Banana Pi BPI-M5 with Amlogic S905X3 chip design
Banana Pi BPI-M5 is a new generation single board computer design , use Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) Processor. Mali-G31 MP2 GPU with 4 x Execution Engines (650Mhz). support 4GB LPDDR4 and 16G eMMC flash. it have 4 USB 3.0 port,1GbE LAN port.
b50aabccf201c2a241c7c8af3fae7b2debfb6e50
main spec:
* Amlogic S905X3 Quad-Core Cortex-A55 (2.0xxGHz) Processor
* Mali-G31 GPU
* 4GB LPDDR4
* 16GB eMMC flash on board.
* 4 USB 3.0 port
* 1 GbE LAN por
* HDMI output
hardware interface:
80ba4a4d04853f639d0af4d9ebf45e7a755a69f3
more please see wiki page, we will keep update on wiki documents.
http://wiki.banana-pi.org/Banana_Pi_BPI-M5
Not a bug with a supported board nor a review nor with plans for board bring up (yet). Therefore moved to general chat for now until further details arrive. Thanks for understanding.
SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:0;SD:0;READ:0;0.0;CHK:0;
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0000 - pwm id 0x01
bl2_stage_init 0xc1
bl2_stage_init 0x02
no sdio debug board detected
L0:00000000
L1:00000703
L2:00008067
L3:15000020
S1:00000000
B2:20282000
B1:a0f83180
TE: 411275
BL2 Built : 15:21:42, Mar 26 2020. g12a g486bc38 - gongwei.chen@droid11-sz
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 1
Load FIP HDR DDR from SD, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
PIEI prepare done
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
DDR4 probe
LPDDR4_PHY_V_0_1_21-Built : 15:37:51, Mar 26 2020. g12a gf098346 - gongwei.chen@droid11-sz
ddr clk to 1320MHz
dmc_version 0001
Check phy result
INFO : End of initialization
INFO : ERROR : Training has failed!
1D training failed
Cfg max: 12, cur: 2. Board id: 255. Force loop cfg
DDR4 probe
ddr clk to 1320MHz
dmc_version 0001
Check phy result
1D training failed
Cfg max: 12, cur: 3. Board id: 255. Force loop cfg
DDR3 probe
ddr clk to 912MHz
dmc_version 0001
Check phy result
1D training failed
Cfg max: 12, cur: 4. Board id: 255. Force loop cfg
DDR3 probe
ddr clk to 912MHz
dmc_version 0001
Check phy result
1D training failed
Cfg max: 12, cur: 5. Board id: 255. Force loop cfg
LPDDR4 probe
ddr clk to 1392MHz
dmc_version 0001
Check phy result
1D training failed
Cfg max: 12, cur: 6. Board id: 255. Force loop cfg
LPDDR4 probe
ddr clk to 1392MHz
dmc_version 0001
Check phy result
INFO : End of CA training
INFO : Training has run successfully!
Check phy result
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of Write leveling coarse delay
Check phy result
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of write delay center optimization
INFO : End of read delay center optimization
INFO : End of max read latency training
1D training succeed
Check phy result
INFO : End of 2D read delay Voltage center optimization
INFO : End of 2D write delay Voltage center optimization
soc_vref_reg_value 0x 00000016 00000017 00000017 00000016 00000018 00000018 00000017 00000015 00000015 00000013 00000017 00000014 00000015 00000014 00000016 00000016 00000016 00000016 00000017 00000016 00000016 00000017 00000017 00000018 00000019 00000019 00000018 00000019 00000016 00000016 00000017 00000017 dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):0004
 dram_vref_reg_value 0x 0000005e
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002cDDR size: 2048MB
cs0 DataBus test pass
cs0 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 454
result report
boot times 0Enable ddr reg access
Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from SD, src: 0x00078200, des: 0x01768000, size: 0x00095200, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
[Image: g12a_v1.1.3394-7d43064d5 2020-05-07 15:37:06 gongwei.chen@droid11-sz]
OPS=0x01
ring efuse init
2b 0b 01 00 01 2a 13 00 00 17 35 38 57 4b 52 50
[0.014467 Inits done]
secure task start!
high task start!
low task start!
