By the way. A word of warning to anyone getting a Nanopi Neo bare board (without RJ45 and USB connectors). I bought a RJ435 Magjack from Sparkfun to provide the Ethernet connection. Although the dimensions and pinout match perfectly with the circuit board it simply doesnt work at all. A careful reading of the Neo schematics, and the circuit details of the Hanrun magjack FA used and the Sparkfun one I see that although they are not wired the same internally. The correct Magjack to use is a Hanrun HR911105A. They are hard to find in the US but $0.75 each from Aliexpress.
Another bit of feedback on the mainline - vanilla Jessie. Only one of the three USB ports is active, USB0. USB1 and USB2 are disabled. For comparison I booted the FA Ubuntu core and the USB ports are OK. Perhaps this is another device tree issue?
Short Feedback:
ARMBIAN Ubuntu 16.04.1 LTS 4.6.7-sun8i works fine on the NanoPi NEO and GNU Octave also installed fine.
Thank you for making armbian such a smooth experience.
I will report more once I get my complete compute stack set up.
Thanks for the information.
Explained in post #167 of this thread. And you don't need to boot FA images since with our legacy kernel images everything else is also fine. As soon as NEO is supported by u-boot the issue will be resolved (but it takes too much time to patch with this device tree stuff around)
Not really, see above. USB is not working due to using Orange Pi One settings and throttling needs some love/attention. Currently the dvfs / cpufreq / throttling settings for all H3 boards with the primitive voltage regulator are pretty bad and need improvements (ability to use 912 MHz CPU clockspeed, better throttling since now when throttling occurs NEO will jump between 816 and 1200 MHz and never uses the 1008 MHz in between).
But things will improve in the future for sure. And it's nice to know that people pay no attention to stuff like that :)
  On 8/23/2016 at 7:29 AM, tkaiser said:
More experimental images based on 4.7.2 with USB OTG support (to be confirmed) and schedutil cpufreq governor available but not active by default herehttp://kaiser-edv.de/tmp/w8JAAY/
dead link ?
I got
curl: (7) Failed to connect to kaiser-edv.de port 80: Connection timed out
when trying to download the image
I just got an order of another 6 of the NEO's and they look to be a different board revision there is a different silkscreen and some small components have moved.
The new revision seems to run much cooler. 34c (New) vs 44c (Old) at 7-10% CPU.
Yes, PCB rev 1.1 is slightly different, added yesterday stuff to our wiki: http://linux-sunxi.org/FriendlyARM_NanoPi_NEO#See_also(thanks for mentioning that heat emissions seem to have improved -- can you spot a difference regarding the PCB? Thicker? Copper layers inside?)
It would be great if you could provide from both board revisions the output from 'sudo armbianmonitor -m' while running
sysbench --test=cpu --cpu-max-prime=20000 run --num-threads=4
Would be good if the output contains 10 seconds before you start sysbench and 180 seconds after. And of course environmental conditions should be identical (same place, same temperatures, same OS image, same PSU :) )
Please use pastebin.com or spoiler tags when providing armbianmonitor output.
Img of setup https://goo.gl/photos/oBcKhFXhkVx9zYs99
The V1 (CPU G3088BA 63R3)
  Reveal hidden contents
The V1.1 (CPU G5074BA 65R3)
Before
5.12v
.26A
During
5.12V
.45A - .48A
After
5.13V
.31A
How did you get these informations ? CPU G3088BA 63R3 ....
Armbian 5.20, Debian Jessie, kernel 4.7.4, uboot 09.2016 don't boot on Nanopi Neo 512  :(
I checked after upgrading from version 5.17 (kernel 4.7.3) and built from source.
Version 3.4.112 works well.
Tomorrow I will try to debug.
