valik228 Posted November 22, 2020 Posted November 22, 2020 hello! I'm trying to build a kernel and I think it did. but the script shows the error: CC [M] kernel/kheaders.o [ error ] ERROR in function compile_kernel [ compilation.sh:411 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated root@valik-comp:~/armbian-build# and no errors in the text above. (full logs in attachments). please tell me what to do ..? fulllog.txt.gzFetching info...
lanefu Posted November 22, 2020 Posted November 22, 2020 What parameters are you passing to compile.sh
Werner Posted November 22, 2020 Posted November 22, 2020 From what I got in the logs its rk322x-current. However this branch is on 5.9. So either some modifications to the build script or a checkout a older commit. Edit: 5.9 builds nicely for me btw. A few patches fail to apply though. Probably never reviewed them for a while.
valik228 Posted November 22, 2020 Author Posted November 22, 2020 On 11/22/2020 at 4:59 AM, lanefu said: What parameters are you passing to compile.sh Expand i run the script without parameters, after that I select rk3229 from menu... On 11/22/2020 at 6:23 AM, Werner said: From what I got in the logs its rk322x-current. However this branch is on 5.9. So either some modifications to the build script or a checkout a older commit. Edit: 5.9 builds nicely for me btw. A few patches fail to apply though. Probably never reviewed them for a while. Expand I want to understand what the error is
Solution Werner Posted November 22, 2020 Solution Posted November 22, 2020 This means that something went wrong when compiling some part of the kernel. Checkout the output/debug/ folder. There you will find all recorded errors in detail.
valik228 Posted November 22, 2020 Author Posted November 22, 2020 On 11/22/2020 at 12:48 PM, Werner said: This means that something went wrong when compiling some part of the kernel. Checkout the output/debug/ folder. There you will find all recorded errors in detail. Expand Ok, Thnx! drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c:7365:2: error: #else after #else 7365 | #else | ^~~~ drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c:7330: error: the conditional began here 7330 | #if (LINUX_VERSION_CODE >= KERNEL_VERSION(5, 8, 0)) | drivers/net/wireless/rtl88x2bu/os_dep/linux/ioctl_cfg80211.c:9708:3: error: ‘cfg80211_rtw_update_mgmt_frame_register’ undeclared here (not in a function) 9708 | cfg80211_rtw_update_mgmt_frame_register, | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Igor Posted November 22, 2020 Posted November 22, 2020 On 11/22/2020 at 6:39 PM, valik228 said: Ok, Thnx! Expand Those errors can't be reproduced. You probably use some old / not updated build script. Make a clean clone.