boot bl31
NOTICE:  BL31: v1.3(release):5d6723eeb
NOTICE:  BL31: Built : 15:05:59, Mar 17 2020
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2020.04 (Sep 16 2020 - 21:47:01 +0800) odroid-c4
Model: Hardkernel ODROID-C4
SoC:   Amlogic Meson SM1 (Unknown) Revision 2b:b (1:2)
DRAM:  2 GiB
MMC:   sd@ffe05000: 0, mmc@ffe07000: 1
In:    serial
Out:   serial
Err:   serial
Net:
Warning: ethernet@ff3f0000 (eth0) using random MAC address - a6:61:90:37:1d:e0
eth0: ethernet@ff3f0000
Hit any key to stop autoboot:  2 ��� 1 ��� 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3252 bytes read in 2 ms (1.6 MiB/s)
## Executing script at 08000000
201 bytes read in 5 ms (39.1 KiB/s)
15825064 bytes read in 1396 ms (10.8 MiB/s)
24576512 bytes read in 2168 ms (10.8 MiB/s)
72339 bytes read in 11 ms (6.3 MiB/s)
232 bytes read in 4 ms (56.6 KiB/s)
Applying kernel provided DT fixup script (meson-fixup.scr)
## Executing script at 34000000
## Loading init Ramdisk from Legacy Image at 13000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15825000 Bytes = 15.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 08008000
   Booting using the fdt blob at 0x8008000
   Loading Ramdisk to 7b032000, end 7bf49868 ... OK
   Loading Device Tree to 000000007afb7000, end 000000007b031fff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd050]
[    0.000000] Linux version 5.8.7-meson64 (root@bpi-iot-ros-ai-x64-66-gtx1050) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #trunk SMP PREEMPT Wed Sep 9 21:20:25 CST 2020
[    0.000000] Machine model: Banana Pi BPI-M5 (20200920A2)
[    0.000000] efi: UEFI not found.
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000042c00000, size 896 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fba5100-0x7fba6fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000004ffffff]
[    0.000000]   node   0: [mem 0x0000000005300000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] On node 0 totalpages: 523520
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 261376 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 262144 pages, LIFO batch:63
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 23 pages/cpu s54360 r8192 d31656 u94208
[    0.000000] pcpu-alloc: s54360 r8192 d31656 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 515328
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: root=UUID=c86ab25f-9e55-4201-9780-9ebb42548fd2 rootwait rootfstype=ext4 bootsplash.bootfile=bootsplash.armbian console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=8 ubootpart=667f95c4-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory swapaccount=1
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 1029804K/2094080K available (13756K kernel code, 1280K rwdata, 5568K rodata, 3328K init, 587K bss, 146772K reserved, 917504K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]     Trampoline variant of Tasks RCU enabled.
[    0.000000]     Rude variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized
[    0.000000] random: get_random_bytes called from start_kernel+0x35c/0x528 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000175] Console: colour dummy device 80x25
[    0.000658] printk: console [tty1] enabled
[    0.000738] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000761] pid_max: default: 32768 minimum: 301
[    0.000846] LSM: Security Framework initializing
[    0.000879] Yama: becoming mindful.
[    0.000971] AppArmor: AppArmor initialized
[    0.001023] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.001044] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.002465] rcu: Hierarchical SRCU implementation.
[    0.005169] EFI services will not be available.
[    0.005506] smp: Bringing up secondary CPUs ...
[    0.006305] Detected VIPT I-cache on CPU1
[    0.006362] CPU1: Booted secondary processor 0x0000000100 [0x411fd050]
[    0.007173] Detected VIPT I-cache on CPU2
[    0.007210] CPU2: Booted secondary processor 0x0000000200 [0x411fd050]
[    0.007963] Detected VIPT I-cache on CPU3
[    0.007994] CPU3: Booted secondary processor 0x0000000300 [0x411fd050]
[    0.008065] smp: Brought up 1 node, 4 CPUs
[    0.008125] SMP: Total of 4 processors activated.
