
[  303.084308] Purging 540672 bytes
[  303.087440] Purging 1597440 bytes
[  303.095160] Purging 8560640 bytes
[  303.098169] Purging 2379776 bytes
[  303.104550] Purging 8454144 bytes
[  303.111068] Purging 8458240 bytes
[  303.112070] Purging 974848 bytes
[  303.412310] Purging 851968 bytes
[  303.418661] Purging 7028736 bytes
[  336.803189] panfrost_gem_shrinker_scan: 15 callbacks suppressed
[  336.803193] Purging 2535424 bytes
[  336.805305] Purging 1175552 bytes
[  336.806933] Purging 1142784 bytes
[  336.808992] Purging 1417216 bytes
[  336.810715] Purging 1355776 bytes
[  336.812548] Purging 1372160 bytes
[  336.815030] Purging 1363968 bytes
[  337.227409] Purging 1372160 bytes
[  337.229626] Purging 1413120 bytes
[  337.231460] Purging 622592 bytes
[  342.021936] panfrost_gem_shrinker_scan: 43 callbacks suppressed
[  342.021941] Purging 1712128 bytes
[  342.023722] Purging 1720320 bytes
[  342.025371] Purging 1728512 bytes
[  342.027059] Purging 1736704 bytes
[  342.032693] Purging 1765376 bytes
[  342.039879] Purging 1753088 bytes
[  342.048432] Purging 1859584 bytes
[  343.014667] Purging 1773568 bytes
[  343.019273] Purging 1789952 bytes
[  343.025053] Purging 1781760 bytes
[  347.891978] panfrost_gem_shrinker_scan: 14 callbacks suppressed
[  347.891981] Purging 2076672 bytes
[  347.901486] Purging 2084864 bytes
[  347.908091] Purging 2101248 bytes
[  347.912523] Purging 2105344 bytes
[  353.839712] Purging 2240512 bytes
[  353.845658] Purging 2248704 bytes
[  353.850525] Purging 2256896 bytes
[  353.856851] Purging 2260992 bytes
[  353.861306] Purging 2277376 bytes
[  353.866121] Purging 2293760 bytes
[  353.871042] Purging 2301952 bytes
[  362.459003] Purging 761856 bytes
[  362.466171] Purging 4206592 bytes
[  362.474381] Purging 4710400 bytes
[  362.481592] Purging 4411392 bytes
[  362.488035] Purging 4182016 bytes
[  362.495126] Purging 4575232 bytes
[  362.500486] Purging 544768 bytes
[  362.719465] Purging 4624384 bytes
[  362.725335] Purging 4710400 bytes
[  362.734286] Purging 5066752 bytes
[  397.967577] panfrost_gem_shrinker_scan: 10 callbacks suppressed
[  397.967580] Purging 524288 bytes
[  397.971471] Purging 2277376 bytes
[  397.977422] Purging 2338816 bytes
[  397.982586] Purging 2318336 bytes
[  397.987613] Purging 2355200 bytes
[  397.992111] Purging 2371584 bytes
[  397.997472] Purging 2347008 bytes
[  398.003546] Purging 2396160 bytes
[  398.009486] Purging 2400256 bytes
[  398.013961] Purging 2334720 bytes
[  404.491386] panfrost_gem_shrinker_scan: 25 callbacks suppressed
[  404.491391] Purging 901120 bytes
[  404.496828] Purging 528384 bytes
[  404.506991] Purging 7028736 bytes
[  404.517491] Purging 561152 bytes
[  404.533799] Purging 8388608 bytes
[  404.545562] Purging 598016 bytes
[  404.559116] Purging 8663040 bytes
[  430.716132] Purging 987136 bytes
[  430.723828] Purging 716800 bytes
[  430.737469] Purging 7872512 bytes
[  430.744479] Purging 589824 bytes
[  430.750909] Purging 708608 bytes
[  430.763054] Purging 8777728 bytes
[  431.833456] Purging 958464 bytes
[  431.842120] Purging 667648 bytes
[  431.848829] Purging 524288 bytes
[  431.854520] Purging 548864 bytes
[  437.120454] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.125641] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.135203] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000016037600
               Reason: TODO
               raw fault status: 0x6F002C2
               exception type 0xC2: TRANSLATION_FAULT_LEVEL2
               source id 0x6F0
[  437.170251] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000005A1921C0
               Reason: TODO
               source id 0x4F0
[  437.205242] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000016037600
               Reason: TODO
               source id 0x6F0
[  437.219819] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000005A1921C0
               Reason: TODO
               source id 0x4F0
[  437.265320] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.267419] panfrost_gem_shrinker_scan: 3 callbacks suppressed
[  437.267424] Purging 1064960 bytes
[  437.271147] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000005A1921C0
               Reason: TODO
               source id 0x4F0
[  437.272073] Purging 737280 bytes
[  437.277759] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.278278] Purging 536576 bytes
[  437.286562] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000016037600
               Reason: TODO
               source id 0x6F0
[  437.293164] Purging 8466432 bytes
[  437.310341] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.330194] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.380058] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.430286] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.436767] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.478780] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.485326] Purging 8396800 bytes