Edit:
First boot log Armbian 5.20, Debian Jessie, uboot 09.2016,
U-Boot SPL 2016.09-armbian (Sep 17 2016 - 22:45:42)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2016.09-armbian (Sep 17 2016 - 22:45:42 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi One
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2889 bytes read in 185 ms (14.6 KiB/s)
gpio: pin PL10 (gpio 298) value is 1
   Warning: value of pin is still 0
gpio: pin PG11 (gpio 203) value is 1
0 bytes read in 132 ms (0 Bytes/s)
0 bytes read in 140 ms (0 Bytes/s)
33585 bytes read in 1091 ms (29.3 KiB/s)
3973743 bytes read in 412 ms (9.2 MiB/s)
5794224 bytes read in 567 ms (9.7 MiB/s)
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    3973679 Bytes = 3.8 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49c35000, end 49fff22f ... OK
   Loading Device Tree to 49c29000, end 49c34330 ... OK
Using machid 0x1029 from environment
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.7.4-sun8i (root@ubuntuVM) (gcc version 5.4.0 2016
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] Machine model: Xunlong Orange Pi One
[    0.000000] cma: Reserved 16 MiB at 0x5ec00000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 13 pages/cpu @dff6c000 s23820 r8192 d21236 u5328
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa0
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev7
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 485680K/524288K available (8401K kernel code, 296K rwdat)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0bab7b0   (11918 kB)
[    0.000000]       .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
[    0.000000]       .data : 0xc0d00000 - 0xc0d4a080   ( 297 kB)
[    0.000000]        .bss : 0xc0d4c000 - 0xc0d987d0   ( 306 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398s
[    0.000019] Switching to timer-based delay loop, resolution 41ns
[    0.000337] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, maxs
[    0.000712] Console: colour dummy device 80x30
[    0.001192] console [tty1] enabled
[    0.001228] Calibrating delay loop (skipped), value calculated using timer f)
[    0.001265] pid_max: default: 32768 minimum: 301
[    0.001416] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001441] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.002283] CPU: Testing write buffer coherency: ok
[    0.002729] CPU0: update cpu_capacity 1024
[    0.002760] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002806] Setting up static identity map for 0x40100000 - 0x40100058
[    0.015088] CPU1: update cpu_capacity 1024
[    0.015096] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.025863] CPU2: update cpu_capacity 1024
[    0.025869] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.036624] CPU3: update cpu_capacity 1024
[    0.036630] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.036700] Brought up 4 CPUs
[    0.036821] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.036840] CPU: All CPU(s) started in HYP mode.
[    0.036855] CPU: Virtualization extensions available.
[    0.037893] devtmpfs: initialized
[    0.047252] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[    0.047788] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.048487] xor: measuring software checksum speed
[    0.146477]    arm4regs  :  1261.600 MB/sec
[    0.246538]    8regs     :   876.800 MB/sec
[    0.346594]    32regs    :   875.200 MB/sec
[    0.446651]    neon      :  1282.400 MB/sec
[    0.446671] xor: using function: neon (1282.400 MB/sec)
[    0.446792] pinctrl core: initialized pinctrl subsystem
[    0.448166] NET: Registered protocol family 16
[    0.449471] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.475370] cpuidle: using governor ladder
[    0.496048] cpuidle: using governor menu
[    0.501418] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[    0.501459] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.676983] raid6: int32x1  gen()   180 MB/s
[    0.847055] raid6: int32x1  xor()   166 MB/s
[    1.017209] raid6: int32x2  gen()   232 MB/s
[    1.187217] raid6: int32x2  xor()   172 MB/s
[    1.357339] raid6: int32x4  gen()   225 MB/s
[    1.527405] raid6: int32x4  xor()   172 MB/s
[    1.697673] raid6: int32x8  gen()   223 MB/s
[    1.867771] raid6: int32x8  xor()   149 MB/s
[    2.037743] raid6: neonx1   gen()   494 MB/s
[    2.207806] raid6: neonx1   xor()   363 MB/s
[    2.377883] raid6: neonx2   gen()   650 MB/s
[    2.548009] raid6: neonx2   xor()   473 MB/s
[    2.718149] raid6: neonx4   gen()   721 MB/s
[    2.888218] raid6: neonx4   xor()   499 MB/s
[    3.058316] raid6: neonx8   gen()   694 MB/s
[    3.228462] raid6: neonx8   xor()   484 MB/s
[    3.228481] raid6: using algorithm neonx4 gen() 721 MB/s
[    3.228498] raid6: .... xor() 499 MB/s, rmw enabled
[    3.228516] raid6: using intx1 recovery algorithm
[    3.228849] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soe
[    3.229669] gpio-regulator gpio-regulator: could not find pctldev for node /e
[    3.230418] SCSI subsystem initialized
[    3.230967] usbcore: registered new interface driver usbfs
[    3.231051] usbcore: registered new interface driver hub
[    3.231143] usbcore: registered new device driver usb
[    3.231373] media: Linux media interface: v0.10
[    3.231436] Linux video capture interface: v2.00
[    3.231539] pps_core: LinuxPPS API ver. 1 registered
[    3.231558] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    3.231603] PTP clock support registered
[    3.233405] clocksource: Switched to clocksource arch_sys_counter
[    3.242472] NET: Registered protocol family 2
[    3.243206] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    3.243279] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    3.243353] TCP: Hash tables configured (established 4096 bind 4096)
[    3.243520] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    3.243580] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    3.243806] NET: Registered protocol family 1
[    3.244213] RPC: Registered named UNIX socket transport module.
