FriendlyELEC sells an 11.6inch eDP FHD LCD Display with Capacitive Touch for the nanoPC-T4. I'm trying my hardest to get it working with Armbian. Unfortunately, Armbian doesn't seem to detect the display:
It works in the stock lubuntu image they provide so I'm trying to gather as much configuration information as I can from lubuntu to see what I need to do to get it working.
I want to try a few different experiments.. I have a kernel.img file from lubuntu that I'd like to try booting with Armbian but I don't understand uboot very well and simply copying the kernel.img file to /boot under the same name as the existing vmlinuz file seemed to only brick the install (even after I copied back the old image). Is there a way to properly get uboot to boot that image with Armbian?
Here's what I've gotten so far from lubuntu configuration:
I did notice that lcd=LC116LF1L01 line.. I have no idea what that's for and adding that to Armbian kernel command line did nothing :/
root@FriendlyELEC:~# xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
eDP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1920x1080 60.00*
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
root@FriendlyELEC:~# xrandr --listmonitors
Monitors: 1
0: +eDP-1 1920/508x1080/286+0+0 eDP-1
Xorg.0.log:
X.Org X Server 1.18.4
Release Date: 2016-07-19
[1713143.338] X Protocol Version 11, Revision 0
[1713143.338] Build Operating System: Linux 4.6.0-1-amd64 x86_64 Debian
[1713143.338] Current Operating System: Linux FriendlyELEC 4.4.179 #1 SMP Thu Aug 13 12:57:41 CST 2020 aarch64
[1713143.339] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 rootwait coherent_pool=1m root=/dev/mmcblk0p1 rw rootfstype=ext4 data=/dev/mmcblk0p2 consoleblank=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 lcd=LC116LF1L01 storagemedia=sd uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2020-03-16_16:45:22 SecureBootCheckOk=0
[1713143.339] Build Date: 23 December 2016 10:24:38AM
[1713143.339] xorg-server 2:1.18.4-1 (http://www.debian.org/support)
[1713143.339] Current version of pixman: 0.33.6
[1713143.339] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[1713143.339] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[1713143.340] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 7 01:09:37 2020
[1713143.341] (==) Using config directory: "/etc/X11/xorg.conf.d"
[1713143.341] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[1713143.342] (==) No Layout section. Using the first Screen section.
[1713143.342] (==) No screen section available. Using defaults.
[1713143.342] (**) |-->Screen "Default Screen Section" (0)
[1713143.343] (**) | |-->Monitor "<default monitor>"
[1713143.343] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[1713143.343] (**) | |-->Device "Rockchip Graphics"
[1713143.343] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[1713143.343] (==) Automatically adding devices
[1713143.343] (==) Automatically enabling devices
[1713143.343] (==) Automatically adding GPU devices
[1713143.343] (==) Max clients allowed: 256, resource mask: 0x1fffff
[1713143.343] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[1713143.343] Entry deleted from font path.
[1713143.343] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[1713143.344] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[1713143.344] Entry deleted from font path.