[    0.008135] CPU features: detected: Privileged Access Never
[    0.008145] CPU features: detected: LSE atomic instructions
[    0.008155] CPU features: detected: User Access Override
[    0.008164] CPU features: detected: 32-bit EL0 Support
[    0.008174] CPU features: detected: Common not Private translations
[    0.008185] CPU features: detected: RAS Extension Support
[    0.008194] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.008208] CPU features: detected: CRC32 instructions
[    0.008218] CPU features: detected: 32-bit EL1 Support
[    0.028175] CPU: All CPU(s) started at EL2
[    0.030103] devtmpfs: initialized
[    0.040239] Registered cp15_barrier emulation handler
[    0.040268] Registered setend emulation handler
[    0.040770] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.040814] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.059870] xor: measuring software checksum speed
[    0.096173]    8regs     :  2243.000 MB/sec
[    0.136213]    32regs    :  2834.000 MB/sec
[    0.176259]    arm64_neon:  2486.000 MB/sec
[    0.176270] xor: using function: 32regs (2834.000 MB/sec)
[    0.176288] pinctrl core: initialized pinctrl subsystem
[    0.176997] thermal_sys: Registered thermal governor 'fair_share'
[    0.177001] thermal_sys: Registered thermal governor 'bang_bang'
[    0.177025] thermal_sys: Registered thermal governor 'step_wise'
[    0.177036] thermal_sys: Registered thermal governor 'user_space'
[    0.177788] DMI not present or invalid.
[    0.178277] NET: Registered protocol family 16
[    0.179521] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.180113] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.180414] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.180492] audit: initializing netlink subsys (disabled)
[    0.180659] audit: type=2000 audit(0.180:1): state=initialized audit_enabled=0 res=1
[    0.182151] cpuidle: using governor menu
[    0.182449] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.182549] ASID allocator initialised with 65536 entries
[    0.183567] Serial: AMBA PL011 UART driver
[    0.212929] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.212955] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.212968] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.212980] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.215070] cryptd: max_cpu_qlen set to 1000
[    0.284530] raid6: neonx8   gen()  2131 MB/s
[    0.352562] raid6: neonx8   xor()  1657 MB/s
[    0.420630] raid6: neonx4   gen()  2192 MB/s
[    0.488687] raid6: neonx4   xor()  1649 MB/s
[    0.556753] raid6: neonx2   gen()  2069 MB/s
[    0.624805] raid6: neonx2   xor()  1511 MB/s
[    0.692865] raid6: neonx1   gen()  1766 MB/s
[    0.760927] raid6: neonx1   xor()  1279 MB/s
[    0.828984] raid6: int64x8  gen()  1522 MB/s
[    0.897077] raid6: int64x8  xor()   784 MB/s
[    0.965122] raid6: int64x4  gen()  1645 MB/s
[    1.033180] raid6: int64x4  xor()   840 MB/s
[    1.101237] raid6: int64x2  gen()  1473 MB/s
[    1.169284] raid6: int64x2  xor()   747 MB/s
[    1.237356] raid6: int64x1  gen()  1115 MB/s
[    1.305412] raid6: int64x1  xor()   580 MB/s
[    1.305423] raid6: using algorithm neonx4 gen() 2192 MB/s
[    1.305432] raid6: .... xor() 1649 MB/s, rmw enabled
[    1.305442] raid6: using neon recovery algorithm
[    1.306040] ACPI: Interpreter disabled.
[    1.306966] 5V: supplied by 12V
[    1.308054] VDDAO_3V3: supplied by 12V
[    1.308767] iommu: Default domain type: Translated
[    1.308940] vgaarb: loaded
[    1.309920] SCSI subsystem initialized
[    1.310246] usbcore: registered new interface driver usbfs
[    1.310313] usbcore: registered new interface driver hub
[    1.310420] usbcore: registered new device driver usb
[    1.310762] pps_core: LinuxPPS API ver. 1 registered
[    1.310779] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.310811] PTP clock support registered
[    1.311071] EDAC MC: Ver: 3.0.0
[    1.312434] NetLabel: Initializing
[    1.312456] NetLabel:  domain hash size = 128
[    1.312465] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.312521] NetLabel:  unlabeled traffic allowed by default
[    1.312922] clocksource: Switched to clocksource arch_sys_counter
[    1.313323] VFS: Disk quotas dquot_6.6.0
[    1.313396] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.313874] AppArmor: AppArmor Filesystem Enabled
[    1.313955] pnp: PnP ACPI: disabled
[    1.320864] NET: Registered protocol family 2
[    1.321380] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.321445] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.321602] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.321773] TCP: Hash tables configured (established 16384 bind 16384)
[    1.322157] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.322207] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.322383] NET: Registered protocol family 1
[    1.322413] PCI: CLS 0 bytes, default 64
[    1.322615] Trying to unpack rootfs image as initramfs...
