Ford_Prefect Posted January 6, 2021 Posted January 6, 2021 Hi All, since i had many problem with my old OPI R1 (without PLUS) I just ordered the newer Model with 1 Gig Ram, RK3328 CPU and two Gigabit Ports. There Is a debian Image available on their Google Drive Share right now, I'll certainly try that out, but Is there a generic Armbian Image as well, I can take? Should be pretty straigt forward Device, I tink.... HDMI Out is not available, only USB Gigabit Ethernet and Rockchip Gigabit Ethernet. Would be great if Hardware encryption for IPSec is also availaibe. Any thoughts? Cheers Ford Prefect 0 Quote
Igor Posted January 6, 2021 Posted January 6, 2021 On 1/6/2021 at 10:19 AM, Ford_Prefect said: Hardware encryption Expand Don't know. But even more basic hw function have no gain so I would not have big expectations on Rockchip: https://github.com/armbian/build/pull/2462 On 1/6/2021 at 10:19 AM, Ford_Prefect said: but Is there a generic Armbian Image as well Expand Why? (if it's not here https://www.armbian.com/download/ it does not exists) On 1/6/2021 at 10:19 AM, Ford_Prefect said: I can take? Expand What about give?? 0 Quote
Ford_Prefect Posted January 12, 2021 Author Posted January 12, 2021 On 1/6/2021 at 11:52 AM, Igor said: Don't know. But even more basic hw function have no gain so I would not have big expectations on Rockchip: https://github.com/armbian/build/pull/2462 Expand Hmm, that does not sound very promising at all :-( On 1/6/2021 at 12:52 PM, Igor said: What about give?? Expand I gave a lot back to the Open Source community and their developers. Wrong target here:-) But I know what you mean. Cheers, Ford 1 Quote
thanh_tan Posted January 21, 2021 Posted January 21, 2021 I have tried to test this board. The OpenWRT version on xunlong site (http://www.orangepi.org/downloadresources/) doesn't work The Debian/Ubuntu version is booted, but i don't know why it always crash and reboot. I am planning to install PiHole on this device to bring it to a hub that can block ads on internet natively, like this flow Internet <=> Modem <=> R1 Plus (PI Hole) <=> Wireless Router any thought? 0 Quote
Ford_Prefect Posted February 1, 2021 Author Posted February 1, 2021 On 1/21/2021 at 3:51 PM, thanh_tan said: Internet <=> Modem <=> R1 Plus (PI Hole) <=> Wireless Router any thought? Expand Did you attache a Heatsink to the CPU? I doubt the rk3328 is able to cope with its temperature without.... I just bootet debian up and the cpu was nearly instantaniously at 75°C.... With a passive heatsink it is still 62° Idling.... seems to much for my feeling More testing to come - also armbian. Cheers FP 0 Quote
ChrisO Posted February 15, 2021 Posted February 15, 2021 I received almost the same time a RockPi-E and an OrangePi-1+ First I started to play witch RockPi-E and then, as I realised OpiR1+ is not supported, I tried the RockPi-E Raspbian image and it works OK. At least for what I use it for, as router and WiFI access point, iptables and such. Only strange thing is I "have" three Ethernet interfaces :-) ifconfig shows eth[012]. OpiR1+ does indeed get hot even if doing almost nothing, going to buy tomorrow a heatsink. RockPi-E Regards, Chris 0 Quote
Igor Posted February 15, 2021 Posted February 15, 2021 On 2/15/2021 at 8:40 PM, ChrisO said: Only strange thing is I "have" three Ethernet interfaces :-) ifconfig shows eth[012]. Expand I have no idea which OS you are running. Without providing logs (armbianmonitor -u) nobody knows what you are talking about. You are talking about Raspbian on Armbian forum ... ?! On 2/15/2021 at 8:40 PM, ChrisO said: as I realised OpiR1+ is not supported Expand Try image from Nanopi R2S (but it's no warranty that it will work). You can proceed working on this https://github.com/armbian/build/pull/2617 I don't have hardware nor any time to proceed. 0 Quote