[    3.244246] RPC: Registered udp transport module.
[    3.244264] RPC: Registered tcp transport module.
[    3.244281] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.244645] Trying to unpack rootfs image as initramfs...
[    3.470645] Freeing initrd memory: 3884K (c9c35000 - ca000000)
[    3.472346] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    3.472790] Initialise system trusted keyrings
[    3.473351] workingset: timestamp_bits=12 max_order=17 bucket_order=5
[    3.481287] zbud: loaded
[    3.484443] NFS: Registering the id_resolver key type
[    3.484527] Key type id_resolver registered
[    3.484546] Key type id_legacy registered
[    3.484571] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.484591] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.486072] JFS: nTxBlock = 3952, nTxLock = 31621
[    3.493285] SGI XFS with ACLs, security attributes, realtime, no debug enabld
[    3.500640] Key type asymmetric registered
[    3.500978] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    3.501158] io scheduler noop registered
[    3.501180] io scheduler deadline registered
[    3.501240] io scheduler cfq registered (default)
[    3.502011] sun4i-usb-phy 1c19400.phy: could not find pctldev for node /soc/e
[    3.504512] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.505339] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    3.560381] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.563150] console [ttyS0] disabled
[    3.583364] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 35, base_baud = 1A
[    4.393767] console [ttyS0] enabled
[    4.401390] brd: module loaded
[    4.411343] loop: module loaded
[    4.416865] usbcore: registered new interface driver catc
[    4.422328] usbcore: registered new interface driver kaweth
[    4.427933] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet drr
[    4.435395] usbcore: registered new interface driver pegasus
[    4.441090] usbcore: registered new interface driver rtl8150
[    4.446822] usbcore: registered new interface driver r8152
[    4.452368] usbcore: registered new interface driver lan78xx
[    4.458099] usbcore: registered new interface driver asix
[    4.463555] usbcore: registered new interface driver ax88179_178a
[    4.469692] usbcore: registered new interface driver cdc_ether
[    4.475578] usbcore: registered new interface driver cdc_eem
[    4.481280] usbcore: registered new interface driver dm9601
[    4.486904] usbcore: registered new interface driver sr9700
[    4.492535] usbcore: registered new interface driver CoreChips
[    4.498456] usbcore: registered new interface driver smsc75xx
[    4.504274] usbcore: registered new interface driver smsc95xx
[    4.510064] usbcore: registered new interface driver gl620a
[    4.515694] usbcore: registered new interface driver net1080
[    4.521398] usbcore: registered new interface driver plusb
[    4.526929] usbcore: registered new interface driver rndis_host
[    4.532894] usbcore: registered new interface driver cdc_subset
[    4.538879] usbcore: registered new interface driver MOSCHIP usb-ethernet drr
[    4.546388] usbcore: registered new interface driver cdc_ncm
[    4.552094] usbcore: registered new interface driver huawei_cdc_ncm
[    4.558416] usbcore: registered new interface driver cdc_mbim
[    4.564175] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.570706] ehci-platform: EHCI generic platform driver
[    4.576246] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.582450] ohci-platform: OHCI generic platform driver
[    4.587966] usbcore: registered new interface driver cdc_wdm
[    4.593714] usbcore: registered new interface driver usb-storage
[    4.600817] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    4.607660] sun6i-rtc 1f00000.rtc: RTC enabled
[    4.612271] i2c /dev entries driver
[    4.616916] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, no)
[    4.626490] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    4.663435] sunxi-mmc 1c0f000.mmc: base:0xe0ab8000 irq:23
[    4.669549] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    4.710541] mmc0: host does not support reading read-only switch, assuming we
[    4.718615] sunxi-mmc 1c10000.mmc: base:0xe0aba000 irq:24
[    4.721233] mmc0: new high speed SDHC card at address e624
[    4.721913] mmcblk0: mmc0:e624 SU32G 29.7 GiB
[    4.723173]  mmcblk0: p1
[    4.737301] ledtrig-cpu: registered to indicate activity on CPUs
[    4.743437] hidraw: raw HID events driver (C) Jiri Kosina
[    4.748995] usbcore: registered new interface driver usbhid
[    4.754589] usbhid: USB HID core driver
[    4.759246] Initializing XFRM netlink socket
[    4.764510] NET: Registered protocol family 10
[    4.770013] NET: Registered protocol family 17
[    4.774530] NET: Registered protocol family 15
[    4.775428] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 8, RTO !!
