rna Posted December 24, 2020 Posted December 24, 2020 Dear All, I just want to make a Tutorial on my successful attempt in Installing Box86 on Arm64 and Install Wine X86 apps. In this example it is Sketchup 7.1 and Sketchup 8 But before starting I want to thanks to PtitSeb for his hard work to bring this dream into reality (running x86 apps on arm64 box). My system is X96 Max+ S905x3. I used @balbes150 older image to boot to Armbian, many thanks for him. So In general every box running Armbian 64bit should work. This tutorial will use debootstrap Debian Buster Armhf as base for chroot. The keyword is "Arm64" support "Armhf", therefore you do not need to use Qemu or Binfmt_misc as it is very slow. Here's my report on Manjaro Arm Forum: https://archived.forum.manjaro.org/t/x86-64-chroot-on-manjaro-arm-install-x86-64-deb-install-wine-windows-apps/150420/103 Here's what you need: 1. Open terminal, then type: sudo apt install schroot debootstrap sudo mkdir /srv/chroot sudo mkdir /srv/chroot/debian-armhf sudo debootstrap --arch armhf --foreign buster /srv/chroot/debian-armhf http://debian.xtdv.net/debian sudo chroot "/srv/chroot/debian-armhf" /debootstrap/debootstrap --second-stage 2. Then add a config file for debian-armhf: sudo nano /etc/schroot/chroot.d/debian-armhf.conf Copy paste this code, and change <username> into your computer username [debian-armhf] description=Debian Armhf chroot aliases=debian-armhf type=directory directory=/srv/chroot/debian-armhf profile=desktop personality=linux preserve-environment=true root-users=<username> users=<username> 3. Then edit the nssdatabases sudo nano /etc/schroot/desktop/nssdatabases copy paste this code # System databases to copy into the chroot from the host system. # # <database name> #passwd shadow #group gshadow services protocols #networks #hosts #user 4. Edit the stateoverride, and change the first contrab to root sudo nano /srv/chroot/debian-armhf/var/lib/dpkg/statoverride copy paste this code root root 2755 /usr/bin/crontab 5. Now you should be able to schroot by typing sudo schroot -c debian-armhf 6. edit the bashrc nano ~/.bashrc add this code to the bottom of the line export LANGUAGE="C" export LC_ALL="C" export DISPLAY=:0 7. let's restart chroot environment by exit and login again, then add a username that is similar to your main system username exit id sudo schroot -c debian-armhf adduser <username> su - <username> then again add bashrc nano ~/.bashrc again add this code to the bottom of the line export LANGUAGE="C" export LC_ALL="C" export DISPLAY=:0 8. Then restart chroot by double exit and login again, then install the following package exit exit sudo schroot -c debian-armhf apt update && apt upgrade apt install git wget cmake build-essential python3 apt install gcc-arm-linux-gnueabihf 9. Now let's compile the Box86 within Chroot environment git clone https://github.com/ptitSeb/box86 cd box86 mkdir build; cd build; cmake .. -DARM_DYNAREC=ON -DCMAKE_BUILD_TYPE=RelWithDebInfo; make exit 10. Now login to chroot again then download wine from twisteros: https://twisteros.com/wine.tgz then extract it to your home folder. Your extracted wine location should be in: ~/wine/bin/wine sudo schroot -c debian-armhf wget https://twisteros.com/wine.tgz tar zxvf wine.tgz 11. Install Zenity in chroot environment, as wine will not have window without it: apt install zenity 12. Exit from chroot environment by typing exit 13. To install a windows app, in this case sketchup 7.1 and 8 you can download it from: http://www.oldversion.com/windows/google-sketchup/ then type: schroot -c debian-armhf ~/box86/build/box86 ~/wine/bin/wine 'your/installation/folder/It/is/better/to/drag/and/drop/the/installer' 14. To run the installed program you can type this or make it as a shortcut from desktop launcher: schroot -c debian-armhf ~/box86/build/box86 ~/wine/bin/wine your/installed/program/location and here's my final sketchup running smoothly on LLVM Pipe Graphics. I also attached the Box86 running on Manjaro Arm with the good performance as well for addition. To be honest, I didn't expect the performance to be this good. It almost remind me of "Rosetta 2" of Apple Silicon, but it is open source. Big respect for PtitSeb for bringing this magic to the Arm64 World. I also want to thanks to Xabbu and Lolix from Manjaro Forum to help me figuring out the chroot environment in my older Manjaro Forum Post. Hope that helps, Many Thanks, rna UPDATE 1 *IMPORTANT NOTE: To fix Sketchup 7/8 OpenGL Display Error: You have to edit the wine regedit and change the sketchup display setting from "0" to "1" - Open Sketchup then close - Open terminal then run regedit by typing: schroot -c debian-armhf ~/box86/build/box86 ~/wine/bin/wine regedit - Then find: HKEY_CURRENT_USER\Software\Google\SketchUp7\GLConfig\Display - Then change the “HW_OK” from “0” to “1” - Then close your regedit - Then open Sketchup 7/8. Now you should be ok. UPDATE 2 you can also follow the Box86 compatibility list here: https://github.com/ptitSeb/box86-compatibility-list/issues You can also use winetricks to install some dependency, like .NET 4.0 as detailed by WheezyE here: https://github.com/ptitSeb/box86-compatibility-list/issues/46 In fact, by using WheezyE method I was able to install all depencencies to install sketchup 2014 successfully from winetricks in Armbian Reforge (Just to let you know that Armbian Reforge is embedded with Box86 by default). However, at the moment winetricks does not works in our chroot method. Therefore, Help would be appreciated. BONUS: For those of you that desperately want to install blender 2.79 on Armbian Focal / Manjaro, you can use this method. Open terminal, then type: sudo schroot -c debian-armhf apt install blender exit Now to open blender, you can use this command (you can also make launcher): schroot -c debian-armhf blender Now Blender 2.79b should run perfectly on you system 2
markonmoto2 Posted December 27, 2020 Posted December 27, 2020 I followed your guide and installed it (looks successfuly - i only opened steam installer with it without finilizing instalation) on Nanopi M4 running Manjaro ARM and except of using -DRK3399 compile parameter and installing debian-archive-keyring via pacman it went smoothly thank for this guide !Sent from my Redmi 4X using Tapatalk
rna Posted December 28, 2020 Author Posted December 28, 2020 On 12/27/2020 at 4:45 PM, markonmoto2 said: I followed your guide and installed it (looks successfuly - i only opened steam installer with it without finilizing instalation) on Nanopi M4 running Manjaro ARM and except of using -DRK3399 compile parameter and installing debian-archive-keyring via pacman it went smoothly thank for this guide ! Great, so happy to hear that it works. If you can test, maybe you could report some applications that work by using this method. So that we can have a list of x86 program than can run for the others. Many thanks
ruggero Posted December 30, 2020 Posted December 30, 2020 Thanks a lot! The tutorial also works on Ubuntu-Mate 20.10 raspberry pi4 8GB Ruggero
Le Raccoon Posted January 4, 2021 Posted January 4, 2021 Thanks for this, it looks really nice and is easy to follow. Unfortunately, I have come across an issue in the very first step: When I run ~$ sudo debootstrap --arch armhf --foreign buster /srv/chroot/debian-armhf http://debian.xtdv.net/debian I get this mknod: /srv/chroot/debian-armhf/test-dev-null: Operation not permitted E: Cannot install into target '/srv/chroot/debian-armhf' mounted with noexec or nodev I have tried to do this: ~$ sudo mount -o -i remount,exec,dev /srv/chroot/debian-armhf/ but I get this mount: /srv/chroot/debian-armhf: permission denied. I am on a Lenovo duet chrome book (Arm64, debian 10) Can you help?
rna Posted January 11, 2021 Author Posted January 11, 2021 On 1/5/2021 at 1:31 AM, Le Raccoon said: Thanks for this, it looks really nice and is easy to follow. Unfortunately, I have come across an issue in the very first step: When I run ~$ sudo debootstrap --arch armhf --foreign buster /srv/chroot/debian-armhf http://debian.xtdv.net/debian I get this mknod: /srv/chroot/debian-armhf/test-dev-null: Operation not permitted E: Cannot install into target '/srv/chroot/debian-armhf' mounted with noexec or nodev I have tried to do this: ~$ sudo mount -o -i remount,exec,dev /srv/chroot/debian-armhf/ but I get this mount: /srv/chroot/debian-armhf: permission denied. I am on a Lenovo duet chrome book (Arm64, debian 10) Can you help? try to use Armbian Ubuntu Focal.
rna Posted January 28, 2021 Author Posted January 28, 2021 To fix Sketchup 7/8 Display Error: You have to edit the wine regedit and change the display setting 1. Open Sketchup then close 2. Open terminal then run regedit by typing: schroot -c debian-armhf ~/box86/build/box86 ~/wine/bin/wine regedit 3. Then find: HKEY_CURRENT_USER\Software\Google\SketchUp7\GLConfig\Display 4. Then change the “HW_OK” from “0” to “1” 5. Then close your regedit 6. Then open Sketchup 7/8, you should be ok.
