Hi All,
since i had many problem with my old OPI R1 (without PLUS) I  just ordered the newer Model with 1 Gig Ram, RK3328 CPU and two Gigabit Ports.
There Is a debian Image available on their Google Drive Share right now, I'll certainly try that out, but Is there a generic Armbian Image as well, I can take?
Should be pretty straigt forward Device, I tink.... HDMI Out is not available, only USB Gigabit Ethernet and Rockchip Gigabit Ethernet.
Would be great if Hardware encryption for IPSec is also availaibe.
Any thoughts?
Cheers
Ford Prefect
1 hour ago, Ford_Prefect said:
Hardware encryption
Don't know. But even more basic hw function have no gain so I would not have big expectations on Rockchip:
https://github.com/armbian/build/pull/2462
Why? (if it's not here https://www.armbian.com/download/ it does not exists)
I can take?
What about give??
Hmm, that does not sound very promising at all :-(
What about give??
I gave a  lot back to the Open Source community and their developers. Wrong target here:-) But I know what you mean.
Cheers,
Ford
I have tried to test this board.
The OpenWRT version on xunlong site (http://www.orangepi.org/downloadresources/) doesn't work
The Debian/Ubuntu version is booted, but i don't know why it always crash and reboot.
I am planning to install PiHole on this device to bring it to a hub that can block ads on internet natively, like this flow
Internet <=> Modem <=> R1 Plus (PI Hole) <=> Wireless Router
any thought?
any thought?
Did you attache a Heatsink to the CPU? I doubt the rk3328 is  able to cope with its temperature without....
I just bootet debian up and  the cpu was nearly instantaniously at 75°C....
With a passive heatsink it is still 62° Idling.... seems to much for my feeling
More testing to come - also armbian.
Cheers
FP
I received almost the same time a RockPi-E and an OrangePi-1+
First I started to play witch RockPi-E and then, as I realised OpiR1+ is not supported, I tried the RockPi-E Raspbian image and it works OK. At least for what I use it for, as router and WiFI access point, iptables and such.
Only strange thing is I "have" three Ethernet interfaces :-) ifconfig shows eth[012].
OpiR1+ does indeed get hot even if doing almost nothing, going to buy tomorrow a heatsink. RockPi-E
Regards,
Chris
I have no idea which OS you are running. Without providing logs (armbianmonitor -u) nobody knows what you are talking about. You are talking about Raspbian on Armbian forum ... ?!
Try image from Nanopi R2S (but it's no warranty that it will work). You can proceed working on this https://github.com/armbian/build/pull/2617 I don't have hardware nor any time to proceed.
Sorry, silly me.
Welcome to Armbian 20.11.6 Buster with Linux 5.9.14-rockchip64
root@opir1-plus:~# uname -a
Linux opir1-plus 5.9.14-rockchip64 #20.11.4 SMP PREEMPT Tue Dec 15 08:52:20 CET 2020 aarch64 GNU/Linux
25 minutes ago, ChrisO said:
Sorry, silly me.
Where did you get that image? You build it? Does it work well? Run as root:
armbianmonitor -u
This is the official Armbian image Armbian_20.11.10_Rockpi-e_buster_current_5.9.14.img from  https://redirect.armbian.com/rockpi-e/Buster_current
armbianmonitor -u output is here http://ix.io/2PDj
So far it works OK. I didn't do any special tests. Just set-up a WiFI accesspoint with hostapd (on bridge eth2/wlan0) and udhcpd. iptables for masquerading and just now accessing internet from my phone using
this AP.
ifconfig shows three Ethernet interfaces. the two real ones are eth0 and eth2.
Let me know if I could be of any help. Would be a pleasure for me to give a bit back to Armbian :-)
Both, RockPi-E and OpiR1+ generate a Kernel panic at the end of "init 0"  harmless AFAICS. Output is attached.
Regards,
Chris
rockpi-e.oops r1plus.oops
48 minutes ago, zeno979 said:
Nanopi r2s Buster image with DTB from Orangepi runs well
We need to know how R2S image works on Orangepi R1+ (which we don't have yet around to check).
Erm... I think you are wrong with that - this little thinge is blazing fast in encryption/decryption - at least for a SBC.
I just configured the latest strongswan, setup xfrm interfaces and a straight forward  configuration wit AES_GCM_16/MODP2048 and I am totally astonished...
Not really CPU Load and  about  420 MBit/s decrypting and 270 MBit Encrypting (via Gigabit-LAN to a Ryzen3 Machine)
I had to setup up this extra scenario, because the little device maxed out my 300 MBit+ WAN Link :-)
opir1plus-swanctl.png.4608cc65b0b0deb80b5c8a259b1a0679.pngimage.png.a6bcbc9c425fd7bfe2abf5c843ebb4f0.png
For that, I build iproute2 and strongswan+swanctl myself on top of the  OPI Debian Image, which works really stable, I have to say!  Much better than the OPI R1 without Plus (which, BTW,  was maxed out at around 40 MBit/s IPsec Traffic)
Cheers
Ford Prefect
I am not saying its slow. Just HW assisted driver contributes no gain. Here you can compare with others.