[    4.779505] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 55, RTO !!
[    4.780325] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 55, RTO !!
[    4.781145] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 55, RTO !!
[    4.781965] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 55, RTO !!
[    4.782815] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 1, RTO !!
[    4.812841] bridge: automatic filtering via arp/ip/ip6tables has been deprec.
[    4.825537] 8021q: 802.1Q VLAN Support v1.8
[    4.829777] Key type dns_resolver registered
[    4.834406] Registering SWP/SWPB emulation handler
[    4.839899] registered taskstats version 1
[    4.844032] Loading compiled-in X.509 certificates
[    4.848927] zswap: loaded using pool lzo/zbud
[    4.855930] Btrfs loaded, crc32c=crc32c-generic
[    4.860479] BTRFS: selftest: sectorsize: 4096  nodesize: 4096
[    4.866253] BTRFS: selftest: sectorsize: 4096  nodesize: 8192
[    4.872003] BTRFS: selftest: sectorsize: 4096  nodesize: 16384
[    4.877853] BTRFS: selftest: sectorsize: 4096  nodesize: 32768
[    4.883702] BTRFS: selftest: sectorsize: 4096  nodesize: 65536
[    4.904614] Key type encrypted registered
[    4.911296] ehci-platform 1c1a000.usb: EHCI Host Controller
[    4.916961] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus 1
[    4.925106] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    4.943478] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    4.949889] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.956706] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    4.963952] usb usb1: Product: EHCI Host Controller
[    4.968829] usb usb1: Manufacturer: Linux 4.7.4-sun8i ehci_hcd
[    4.974675] usb usb1: SerialNumber: 1c1a000.usb
[    4.980015] hub 1-0:1.0: USB hub found
[    4.983844] hub 1-0:1.0: 1 port detected
[    4.988562] ehci-platform 1c1b000.usb: EHCI Host Controller
[    4.994197] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus 2
[    5.002161] ehci-platform 1c1b000.usb: irq 28, io mem 0x01c1b000
[    5.023408] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    5.029774] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    5.036586] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    5.043835] usb usb2: Product: EHCI Host Controller
[    5.048720] usb usb2: Manufacturer: Linux 4.7.4-sun8i ehci_hcd
[    5.054570] usb usb2: SerialNumber: 1c1b000.usb
[    5.059715] hub 2-0:1.0: USB hub found
[    5.063562] hub 2-0:1.0: 1 port detected
[    5.963475] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    5.970128] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus 3
[    5.978162] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    6.047687] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    6.054515] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.061749] usb usb3: Product: Generic Platform OHCI controller
[    6.067690] usb usb3: Manufacturer: Linux 4.7.4-sun8i ohci_hcd
[    6.073542] usb usb3: SerialNumber: 1c1a400.usb
[    6.078720] hub 3-0:1.0: USB hub found
[    6.082529] hub 3-0:1.0: 1 port detected
[    6.087221] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    6.093903] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus 4
[    6.101829] ohci-platform 1c1b400.usb: irq 29, io mem 0x01c1b400
[    6.167668] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    6.174494] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.181729] usb usb4: Product: Generic Platform OHCI controller
[    6.187665] usb usb4: Manufacturer: Linux 4.7.4-sun8i ohci_hcd
[    6.193518] usb usb4: SerialNumber: 1c1b400.usb
[    6.198720] hub 4-0:1.0: USB hub found
[    6.202525] hub 4-0:1.0: 1 port detected
[    6.207252] usb_phy_generic.0.auto supply vcc not found, using dummy regulatr
[    6.214899] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    6.220661] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus5
[    6.228767] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    6.235586] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.242820] usb usb5: Product: MUSB HDRC host driver
[    6.247802] usb usb5: Manufacturer: Linux 4.7.4-sun8i musb-hcd
[    6.253654] usb usb5: SerialNumber: musb-hdrc.1.auto
[    6.259243] hub 5-0:1.0: USB hub found
[    6.263058] hub 5-0:1.0: 1 port detected
[    6.303988] of_cfs_init
[    6.306557] of_cfs_init: OK
[    6.312681] vcc3v0: disabling
[    6.315727] vcc5v0: disabling
[    6.320146] Freeing unused kernel memory: 1024K (c0c00000 - c0d00000)
[    6.369001] systemd-udevd[148]: starting version 215
[    6.376089] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    6.967636] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode)
[    7.292010] random: systemd: uninitialized urandom read (16 bytes read, 11
[    7.327021] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SE)
[    7.340768] systemd[1]: Detected architecture 'arm'.