[1713143.344] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
built-ins
[1713143.344] (==) ModulePath set to "/usr/lib/xorg/modules"
[1713143.344] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[1713143.344] (II) Loader magic: 0x16af40
[1713143.344] (II) Module ABI versions:
[1713143.344] X.Org ANSI C Emulation: 0.4
[1713143.344] X.Org Video Driver: 20.0
[1713143.344] X.Org XInput driver : 22.1
[1713143.344] X.Org Server Extension : 9.0
[1713143.348] (--) using VT number 2
[1713143.348] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[1713143.350] (II) xfree86: Adding drm device (/dev/dri/card0)
[1713143.368] (II) no primary bus or device found
[1713143.368] falling back to /sys/devices/platform/display-subsystem/drm/card0
[1713143.368] (II) LoadModule: "glx"
[1713143.369] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[1713143.374] (II) Module glx: vendor="X.Org Foundation"
[1713143.374] compiled for 1.18.4, module version = 1.0.0
[1713143.374] ABI class: X.Org Server Extension, version 9.0
[1713143.374] (==) AIGLX enabled
[1713143.374] (II) LoadModule: "modesetting"
[1713143.374] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[1713143.375] (II) Module modesetting: vendor="X.Org Foundation"
[1713143.375] compiled for 1.18.4, module version = 1.18.4
[1713143.375] Module class: X.Org Video Driver
[1713143.375] ABI class: X.Org Video Driver, version 20.0
[1713143.375] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[1713143.450] (II) modeset(0): using drv /dev/dri/card0
[1713143.451] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[1713143.451] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[1713143.451] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[1713143.451] (**) modeset(0): Option "AccelMethod" "glamor"
[1713143.451] (==) modeset(0): RGB weight 888
[1713143.451] (==) modeset(0): Default visual is TrueColor
[1713143.451] (II) Loading sub module "glamoregl"
[1713143.451] (II) LoadModule: "glamoregl"
[1713143.452] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[1713143.489] (II) Module glamoregl: vendor="X.Org Foundation"
[1713143.489] compiled for 1.18.4, module version = 1.0.0
[1713143.490] ABI class: X.Org ANSI C Emulation, version 0.4
[1713143.490] (II) glamor: OpenGL accelerated X.org driver based.
[1713143.494] (II) glamor: EGL version 1.4 Midgard-"r14p0-01rel0":
[1713143.494] EGL_KHR_surfaceless_gles2 required.
[1713143.498] (II) modeset(0): Using GLES2.
[1713143.498] (WW) modeset(0): Glamor is using GLES2 but GLX needs GL. Indirect GLX may not work correctly.
[1713143.498] (II) modeset(0): glamor initialized
[1713143.501] (II) modeset(0): Output eDP-1 has no monitor section
[1713143.501] (II) modeset(0): Output HDMI-1 has no monitor section
[1713143.501] (II) modeset(0): Output DP-1 has no monitor section
[1713143.502] (II) modeset(0): EDID for output eDP-1
[1713143.502] (II) modeset(0): Printing probed modes for output eDP-1
[1713143.502] (II) modeset(0): Modeline "1920x1080"x60.0 138.65 1920 1968 2000 2080 1080 1083 1088 1111 +hsync +vsync (66.7 kHz)
[1713143.502] (II) modeset(0): EDID for output HDMI-1
[1713143.502] (II) modeset(0): EDID for output DP-1
[1713143.502] (II) modeset(0): Output eDP-1 connected
[1713143.502] (II) modeset(0): Output HDMI-1 disconnected
[1713143.502] (II) modeset(0): Output DP-1 disconnected
[1713143.502] (II) modeset(0): Using sloppy heuristic for initial modes
[1713143.502] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[1713143.502] (II) modeset(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[1713143.502] (==) modeset(0): DPI set to (96, 96)
[1713143.502] (II) Loading sub module "fb"
[1713143.502] (II) LoadModule: "fb"
[1713143.503] (II) Loading /usr/lib/xorg/modules/libfb.so
[1713143.503] (II) Module fb: vendor="X.Org Foundation"
[1713143.503] compiled for 1.18.4, module version = 1.0.0
[1713143.503] ABI class: X.Org ANSI C Emulation, version 0.4
[1713143.504] (==) Depth 24 pixmap format is 32 bpp
[1713143.727] (==) modeset(0): Backing store enabled
