Zageron Posted January 6, 2021 Share Posted January 6, 2021 (edited) My plan is as follows: - Insert SD card. - Make a clone / back-up of boot and system using armbian-config whenever I'm about to do something major. (boot and system are both on eMMC) - "unclick" SD card and leave it in the back. - (repeat, until something breaks, and then just insert it and restore using armbian-config if something goes wrong.) I am confused by the eMMC to SD card path though. Here's some context: ❯ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT loop0 7:0 0 86.6M 1 loop /snap/core/10578 loop1 7:1 0 178.2M 1 loop /snap/microk8s/1866 loop2 7:2 0 86.6M 1 loop /snap/core/10585 sda 8:0 0 931.5G 0 disk ├─bcache0 253:0 0 9.1T 0 disk /mnt/storage ├─bcache1 253:128 0 9.1T 0 disk ├─bcache2 253:256 0 9.1T 0 disk └─bcache3 253:384 0 9.1T 0 disk sdb 8:16 0 9.1T 0 disk └─bcache0 253:0 0 9.1T 0 disk /mnt/storage sdc 8:32 0 9.1T 0 disk └─bcache1 253:128 0 9.1T 0 disk sdd 8:48 0 9.1T 0 disk └─bcache3 253:384 0 9.1T 0 disk sde 8:64 0 9.1T 0 disk └─bcache2 253:256 0 9.1T 0 disk mmcblk1 179:0 0 14.6G 0 disk └─mmcblk1p1 179:1 0 14.4G 0 part / mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk mmcblk0 179:96 0 59.5G 0 disk └─mmcblk0p1 179:97 0 59.5G 0 part zram0 251:0 0 1.9G 0 disk [SWAP] zram1 251:1 0 50M 0 disk /var/log ❯ ls -l /sys/block/ total 0 lrwxrwxrwx 1 root root 0 Jan 5 11:46 bcache0 -> ../devices/virtual/block/bcache0 lrwxrwxrwx 1 root root 0 Jan 5 11:46 bcache1 -> ../devices/virtual/block/bcache1 lrwxrwxrwx 1 root root 0 Jan 5 11:46 bcache2 -> ../devices/virtual/block/bcache2 lrwxrwxrwx 1 root root 0 Jan 5 11:46 bcache3 -> ../devices/virtual/block/bcache3 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop0 -> ../devices/virtual/block/loop0 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop1 -> ../devices/virtual/block/loop1 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop2 -> ../devices/virtual/block/loop2 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop3 -> ../devices/virtual/block/loop3 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop4 -> ../devices/virtual/block/loop4 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop5 -> ../devices/virtual/block/loop5 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop6 -> ../devices/virtual/block/loop6 lrwxrwxrwx 1 root root 0 Jan 5 11:46 loop7 -> ../devices/virtual/block/loop7 lrwxrwxrwx 1 root root 0 Jan 5 19:38 mmcblk0 -> ../devices/platform/fe320000.mmc/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0 lrwxrwxrwx 1 root root 0 Jan 5 11:46 mmcblk1 -> ../devices/platform/fe330000.sdhci/mmc_host/mmc1/mmc1:0001/block/mmcblk1 lrwxrwxrwx 1 root root 0 Jan 5 11:46 mmcblk1boot0 -> ../devices/platform/fe330000.sdhci/mmc_host/mmc1/mmc1:0001/block/mmcblk1/mmcblk1boot0 lrwxrwxrwx 1 root root 0 Jan 5 11:46 mmcblk1boot1 -> ../devices/platform/fe330000.sdhci/mmc_host/mmc1/mmc1:0001/block/mmcblk1/mmcblk1boot1 lrwxrwxrwx 1 root root 0 Jan 5 11:46 sda -> ../devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jan 5 11:46 sdb -> ../devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jan 5 11:46 sdc -> ../devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata3/host2/target2:0:0/2:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Jan 5 11:46 sdd -> ../devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata4/host3/target3:0:0/3:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Jan 5 11:46 sde -> ../devices/platform/f8000000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Jan 5 11:46 zram0 -> ../devices/virtual/block/zram0 lrwxrwxrwx 1 root root 0 Jan 5 11:46 zram1 -> ../devices/virtual/block/zram1 lrwxrwxrwx 1 root root 0 Jan 5 11:46 zram2 -> ../devices/virtual/block/zram2 ❯ sudo cat /etc/fstab # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=67ef9041-8705-49af-9bff-748ee9580b57 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 UUID=a27e49e9-329b-4bba-a6d3-ec5b23148e6c /mnt/storage btrfs defaults 0 2 - mmcblk0 is the SD card. - mmcblk1 is the eMMC, and is my boot. - What should I be clicking in armbian-config to clone my boot and system to the sd card? - Is there an alternative recommendation for making a backup? Any other recommendations? Thank you very much! Edited January 6, 2021 by Zageron clarification 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 6, 2021 Share Posted January 6, 2021 14 hours ago, Zageron said: What should I be clicking in armbian-config to clone my boot and system to the sd card? This function does not exists. Also implementation is questionable since code quality of this app is not the best which is why we planned long time ago to write this application from scratch and perhaps implement backup functionality ... but we just throw away insane amount of our money and got nowhere. This task sadly exceeds our resources - we can't afford to cover. 14 hours ago, Zageron said: Is there an alternative recommendation for making a backup? Proper easy way? No. But why you want to clone image? Use Ansible or similar to recreate your system on top of clean Armbian image, backup data. We are only interested in a solution for all boards - specifically for this one, we don't care. In ARM world, there are little standards and each hardware can have its own way of booting which you need to make use of. Well, we could do this once by the end of the year if you cover R&D expenses, but we have no plans to donate to build a backup application for you. Users already created a wishlist for several million dollars worth of work while we fund this project with our private cash. 0 Quote Link to comment Share on other sites More sharing options...
Zageron Posted January 7, 2021 Author Share Posted January 7, 2021 Alrighty, thank you. I've been meaning to learn Ansible, so I'll give that a shot. 0 Quote Link to comment Share on other sites More sharing options...
gprovost Posted January 7, 2021 Share Posted January 7, 2021 @Zageron You could boot in recovery mode in order to expose the Heliso64 eMMC as USB Mass Storage device to a PC connected to Helios64 via the USB-C port. Then on your PC use a tool to clone the exposed USB Storage device. You can use dd for example. dd bs=4M if=/dev/sdb | gzip > image1-`date +%d%m%y`.img.gz Replace /dev/sdb by the path of the exposed USB storage device. But there are many other tools and way to clone, you can find tutorial. The day you need to revert to an old backup you can use again use the recovery mode but this time you burn your backup image to the exposed USB Mass Storage (the eMMC of Helios64). 0 Quote Link to comment Share on other sites More sharing options...