[    7.363267] systemd[1]: Set hostname to <nanopineo>.
[    7.450335] random: systemd-sysv-ge: uninitialized urandom read (16 bytes re)
[    7.537466] random: systemd: uninitialized urandom read (16 bytes read, 14
[    7.547760] random: systemd: uninitialized urandom read (16 bytes read, 14
[    7.558014] random: systemd: uninitialized urandom read (16 bytes read, 14
[    7.581370] random: systemd: uninitialized urandom read (16 bytes read, 14
[    7.591344] random: systemd: uninitialized urandom read (16 bytes read, 14
[    7.600751] random: systemd: uninitialized urandom read (16 bytes read, 14
[    7.641392] random: systemd: uninitialized urandom read (16 bytes read, 15
[    7.756740] systemd[1]: Cannot add dependency job for unit display-manager.s.
[    7.774506] systemd[1]: Starting Forward Password Requests to Wall Directory.
[    7.782571] systemd[1]: Started Forward Password Requests to Wall Directory .
[    7.790288] systemd[1]: Expecting device dev-ttyS0.device...
[    7.796432] systemd[1]: Starting Remote File Systems (Pre).
[    7.802238] systemd[1]: Reached target Remote File Systems (Pre).
[    7.808514] systemd[1]: Starting Dispatch Password Requests to Console Direc.
[    7.816756] systemd[1]: Started Dispatch Password Requests to Console Direct.
[    7.824759] systemd[1]: Starting Paths.
[    7.828808] systemd[1]: Reached target Paths.
[    7.833229] systemd[1]: Starting Encrypted Volumes.
[    7.838334] systemd[1]: Reached target Encrypted Volumes.
[    7.843899] systemd[1]: Starting Arbitrary Executable File Formats File Syst.
[    7.853354] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[    7.862875] systemd[1]: Starting Swap.
[    7.866854] systemd[1]: Reached target Swap.
[    7.871190] systemd[1]: Starting Root Slice.
[    7.875759] systemd[1]: Created slice Root Slice.
[    7.880524] systemd[1]: Starting User and Session Slice.
[    7.886225] systemd[1]: Created slice User and Session Slice.
[    7.892032] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    7.899022] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.906073] systemd[1]: Starting Delayed Shutdown Socket.
[    7.911766] systemd[1]: Listening on Delayed Shutdown Socket.
[    7.917609] systemd[1]: Starting Journal Socket (/dev/log).
[    7.923514] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.929524] systemd[1]: Starting udev Control Socket.
[    7.934863] systemd[1]: Listening on udev Control Socket.
[    7.940335] systemd[1]: Starting udev Kernel Socket.
[    7.945569] systemd[1]: Listening on udev Kernel Socket.
[    7.950970] systemd[1]: Starting Journal Socket.
[    7.955924] systemd[1]: Listening on Journal Socket.
[    7.961028] systemd[1]: Starting System Slice.
[    7.965900] systemd[1]: Created slice System Slice.
[    7.970881] systemd[1]: Started File System Check on Root Device.
[    7.977064] systemd[1]: Starting system-serial\x2dgetty.slice.
[    7.983374] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.989769] systemd[1]: Starting system-getty.slice.
[    7.995153] systemd[1]: Created slice system-getty.slice.