[1713143.728] (==) modeset(0): Silken mouse enabled
[1713143.728] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[1713143.728] (==) modeset(0): DPMS enabled
[1713143.728] (WW) modeset(0): Option "DRI" is not used
[1713143.728] (II) modeset(0): [DRI2] Setup complete
[1713143.728] (II) modeset(0): [DRI2] DRI driver: rockchip
[1713143.728] (II) modeset(0): [DRI2] VDPAU driver: rockchip
[1713143.750] (--) RandR disabled
[1713143.761] (II) SELinux: Disabled on system
[1713143.762] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/rockchip_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/rockchip_dri.so: cannot open shared object file: No such file or directory)
[1713143.762] (EE) AIGLX: reverting to software rendering
[1713143.812] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[1713143.813] (II) AIGLX: Loaded and initialized swrast
[1713143.813] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[1713143.835] (II) modeset(0): Setting screen physical size to 508 x 285
[1713143.917] (II) config/udev: Adding input device adc-keys (/dev/input/event2)
[1713143.917] (**) adc-keys: Applying InputClass "evdev keyboard catchall"
[1713143.917] (II) LoadModule: "evdev"
[1713143.917] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[1713143.918] (II) Module evdev: vendor="X.Org Foundation"
[1713143.918] compiled for 1.18.1, module version = 2.10.1
[1713143.918] Module class: X.Org XInput Driver
[1713143.918] ABI class: X.Org XInput driver, version 22.1
[1713143.918] (II) Using input driver 'evdev' for 'adc-keys'
[1713143.918] (**) adc-keys: always reports core events
[1713143.919] (**) evdev: adc-keys: Device: "/dev/input/event2"
[1713143.919] (--) evdev: adc-keys: Vendor 0x1 Product 0x1
[1713143.919] (--) evdev: adc-keys: Found keys
[1713143.919] (II) evdev: adc-keys: Configuring as keyboard
[1713143.919] (**) Option "config_info" "udev:/sys/devices/platform/adc-keys/input/input2/event2"
[1713143.919] (II) XINPUT: Adding extended input device "adc-keys" (type: KEYBOARD, id 6)
[1713143.919] (**) Option "xkb_rules" "evdev"
[1713143.919] (**) Option "xkb_model" "pc105"
[1713143.919] (**) Option "xkb_layout" "us"
[1713143.921] (II) config/udev: Adding input device Typec_Headphone (/dev/input/event0)
[1713143.921] (II) No input driver specified, ignoring this device.
[1713143.921] (II) This device may have been added with another device file.
[1713143.922] (II) config/udev: Adding input device EP0790M09 (/dev/input/event1)
[1713143.922] (**) EP0790M09: Applying InputClass "evdev touchscreen catchall"
[1713143.922] (II) Using input driver 'evdev' for 'EP0790M09'
[1713143.922] (**) EP0790M09: always reports core events
[1713143.922] (**) evdev: EP0790M09: Device: "/dev/input/event1"
[1713143.922] (--) evdev: EP0790M09: Vendor 0 Product 0
[1713143.922] (--) evdev: EP0790M09: Found absolute axes
[1713143.922] (--) evdev: EP0790M09: Found absolute multitouch axes
[1713143.922] (II) evdev: EP0790M09: No buttons found, faking one.
[1713143.922] (--) evdev: EP0790M09: Found x and y absolute axes
[1713143.922] (--) evdev: EP0790M09: Found absolute touchscreen
[1713143.922] (II) evdev: EP0790M09: Configuring as touchscreen
[1713143.922] (**) evdev: EP0790M09: YAxisMapping: buttons 4 and 5
[1713143.922] (**) evdev: EP0790M09: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[1713143.922] (**) Option "config_info" "udev:/sys/devices/platform/ff3d0000.i2c/i2c-4/4-0038/input/input1/event1"
[1713143.922] (II) XINPUT: Adding extended input device "EP0790M09" (type: TOUCHSCREEN, id 7)
[1713143.922] (II) evdev: EP0790M09: initialized for absolute axes.
[1713143.922] (**) EP0790M09: (accel) keeping acceleration scheme 1
[1713143.922] (**) EP0790M09: (accel) acceleration profile 0
[1713143.922] (**) EP0790M09: (accel) acceleration factor: 2.000
[1713143.922] (**) EP0790M09: (accel) acceleration threshold: 4
[1713143.923] (II) config/udev: Adding input device EP0790M09 (/dev/input/mouse0)
[1713143.923] (II) No input driver specified, ignoring this device.