[  437.490335] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000016037600
               Reason: TODO
               source id 0x6F0
[  437.496870] Purging 8392704 bytes
[  437.597315] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000000058141200
               Reason: TODO
               source id 0x6F0
[  437.603522] Purging 8527872 bytes
[  437.613046] panfrost ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x000000005A1921C0
               Reason: TODO
               source id 0x4F0
[  437.619448] Purging 8454144 bytes
[  437.639595] panfrost ff9a0000.gpu: gpu sched timeout, js=0, config=0x3300, status=0x8, head=0x4375b80, tail=0x4375b80, sched_job=00000000f44c44bf
[  437.743690] Purging 647168 bytes
[  437.753323] Purging 536576 bytes
[  442.414614] panfrost_gem_shrinker_scan: 20 callbacks suppressed
[  442.414622] Purging 724992 bytes
[  442.434380] Purging 8417280 bytes
[  442.446914] Purging 1421312 bytes
[  442.472333] Purging 1118208 bytes
[  442.495068] Purging 8396800 bytes
After last nights test it didn't fully crash on 1.42Ghz. But my test programs were closed, and wifi was gone. So it clearly was not ok. It was running for +13hours.
Update : It was a mesa bug that produced the crashes.
RK3399 is now back stable with latest updates. Even at 2Ghz and ondemand governor.
But not all problems are fixed yet with mesa/panfrost. The errors in dmesg are still there. And some things that use panfrost will not work.
Mesa has had a major update to version 20.2.4. So if you need panfrost, best to use mesa 20.2.3. https://docs.mesa3d.org/relnotes/20.2.4.html
You can also download the old version of Armbian Reforged with mesa 20.2.3. But be sure not to upgrade for the moment.
1 hour ago, Pedro Lamas said:
Excellent work @NicoD, does that mean one can now create a PR to improve this and submit to the Armbian repo?
It isn't an Armbian thing.
It should be in this repo, if you don't have it, add it:
sudo add-apt-repository ppa:oibaf/graphics-drivers
I still have questions on how and why Panfrost is enabled by default on the latest images.
And it seems to be missing the graphics repo. @Igor Do you have info on that? Or maybe @JMCC
Mesa 20.2.1 has been on Focal-proposed for almost two weeks, so it should be hitting focal-updates at any moment.
Enviado desde mi moto g(6) plus mediante Tapatalk
As a side note, if I get to work on mainline multimedia integration, one of the goals would be to fix the xorg.conf files. I haven't tinkered much with it so far, IIRC latest x server enables the panfrost-modesetting driver by default if no other driver is set.
Don't know. It shouldn't be. Also that repository should be in there. But its in there if you build image from a desktop branch and select 3D support.
Not sure how much it matters or not, but I thought best to point out that I'm actually running Debian Buster and not Ubuntu Focal, plus I run my Nanopi M4V2 completely headless (no screen connected to it) and still experienced the crashes while using the "ondemand" governor.
I've only tried a few hours without crashes and after doing update/upgrade. I couldn't do that yesterday at all. Also using Firefox crashed it every time and now not.
The problem of ondemand governor is unrelated tho to the mesa issue. They might have worked together in decreasing stability since it was more stable at lower clocks but not fully.
What kernel version are you using? Are you using a server image? What does dmesg say? or armbianmonitor -u
I'll do more tests tomorrow.
25 minutes ago, Pedro Lamas said:
Here's my most current armbianmonitor output: http://ix.io/2HmF
There's a few things springing out.
17.643595] panfrost ff9a0000.gpu: clock rate = 500000000
[   17.688112] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   17.688123] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   17.688129] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   17.688133] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   17.706870] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1
[   17.723351] cdc_acm 7-1.3:1.0: ttyACM0: USB ACM device
And at the end you've got
[   20.317067] systemd-journald[684]: Received request to flush runtime journal from PID 1
So even the server images have panfrost enabled??? Very strange.
The other seems to point to a storage problem I think?
All makes my head hurt.
Has this always been this way on mainline? I'm still using legacy for my daily needs. I was not very aware of the issues on mainline.
All images for a certain board share the same kernel.  After all, a desktop image is just a server image in which you install Xfce and the rest of the desktop apps.
However, panfrost should not give any trouble if you are not using any graphical application. But if you want to disable it anyway, just add a line like this:
blacklist panfrost
to a newly created file
/etc/modprobe.d/blacklist-panfrost.conf