ChrisO Posted February 15, 2021 Posted February 15, 2021 Sorry, silly me. Welcome to Armbian 20.11.6 Buster with Linux 5.9.14-rockchip64 root@opir1-plus:~# uname -a Linux opir1-plus 5.9.14-rockchip64 #20.11.4 SMP PREEMPT Tue Dec 15 08:52:20 CET 2020 aarch64 GNU/Linux 0 Quote
Igor Posted February 16, 2021 Posted February 16, 2021 On 2/15/2021 at 11:43 PM, ChrisO said: Sorry, silly me. Welcome to Armbian 20.11.6 Buster with Linux 5.9.14-rockchip64 root@opir1-plus:~# uname -a Linux opir1-plus 5.9.14-rockchip64 #20.11.4 SMP PREEMPT Tue Dec 15 08:52:20 CET 2020 aarch64 GNU/Linux Expand Where did you get that image? You build it? Does it work well? Run as root: armbianmonitor -u 0 Quote
ChrisO Posted February 16, 2021 Posted February 16, 2021 This is the official Armbian image Armbian_20.11.10_Rockpi-e_buster_current_5.9.14.img from https://redirect.armbian.com/rockpi-e/Buster_current armbianmonitor -u output is here http://ix.io/2PDj So far it works OK. I didn't do any special tests. Just set-up a WiFI accesspoint with hostapd (on bridge eth2/wlan0) and udhcpd. iptables for masquerading and just now accessing internet from my phone using this AP. ifconfig shows three Ethernet interfaces. the two real ones are eth0 and eth2. Let me know if I could be of any help. Would be a pleasure for me to give a bit back to Armbian :-) Both, RockPi-E and OpiR1+ generate a Kernel panic at the end of "init 0" harmless AFAICS. Output is attached. Regards, Chris rockpi-e.oopsFetching info... r1plus.oopsFetching info... 1 Quote
Igor Posted February 17, 2021 Posted February 17, 2021 On 2/16/2021 at 4:08 PM, ChrisO said: Let me know if I could be of any help. Expand https://forum.armbian.com/forum/54-help-wanted/ https://www.armbian.com/donate 0 Quote
zeno979 Posted February 22, 2021 Posted February 22, 2021 Nanopi r2s Buster image with DTB from Orangepi runs well 0 Quote
Igor Posted February 22, 2021 Posted February 22, 2021 On 2/22/2021 at 8:10 PM, zeno979 said: Nanopi r2s Buster image with DTB from Orangepi runs well Expand We need to know how R2S image works on Orangepi R1+ (which we don't have yet around to check). 0 Quote
Ford_Prefect Posted March 4, 2021 Author Posted March 4, 2021 On 1/6/2021 at 11:52 AM, Igor said: Don't know. But even more basic hw function have no gain so I would not have big expectations on Rockchip: https://github.com/armbian/build/pull/2462 Expand Erm... I think you are wrong with that - this little thinge is blazing fast in encryption/decryption - at least for a SBC. I just configured the latest strongswan, setup xfrm interfaces and a straight forward configuration wit AES_GCM_16/MODP2048 and I am totally astonished... Not really CPU Load and about 420 MBit/s decrypting and 270 MBit Encrypting (via Gigabit-LAN to a Ryzen3 Machine) I had to setup up this extra scenario, because the little device maxed out my 300 MBit+ WAN Link :-) t For that, I build iproute2 and strongswan+swanctl myself on top of the OPI Debian Image, which works really stable, I have to say! Much better than the OPI R1 without Plus (which, BTW, was maxed out at around 40 MBit/s IPsec Traffic) Cheers Ford Prefect 0 Quote
Igor Posted March 4, 2021 Posted March 4, 2021 On 3/4/2021 at 7:28 PM, Ford_Prefect said: I think you are wrong with that - this little thinge is blazing fast in encryption/decryption - at least for a SBC. Expand I am not saying its slow. Just HW assisted driver contributes no gain. Here you can compare with others. On 3/4/2021 at 7:28 PM, Ford_Prefect said: Much better than the OPI R1 without Plus Expand Comparing apples and oranges. Those are totally different SoCs. Also generation wise. On 3/4/2021 at 7:28 PM, Ford_Prefect said: which works really stable Expand They copied our build tools, remove others and refactor few things then run search "armbian" replace with "orangepi". https://github.com/orangepi-xunlong/orangepi-build/commit/2a7bfed3c38abd758539d4f4c02c70b4fd62eb34 In case of troubles, you have to check their forum since we don't deal with 3rd party creations. 0 Quote