[    8.000696] systemd[1]: Starting Increase datagram queue length...
[    8.044213] systemd[1]: Starting Restore / save the current clock...
[    8.055916] systemd[1]: Mounted Huge Pages File System.
[    8.076714] systemd[1]: Started Set Up Additional Binary Formats.
[    8.100441] systemd[1]: Starting Load Kernel Modules...
[    8.109517] systemd[1]: Mounting Debug File System...
[    8.118117] systemd[1]: Starting udev Coldplug all Devices...
[    8.128426] systemd[1]: Starting Create list of required static device nodes.
[    8.141810] systemd[1]: Mounting POSIX Message Queue File System...
[    8.146871] fuse init (API version 7.25)
[    8.155639] systemd[1]: Starting LSB: Set keymap...
[    8.165103] systemd[1]: Starting Slices.
[    8.169724] systemd[1]: Reached target Slices.
[    8.177760] systemd[1]: Mounted POSIX Message Queue File System.
[    8.184879] systemd[1]: Mounted Debug File System.
[    8.191810] systemd[1]: Started Increase datagram queue length.
[    8.203648] systemd[1]: Started Restore / save the current clock.
[    8.211063] systemd[1]: Started Load Kernel Modules.
[    8.221240] systemd[1]: Started Create list of required static device nodes .
[    8.232866] systemd[1]: Started LSB: Set keymap.
[    8.248620] systemd[1]: Time has been changed
[    8.313094] systemd[1]: Started udev Coldplug all Devices.
[    8.374486] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.444204] systemd[1]: Starting Apply Kernel Variables...
[    8.453835] systemd[1]: Mounting FUSE Control File System...
[    8.463162] systemd[1]: Mounting Configuration File System...
[    8.473061] systemd[1]: Starting Syslog Socket.
[    8.478611] systemd[1]: Listening on Syslog Socket.
[    8.483831] systemd[1]: Starting Journal Service...
[    8.493067] systemd[1]: Started Journal Service.
[    8.578061] systemd-udevd[250]: starting version 215
after this freeze  :( I changed the sd-card, power supply. Nothing helps...
Igor & tkaiser check it out.
Edited by zador.blood.stained
Added spoiler tags
I made a quick test on Orange Pi One and I could boot into self build kernel 4.7.4 ... network works, but only one CPU is detected. I did not investigate why ...
Since we are talking about immature kernel, problems are expected. This kernel is from our point of view still in testing mode and not yet for usage so we don't support it. If it does not work, you are basically on your own. Of course we will try to help and we are happy to get feedback and if it's possible, we will fix it, but not right on the spot.
4.7.3 boot and worked well. How can (now) I build a image with kernel  >/=4.7.3?
First boot log Armbian 5.17, Debian Jessie, kernel 4.6.7 uboot 2016.07 ---> boot ok
Edit:
Kernel  4.7.4 install manualy on Armbian_5.17_Nanopineo_Debian_jessie_4.6.7 work great.
Hi All, As you know, with Default OS presented by FreandlyARM, Many apps & Features are disabled. for example, it hasn't nano editor, python3 and either it's most known libraries,flexibility for installing most of new apps, and so on. I really can't tolerate this situation that i had to try many ways, just for installing one python3 library!! :( .
while your Beta OS is extremely better in this fields, but it is suffers too from Somethings like AUDIO Output(& maybe input?), Usb device compatibility , OTG support, and long boot time.
So,you will be glad all, if you can work harder to make better one, that you can support, and we can relay that.a version with good performance and application.
I Know that you can. Go Ahead leaders!  :)
(Sorry for poor English  :unsure: )
I 'm new to Armbian forum and at first I would like to thank all of you admin&devs guys here for your work!
Got my 2xNanoPi-NEO v1.1 yesterday and would like to jump into armbian releases.
Seen the relevant NEO downloads page and in there are Jessie and Xenial with kernel 3.4.112.
Can someone please point me to the latest available NEO images with kernel  4.7.x?
Christos
  On 9/29/2016 at 10:45 AM, Christos said:
Christos
Hi Christos,
i am in the same crazy situation... first tests... maybe i can help you with some info... and we get this solved together... :)
1. I think you should update and upgrade the available distro.
(http://docs.armbian.com/User-Guide_Getting-Started/#how-to-update)
2. Then you should just install the actual kernel which is simply availabe via apt-get install.
(http://www.armbian.com/kernel/)
But after rebooting my NanoPI Neo doesn't answer anymore on SSH Terminal...
