I have installed Armbian distrubution focal
i am running with boot from sd and system on nvme
I installed gnome disks and i did a benchmark.
drive/ model number
Transcend 512GB NVMe PCIe Gen3 x4 MTE220S M.2 TS512GMTE220S
advertised speeds 3100 read/2100 write
The results where as followed:
750 mbs read >>>inline with epectations
150 mbs >>> way below expectations for the drive
is there a atch availeble?
The M4V2 only has 2 lanes PCIe. So 750MB/s is about the limit I think. The RockPi4 has 4 lanes so that can do a bit beter. There is a setting for that to use gen3.
The write speed doesn't seem right. What filesize do you use to benchmark? I use 100MB.
How you do the tests?
I've noticed the fuller the NVMe the slower it is. Greetings
it is the nanopi m4 v2
i am aware of the pcie gen 2 speeds(and i sough ur video  sys on nvme "nico D big fan")
i did the default test with default sizes and i did the same test with blocks of 100mb
it is the low write speed that makes it odd makes me think somthing is wrong
its a near empty nvme of 512 gb (less then 20 gb is occupied)
i used the default kernel when you download the armbian focal image of the website.
if the problem persist il try to instal buster image....aldo i hope there is a patch
Will most likely not make any difference since both flavors sharing the very same kernel package.