Ford_Prefect Posted March 4, 2021 Author Posted March 4, 2021 Quote Comparing apples and oranges. Those are totally different SoCs. Also generation wise. Expand Not really apples and whatever... It's the 'same' type of SBC, and costs are similar. This is the fastest encrypt/decrypt sbc besides the atom based 'Atomic Pi' - which has AES-NI enabled. Cheers, Ford 0 Quote
Igor Posted March 4, 2021 Posted March 4, 2021 On 3/4/2021 at 8:33 PM, Ford_Prefect said: It's the 'same' type of SBC, and costs are similar. Expand Also anything that has "pi" in the name or looks like "pi" and costs between 20 - 50 is the same sh*, right? From technical perspective, things which you are comparing, they are very different ... 32 vs 64 bit soc, different generation, dual fast lan, dual gigabit lan, internal fast lan, internal gigabit lan, usb2 vs usb3, allwinner vs rockchip .... On 3/4/2021 at 8:33 PM, Ford_Prefect said: This is the fastest encrypt/decrypt sbc Expand This means you didn't check this? https://github.com/ThomasKaiser/sbc-bench/blob/master/Results.md 1 Quote
Ford_Prefect Posted March 5, 2021 Author Posted March 5, 2021 Quote Also anything that has "pi" in the name or looks like "pi" and costs between 20 - 50 is the same sh*, right? From technical perspective, things which you are comparing, they are very different ... 32 vs 64 bit soc, different generation, dual fast lan, dual gigabit lan, internal fast lan, internal gigabit lan, usb2 vs usb3, allwinner vs rockchip .... Expand No, its the other way round... I was looking for a SBC with 2 NICs (preferebly Gigabit, off Course) which is capable of running debian to connect me with strongswan (+ xfrm interfaces for the sake of it) with a reasonable encrypting speed and easy t otravel with - so the size of the Atomic Pi was too big, and it lacks a second ethernet port. Let's take a look on the market.... there is not much, is there? So the Orangepi R1 Plus is the optimal choice for me.... it seems:-) Quote This means you didn't check this? https://github.com/ThomasKaiser/sbc-bench/blob/master/Results.md Expand No, I didn't know about that. But "pure" AES Benchmarks doesn't help too much compared with 'real' IPsec throughput. Off course, you get a 'hint' which is faster but no absolute benchmarking regarding to network traffic is possible, because you don't know how the NICs behave together with the rest of the system. Cheers Ford 0 Quote
Igor Posted March 5, 2021 Posted March 5, 2021 On 3/5/2021 at 6:52 AM, Ford_Prefect said: Let's take a look on the market.... there is not much, is there? Expand You should at least check our download pages: https://www.armbian.com/download/?tx_category=networking We support 6 such devices, where one is identical to R1+ (Nanopi R2S) and two that we don't support anymore or we never did. On 3/5/2021 at 6:52 AM, Ford_Prefect said: So the Orangepi R1 Plus is the optimal choice for me.... it seems:-) Expand Probably it is. I am not arguing about that. On 3/5/2021 at 6:52 AM, Ford_Prefect said: No, I didn't know about that. But "pure" AES Benchmarks doesn't help too much compared with 'real' IPsec throughput. Off course, you get a 'hint' which is faster but no absolute benchmarking regarding to network traffic is possible, because you don't know how the NICs behave together with the rest of the system. Expand FYI https://www.armbian.com/nanopi-r4s/ should be faster in all real world scenarios but I doubt you need all that extra power. 0 Quote