[    1.940357] Freeing initrd memory: 15452K
[    1.941258] kvm [1]: IPA Size Limit: 40bits
[    1.941411] kvm [1]: vgic interrupt IRQ1
[    1.941550] kvm [1]: VHE mode initialized successfully
[    1.947240] Initialise system trusted keyrings
[    1.947295] Key type blacklist registered
[    1.947415] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    1.952050] zbud: loaded
[    1.953348] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.954074] fuse: init (API version 7.31)
[    1.955132] integrity: Platform Keyring initialized
[    1.990356] Key type asymmetric registered
[    1.990375] Asymmetric key parser 'x509' registered
[    1.990445] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.990589] io scheduler mq-deadline registered
[    1.990605] io scheduler kyber registered
[    1.990741] io scheduler bfq registered
[    1.994006] gpio-447 (usb-hub-reset): hogged as output/high
[    1.997525] EINJ: ACPI disabled.
[    2.004268] soc soc0: Amlogic Meson SM1 (Unknown) Revision 2b:b (1:2) Detected
[    2.005892] pwm-regulator: supplied by regulator-dummy
[    2.006135] VCC_3V3: supplied by VDDAO_3V3
[    2.006185] FLASH_1V8: supplied by VCC_3V3
[    2.006234] VCC_1V8: supplied by VCC_3V3
[    2.006286] VDDAO_1V8: supplied by VDDAO_3V3
[    2.007089] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.009924] Serial: AMBA driver
[    2.010373] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 13, base_baud = 1500000) is a meson_uart
[    3.119704] printk: console [ttyAML0] enabled
[    3.124729] ffd24000.serial: ttyAML1 at MMIO 0xffd24000 (irq = 22, base_baud = 1500000) is a meson_uart
[    3.139867] loop: module loaded
[    3.144603] libphy: Fixed MDIO Bus: probed
[    3.145290] tun: Universal TUN/TAP device driver, 1.6
[    3.149060] thunder_xcv, ver 1.0
[    3.151311] thunder_bgx, ver 1.0
[    3.154520] nicpf, ver 1.0
[    3.157907] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    3.162931] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.168839] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    3.175692] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.181259] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    3.188973] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.195041] sky2: driver version 1.30
[    3.198987] VFIO - User Level meta-driver version: 0.3
[    3.205244] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.210042] ehci-pci: EHCI PCI platform driver
[    3.214472] ehci-platform: EHCI generic platform driver
[    3.219773] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.225731] ohci-pci: OHCI PCI platform driver
[    3.230164] ohci-platform: OHCI generic platform driver
[    3.235793] usbcore: registered new interface driver usb-storage
[    3.242855] mousedev: PS/2 mouse device common for all mice
[    3.247399] i2c /dev entries driver
[    3.256768] thermal thermal_zone0: binding zone cpu-thermal with cdev thermal-cpufreq-0 failed:-17
[    3.260992] sdhci: Secure Digital Host Controller Interface driver
[    3.266236] sdhci: Copyright(c) Pierre Ossman
[    3.270799] Synopsys Designware Multimedia Card Interface Driver
[    3.277817] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq
[    3.308933] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.310181] ledtrig-cpu: registered to indicate activity on CPUs
[    3.315445] meson-sm: secure-monitor enabled
[    3.319434] hid: raw HID events driver (C) Jiri Kosina
[    3.324362] usbcore: registered new interface driver usbhid
[    3.329762] usbhid: USB HID core driver
[    3.335042] NET: Registered protocol family 10
[    3.338619] Segment Routing with IPv6
[    3.341657] NET: Registered protocol family 17
[    3.346065] 8021q: 802.1Q VLAN Support v1.8
[    3.350227] Key type dns_resolver registered
[    3.354680] registered taskstats version 1
[    3.358402] Loading compiled-in X.509 certificates
[    3.364798] Loaded X.509 cert 'Build time autogenerated kernel key: e57a8865a56fa2714e522a1b383c5dc4bf89cb23'
[    3.373082] zswap: loaded using pool lzo/zbud
[    3.377547] Key type ._fscrypt registered
[    3.381251] Key type .fscrypt registered
[    3.383706] mmc0: new HS200 MMC card at address 0001
[    3.385162] Key type fscrypt-provisioning registered
[    3.390618] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[    3.396688] Btrfs loaded, crc32c=crc32c-generic
[    3.399818] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[    3.410204] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[    3.412078] Key type encrypted registered
[    3.415834] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB, chardev (242:0)
[    3.419646] AppArmor: AppArmor sha1 policy hashing enabled
[    3.442165] HUB_5V: supplied by 5V
[    3.442436] USB_PWR_EN: supplied by 5V
[    3.446313] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2