[1713143.923] (II) This device may have been added with another device file.
[1713143.924] (II) config/udev: Adding input device gpio-keys (/dev/input/event4)
[1713143.924] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[1713143.924] (II) Using input driver 'evdev' for 'gpio-keys'
[1713143.924] (**) gpio-keys: always reports core events
[1713143.924] (**) evdev: gpio-keys: Device: "/dev/input/event4"
[1713143.924] (--) evdev: gpio-keys: Vendor 0x1 Product 0x1
[1713143.924] (--) evdev: gpio-keys: Found keys
[1713143.924] (II) evdev: gpio-keys: Configuring as keyboard
[1713143.924] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input4/event4"
[1713143.924] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 8)
[1713143.924] (**) Option "xkb_rules" "evdev"
[1713143.924] (**) Option "xkb_model" "pc105"
[1713143.924] (**) Option "xkb_layout" "us"
[1713143.925] (II) config/udev: Adding input device realtek,rt5651-codec Headphones (/dev/input/event3)
[1713143.925] (II) No input driver specified, ignoring this device.
[1713143.925] (II) This device may have been added with another device file.
[1713190.723] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/mouse1)
[1713190.723] (II) No input driver specified, ignoring this device.
[1713190.723] (II) This device may have been added with another device file.
[1713190.735] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/event5)
[1713190.735] (**) Logitech K400 Plus: Applying InputClass "evdev pointer catchall"
[1713190.735] (**) Logitech K400 Plus: Applying InputClass "evdev keyboard catchall"
[1713190.735] (II) Using input driver 'evdev' for 'Logitech K400 Plus'
[1713190.735] (**) Logitech K400 Plus: always reports core events
[1713190.735] (**) evdev: Logitech K400 Plus: Device: "/dev/input/event5"
[1713190.736] (--) evdev: Logitech K400 Plus: Vendor 0x46d Product 0x404d
[1713190.736] (--) evdev: Logitech K400 Plus: Found 20 mouse buttons
[1713190.736] (--) evdev: Logitech K400 Plus: Found scroll wheel(s)
[1713190.736] (--) evdev: Logitech K400 Plus: Found relative axes
[1713190.736] (--) evdev: Logitech K400 Plus: Found x and y relative axes
[1713190.736] (--) evdev: Logitech K400 Plus: Found absolute axes
[1713190.736] (II) evdev: Logitech K400 Plus: Forcing absolute x/y axes to exist.
[1713190.736] (--) evdev: Logitech K400 Plus: Found keys
[1713190.736] (II) evdev: Logitech K400 Plus: Configuring as mouse
[1713190.736] (II) evdev: Logitech K400 Plus: Configuring as keyboard
[1713190.736] (II) evdev: Logitech K400 Plus: Adding scrollwheel support
[1713190.736] (**) evdev: Logitech K400 Plus: YAxisMapping: buttons 4 and 5
[1713190.736] (**) evdev: Logitech K400 Plus: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[1713190.736] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input5/event5"
[1713190.736] (II) XINPUT: Adding extended input device "Logitech K400 Plus" (type: KEYBOARD, id 9)
[1713190.736] (**) Option "xkb_rules" "evdev"
[1713190.736] (**) Option "xkb_model" "pc105"
[1713190.736] (**) Option "xkb_layout" "us"
[1713190.736] (WW) Option "xkb_variant" requires a string value
[1713190.736] (WW) Option "xkb_options" requires a string value
[1713190.738] (II) evdev: Logitech K400 Plus: initialized for relative axes.
[1713190.738] (WW) evdev: Logitech K400 Plus: ignoring absolute axes.
[1713190.738] (**) Logitech K400 Plus: (accel) keeping acceleration scheme 1
[1713190.738] (**) Logitech K400 Plus: (accel) acceleration profile 0
[1713190.738] (**) Logitech K400 Plus: (accel) acceleration factor: 2.000
[1713190.738] (**) Logitech K400 Plus: (accel) acceleration threshold: 4
[1713296.783] (II) config/udev: removing device Logitech K400 Plus
[1713296.789] (II) evdev: Logitech K400 Plus: Close
[1713296.789] (II) UnloadModule: "evdev"
[1713366.491] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/mouse1)
[1713366.491] (II) No input driver specified, ignoring this device.