Comparing apples and oranges. Those are totally different SoCs. Also generation wise.
They copied our build tools, remove others and refactor few things then run search "armbian" replace with "orangepi".
https://github.com/orangepi-xunlong/orangepi-build/commit/2a7bfed3c38abd758539d4f4c02c70b4fd62eb34
In case of troubles, you have to check their forum ;) since we don't deal with 3rd party creations.
Not really apples and whatever... It's the 'same' type of SBC, and costs are similar. This is the fastest encrypt/decrypt sbc besides the atom based 'Atomic Pi' - which has AES-NI enabled.
Cheers,
Ford
Also anything that has "pi" in the name or looks like "pi" and costs between 20 - 50 is the same sh*, right? :P From technical perspective, things which you are comparing, they are very different ... 32 vs 64 bit soc, different generation, dual fast lan, dual gigabit lan, internal fast lan, internal gigabit lan, usb2 vs usb3, allwinner vs rockchip ....
This means you didn't check this? https://github.com/ThomasKaiser/sbc-bench/blob/master/Results.md
No, its the other way round... I was looking for a SBC with 2 NICs (preferebly Gigabit, off Course) which is capable of running debian to connect me with strongswan (+ xfrm interfaces for the sake of it) with a reasonable encrypting speed and easy t otravel with - so the size of the Atomic Pi was too big, and it lacks a second ethernet port.
Let's take a look on the market.... there is not much, is there?
So the Orangepi R1 Plus is the optimal choice for me....  it seems:-)
No, I didn't know about that. But "pure" AES Benchmarks doesn't help too much compared with 'real' IPsec throughput.  Off course, you get a 'hint' which is faster but  no absolute benchmarking regarding to network traffic is possible, because you don't know how the NICs behave together with the rest of the system.
Cheers
Ford
You should at least check our download pages: https://www.armbian.com/download/?tx_category=networking We support 6 such devices, where one is identical to R1+ (Nanopi R2S) and two that we don't support anymore or we never did.
Probably it is. I am not arguing about that.
FYI https://www.armbian.com/nanopi-r4s/ should be faster in all real world scenarios but I doubt you need all that extra power.
How to change the DTB from Nanopi to Orangepi? Did you biuld your version?
Hi All,
I ran Armbian at orangepi r1 plus.
Details:
Firstly, OrangePi R1 Plus is booted with Armbian_21.02.3_Nanopi-r2s_buster_current_5.10.21. But I got the error:
Begin: Running /scripts/local-block ... done.
done.
Gave up waiting for root file system device.  Common problems:
 - Boot args (cat /proc/cmdline)
   - Check rootdelay= (did the system wait long enough?)
 - Missing modules (cat /proc/modules; ls /dev)
ALERT!  UUID=1430eaac-3ff0-465a-a7b0-66b51608ccd1 does not exist.  Dropping to a shell!
(initramfs)
All Boot Output:
https://pastebin.pl/view/c23b4566
After that,
  • Orange Pi R1 Plus is successfully booted with Orangepir1plus_2.1.0_debian_buster_server_linux5.8.18.
  • I inserted another sd card (it has Armbian_21.02.3_Nanopi-r2s_buster_current_5.10.21 image) to the R1 Plus and mounted.
  • I copied /boot/dtb/rockchip/rk3328-orangepi-r1plus.dtb and paste into the sd card.
  • I changed /boot/armbianEnv.txt as follows:
# more /boot/armbianEnv.txt
verbosity=1
bootlogo=false
overlay_prefix=rockchip
fdtfile=rockchip/rk3328-orangepi-r1plus.dtb
rootdev=UUID=1430eaac-3ff0-465a-a7b0-66b51608ccd1
rootfstype=ext4
console=serial
Orange Pi R1 Plus is booted. But it has some issues. The device did not detect 2nd ethernet and first ethernet is not working properly.
Orange Pi R1 Plus Armbian Boot Output:
https://pastebin.pl/view/ba0f9789
I will work on it.
My fault, I tested: Ethernet interfaces are working properly.
First ethernet is eth0, Second Ethernet is lan0.
I will test all components ASA
I started here https://github.com/armbian/build/pull/2617 but don't have device so I stopped. Welcome to extend that PR.
Thank you for bringing support to this board. I tried latest image (Buster and Focal) and couldn't boot.
It always ends up with:
ALERT!  UUID=e5dd5e3a-06ae-43df-964d-5e3c5dc07a7f does not exist.  Dropping to a shell!
(initramfs)
Here is the full boot sequence (2 boots):
https://pastebin.com/CNssk1uG
Tried with 3 differentt Sandisk Ultra and also with Etcher (Linux and Windows) and Rufus.
Anything else I could try?
Thanks
Edited by Vasco
Correcting some info
