check if freepbx distro iso image works on nanopi neo core
This is the image i downloaded from freepbx https://www.freepbx.org/downloads/
you could view all versions to check the iso images available.
so this image contains freepbx with asterisk.
i want to install this image on my nanopi neo core but i am afraid if it wont work.
for more information about this operating system
at my pc :
command: cat /etc/os-release
output:
NAME="Sangoma Linux"
VERSION="7 (Core)"
ID="sangoma"
ID_LIKE="centos rhel fedora"
VERSION_ID="7"
PRETTY_NAME="Sangoma Linux 7 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:sangoma:sng:7::server:utf8"
HOME_URL="https://distro.sangoma.net/"
BUG_REPORT_URL="https://issues.sangoma.net/"
CENTOS_MANTISBT_PROJECT="Sangoma-7"
CENTOS_MANTISBT_PROJECT_VERSION="7"
REDHAT_SUPPORT_PRODUCT="sangoma"
REDHAT_SUPPORT_PRODUCT_VERSION="7"
command: hostnamectl
output:
   Static hostname: freepbx.sangoma.local
         Icon name: computer-laptop
           Chassis: laptop
        Machine ID: b230bc99e3f54757988c502759a40135
           Boot ID: e7f281a29a2d47daa7c82fc79d4302a2
  Operating System: Sangoma Linux 7 (Core)
       CPE OS Name: cpe:/o:sangoma:sng:7::server:utf8
            Kernel: Linux 3.10.0-1127.19.1.el7.x86_64
      Architecture: x86-64
so does this kind of linux images work on nanopi neo core or not ?
Of course not. Search gives this:
6 minutes ago, Igor said:
Of course not.
looks like then i have to install each package manually.
would this work on nanopi neo core?
It must work. But if this hardware is good enough in term of memory and performances you are asking wrong people. Ask software authors / their pro users ... they know how much resources it eats.
But if there is a report that persons manage to use it on Orangepi PC, then this board should also be fine.
42 minutes ago, sami said:
https://wiki.freepbx.org/display/FOP/Installing+FreePBX+15+on+Debian+9.6
would this work on nanopi neo core?  if yes then what is the operating system(debian 9.6) that i should install? it would be great if there is a link.
I have installed freepbx on ubuntu/armbian in the past using the instrustions found on the freepbx wiki like the ones you linked to for debian above.  I didn't run into any issues specific to armbian.  This isn't really an armbian question and more appropriate for a freepbx forum.  In looking at the freepbx forum I see you have already asked the same question over there and got the answer: google it, which from the above post you did, and found the answer.
did you run into other issues? just curious.