[    3.448835] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1
[    3.456891] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator
[    3.461158] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator
[    3.468350] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[    3.476065] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.480612] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.488297] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010
[    3.497523] xhci-hcd xhci-hcd.0.auto: irq 30, io mem 0xff500000
[    3.503548] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.511555] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.518726] usb usb1: Product: xHCI Host Controller
[    3.523535] usb usb1: Manufacturer: Linux 5.8.7-meson64 xhci-hcd
[    3.529486] usb usb1: SerialNumber: xhci-hcd.0.auto
[    3.534651] hub 1-0:1.0: USB hub found
[    3.538051] hub 1-0:1.0: 2 ports detected
[    3.542215] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.547436] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.555024] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.561523] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    3.569583] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[    3.577702] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.584858] usb usb2: Product: xHCI Host Controller
[    3.589687] usb usb2: Manufacturer: Linux 5.8.7-meson64 xhci-hcd
[    3.595638] usb usb2: SerialNumber: xhci-hcd.0.auto
[    3.600769] hub 2-0:1.0: USB hub found
[    3.604201] hub 2-0:1.0: 1 port detected
[    3.608483] dwc3-meson-g12a ffe09000.usb: switching to Device Mode
[    3.614970] meson-gx-mmc ffe05000.sd: Got CD GPIO
[    3.648743] Freeing unused kernel memory: 3328K
[    3.668967] Run /init as init process
[    3.668991]   with arguments:
[    3.669926]     /init
[    3.672168]   with environment:
[    3.675295]     HOME=/
[    3.677610]     TERM=linux
[    3.680276]     ubootpart=667f95c4-01
[    3.683906]     cgroup_enable=memory
[    3.702915] mmc1: new high speed SDHC card at address aaaa
[    3.703599] mmcblk1: mmc1:aaaa SL08G 7.40 GiB
[    3.708903]  mmcblk1: p1
[    3.942960] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found
[    3.943939] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found
[    3.988386] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock
[    3.988762] meson8b-dwmac ff3f0000.ethernet: no reset control found
[    4.006807] meson-vrtc ff8000a8.rtc: registered as rtc0
[    4.006876] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
[    4.018928] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[    4.021551] meson8b-dwmac ff3f0000.ethernet:     DWMAC1000
[    4.026722] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported
[    4.034113] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported
[    4.041558] meson8b-dwmac ff3f0000.ethernet: COE Type 2
[    4.046742] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported
[    4.053734] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported
[    4.057013] spidev spi0.0: probing from DT
[    4.060107] meson8b-dwmac ff3f0000.ethernet: Normal descriptors
[    4.070075] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled
[    4.075866] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.076251] random: fast init done
[    4.084131] libphy: stmmac: probed
[    4.091898] libphy: mdio_mux: probed
[    4.103929] libphy: mdio_mux: probed
[    4.489382] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
[    4.916949] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    5.044967] usb 1-1: device descriptor read/64, error -71
[    5.195121] systemd[1]: System time before build time, advancing clock.
[    5.219209] systemd[1]: Inserted module 'autofs4'
[    5.271965] systemd[1]: systemd 245.4-4ubuntu3.2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    5.280972] usb 1-1: device descriptor read/64, error -71
[    5.289074] systemd[1]: Detected architecture arm64.
[    5.334576] systemd[1]: Set hostname to <bpi-iot-ros-ai>.
[    5.528969] usb 1-1: new high-speed USB device number 3 using xhci-hcd
[    5.656972] usb 1-1: device descriptor read/64, error -71
[    5.696295] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket 鈫?/run/dbus/system_bus_socket; please update the unit file accordingly.
[    5.875897] random: systemd: uninitialized urandom read (16 bytes read)
[    5.879266] systemd[1]: Created slice system-modprobe.slice.
[    5.882923] random: systemd: uninitialized urandom read (16 bytes read)
[    5.889943] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.892987] usb 1-1: device descriptor read/64, error -71
[    5.900822] random: systemd: uninitialized urandom read (16 bytes read)
[    5.907999] systemd[1]: Created slice User and Session Slice.
