39 минут назад, NicoD сказал:
It is working. No idea what is different now. It boots, at first boot NVMe was working. Then I did update/upgrade. It wasn't working anymore. Then I replaced the dtb with your file and NVMe is working.
It looks like the sound chip is on the underside of the board. But I can not yet disassemble and check (the equipment is in operation).
When updating, the kernel is replaced and the system tries to use the wrong DTB. :)
The Samsung EVO 250 G did not show up on station -p1 5-10-12-rockchip64 until I did unplug the mezzanine -remove the envm drive and clean the connectors and then plug it all together again and then then /dev/nvme0n1 did show up as expected.    Probably some dirt at the connectors on the nvme.
19 hours ago, balbes150 said:
I found the marking of the sound chip - this is es8388
Just to be informative this is excellent sound output to speakers through ordinary usb on every SBC board https://www.aliexpress.com/item/32809504593.html?spm=a2g0s.9042311.0.0.688a4c4d4jtZa4
It have CM6631A ship and gives the possibility to Coaxial/Optical fiber SPDIF I2S Converter DAC Board 24bit 192khz.  Gives a superb sound quality.
On 2/7/2021 at 10:23 AM, balbes150 said:
@NicoDDo you have a photo with the maximum resolution of the main board P1 top view and bottom view ? I am interested in marking the ES83xx sound chip.
ES 8388  SR08T884
On 2/3/2021 at 7:15 AM, Werner said:
How much additional height would be needed? Maybe I can design kind a adapter for it milled from aluminum...
10 mm between will do about 1,5 - 2 mm gap.
@balbes150Do you know what app to use to write the images in Android?
I've just tried and could find any. EtchDroid doesn't do .img
Then others only do images for raspberry pi. Android also isn't nice to my capture devices. Had to search a long time to find a configuration that works. I hate Android :)
15 часов назад, NicoD сказал:
I don't use android, after version 4 (after googl messed it up and turned it into shit).
I hate Android
I totally agree :)
@balbes150 Using this image I now can't upgrade fully.
https://yadi.sk/d/TnDjwCsvG9-nuA?w=1
nicod@station-p1:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  linux-image-legacy-rockchip64
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
25 not fully installed or removed.
Need to get 0 B/17.7 MB of archives.
After this operation, 6,483 kB disk space will be freed.
Do you want to continue? [Y/n] y
Setting up systemd (241-7~deb10u6) ...
(Reading database ... 83639 files and directories currently installed.)
Preparing to unpack .../linux-image-legacy-rockchip64_21.02.1_arm64.deb ...
/var/lib/dpkg/tmp.ci/preinst: 23: /var/lib/dpkg/tmp.ci/preinst: [[: not found
Unpacking linux-image-legacy-rockchip64 (21.02.1) over (21.02.0-trunk) ...
dpkg: error processing archive /var/cache/apt/archives/linux-image-legacy-rockchip64_21.02.1_arm64.deb (--unpack):
 unable to make backup link of './boot/System.map-4.4.213-rockchip64' before installing new version: Operation not permitted
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
mv: cannot stat '/boot/vmlinux-4.4.213-rockchip64': No such file or directory
dpkg: error while cleaning up:
 installed linux-image-legacy-rockchip64 package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I'm doing the writing in Linux, I can't find a good free tool to write .img to an sd-card in Android.
I'll see if I can continue with this.
p.s.: Media script also can't be installed.
 media-buster-legacy-rk3399
17 часов назад, NicoD сказал:
You are trying to put a kernel from network repositories that is not suitable for P1 (it does not have any support for P1). Disable the kernel update.
18 часов назад, NicoD сказал:
I'm going to ask a stupid question.  Have you tried using the terminal and dd?
No. I haven't. I'll try that. Thanks for the tip.
Updated the Armbian\ArmbianTV images (20210211).
I checked both variants of Buster-legacy + media script on P1 (rk3399). I froze the kernel update, installed the script, checked the HW acceleration, everything works. Including remote control in KODI and on the desktop, analog sound works (by default, the sound level is set low, you need to go to settings and increase the volume), 4k works.  :)
Everything indeed works as should. I've done a test install and everything was fine.
Just my capture devices do not want to work with me. In console they give an awful green picture, or default to 4k. With Android nothing seems to work. I don't get it.
Maybe it is possible to perform a simple recording of what is happening on the monitor on a regular video camera or take photos of your favorite moments ?