So i miss something too...
I don't think that there is a really actual readymade image actually simply for download...
Greetings Chris
  On 8/23/2016 at 7:05 PM, rm-rfstar said:
... i used the vanilla jessie image here: http://www.armbian.com/donate/?f=Armbian_5.17_Nanopineo_Debian_jessie_4.6.7.7z
so far so good..
Is there any page that shows a list of created images (even test ones), like this one? apart from this direct link I could not find any relevant site page..
Also, tkaiser's link is not working so not able to download its image.
  On 9/29/2016 at 12:41 PM, zador.blood.stained said:
but if something doesn't work - sorry, maintaining this configuration currently has very low priority)
The one thing does not work (the USB port) has to be fixed by using the dtc tool (the vanilla images for NEO rely on device tree configuration for Orange Pi One where usb1 is exposed as the single type A USB port while it's usb3 on NanoPi NEO). And of course the vanilla images available for some H3 boards are considered experimental which means any 'apt-get upgrade' from apt.armbian.com might render them unusable.
Also performance should be lower (not optimized cpufreq / throttling settings now). And as Zador already mentioned: very low priority to change that (we're waiting for dvfs and Ethernet patches becoming more stable and included upstream). We released the images back then to get some feedback regarding dvfs / cpufreq scaling (to no avail) and they remain in exactly this state: For developers only :)
  On 9/29/2016 at 1:31 PM, tkaiser said:
The one thing does not work (the USB port) has to be fixed by using the dtc tool ..
Ok, thanks for clearing out these.
Just one more question though, any actual link for the 'dtc tool' you mention here? what exactly is it?
Thanks again,
Christos
P.S.
I might give it a try on my own to build and test from scratch..
Since we're talking about Armbian we already ship with this package installed by default on any of our images:
tk@lime-a10:~$ dpkg-query -S $(which dtc)
device-tree-compiler: /usr/bin/dtc
You have to convert the used .dtb to .dts, enable there the usb3 nodes and convert back to .dtb (I would then choose a different name and adjust boot.cmd as outlined here).
Thank you zador.blood.stained and TKaiser!
@TKaiser, does the M3 Distanceplaceholder on your NanoPI NEO Clusterpics (Sunxi-Wiki) may do any shortage?
Are M3 Distanceplaceholders save to use in any cases?
Theoretiker
You mean this?
Both NEO are still alive and PCB components are placed so that you can even use metal spacers.
Ok, tried to have a from scratch build here.
Got Ubuntu 14.04 LTS x64.
Followed the instructions on armbian documentation and specifically the things mentioned in https://github.com/igorpecovnik/lib.
Started the build and after a while got this error
[ o.k. ] Syncing clock [ host ]
[ o.k. ] Downloading sources
[ o.k. ] Checking git sources [ u-boot v2016.09 ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ linux-sun8i sun8i ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ sunxi-display-changer master ]
[ .... ] Up to date
[ o.k. ] Checking git sources [ sunxi-tools master ]
[ .... ] Up to date
[ o.k. ] Cleaning [ u-boot/v2016.09 ]
[ o.k. ] Cleaning [ linux-sun8i/sun8i ]
[ o.k. ] Cleaning output/debs for [ orangepione default ]
/home/christos/armbian/lib/common.sh: line 217: arm-linux-gnueabihf-gcc: command not found
awk: cmd. line:1: BEGIN{exit ! ( < 5.3)}
awk: cmd. line:1:                ^ syntax error
[ error ] ERROR in function find_toolchain [ common.sh:251 ]
[ error ] Could not find required toolchain [ arm-linux-gnueabihf-gcc < 5.3 ]
[ o.k. ] Process terminated
Actually this happens when I choose any variant, NanoPi NEO or other board.
Does the compile.sh script downloads the necessary toolchain or should I do it prior to start compile? if so, which toolchain should I use?
Christos
  On 9/30/2016 at 5:43 AM, Christos said:
ok, will do.
Yet, is the compile.sh process meant to load the necessary toolchain?
yes, it takes care of everything.
Ok,
It looks that the first task to have a decent cross-compile environment and be able to build is now in place
Builded on a new Ubuntu 16.04.1 LTS my first Jessie 3.4.112 image, it numbered Armbian 5.21.