[    5.913313] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.921209] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.930030] systemd[1]: Reached target User and Group Name Lookups.
[    5.936071] systemd[1]: Reached target Remote File Systems.
[    5.941549] systemd[1]: Reached target Slices.
[    5.945955] systemd[1]: Reached target Swap.
[    5.950165] systemd[1]: Reached target System Time Set.
[    5.955748] systemd[1]: Listening on Syslog Socket.
[    5.960509] systemd[1]: Listening on fsck to fsckd communication Socket.
[    5.967022] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    5.973882] systemd[1]: Listening on Journal Audit Socket.
[    5.979056] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.985004] systemd[1]: Listening on Journal Socket.
[    5.989942] systemd[1]: Listening on udev Control Socket.
[    5.995100] systemd[1]: Listening on udev Kernel Socket.
[    6.003384] systemd[1]: Mounting Huge Pages File System...
[    6.005101] usb usb1-port1: attempt power cycle
[    6.013321] systemd[1]: Mounting POSIX Message Queue File System...
[    6.019812] systemd[1]: Mounting Kernel Debug File System...
[    6.022270] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[    6.034262] systemd[1]: Starting Restore / save the current clock...
[    6.039896] systemd[1]: Starting Set the console keyboard layout...
[    6.046327] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    6.055281] systemd[1]: Starting Load Kernel Module drm...
[    6.060459] systemd[1]: Started Nameserver information manager.
[    6.063109] systemd[1]: Reached target Network (Pre).
[    6.075433] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    6.079230] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    6.086570] systemd[1]: Starting Load Kernel Modules...
[    6.096599] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.104055] systemd[1]: Starting udev Coldplug all Devices...
[    6.110464] systemd[1]: Mounted Huge Pages File System.
[    6.111204] systemd[1]: Mounted POSIX Message Queue File System.
[    6.117218] systemd[1]: Mounted Kernel Debug File System.
[    6.123962] systemd[1]: Finished Restore / save the current clock.
[    6.130132] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    6.148710] systemd[1]: modprobe@drm.service: Succeeded.
[    6.150050] systemd[1]: Finished Load Kernel Module drm.
[    6.156091] systemd[1]: Finished Load Kernel Modules.
[    6.162425] systemd[1]: Mounting FUSE Control File System...
[    6.166151] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
[    6.168016] systemd[1]: Mounting Kernel Configuration File System...
[    6.180977] systemd[1]: Starting Apply Kernel Variables...
[    6.190718] systemd[1]: Finished Remount Root and Kernel File Systems.
[    6.192628] systemd[1]: Mounted FUSE Control File System.
[    6.198213] systemd[1]: Mounted Kernel Configuration File System.
[    6.206067] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    6.212167] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    6.225586] systemd[1]: Starting Load/Save Random Seed...
[    6.233400] systemd[1]: Starting Create System Users...
Armbian 20.11.0-trunk Focal ttyAML0
bpi-iot-ros-ai login:
test armbian log
On 9/16/2020 at 8:30 AM, Lion Wang said:
main spec:
* Mali-G31 GPU
* 4GB LPDDR4
* 4 USB 3.0 port
* 1 GbE LAN por
* HDMI output
Nice board. Clean and simple.
I like this SoC a lot, very power efficient and good thermals.
What will be the price? When will it be sold?
I'd like to see wifi/BT on-board. But not everyone needs that for their tasks, I understand why not to have it.
I also like to have a barrel jack for power. Type-C is ok. But still a lot of issue's with bad cables and bad contacts.
Good luck.
this board price about 50 USD .
why not add wifi and BT onboad ,Because the GPIO of this chip is too small, if WIFI&BT is added, the available GPIO is too small, so the way of external support is adopted
Agreed.
Also curios about the USB3 performance. I learned about bad performance with the N2+ and wonder how they do on this board.
The BPi M5 is just an ODROID C4 clone (check also the serial console output in the wall of text above) so simply look there. They even took the same VL817 hub (a way better choice than the Genesis Logic thingy on the N2+) but of course decided to change the power circuitry so that their users suffer from the usual Banana undervoltage drama (unlike the C4 which is up to the task powering a number of USB3 consumers with stable 5V unlike the M5 here).
Oh wow.... :o
Thanks for sharing this info.
Welp, nothing much to add here...