On 1/17/2021 at 10:16 AM, balbes150 said:
@NicoD Can you shoot a video on how to download and burn an Armbian image to an SD card using only a regular Android on P1 ? I. e. I am interested in a video how to run Armbian with only P1. This instruction allows any user, without any additional devices (PC, laptop, etc.) to get a working Armbian on any supported device. :)
I did it. Somehow. :D
New version of ArmbianTV 20210218 for P1 and M1.
An important difference. I made the transition to the startup system using the settings only in the "extlinux.conf" file. You no longer need to use a lot of complex scripts and intermediate text files to describe the startup process. Setting up the DTB is done by editing the line in "extlinux.conf". There you can also change any other startup parameters (disable BOOTFLASH, add a forced binding to the MAC, etc.). That is, you can now use the officially supported parameter format for "extlinux.conf". I also stop publishing versions of Armbian images, because they differ little from the official versions of images from the Armbian download site (i.e. I remove redundant duplication).
The new version 20210221.
Important information.
The installation mode in eMMC has changed. Now, the standard application "armbian-config" and the corresponding menu items in it are used for installation in eMMC.
I tried the latest image and it still has the same problem with the media script and NVMe dtb file.
With the NVMe dtb file chromium isn't hw acc, and kodi doesn't work. If I switch back to the default dtb file it all works.
I tried to install the media script with the NVMe dtb file. All installs well, but doesn't work. Switching back to the default dtb makes it work again.
@balbes150Any idea what could cause this in the NVMe dtb file? I've got no clue.
5 минут назад, NicoD сказал:
Awesome. I will try it now.
I was just going to start making a gaming image on the NVMe and buster legacy on sd-card. Buster on NVMe would be way better. Thank you.
In a few hours, I plan to update the images on the site, including with a new version of Buster (which will all have the patched DTB enabled by default).
It works. OMG I'm so happy. You did an amazing work.
Graphics Feature Status
Canvas: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Force enabled
Out-of-process Rasterization: Disabled
OpenGL: Enabled
Hardware Protected Video Decode: Hardware accelerated
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Enabled
Video Decode: Software only. Hardware acceleration disabled
Vulkan: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
And ...
/dev/nvme0n1p1 ext4      458G   70M  435G   1% /media/nicod/3acb3cd1-680c-455f-ab36-36f424ce5302
I'm stoked. I've got a bad habit of staying at a project until it's done. I should have done other things the last month, but every day I kept trying with the P1.
I'll finally be able to finish it and start with another board. And I'll be able to use the P1 as my main machine. And my M4V2 for gaming. Thank you.
I'll wait for that. I don't mind waiting a bit longer.
Version 20210226. Fixed NVMe and added a separate DTB for roc-rk3399-pc (works with Renegade Elite) with Legacy kernel. After testing for several weeks u-boot-2021.01 on different rk3399, the transition to u-boot-2021.01 was made
I remind you that the configuration of DTB and other startup parameters is now performed in the file /boot/extlinux/extlinux.conf
2 hours ago, balbes150 said:
Version 20210226.
Reboot doesn't seem to be working. It either shuts down, or stays on without doing anything.
Otherwise it all looks ok. I do have a problem with kazam when the media script is installed. I've had that too on M4V2 with media script in Buster, so it's not the image.
I'm filming everything to make the video. I'll not use Android to write the image, I'll link to the video of @gounthar instead. He clearly has more Android knowledge, and way more patience.
@balbes150Install to NVMe also doesn't work correct.(with armbian-config) It does copy everything to the NVMe. But still boots from sd-card.
In extlinux.conf it seems to be pointing to the wrong UUID. It works when I set it to the NVMe UUID.
Maybe because you've switched the config file.
No worries for me. As long as I can make it work I'm fine.
14 минут назад, NicoD сказал:
The installation on NVMe works correctly. I checked it with the latest Buster image install to NVMe and there are no problems. When installing, you must select the correct mode (eMMC + NVMe). Most likely, you chose the wrong mode (the first line in the menu), this is installing u-boot on SD and system on NVMe. Look carefully at the names of the menu items, there are many different combinations, you need to choose the right option.
I'll see if I indeed made the wrong choice when I do the video edit. I wasn't paying much attention to be honest.
One more thing, do you know how to set the clocks to 2Ghz/1.5Ghz? I remember reading there was a script for that. But can't remember where or how.
For the media image that's not needed. But for the 2nd Focal mainline gaming image that is very beneficial. Thanks
6 минут назад, NicoD сказал:
If I'm not confused, this option is only available for the main core, it doesn't work for Legacy.
It is for mainline that I want it.