C:\Christos>ssh christos@192.168.1.8
christos@192.168.1.8's password:
setsockopt IP_TOS 16: Invalid argument:
 _   _                   ____  _   _   _
| \ | | __ _ _ __   ___ |  _ \(_) | \ | | ___  ___
|  \| |/ _` | '_ \ / _ \| |_) | | |  \| |/ _ \/ _ \
| |\  | (_| | | | | (_) |  __/| | | |\  |  __/ (_) |
|_| \_|\__,_|_| |_|\___/|_|   |_| |_| \_|\___|\___/
Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i
System load:   0.01             Up time:       4 min
Memory usage:  7 % of 494Mb     IP:            192.168.1.8
CPU temp:      36Β°C
Usage of /:    7% of 15G
Last login: Sat Oct  1 08:10:30 2016 from 192.168.1.6
christos@nanopineo:~$
Flashed on a SD card and is up and running.
I do not know what that "setsockopt IP_TOS 16: Invalid argument:" is though..
Any way, tried to use a WiFi dongle (RTL8192CU) but was not as easy as expected, although I see it with lsmod and dmesg
root@nanopineo:/home/christos# lsmod
sunxi_cir               1601  0
rtl8192cu              61143  0
rtlwifi                45784  1 rtl8192cu
rtl8192c_common        33420  1 rtl8192cu
mac80211              358429  3 rtlwifi,rtl8192c_common,rtl8192cu
root@nanopineo:/home/christos# dmesg | grep 8192cu
[    6.985432] rtl8192cu: Chip version 0x10
[    7.173883] rtl8192cu: MAC address: e8:4e:06:26:ba:70
[    7.173925] rtl8192cu: Board Type 0
[    7.174500] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[    7.175187] usbcore: registered new interface driver rtl8192cu
[    7.179820] rtlwifi: Firmware rtlwifi/rtl8192cufw.bin not available
[    7.237839] rtl8192cu driver version=v4.0.2_9000.20130911
[    7.237895] Error: Driver 'rtl8192cu' is already registered, aborting...
Is there something I could do about it, any relevant how-to page in armbian for the 8192cu wifi?
Thanks anyway for the help so far.
christos
Ok,
To answer my own post, info found here
-> http://forum.armbian.com/index.php/topic/1237-tutorial-opi-one-wireless-success/
due to being identical OPiOne<->NPi-NEO, WiFi RTL8192CU wlan0 its working now ok
root@nanopineo:/home/christos# ifconfig -a
eth0      Link encap:Ethernet  HWaddr 3a:b7:4e:c9:3a:51
          inet6 addr: fe80::38b7:4eff:fec9:3a51/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0   TX bytes:580 (580.0
          Interrupt:114
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1104 (1.0 KiB)  TX bytes:1104 (1.0 KiB)
tunl0     Link encap:IPIP Tunnel  HWaddr
          NOARP  MTU:1480  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0   TX bytes:0 (0.0
wlan0     Link encap:Ethernet  HWaddr e8:4e:06:26:ba:70
          inet addr:192.168.1.131  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: 2a02:582:d2e:1100:ea4e:6ff:fe26:ba70/64 Scope:Global
          inet6 addr: fe80::ea4e:6ff:fe26:ba70/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:119 errors:0 dropped:0 overruns:0 frame:0
          TX packets:102 errors:0 dropped:3 overruns:0 carrier:0
          RX bytes:17160 (16.7 KiB)  TX bytes:16646 (16.2 KiB)
root@nanopineo:/home/christos# ping www.ubuntu.com -c 3
PING www.ubuntu.com (91.189.89.110) 56(84) bytes of data.
64 bytes from www-ubuntu-com.nuno.canonical.com (91.189.89.110): icmp_seq=1 ttl=
52 time=69.8 ms
64 bytes from www-ubuntu-com.nuno.canonical.com (91.189.89.110): icmp_seq=2 ttl=
52 time=71.7 ms
64 bytes from www-ubuntu-com.nuno.canonical.com (91.189.89.110): icmp_seq=3 ttl=
52 time=73.8 ms
--- www.ubuntu.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 69.805/71.794/73.829/1.671 ms
P.S.
Now lets see what can be done with recent kernel builds..