Android[edit]
android source code: https://github.com/BPI-SINOVOIP/BPI-S905X3-Android9
Linux[edit]
Linux BSP code: https://github.com/BPI-SINOVOIP/BPI-M5-bsp
Getting Started with BPI-M5:
http://wiki.banana-pi.org/Getting_Started_with_BPI-M5
Lion, thanks for your input and facts.
Does it come with a heat-sink?
What remains is, when will it be available?
Are there pre-production Beta parts available now?
Thanks, Jon
PS BTW, it looks to me that the Odroid C4 only has a eMMC socket, not onboard flash. So this can raise the price of a "running" system
by yet another 12.90 USD minimum. Yes the socket will allow more options (8, 16 32 and 64GB), but it comes at a price.
BPI M2 Pro, Amlogic S905X3 on sale right now on Aliexpress.
About 52€ plus shipping.
Amlogic S905X3 + Mali-G31 GPU
2GB LPDDR4
16GB eMMC flash
2 USB 3,0
RT8821CU WiFi + BT 4,2 on board
1 GbE ethernet
HDMI
The form factor and port situation is good, more or less like many Android TV box without case.
2GB LPDDR4
16GB eMMC flash
2 USB 3,0
1 GbE ethernet
HDMI
it also can use BPI-M2+ case :
I tried to troubleshoot some USB throughput issues with the M2 Pro unit and possibly narrowed it down to all USB ports apparently being on the same USB 2.0 Bus:
lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 2: Dev 4, If 0, Class=Wireless, Driver=btusb, 480M
        |__ Port 2: Dev 4, If 1, Class=Wireless, Driver=btusb, 480M
        |__ Port 2: Dev 4, If 2, Class=Vendor Specific Class, Driver=rtl8821cu, 480M
From lsusb -v USB HUBs look like this:
Bus 002 Device 002: ID 2109:0817 VIA Labs, Inc. USB3.0 Hub
Bus 001 Device 002: ID 2109:2817 VIA Labs, Inc. USB2.0 Hub
While plugging things into various ports on the board this is what they layout looks like:
1-1.1 - bottom USB
1-1.2 - WiFi
1-1.4 - top USB
1-2 - OTG
Everything is tied to Bus 01.
There does not appear to be anything on the Bus 02 , which is what apparently actually is the USB 3.0 (5000M).
I am a tiny bit out of my depth here, am I reading the output right? Is the M2 board design really broken?
The same layout as Jan Gregor showed is also on the M5.
Additionally, it seems the SD card is not being reset by BL2 (maybe not possible?) when the OS initiates a reboot. Then it doesn't find the SD card anymore and can't continue booting. :(
I tested SanDisk Ultra 128GB, Kingston 16 GB SDCA 10/16GB, Intenso Class 10 64 GB, all with the same problem.
bananapim5 login: root
Password:
 ____  ____  _   __  __ ____    ____  __ ____  ____
| __ )|  _ \(_) |  \/  | ___|  / /  \/  |___ \|  _ \
|  _ \| |_) | | | |\/| |___ \ / /| |\/| | __) | |_) |
| |_) |  __/| | | |  | |___) / / | |  | |/ __/|  __/
|____/|_|   |_| |_|  |_|____/_/  |_|  |_|_____|_|
Welcome to Armbian 23.02.2 Bullseye with bleeding edge Linux 6.2.0-rc3-meson64
No end-user support: untested automated build
System load:   51%              Up time:       25 min   Local users:   4
Memory usage:  7% of 3.70G      IP:            192.168.178.208
CPU temp:      31°C             Usage of /:    8% of 58G
[ General system configuration (beta): armbian-config ]
Last login: Sat Mar 18 14:18:55 CET 2023 on ttyAML0
root@bananapim5:~# reboot
[ 1546.656598] reboot: Restarting system
bl31 reboot reason: 0xd
bl31 reboot reason: 0x0
system cmd  1.
bl2_stage_init 0x01
bl2_stage_init 0x81
bl2_stage_init 0xc1
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:15000020
S1:00000000
B2:20282000
B1:a0f83180
TE: 216002
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 1
FIP HDR CHK: 0x000000ff ADDR 0xfffd0000
reset...
SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:0;SD:400;USB:8;LOOP:1;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:0;SD:400;USB:8;LOOP:2;EMMC:0;READ:0;CHK:1F;READ:0;CHK:1F;READ:0;CHK:1F;SD?:0;SD:400;USB:8;