ning Posted January 28, 2021 Posted January 28, 2021 Box86 only supports 32bit, so Arm64 needs to install arm32 to work. @rna in your case, you add a 32bit chroot env to run Box86, could you try add armhf architecture `sudo dpkg --add-architecture armhf` (I remember armbian already added armhf to arm64) and repeat everything in armbian.
rna Posted January 28, 2021 Author Posted January 28, 2021 15 minutes ago, ning said: in your case, you add a 32bit chroot env to run Box86, could you try add armhf architecture `sudo dpkg --add-architecture armhf` (I remember armbian already added armhf to arm64) It didn't work, I came up with this tutorial because adding multi-arch simply does not make box86 works. You can also try it yourself. I read somewhere that there are two versions of Arm64, one is compatible with multiarch 32bit, and one is not. But I don't know which one is armbian. But my trial attempts told me that Multi-Arch armhf does not works as expected in my box. There are many dependencies that are broken. even installing as simple as "0ad" armhf does not work. Chroot 32bit is the solution for that. I personally contacted PtitSeb, the creator of Box86, and the advice was using a chroot for Arm64. I would be very happy if multi-arch is working for Armbian, that would be my first option if it would be possible in the future.
Heasterian Posted February 1, 2021 Posted February 1, 2021 Aditional steps for Tegra devices without armhf GPU driver (Jetson, Switch etc.) mount /tmp to chroot /tmp, install Xephyr and virglrenderer (recent versions are bugging out with xcb issues, use git checkout to one of November commits and compile working version) on host side and compile virgl mesa driver in chroot. .bashrc of chroot needs also DISPLAY set to :1 (or any port you want to use for Xephyr) and add this two lines ```export LIBGL_ALWAYS_SOFTWARE=1 export GALLIUM_DRIVER=virpipe``` Before you launching wine or any chroot app, you need to start ```Xephyr :1``` and ```virgl_test_server --use-glx```. I'm not sure if you need use Xephyr on Switch, but default xserver from L4T don't want to work for armhf apps. On my Jetson Nano using jetson_clock gives nice performance boost.
Alejandro Posted April 4, 2021 Posted April 4, 2021 Hi there, I get next message wine: '/home/user/.wine' is a 64-bit installation, it cannot be used with a 32-bit wineserver. Any idea, How could I fix it? I'm running it in jetson nano Thanks in advance
Nitesh Kunnath Posted June 25, 2021 Posted June 25, 2021 exit id sudo schroot -c debian-armhf adduser <username> su - <username> After executing this and trying to nano edit bashrc to include the next set of code mentioned, its saying permission denied. Write permissions are denied for the path /home/ubuntu/.bashrc Any help on this?
Pikota Posted June 25, 2021 Posted June 25, 2021 (edited) Didnt worked for me, on the last step when i should install the .exe its not working. I put the .exe inside of Sketchup folder, on the step 13 and 14 there is not sudo written, but if i dont write sudo it dont work Tried on Raspberry pi 4, ubuntu 21 Edited June 25, 2021 by Pikota
Leo Posted July 21, 2021 Posted July 21, 2021 On 6/25/2021 at 10:40 PM, Pikota said: Didnt worked for me, on the last step when i should install the .exe its not working. I put the .exe inside of Sketchup folder, on the step 13 and 14 there is not sudo written, but if i dont write sudo it dont work Tried on Raspberry pi 4, ubuntu 21 You can try set this env variable export DISPLAY=:1
intheundertow Posted November 11, 2021 Posted November 11, 2021 I got through most of this, but am having problems building box86 on a Qualcomm Snapdragon 7c gen2 cc1: error: target CPU does not support ARM mode make[2]: *** [CMakeFiles/dynarec_arm.dir/build.make:115: CMakeFiles/dynarec_arm.dir/src/dynarec/arm_prolog.S.o] Error 1 make[1]: *** [CMakeFiles/Makefile2:112: CMakeFiles/dynarec_arm.dir/all] Error 2 make: *** [Makefile:163: all] Error 2 any ideas?
NicoD Posted November 11, 2021 Posted November 11, 2021 13 hours ago, intheundertow said: any ideas? Have you tried with armbian-gaming? https://github.com/NicoD-SBC/armbian-gaming It is made for Armbian Hirsute. You can watch the source to see what fixes I used to make it work.
rna Posted December 17, 2021 Author Posted December 17, 2021 My Newest Update on how to install Box86-Box64 Wine32-Wine64 Winetricks on Arm64 can be found here: It is a modified version of NicoD Script, TwisterOS Library and Box86 manual. I hope this could help somebody out there. Many Thanks, RNA
