Armbianmonitor:
Hi.
I am digging many things with armbian so I install fresh armbian and many applications so many times.
So I am making a long script to install many applications and edit many configuration.
When it asked "Yes/On" on text prompt, I use "#echo yes | apt install vim". It works well.
But when I install samba, it ask text prompt "yes/no" at first and then with dialog box "yes/no".
So I tried "#echo yes | echo no | apt install samba". But it doesn't work.
How can I send "yes/no" to dialog box in bash shell??
I dont know if it works for a samba-dialog-box, but you could try the following options with apt-get (not only apt):
root@npi-neo2-22(192.168.6.22):~# man apt-get|grep yes
       -y, --yes, --assume-yes
           Automatic yes to prompts; assume "yes" as answer to all prompts and run non-interactively. If an
           Force yes; this is a dangerous option that will cause apt to continue without prompting if it is
       --force-yes
           force-yes can potentially destroy your system! Configuration Item: APT::Get::force-yes. This is
           --assume-yes; where --assume-yes will answer yes to any prompt, --trivial-only will answer no.
So without echo you could try
apt-get install vim -y
or
apt-get install vim --force-yes
Sadly, I have to choose "yes" at first and then "no".
Now I have to wait and hit "Enter" for samba install.
But it saves a lot of time for me.
Anyway thank you, I solved a lot of problems from your replies.
