I added a missing memory region from /dev/gpiomem and tested it.
gpiomem {
compatible = "samsung,exynos-gpiomem";
status = "okay";
reg = <0x13400000 0x1000 0x14010000 0x1000 0x03860000 0x1000>;
I didn't see where to make PR on github.
@WernerI'm not sure where to make changes. The DTS files are in:
./cache/sources/u-boot-odroidxu/odroidxu4-v2017.05/arch/arm/dts/exynos5422-odroidxu4.dts
./cache/sources/linux-odroidxu4/odroid-5.4.y/arch/arm/boot/dts/exynos5422-odroidxu4.dts
DTBs are in:
./cache/sources/u-boot-odroidxu/odroidxu4-v2017.05/arch/arm/dts/exynos5422-odroidxu4.dtb
./cache/sources/linux-odroidxu4/odroid-5.4.y/debian/tmp/usr/lib/linux-image-current-odroidxu4/exynos5422-odroidxu4.dtb
./cache/sources/linux-odroidxu4/odroid-5.4.y/debian/dtbtmp/boot/dtb-5.4.81-odroidxu4/exynos5422-odroidxu4.dtb
./cache/sources/linux-odroidxu4/odroid-5.4.y/arch/arm/boot/dts/exynos5422-odroidxu4.dtb
So if I were a gambling man  I'd change ./cache/sources/linux-odroidxu4/odroid-5.4.y/arch/arm/boot/dts/exynos5422-odroidxu4.dts before ./compile.sh CREATE_PATCHES="yes"?
Hmm, there shouldn't be dtb files in the kernel sources before building...
Yeah, I see it prompts once you add the CREATE_PATCHES="yes" It prompts twice. The only problem is the dts files do not contain the gpiomem section for some reason, but the downloaded image does. I'll figure it out eventually. Then where to put the PR :)
So I make change before kernel is built? Or is dts part of uboot (since it's in /boot :)) process?
Expand
Yes. You start the build process as usual but with CREATE_PATCHES set. It will apply all patches to the kernel source and once it breaks simply open another terminal and go to cache/sources/linux-mainline/yoursource.... and edit the device tree for the board. When finished continue the building and the script will create a patch file from the diff it finds in the device tree file. It will also tell you where it put the patch.
Expand
U-Boot is a different story. The dtbs in /boot are used by the Linux kernel.
@IgorSo I'm thinking about documenting the steps since I didn't see a detailed description in the docs (maybe I missed it). Also, going to try to add pin descriptions for gpio device, so gpioinfo is fully populated. Is this info in the device tree as well?
Expand
No, you did not miss it.  It's "on my list" as well, however I mention this not to dissuade you but rather let you know the thought occurred to me as well.  As it's likely still fresh in your mind (and I am busy elsewhere) go ahead and have at it if you feel like it.
I can always add to / polish it up later (if that's even needed).
Cheers!
@TRS-80OK, I'll do a readme.md and post to my github, so you can scarf that. You need to configure gpg and other junk I wasn't expecting. On the plus side I still have my Ubuntu VM console history!
Better I think would be to commit directly to Armbian docs, I think.  That way takes a little setup, but once done makes it much easier to add little things here and there later on as you come across them.  Up to you though of course.
I'll do that after write doc I build the readm.md. I'm just using the markdown editor in Eclipse. I don't have to put it on github.
I'm going to try github command line, so you don't have to fork, etc. on the web UI. Hopefully I can do it all command line.
@Wernercheck out https://github.com/sgjava/patchbian I just submitted another PR, so I'd have it down exactly. I'll add this to the official docs when I have some more time. For now this is a fresh core dump of the process. Let me know if there's any improvements.  I was done all cli without using GitHub web UI.