[1713366.491] (II) This device may have been added with another device file.
[1713366.520] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/event5)
[1713366.520] (**) Logitech K400 Plus: Applying InputClass "evdev pointer catchall"
[1713366.520] (**) Logitech K400 Plus: Applying InputClass "evdev keyboard catchall"
[1713366.520] (II) Using input driver 'evdev' for 'Logitech K400 Plus'
[1713366.520] (**) Logitech K400 Plus: always reports core events
[1713366.520] (**) evdev: Logitech K400 Plus: Device: "/dev/input/event5"
[1713366.520] (--) evdev: Logitech K400 Plus: Vendor 0x46d Product 0x404d
[1713366.520] (--) evdev: Logitech K400 Plus: Found 20 mouse buttons
[1713366.520] (--) evdev: Logitech K400 Plus: Found scroll wheel(s)
[1713366.520] (--) evdev: Logitech K400 Plus: Found relative axes
[1713366.520] (--) evdev: Logitech K400 Plus: Found x and y relative axes
[1713366.520] (--) evdev: Logitech K400 Plus: Found absolute axes
[1713366.520] (II) evdev: Logitech K400 Plus: Forcing absolute x/y axes to exist.
[1713366.520] (--) evdev: Logitech K400 Plus: Found keys
[1713366.520] (II) evdev: Logitech K400 Plus: Configuring as mouse
[1713366.520] (II) evdev: Logitech K400 Plus: Configuring as keyboard
[1713366.520] (II) evdev: Logitech K400 Plus: Adding scrollwheel support
[1713366.520] (**) evdev: Logitech K400 Plus: YAxisMapping: buttons 4 and 5
[1713366.520] (**) evdev: Logitech K400 Plus: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[1713366.520] (**) Option "config_info" "udev:/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.9.auto/usb5/5-1/5-1:1.2/0003:046D:C52B.0007/0003:046D:404D.0008/input/input6/event5"
[1713366.520] (II) XINPUT: Adding extended input device "Logitech K400 Plus" (type: KEYBOARD, id 9)
[1713366.520] (**) Option "xkb_rules" "evdev"
[1713366.520] (**) Option "xkb_model" "pc105"
[1713366.521] (**) Option "xkb_layout" "us"
[1713366.521] (WW) Option "xkb_variant" requires a string value
[1713366.521] (WW) Option "xkb_options" requires a string value
[1713366.522] (II) evdev: Logitech K400 Plus: initialized for relative axes.
[1713366.522] (WW) evdev: Logitech K400 Plus: ignoring absolute axes.
[1713366.522] (**) Logitech K400 Plus: (accel) keeping acceleration scheme 1
[1713366.522] (**) Logitech K400 Plus: (accel) acceleration profile 0
[1713366.522] (**) Logitech K400 Plus: (accel) acceleration factor: 2.000
[1713366.522] (**) Logitech K400 Plus: (accel) acceleration threshold: 4
[1713389.710] (II) config/udev: removing device Logitech K400 Plus
[1713389.718] (II) evdev: Logitech K400 Plus: Close
[1713389.718] (II) UnloadModule: "evdev"
You can post now and register later.
If you have an account, sign in now to post with your account.
Question
ethDreamer
root@FriendlyELEC:~# xrandr Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192 eDP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm 1920x1080 60.00* HDMI-1 disconnected (normal left inverted right x axis y axis) DP-1 disconnected (normal left inverted right x axis y axis) root@FriendlyELEC:~# xrandr --listmonitors Monitors: 1 0: +eDP-1 1920/508x1080/286+0+0 eDP-1
Xorg.0.log:
Link to comment
Share on other sites
27 answers to this question