Werner Posted March 5, 2021 Posted March 5, 2021 On 3/5/2021 at 7:26 AM, Igor said: FYI https://www.armbian.com/nanopi-r4s/ should be faster in all real world scenarios but I doubt you need all that extra power. Expand Confirmed. The R4S (preferably the 4G LPDDR4 version) is a beast . I love mine. 0 Quote
Ford_Prefect Posted March 5, 2021 Author Posted March 5, 2021 On 3/5/2021 at 7:26 AM, Igor said: FYI https://www.armbian.com/nanopi-r4s/ should be faster in all real world scenarios but I doubt you need all that extra power. Expand Yes, pretty device, I know - but compared with the ultra-cheap (in many ways .-) Orange Pi R1 Plus it is doubled in price :-) Cheers Ford 0 Quote
thanh_tan Posted March 7, 2021 Posted March 7, 2021 On 2/22/2021 at 8:10 PM, zeno979 said: Nanopi r2s Buster image with DTB from Orangepi runs well Expand How to change the DTB from Nanopi to Orangepi? Did you biuld your version? 0 Quote
HilmiEsen Posted March 30, 2021 Posted March 30, 2021 Hi All, I ran Armbian at orangepi r1 plus. Details: Firstly, OrangePi R1 Plus is booted with Armbian_21.02.3_Nanopi-r2s_buster_current_5.10.21. But I got the error: Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=1430eaac-3ff0-465a-a7b0-66b51608ccd1 does not exist. Dropping to a shell! (initramfs) All Boot Output: https://pastebin.pl/view/c23b4566 After that, Orange Pi R1 Plus is successfully booted with Orangepir1plus_2.1.0_debian_buster_server_linux5.8.18. I inserted another sd card (it has Armbian_21.02.3_Nanopi-r2s_buster_current_5.10.21 image) to the R1 Plus and mounted. I copied /boot/dtb/rockchip/rk3328-orangepi-r1plus.dtb and paste into the sd card. I changed /boot/armbianEnv.txt as follows: # more /boot/armbianEnv.txt verbosity=1 bootlogo=false overlay_prefix=rockchip fdtfile=rockchip/rk3328-orangepi-r1plus.dtb rootdev=UUID=1430eaac-3ff0-465a-a7b0-66b51608ccd1 rootfstype=ext4 console=serial usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Orange Pi R1 Plus is booted. But it has some issues. The device did not detect 2nd ethernet and first ethernet is not working properly. Orange Pi R1 Plus Armbian Boot Output: https://pastebin.pl/view/ba0f9789 I will work on it. 0 Quote
HilmiEsen Posted March 30, 2021 Posted March 30, 2021 My fault, I tested: Ethernet interfaces are working properly. First ethernet is eth0, Second Ethernet is lan0. I will test all components ASA 0 Quote
Igor Posted March 30, 2021 Posted March 30, 2021 On 3/30/2021 at 8:18 AM, HilmiEsen said: My fault, I tested: Ethernet interfaces are working properly. First ethernet is eth0, Second Ethernet is lan0. I will test all components ASA Expand I started here https://github.com/armbian/build/pull/2617 but don't have device so I stopped. Welcome to extend that PR. 0 Quote
HilmiEsen Posted March 30, 2021 Posted March 30, 2021 I would like to help to test. Can you guide me? Can you send me a link what can I do? 0 Quote
Werner Posted March 30, 2021 Posted March 30, 2021 On 3/30/2021 at 7:00 PM, HilmiEsen said: I would like to help to test. Can you guide me? Can you send me a link what can I do? Expand The link is right above. Checkout the mentioned PR and build an image which you could test. https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
Vasco Posted May 11, 2021 Posted May 11, 2021 (edited) Thank you for bringing support to this board. I tried latest image (Buster and Focal) and couldn't boot. It always ends up with: Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=e5dd5e3a-06ae-43df-964d-5e3c5dc07a7f does not exist. Dropping to a shell! (initramfs) Here is the full boot sequence (2 boots): https://pastebin.com/CNssk1uG Tried with 3 differentt Sandisk Ultra and also with Etcher (Linux and Windows) and Rufus. Anything else I could try? Thanks Edited May 11, 2021 by Vasco Correcting some info 0 Quote
