micho Posted September 15, 2020 Posted September 15, 2020 Hello, I have used NanoPi M4v2 with "NVMe SSD adapter" (Officially sold by the FriendlyElec). NVMe SSD is detected when I installed ubuntu based kernel 4.4. (FriendlyCore 18.04 or Armbian Bionic desktop based kernal 4.4.y) But When I installed armbian based kernel 5.x, NVMe SSD is not detected. Anyone can advise? 0 Quote
Werner Posted September 15, 2020 Posted September 15, 2020 Providing logs with armbianmonitor -u significantly raises chances that issue is getting addressed. RK3399 is known to have best support with kernel 4.4.x atm. 0 Quote
micho Posted September 15, 2020 Author Posted September 15, 2020 Thank you for your attention. I installed the latest armbian (focal, kernel 5.8.6) to upload logs. And nvme ssd was detected!! I tested the other images (kernel 5.7.15 and 5.4.46). All versions worked fine. I can't explain why this happened. I'm just guessing it might be a compatibility problem with nvme ssd. I'm sorry for the confusion to you. 0 Quote
i5Js Posted October 16, 2020 Posted October 16, 2020 I’m on 5.8.14 and my nvme is not detected.... It was working fine till I updated to that kernel version The logs are uploaded to http://ix.io/2ATb Many thanks.... 0 Quote
i5Js Posted October 16, 2020 Posted October 16, 2020 Could be a power supply issue? jsalas@nanoserver:~$ dmesg | grep -i pci [ 0.008528] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 1.483641] PCI: CLS 0 bytes, default 64 [ 2.709362] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [ 2.771099] ehci-pci: EHCI PCI platform driver [ 2.804225] ohci-pci: OHCI PCI platform driver [ 3.208966] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [ 3.734680] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 3.735230] rockchip-pcie: probe of f8000000.pcie failed with error -110 0 Quote
i5Js Posted October 16, 2020 Posted October 16, 2020 Well clearly is not a power issue. I've installed 4.4 kernel and worked root@nanopct4:~# dmesg | grep -i pcie [ 1.958739] phy phy-pcie-phy.5: Looking up phy-supply from device tree [ 1.958752] phy phy-pcie-phy.5: Looking up phy-supply property in node /pcie-phy failed [ 1.961110] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep [ 1.961124] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup [ 1.961156] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0) [ 1.961403] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree [ 1.961416] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed [ 1.961433] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 1.961443] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree [ 1.961531] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed [ 1.961546] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 1.961556] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree [ 1.961567] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed [ 1.961581] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 1.961591] rockchip-pcie f8000000.pcie: no bus-scan-delay-ms in device tree, default 0 ms [ 1.961601] rockchip-pcie f8000000.pcie: missing "memory-region" property [ 1.961617] PCI host bridge /pcie@f8000000 ranges: [ 2.106173] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 2.113740] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 2.114038] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 2.114051] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 2.114067] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded [ 2.114204] aer 0000:00:00.0:pcie02: service driver aer loaded root@nanopct4:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk1 179:0 0 14.6G 0 disk └─mmcblk1p1 179:1 0 14.4G 0 part mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk mmcblk1rpmb 179:96 0 4M 0 disk mmcblk0 179:128 0 7.5G 0 disk └─mmcblk0p1 179:129 0 7.3G 0 part / zram0 252:0 0 50M 0 disk /var/log zram1 252:1 0 1G 0 disk [SWAP] zram2 252:2 0 1G 0 disk /tmp nvme0n1 259:0 0 931.5G 0 disk ├─nvme0n1p1 259:1 0 450G 0 part ├─nvme0n1p2 259:2 0 400G 0 part └─nvme0n1p3 259:3 0 81.5G 0 part 0 Quote
aprayoga Posted November 12, 2020 Posted November 12, 2020 @i5Js maybe similar issue with the one we encounter on Helios64. The PCIe SATA controller failed in PCIe Gen1 training if Linux kernel do a reset through ep-gpio. you can try to remove ep-gpios on nano pi device tree like in this commit: https://github.com/armbian/build/pull/2213/files#diff-f8fb8dd7f6933c824a8b57561c4ed874d35aae33928cc1b5c797ae5d035a3cddR19 0 Quote
i5Js Posted January 21, 2021 Posted January 21, 2021 Sorry to bump this topic again, I'm trying to use kernel 5 in my nanopc-t4, but is still not detecting the nvme. How can I apply that patch? Thanks. 0 Quote
i5Js Posted January 21, 2021 Posted January 21, 2021 I’ve tried with the kernel 5.10.0-RC7, and It’s detected again.... I would like to know which are the differences with the stable kernel :) 0 Quote
Viper Posted February 18, 2021 Posted February 18, 2021 I have experienced exactly the same issue on a NanoPC T4. Switching back to an older kernel solved the problem, so it is clearly something recently introduced. I hope that we will get it fixed. 0 Quote
i5Js Posted February 24, 2021 Posted February 24, 2021 Now it's working with kernel 5.10.12 i5Js@noldork3sN2:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT mmcblk2 179:0 0 14.6G 0 disk └─mmcblk2p1 179:1 0 14.4G 0 part / mmcblk2boot0 179:32 0 4M 1 disk mmcblk2boot1 179:64 0 4M 1 disk zram0 252:0 0 1.9G 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log nvme0n1 259:0 0 465.8G 0 disk 0 Quote
molodye Posted November 3, 2023 Posted November 3, 2023 On 10/16/2020 at 3:34 PM, i5Js said: I’m on 5.8.14 and my nvme is not detected.... It was working fine till I updated to that kernel version The logs are uploaded to http://ix.io/2ATb Many thanks.... I have encounter the same problem on my nanopc 4 with bookworm 6.1.30. 0 Quote
molodye Posted November 4, 2023 Posted November 4, 2023 On 2/25/2021 at 1:00 AM, i5Js said: Now it's working with kernel 5.10.12 hi,friend. i wonder to know have you tested the armbian 23.81 bookworm 6.1.50 wether the m2 nvme ssd works well? 0 Quote
barbaar Posted January 2, 2024 Posted January 2, 2024 Hi all, best wishes and a better new year 2024. I gave it a try with 6+ Kernels. Unfortunately none worked. With latest version even USB Keyboard didn't work. As I have not enough skills to experiment with kernel-building I would appreciate some help. I could make free one Nanopi M4 V2 for testing. 0 Quote
Werner Posted January 3, 2024 Posted January 3, 2024 I think @NicoD has or had an M4V2. Maybe they can help testing. 0 Quote
barbaar Posted January 16, 2024 Posted January 16, 2024 Meanwhile I tested latest 5.15 and 5.10 Kernel with the result that NVME didn't show up in lsblk. Hopin NicoD will help. 0 Quote
